1 Reply Latest reply on Jun 20, 2012 4:51 PM by JEShort01
    Last Check on New 3930k Build
    db2012_02 Level 1
      I just wanted to run this build by the board one more time before I begin to purchase. Any and all advice and suggestions are welcomed.
      A couple things to consider. I know some consider the Rampage Extreme to be overkill, but I'm going with it anyways for a variety of reasons. I know the Cosmos II is very big. Should I have any problem with the cable length of this power supply? And lastly, for some reasons asus doesn't have the QVL for memory on the Rampage IV Extreme listed on the website. Is there somewhere I can find this to verify the memory is approved? Should I seriously consider faster memory for OC'ing? I'm gonna OC, but not in an extreme fashion.
      Ok, here are the specs again. Thanks in advance for any help and suggestions!
      MB: ASUS Rampage IV Extreme LGA 2011 Intel X79
      CPU: Intel Core i7-3930K Sandy Bridge-E 3.2GHz
      CPU COOLER: NOCTUA NH-D14
      RAM: G.SKILL Ares Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
      Video: EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5
      HD: Crucial M4 CT256M4SSD2CCA 2.5" 256GB SATA III MLC (SSD) with Transfer Kit
             (x3)Seagate Barracuda XT ST32000641AS 2TB 7200 RPM 64MBCache SATA 6.0Gb/s 3.5"
      PSU: CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W
      Case: COOLER MASTER COSMOS II
        • 1. Re: Last Check on New 3930k Build
          JEShort01 Level 4
          Nice build!
          Regarding qualified memory, I believe that most reputable vendors show what memory sticks that they support for particular motherboards. I've had good luck with G. Skill memory that is "recommended" on their site, so if they say those sticks are OK for the memory density that you are using them at, you should be good to go even without Asus's blessing.
          Regarding cable lengths, you may need some extenders. The Cosmos is large as you say.
          Good luck - the real fun is only beginning!
          Jim
