2 Replies Latest reply: Oct 20, 2012 9:18 PM by Charlie Arehart RSS
    Defining components and functions in CFScript
    Community Help Community Member
        • 1. Re:  Defining components and functions in CFScript
          CF-AXL Community Member
          The order of the parameters for writedump in the last code is wrong.
          The correct syntax is the following according to the document.
          writedump(var, output, format, abort, label, metainfo, top, show, hide, keys, expand, showUDFs);
          So it should be something like writedump(myquery, "", "html", true); instead of writedump(myquery, false, html, name);.
          In the second paragraph from the last, where it says "you can add an empty value" should be "you can add an empty string."
          The last line should be writedump(myquery, "browser"); instead of writedump(myquery, html); since there is no html option for the second parameter output.  Although the second parameter in this case is optional since the default value for output is browser.
          • 2. Re:  Defining components and functions in CFScript
            Charlie Arehart CommunityMVP
            In one of the examples above, the function mistakenly uses a paren where it needs an open brace. See the end of the second line below, where I have corrected it:
            public void function foo(String n1=10)
            description="does nothing" hint="overrides hint" {
            WriteOutput("Method foo() called
            Parameter value is " & n1);
