0 Replies Latest reply on Jun 22, 2012 7:11 AM by Pedro Cortez Marques
    Passing external string to author XMP when opening CR2
    Pedro Cortez Marques Level 3
      Sorry I can't find my last year post. I have this code suggested by Paul Riggott or Michael L Hale (...?) that is helping me a lot. But I must improve it a bit more.
      I added an external variable (a text file that contains a variable) but now I must pass that string to each of the several CR2 XMP author .
      This the code (incompleted):
      it reads all the present CR2 files on Bridge on the manual order and open them on ACRaw
      #target photoshop
      main();
      function main(){
          if (!BridgeTalk.isRunning("bridge")){
              alert("Só funciona se houver algumas imagens CR2 com o Bridge aberto!");
              return;
          var fileList =[];
          fileList =GetFilesFromBridge();
          if(!fileList.length){
              alert("Nenhumas imagens em Bridge!");
              return;
          var Path = Folder(fileList[0].path);
          var name = Folder(fileList[0].path).name;
          var newName=[];
          for(var a in fileList){
              var nname = fileList[a].name;
              newName.push(nname);
              fileList[a].rename(newName[a]);
      ////////  I have a folder named upload on Desktop (PC) with a text file:
          var uploadFolder =  Folder("~/Desktop/upload");
          var fileEditor = File(uploadFolder + '/edita.txt');
          if (fileEditor.open('r')) {
              var ler = fileEditor.read();
              var keyList = [];
              keyList[0] = ler.replace(/\.[^\.]+$/, '');
              fileEditor.close();
          var bt = new BridgeTalk();
          bt.target = "bridge";
          bt.body ="var d=app.document; d.deselectAll(); var f=d.getSelection('cr2'); for(var a in f){d.select(f[a])} d.chooseMenuItem('OpenInCameraRaw');";
          bt.send(8);
          bt.pump();
          BridgeTalk.bringToFront ("bridge");
              function GetFilesFromBridge() {
                  function script(){
                      app.document.deselectAll();
                      var fL = app.document.getSelection('cr2');
                      var tF=[];
                      for(var a in fL){
                          if(fL[a].type =='file'){
                              tF.push(new File(encodeURI(fL[a].spec.fsName)));
                      return tF.toSource();
                   var fileList;
                  bt.body = "var ftn = " + script.toSource() + "; ftn();";
                  bt.onResult = function( inBT ) { fileList = eval( inBT.body ); }
                  bt.onError = function( inBT ) { fileList = new Array(); }
                  bt.send(8);
                  bt.pump();
                   if ( undefined == fileList ) fileList = new Array();
                   return fileList;
