3 Replies Latest reply on Jun 21, 2012 8:51 AM by [Jongware]
    GREP style for one specific paragraph
    wouterschoutteten
      Hi all,
      I'm faced with the following problem in a textdocument I've got to rework in InDesign.
      The text is based on 3 'groups' of information. First there is a title, beginning with:
      "1.1. Title (so two digits and a paragraph),
      a body text,
      and a source, starting with: 'source: This is the source' and
      '*: this is the source'.
      Now I want all paragraphs starting with two digits in the same style, and all lines starting with 'Source' or '*' in the same style.
      I'm pretty new with GREP, but I believe that might be the solution. Or any other ideas to to this fast and automated?
      Is there a code that specifies a style for a whole paragraph?
      All help is very much appreciated since this is a very laaaarge document.
      Thanks!
        • 1. Re: GREP style for one specific paragraph
          GREP styles (which you seem to think of) only apply character styles. So that's out for entire paragraphs.
          Select all text and assign it your Body text paragraph style. Then use this in the Find/Replace dialog, GREP section. Find:
          ^\d+\.\d+
          Replace: leave blank, but select the name of the title style in the Change To formatting fiend.
          Press Change All. Done.
          • 2. Re: GREP style for one specific paragraph
            wouterschoutteten Level 1
            Works great, thanks for that line.
            Any ideas on the 'source' and '*' lines? By using GREP i've highlighted those words and signs so I can easily find them in the long texts and manualy assign the paragraph style, but there must be an easier way...
            • 3. Re: GREP style for one specific paragraph
              Ah, sorry -- I thought the three you mentioned were all of your text. So the text "Soucre" or the asterisk are always at the start of these paragraphs? Then search for this:
              ^(Source|\*)
              and 'replace' with a style, the same way as you did with the numbered headings.
