0 Replies Latest reply on Jun 26, 2012 2:40 PM by robisio
    RichText within CompositeField
    robisio
      The custom widget I created is based on the CompositeField widget and contains RichText widgets.
      For testing purposes, I am simplifying this to a single RTE within each CompositeField instance.
      When the dialog "OK" button is pressed, I am expecting the contents of each RTE to be stored as a
      json stringified object in a multivalue String[] like this:
      items  String[]
      {"question":"<p>What is the question?</p>"}
      {"question":"<p>What time is it?</p>"}
      This works fine when using Text or TextArea, but, with the RTE, a javascript error is thrown.
      Can anyone clue me in on what is wrong?
      Rob
      The specific javascript error is:
      Uncaught TypeError: Cannot set property 'value' of undefined
      CQ.form.RichText.CQ.Ext.extend.syncValuewidgets.js:127745
      (anonymous function)widgets.js:127373
      EXTUTIL.Event.firewidgets.js:4760
      EXTUTIL.Observable.fireEventwidgets.js:4401
      CQ.Dialog.CQ.Ext.extend.okwidgets.js:103049
      handlerwidgets.js:102981
      CQ.Ext.Button.CQ.Ext.extend.onClickwidgets.js:54680
      hwidgets.js:11643
      Here is my widget code:
      CQ.ATestWidget = CQ.Ext.extend(CQ.form.CompositeField, {
          hiddenField: null,
          itemQuestion: null,
          formPanel: null,
          constructor: function (config) {
              config = config || {};
              var defaults = {
                  "border": true,
                  "autoWidth" :true,
                  "layout": "form",
                  "padding": 10,
                  "collapsible": "true"
              config = CQ.Util.applyDefaults(config, defaults);
              CQ.ATestWidget.superclass.constructor.call(this, config);
          //overriding CQ.Ext.Component#initComponent
          initComponent: function () {
              CQ.ATestWidget.superclass.initComponent.call(this);
              // Hidden field
              this.hiddenField = new CQ.Ext.form.Hidden({
              this.add(this.hiddenField);
              // Item question
              this.itemQuestion = new CQ.form.RichText({
                  fieldLabel: "Question: ",
                  allowBlank: false,
                  ignoreData: true,
                  submitValue: false,
                  anchor: '100%',
                  height: 75,
                  addItemLabel: "Add new question",
                  autoWidth :true,
                  listeners: {
                      change: {
                          scope: this,
                          fn: this.updateHidden
              this.add(this.itemQuestion);
          setValue: function (value) {
              var item = JSON.parse(value);
              this.itemQuestion.setValue(item.question);
              this.hiddenField.setValue(value);
          getValue: function () {
              return this.getRawValue();
          getRawValue: function () {    // read from crx
              var item = {
                  "question": this.itemQuestion.getValue(),
              return JSON.stringify(item);
          updateHidden: function () {
              this.hiddenField.setValue(this.getValue());
      CQ.Ext.reg('atestrte', CQ.ATestWidget);
