19 Replies Latest reply on Feb 25, 2017 5:05 AM by Natanaelds
    there was an error processing a page. there was a problem reading this document (110)?
    kapilbtrivedi Level 1
      hi
      my name is kapil and i am trying to open one (which is downloded) pdf document.which giving me an error as there was an error processing a page. there was a problem reading this document (110) for some page only. i am using acrobat reader x. is it any 3d setting or any thing else please give me an idea. i am waiting for replay as soon as possible...........
      your sincerely
      KAPIL TRIVEDI
        • 1. Re: there was an error processing a page. there was a problem reading this document (110)?
          Aldora310 Level 1
          I opened a pdf document in Adobe Reader X. When I attempted to scroll through the pages the following error message appeared, “There was an error processing a page. There was a problem reading the document (110). After an Internet search to try to find the reason for the error and a solution, I came across a site that suggested it was an issue regarding the fonts of the document. I then reopened the document and went into the document’s font properties (FILE – PROPERTIES – FONTS tab). There I noticed that the “Gathering font information” stopped at 2% which, of course, I took to mean that Adobe Reader X was having a difficult time in loading the font’s information. Another site suggested opening the document in the pdf reader, Foxit. So I did, and the document loaded properly with no error messages. I was still curious as to why the document did not load entirely in Adobe Reader X and if the same problem would occur using a different reader. I then downloaded the pdf reader, Nitro Reader 2.  I opened the same document and initially received the following message, “The requested page number is invalid and does not exist in this document.” I closed the message and proceeded to scroll through the document. As I scrolled, the following message appeared, “This file was damaged (corrupted) and has been repaired.” I thought, “Wonderful!” I then chose <FILE – SAVE AS – PDF DOCUMENT> and saved the “repaired” document under a new name. When I opened the “repaired” document with Adobe Reader X, behold, the document opened entirely with no error message. I was curious, so I went into the document’s font properties and noticed, this time around, that the “Gathering font information” loaded to 100%. Nitro Reader 2 detected the error and fixed it. Now I’m left to wonder…why wasn’t Adobe Reader X able to do the same? I hope this post helps others who are experiencing the same issue.
          2 people found this helpful
          • 2. Re: there was an error processing a page. there was a problem reading this document (110)?
            yhdg7te65656 Level 1
            I keep getting the same 110 error with Acrobat XI Pro when I open certain pdf's.  It's interesting that every other program I've tried opens the questionable pdf without issues.  So logically this is more of an acrobat issue and not problem with the pdf itself.  So how come the best (allegedly) pdf software out there is the only one that can't open it's own native format because it can't recognize some font??  That's just shameful.  I have to resort to a free reader like SumatraPDF or Nitro.
            • 3. Re: there was an error processing a page. there was a problem reading this document (110)?
              It's true that when I open the pdf in Nitro and look at the file properties, I see many more fonts loaded than in Acrobat.  I tried doing what user Aldora310 did by fixing the issue in Nitro, but unfortunately and ironically I don't get an error message in Nitro, so no 'repair' is possible cuz there's nothing to repair.
              Acrobat is so rudimentary in its error handling.  "Can't open pdf, error # gazillion and five".  Well what the hell is error # gazillion and five.  "Shht be quite, nobody is supposed to know".  Then I search a bunch of forums and find that it MIGHT have something to do with fonts.  Then I noticed that more fonts load in Nitro than the almighty Acrobat.  The whole thing is pathetic.  Can't Acrobat tell me that its a problem with fonts and POSSIBLY give me a suggestion?
              Anyway, when Acrobat can't 'process' a file because of font issues, while every other free pdf program on the face of the planet can open it without a problem, something is laughably wrong.
              • 4. Re: there was an error processing a page. there was a problem reading this document (110)?
                zopfan Level 1
                When I encountered an error "there was a problem reading this document 110" in Acrobat Pro 11 on 28.7 MB CS6 file, it indeed was very frustrating.
                I solved my problem, but since I don't know which step benefitted me, I've to enumerate all the steps I took:
                Read below:
                1.1. I could copy the file anywhere on the drive, but couldn't 'save as' from Acrobat Pro.
                1.2. No document security was applied of any sort on the file.
                1.3. Still in the first tab of the document properties, all details under advance section were empty. No 'PDF Version' 'location' 'file size' etc were populated. Nothing.
                1.4. I couldn't change and save anything in any of property dialogue. I could comment on the text, but as soon as I tried to save, it gave an error (some sort of 'File reading' error).
                1.5. When I tried to extract a page (I tried many), it gave 'reading error'.
                1.6. I didn't try 'splitting error'. Since I was 100% sure, it'll give me same reading error.
                1.7. I opened the file in Firefox and tried saving it as pdf from there. But no error, but no save either.
                1.8. I ran 'Remove Hidden Information' from protection panel without any errors.
                1.9. I tried 'sanitize document' from the same tab, but didn't succeed.
                1.10. Then (here I think the problem was resolved), from Document Processing panel, I did some commands. 1st, 'Export all images', successfully. Then 'Remove all links', it found 0.
                1.11. Then in 'print production' panel, I clicked/tried to open acrobat distiller. The same opened, did some processing. But I don't know if it did something in solving the problem or not.
                1.12. Although I think my problem was resolved till now, but the last step I did was 'Saved As' the file (from the file menu) as a .ps file. Though I've not yet reopened/used that ps file (to convert it into a pdf file again). But around here I wanted to close the file and it asked me whether I wanted to save the file, I said yes. And it saved the file correctly. And I checked that in properties dialogue, the missing information was populated too.
                1.13. Sorry for so lengthy instructions, but I had no choice.
                • 5. Re: there was an error processing a page. there was a problem reading this document (110)?
                  Adobo0 Level 1
                  Adobe Acrobat X 10.0.2 Pro:
                  Error Message:
                  The document could not be saved. There was a problem reading this document (110).
                  File > Properties > Fonts
                  Gathering font information... (15%)
                  At this point Adobe gets stuck.
                  I have solved this issue.
                  Nitro Pro v9.0.5.9 (x64): http://en.wikipedia.org/wiki/Nitro_PDF
                  FILE > Save As > Standard PDF
                  Nitro Pro will review the PDF's integrity and save a repaired version of your PDF document.
                  Now you can open the PDF in Adobe Acrobat.
                  Gathering font information... (100%)
                  You can now edit and save your PDF without hassle.
                  Problem solved.
                  6 people found this helpful
                  • 6. Re: there was an error processing a page. there was a problem reading this document (110)?
                    pwillener Level 8
                    What if you update AcrobatX to the latest version 10.1.9?
                    • 8. Re: there was an error processing a page. there was a problem reading this document (110)?
                      jan vis Level 1
                      I still got the message "The document could not be saved. There was a problem reading this document (110)"
                      In more detail:
                      - I am using the latest version of both 'Adobe Reader' and 'Adobe Acrobat Pro'
                      - I am using the latest version of OSX, i.e OSX 10.9.5
                      - I downloaded some pdf file
                      - I opened the file (both with 'Adobe Reader' and 'Adobe Acrobat Pro')
                           I could read the file (and did not receive any warning on opening)
                      - I highlighted a small piece of text and tried to save the modified file
                      - I got the message  "The document could not be saved. There was a problem reading this document (110)"
                            (from both 'Adobe Reader' and 'Adobe Acrobat Pro')
                      - I did not get any warning when reading the file
                      So, can someone please:
                      -    explain the details of  message "The document could not be saved. There was a problem reading this document (110)"
                      - tell me how I can circumvent / deal  this annoying problem
                      • 10. Re: there was an error processing a page. there was a problem reading this document (110)?
                        ashraf t Level 1
                        Error Message:
                        Problem solved.
                        This method worked for me.
                        • 11. Re: there was an error processing a page. there was a problem reading this document (110)?
                          DKLLP Level 1
                          We are also having the same issue with Acrobat DC now. Why is Adobe not able to fix the issue directly?
                          • 12. Re: there was an error processing a page. there was a problem reading this document (110)?
                            Datekane Level 1
                            Actually I got the same issue. And, after reading those reply. I consolidate 2 situation and question
                            1) Once I got this issue and I use "Gathering font information". If it stop loading in X%, what can I do for next step? (I can't use other software to replace adobe as it;s corporate platform that third party software installation blocked.
                            2) Once I got this issue and I use "Gathering font information". If it loaded 100%, what is the next step? refresh my browser? And what can I do after if it still failure after refresh my browser?
                            Thank you very much
                            Some more information:
                            OS: Window 7
                            IE: 9.0.8112
                            Adobe reader: 11.0.15
                            • 13. Re: there was an error processing a page. there was a problem reading this document (110)?
                              younism37709329 Level 1
                              Perfect way to solve this problem.
                              100% done with me.
                              grateful(thank you) a lot.
                              • 14. Re: there was an error processing a page. there was a problem reading this document (110)?
                                shenk22558790 Level 1
                                I think your are open the PDF from office ppt files  . Fist insert  PDF you can printer a new PDF and insert again
                                • 15. Re: there was an error processing a page. there was a problem reading this document (110)?
                                  torsonmarka Level 1
                                  I had the same issue opening PDF bank statements. I used PDF-JPG converter software and was able to read and print the file.
                                  • 16. Re: there was an error processing a page. there was a problem reading this document (110)?
                                    thomas92 Level 1
                                    On the mac, I opened with Preview, then exported a new PDF.  The new PDF has all the same content, but no error 110.
                                    • 17. Re: there was an error processing a page. there was a problem reading this document (110)?
                                      PerryCodes Level 1
                                      The new PDF actually doesn't have the same content - same as if you export to .ps and create new PDF using the .ps ... you lose ALL bookmarks, so if this is a textbook, good luck taking the time to put them all back in.  No Thanks.
                                      • 18. Re: there was an error processing a page. there was a problem reading this document (110)?
                                        thomas92 Level 1
                                        You're so right, I should have added this disclaimer:
                                        This is a fast and easy solution that saves the text, images and format of the original PDF to a new file without having to download additional software when on a mac.  I used it to fix a textbook file I couldn't otherwise access without downloading additional software.  Beware, you might have to use the find function to jump to a specific chapter or section number rather than using the bookmarks.  If you can't live without the bookmarks, see the posts above about downloading Nitro Pro to fix the original PDF rather than making a duplicate.
