2 Replies Latest reply on Jun 20, 2012 2:53 AM by kimmo242
    Exporting Secured PDF from indesign using apple script
    kimmo242 Level 1
      hi there, this is my first go at scripting,
      basically what i am trying to do is:
      tell indesign to turn on a layer called "proof" in the active document
      then export pdf - set pdf preference to smallest file size, all pages, and secure the file WITH A PASSWORD so that it can be opened but not edited (unless by someone at my agency who knows this password). this easy enough to manually, but im sick of typing out a password everytime i save a proof.
      then save to a specific folder on the desktop, using the already existing filename - so 'myfile.pdf'
      the code below gives me this message "
      error "Can’t make name of PDF export preferences into type Unicode text." number -1700 from name of «class DFpf» to Unicode text
      could someone please help me word this properly? I tried first referring to a pdf preset instead of setting all the values ie set color bitmap etc but i couldnt get the password to work,
      here is what i have so far, written from snippets that other people have tried:
      tell application "Adobe InDesign CS4"
                tell active document
        try
                                    set visible of layer "PROOF" to false
                          end try
        set docName to name
                          set baseName to text item 1 of docName
                          set ASTID to AppleScript's text item delimiters
                          set AppleScript's text item delimiters to "."
                          set AppleScript's text item delimiters to ASTID
                tell PDF export preferences
                          set acrobat compatibility to acrobat 4 --> create a 1.3 pdf
                          set use security to true
                          set disallow changing to true
                          set disallow copying to true
                          set disallow document assembly to true
                          set disallow extraction for accessibility to true
                          set disallow form fill in to true
                          set disallow notes to true
                          set disallow hi res printing to false
                          set color bitmap sampling DPI to 100
                          set grayscale bitmap sampling DPI to 100
                          set monochrome bitmap sampling DPI to 100
        --set image quality
                          set color bitmap quality to minimum
                          set grayscale bitmap quality to minimum
        --set fonts
                          set subset fonts below to 0
        --set security
                          set change security password to "editedit"
                          set disallow extraction for accessibility to false
                          export format PDF type to "/Users/kimwilson242/Desktop/_PROOFS/" & name & ".pdf" without showing options
                end tell
      end tell
        • 1. Re: Exporting Secured PDF from indesign using apple script
          Muppet Mark Level 5
          tell application "Adobe InDesign CS5"
            -- prefs belong to app so use in tell app block
            --set image quality
            --set fonts
            --set security
                    end tell
            -- now deal with the doc
                              try
                              end try
                              set docName to name
            -- use flexible path to user desktop… path strings are HFS (colon delimited)
                              export format PDF type to (path to desktop as text) & "PROOFS:" & name & ".pdf" without showing options
                    end tell
          end tell
          • 2. Re: Exporting Secured PDF from indesign using apple script
            kimmo242 Level 1
            Thank you so much Mark!!!!! getting a bit stuck on the proper order of things, sure ill get there after writing a few more and doing some more reading very much appreciated!!!!!
