1. Re: DTS-HD MA files
ram8kumar Jun 26, 2012 4:23 AM (in response to m2425)The extension I have heard of is .dtshd and that works fine with Encore CS6 but you can not add it to motion menu because Encore does not process the any DTS files and adding it to motion menu means the file is subject tp processing.
Even sometimes the DTS-HD file in slideshow might cause problem. Because there is a limit on the bit rate of the slideshow encoding imposed by Blu-ray spec. If the audio file bit rate goes above that then the burning will give error.
-Ramesh.
2. Re: DTS-HD MA files
m2425 Jun 26, 2012 9:55 AM (in response to ram8kumar)Thanks again Ramesh, I'm glad that Adobe chose DTS-HD over Dolby TrueHD because the DTS-HD comes with the core already in it while Dolby TrueHD has the core (.ac3) and the lossless (.mlp) separate.
3. Re: DTS-HD MA files
It certainly does, and you forgot to mention that the DTS Core audio also sounds a lot better than AC3 ever did.
