1 Reply Latest reply on Jun 19, 2012 10:55 PM by George_Johnson
      • 1. Re: If I enter today's date in Box 1, how can I get Box 2 to auto-fill the same date +30 days?
        George_Johnson MVP & Adobe Community Professional
        You can use the following script for the custom Calculate script for the Box 2 field:
        // Custom calculate script for Box 2 field
        (function () {
            // Get date from field
            var v = getField("Box1").valueAsString;
            // Convert string to date
            var d = util.scand("mm/dd/yyyy", v);
            // Add 30 days
            d.setDate(d.getDate() + 30);
            // Populate this field with the result
            if (v) {
                event.value = util.printd("mm/dd/yyyy", d);
            } else {
                event.value = "";
        Replace "Box1" in the code above with the actual name of the field.
