4 Replies Latest reply on Jun 28, 2012 11:54 AM by davidbeisner2010
    MediaInfo on an XDCAM-EX file that won't open in PrPro6 due to "missing codecs"
    davidbeisner2010 Level 3
      Had a friend do the edit on a video for me in PP5.5 on the Mac. I'm doing the final grading and audio master in PP6 on the PC. All the footage was shot with my JVC GY-HM700u in XDCAM-EX and has worked just fine for me on my system... I gave him .mp4 files, and they've all come back to me as .mov files, and PrPro says it doesn't have the required codec. I'm not willing to do the final work on his systems cause they're old iMacs... my PC has multiple RAID arrays, 24GB ram, good CPU, etc and screams on the audio mastering and grading.
      Here's the MediaInfo on one of the files:
      General
      Complete name                    : E:\Academics\Majors Videos\Biology\Copied_Biology Promo\BIOL0240_01.mov
      Format                           : QuickTime
      Format/Info                      : Original Apple specifications
      Format_Commercial_IfAny          : XDCAM EX 35
      File size                        : 286 MiB
      Duration                         : 1mn 7s
      Overall bit rate mode            : Variable
      Overall bit rate                 : 35.6 Mbps
      Movie name/More                  : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
      Encoded date                     : UTC 2012-04-21 21:14:05
      Tagged date                      : UTC 2012-04-23 12:04:14
      Writing library                  : Apple QuickTime
      Original source medium           : Eisenbach
      com.apple.quicktime.information  : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
      com.sony.bprl.mxf.nrtmetadata    : <?xml version="1.0" encoding="UTF-8" standalone="yes"?><NonRealTimeMeta xmlns="urn:schemas-professionalDisc:nonRealTimeMeta:ver.1.30" xmlns:lib="urn:schemas-professionalDisc:lib:ver.1.30" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" lastUpdate="2011-02-04T12:44:59-06:00"><TargetMaterial umidRef="060A2B340101010501010D43130000007C18C1C7965505C00080884F85010A03"></TargetMateri al><Duration value="2025"></Duration><LtcChangeTable tcFps="30" halfStep="false"><LtcChange frameCount="0" value="54462102" status="increment"></LtcChange><LtcChange frameCount="2024" value="40542202" status="end"></LtcChange></LtcChangeTable><CreationDate value="2011-02-04T12:43:51-06:00"></CreationDate><TypicalUbit value="0000000000000000"></TypicalUbit><BodyUmidBasicChangeTable><BodyUmidBasicChange frameCount="0" value="060A2B340101010501010D43330000007C18C1C7965505C00080884F85010A03" status="start"></BodyUmidBasicChange></BodyUmidBasicChangeTable><KlvPacketTable><KlvPacke t key="060E2B34010101050301020A02000000" frameCount="0" lengthValue="095F5265635374617274" status="spot"></KlvPacket></KlvPacketTable><VideoFormat><VideoRecPort port="DIRECT"></VideoRecPort><VideoFrame videoCodec="MPEG2HD35_1920_1080_MP@HL" captureFps="29.97p" recFps="29.97" formatFps="29.97p"></VideoFrame><VideoLayout pixel="1920" numOfVerticalLine="1080" aspectRatio="16:9"></VideoLayout></VideoFormat><AudioFormat numOfChannel="2"><AudioRecPort port="ANALOG" audioCodec="LPCM16" trackDst="CH1"></AudioRecPort><AudioRecPort port="ANALOG" audioCodec="LPCM16" trackDst="CH2"></AudioRecPort></AudioFormat><Device manufacturer="JVC" modelName="GY-HM700" serialNo="105V0780"></Device><RecordingMode type="normal" cacheRec="true"></RecordingMode></NonRealTimeMeta>
      com.sony.bprl.mxf.umid           : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
      org.smpte.mxf.package.material.p : 0x060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
      com.sony.professionaldisc.nonrea : 2011-02-04 12:44:59 -0600
      com.sony.bprl.xdcamtransfer.vers : 2.13.0.650
      com.apple.proapps.reel           : Eisenbach
      com.apple.proapps.clipID         : 060A2B340101010501010D43130000007C18C1C7965505C00080884F85010A03
      com.apple.proapps.originalFormat : XDCAM EX 1080p30 (35 Mb/s VBR)
      Origin                           : MPEG HD
      ©TSC                             : 2997
      ©TSZ                             : 100
      Video
      Format                           : MPEG Video
      Format version                   : Version 2
      Format profile                   : Main@High
      Format settings, BVOP            : Yes
      Format settings, Matrix          : Custom
      Format settings, GOP             : M=3, N=15
      Codec ID                         : xdvf
      Duration                         : 1mn 7s
      Bit rate mode                    : Variable
      Bit rate                         : 34.0 Mbps
      Maximum bit rate                 : 35.0 Mbps
      Width                            : 1 888 pixels
      Original width                   : 1 920 pixels
      Height                           : 1 062 pixels
      Original height                  : 1 080 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Progressive
      Compression mode                 : Lossy
      Bits/(Pixel*Frame)               : 0.566
      Stream size                      : 274 MiB (96%)
      Language                         : English
      Tagged date                      : UTC 2012-04-21 21:20:58
      Color primaries                  : BT.709
      Transfer characteristics         : BT.709
      Matrix coefficients              : BT.709
      Audio #1
      Format                           : PCM
      Format settings, Endianness      : Big
      Format settings, Sign            : Unsigned
      Codec ID                         : lpcm
      Duration                         : 1mn 7s
      Bit rate mode                    : Constant
      Bit rate                         : 768 Kbps
      Channel(s)                       : 1 channel
      Sampling rate                    : 48.0 KHz
      Bit depth                        : 16 bits
      Stream size                      : 6.19 MiB (2%)
      Language                         : English
      Audio #2
      Format                           : PCM
      Codec ID                         : lpcm
      Duration                         : 1mn 7s
      Bit rate                         : 768 Kbps
      Bit depth                        : 16 bits
      Language                         : English
      Menu
      Language                         : English
      Bit rate mode                    : CBR
