2 Replies Latest reply on Feb 14, 2008 1:21 AM by tware
    Is It Possbible To Monitor Any Given TCP Port In Director!
    tware Level 1
      Hi
      Using Director MX 2004 under WinXP Pro.
      Does anyone know if it's possible to use WaitForNetConnection to monitor any given TCP port where the incoming data could be anything, but most certainly isn't from another Director application, but might be from say a mail server, telnet, an FTP server responding on the specified port, or whatever...!
      I've not had a lot of success using WaitForNetConnection to do this... (Code below).
      If WaitForNetConnection cannot be used to monitor a TCP port, does anyone know if there are any xtras commercial or otherwise that will do this?
      Many Thanks
      TW.
      Code:
      gMuiR.setNetMessageHandler(#xFTPHandlerIn, script "CallBacksIn")
      gMuiR.setNetBufferLimits( 128 * 1024, 512 * 1024, 250 )
      on FTPWaitForConnection n, p
      -- n = IpAddress of FTP Server in "x.x.x.x" format, p = integer, port no
      global gMuiR, svIPAdr
      if gMuiR.WaitForNetConnection( svIPAdr, p, 4) = 0 then
      put "Waiting For Net Connection On Port : " & p
      r = 0
      else
      put "Error On Wait For Net Connection."
      r = 1
      end if
      return r
      end
      When I connect to the specified port using telnet or whatever, the callback handler returns error -2147216214 (the hugely informative "connection problem"...).
        • 1. Re: Is It Possbible To Monitor Any Given TCP Port In Director!
          Level 7
          If by 'monitor' you mean launch a host that will accept tcp connections,
          then:
          The multiuser xtra supports text mode, but does not support binary transfers
          when in text mode (null character terminated strings).
          With smtp you should be ok, due to the encoding of the mail content.
          For ftp, it just won't work, since binary data are exchanged.
          > know
          If you mean an Xtra that can accept tcp connections and allow you to process
          the data received, contact me off-list at info at rtr gr..
          "tware" <webforumsuser@macromedia.com> wrote in message
          news:fova33$ck1$1@forums.macromedia.com...
          > Hi
          > any
          > certainly
          > server,
          > (Code
          > below).
          > know
          > Many Thanks
          > TW.
          > Code:
          > r = 0
          > else
          > r = 1
          > end if
          > return r
          > end
          > callback
          > problem"...).
          • 2. Re: Is It Possbible To Monitor Any Given TCP Port In Director!
            tware Level 1
            >then:
            I'm glad you know what I meant to mean!
            Yes, but I would have thought I could handle the text based control channel stuff...
            Be there in a minute! Thanks.
