0 Replies Latest reply on Jun 21, 2012 11:45 AM by AlexMxi
    Path to includes are not resolving when define is used
    AlexMxi Level 1
      in a Php document path to a class specified with a string resolved without a problem:
      require_once ( './classes/class.php' );
      However, if a defined variable is used, the path does not resolve and Dreamweaver doesn't help with method hints:
      define ( CLASS_DIR . './classes/' );
      require_once ( CLASS_DIR . 'class.php' );
      As a note,  CLASS_DIR might not be defined in the same document, bu linked from another one that contains the define:
      require_once ( './config.php' ); //contains  define ( CLASS_DIR . './classes/' );
      As I use defined paths, I can take no advantage of Dreamweaver's hints.
