4 Replies Latest reply: Jun 20, 2012 11:23 AM by Johannes Eckert RSS
    Reporting Bug: Timing Problems
    Johannes Eckert Community Member
      I encounter a few timing problems that I try to narrow down. What you see here is a set of 6 MSOs that fade away after each other. (This is a trick to maintain beautiful sharp vector type in a title animation that would look pixelated if the type was part of the MSO).
      anyway, when I swipe to the article, everything looks fine.
      If I navigate to the article from the browse mode, the delay setting is ignored, every slideshow is appearing right away.
      Video here:
      https://dl.dropbox.com/u/115270/digital%20publishing%20blog/MSO-timing-v21.mov
      Settings of each MSO:
      I used v21 with preview on device. Same result when going through the cloud (altough I got blank grey pages on the first try, then updated and saw my layouts).
      Same behaviour occurs when you start swiping the article, then all the remaining MSOs appear at altogether.
      Additionally, you see some color differences in the rasterized MSO compared to the background, although they have the same color used in InDesign (PDF folio).
      —Johannes
