5 Replies Latest reply on Jun 20, 2012 2:09 PM by esdebon
    Once a timer is at 40 go to the next frame.
    TheEricBraun Level 1
      Hey there,
      When a timer in my game hits 40 I want it to go to the next frame. Here is what I have:
      onClipEvent (enterFrame) {
                var atFrame:Boolean = false;
                if (_root.timer == 40) {
                          atFrame = true;
                } else {
                          _root.timer++;
                if (atFrame == true) {
                          myRandom = random(3);
                          if (myRandom == 0) {
                                    gotoAndStop("game1");
                          if (myRandom == 1) {
                                    gotoAndStop("game2");
                          if (myRandom == 2) {
                                    gotoAndStop("game3");
      Where "game1-3" are the names of my frames. And timer is the name of my dynamicText.
      Any suggestions as to why this isn't working would be greatly appreciated.
      Kind Regards, Eric
        • 1. Re: Once a timer is at 40 go to the next frame.
          esdebon Level 4
          first of all your variable must be initiated
          _root.timer=0
          Yor code is insede a MovieClip?
          I change the code
          _root.timer = 0;
                    if (++_root.timer == 40) {
          goGame();
          function goGame() {
               myRandom = int(Math.random()*3);
                    _root.gotoAndStop("game1");
          _root.gotoAndStop("game2");
          _root.gotoAndStop("game3");
          • 2. Re: Once a timer is at 40 go to the next frame.
            That did clean up my code, although it seems to be doing the same thing, timer just keeps increasing and the frame doesn't change :/
            • 3. Re: Once a timer is at 40 go to the next frame.
              esdebon Level 4
              "game1","game2","game3" are the label in the time line or the name of the frames inside the movieclip?
              try this
              code in the time line:
              _root.timer = 0;
              stop();
              function goGame() {
              code in the moveclip
                        if (int(++_root.timer) == int(40)) {
                                  _parent.goGame();
              • 4. Re: Once a timer is at 40 go to the next frame.
                Thank you very much
                • 5. Re: Once a timer is at 40 go to the next frame.
                  esdebon Level 4
                  you´re welcome
                  is too a solution
                  onClipEvent (load) {
                      function goGame() {
                              gotoAndStop("game1"); //for frame inside the movieclip or _parent.gotoAndStop("game1");
                              gotoAndStop("game2"); //for frame inside the movieclip or _parent.gotoAndStop("game2");
                              gotoAndStop("game3"); //for frame inside the movieclip or _parent.gotoAndStop("game3");
                      if (++_root.timer==40) {
                          goGame();
