0 Replies Latest reply on Jun 25, 2012 4:24 PM by iHomaid
    How to enable server’s firewall (inbound) rules to permit TCP connections on its port (default 4502)
    iHomaid
      We Have an instance running on the CQ Cloud services.I am trying to setup my ecplise IDE. However, when trying to use VLT to check out the CQ5 content into my ui project I get this error
      ERROR] checkout: com.day.jcr.vault.vlt.VltException: Unable to mount filesystem
      caused by: javax.jcr.RepositoryException: java.net.ConnectException: Connection refused: connect
      caused by: java.net.ConnectException: Connection refused: connect
      After searching the docs here is what I found:
      Make sure that a CQ “author” instance is up and running.  If it is remote, make sure that the server’s firewall (inbound) rules permit TCP connections on its port (default 4502).  Otherwise, you’ll get the following error message:
