10 Replies Latest reply on Jul 3, 2012 8:53 AM by Trevorׅ
    Define/Redefine styles
    Jump_Over Level 5
      Is that possible, using script code (method) to define/redefine object/paragraph style based on selected object/paragraph as one can do in UI by click?
      thx
        • 1. Re: Define/Redefine styles
          Trevorׅ Adobe Community Professional
          Easy Peasy.
          This is one way of doing it
          Go through Jongware's Object reference and go through all the properties of paragraph style and continue the list I started.  Should only take an hour or so.
          Do the same with object properties, could take a very lot of hours there But it will work
          should be a more normal way to get all the properties but it's time for me to get to sleep
          mySelection=app.selection[0]
          saps=mySelection.appliedParagraphStyle
          newOrRefinedStyle="My new or refined style"; // change the name as you please ;-)
          (app.activeDocument.paragraphStyles.item(newOrRefinedStyle).isValid) ? 0 : app.activeDocument.paragraphStyles.add ({name: newOrRefinedStyle});
          with (app.activeDocument.paragraphStyles.item(newOrRefinedStyle))
              alignToBaseline = saps.alignToBaseline;
              allowArbitraryHyphenation = saps.allowArbitraryHyphenation;
              appliedFont = saps.appliedFont;
              appliedLanguage = saps.appliedLanguage;
              // and so on and so on .............
          • 2. Re: Define/Redefine styles
            Jump_Over Level 5
            Each scripting item corresponds to a tool or a palette or menu item in an Adobe application. In other
            words, each scripting element is something you already know through your Adobe expertise. If you know
            what you’d like your Adobe applications to do, you can easily learn to write scripts...
            Thats one of first sentence in Adobe Introdution to Scripting. Thats why i hoped to find some solution for scripter, not for a monk...
            • 3. Re: Define/Redefine styles
              Ok. I get the point.
              To make a new style is realy easy
              Just use
              tempPS=saps.duplicate ();
              tempPS.name=newOrRefinedStyle;
              The problem is changing the properties if the style that exits.
              You might be able to loop through them
              • 4. Re: Define/Redefine styles
                OK If you don't want to be a monk then
                try{tempPS.name=newOrRefinedStyle}
                catch (exists)
                {app.activeDocument.paragraphStyles.item(newOrRefinedStyle).remove (tempPS);
                use the same idea for the objectstlye.
                I'm off to bed now bye ZZZZZZzzzzzz
                • 5. Re: Define/Redefine styles
                  Well I think finally cottoned on to what you want to do.
                  You want the new style not to be based on an existing style of the selection but rather on the properties of the selected paragraph / object that have even though they don't have a style.
                  The below script does not do that !
                  It copies styles but might be a guide of how to go about things
                  You might be able to invoke a menu action to add the new style and then rename it using an addaption of the script bellow
                  try {
                      sas=mySelection.insertionPoints[0].appliedParagraphStyle;
                      pOrOStyles = app.activeDocument.paragraphStyles;
                  catch (selectionDosentHaveParaStyle) {
                      try {
                          sas=mySelection.appliedObjectStyle
                          pOrOStyles =app.activeDocument.objectStyles;
                      catch (selectionDosentHaveObjectStyle) {alert("Select A paragraph with paragraph style or an object with an object style")}
                  try {
                  tempPS=sas.duplicate ();
                  catch (exists)
                    pOrOStyles.item(newOrRefinedStyle).remove (tempPS);
                  catch (noStyle) {}
                  I was looking through my menu actions and a came across this script by monk Thomas
                  a partial solution
                      Auto create paragraph and character styles
                      Version: 1.0
                      Script by Thomas Silkjær
                      http://indesigning.net/
                  var the_document = app.documents.item(0);
                  var the_story = app.selection[0].parentStory;
                  var auto_pstyle_number = 0;
                  var auto_cstyle_number = 0;
                  counter = 0;
                  do {
                      var current_paragraph = the_story.paragraphs.item(counter);
                      counter_2 = 0;
                      do {
                          pstyle_is_applied = 0;
                          if(pstylePropertyDifferences(current_paragraph,the_document.paragraphStyles.item(counter_2),0) != 1) {
                              current_paragraph.applyParagraphStyle(the_document.paragraphStyles.item(counter_2),false);
                              counter_2 = the_document.paragraphStyles.length;
                              pstyle_is_applied = 1;
                      counter_2++;
                      } while (counter_2 < the_document.paragraphStyles.length);
                      if(pstyle_is_applied == 0) {
                          auto_pstyle_number++;
                          var created_style = pstylePropertyDifferences(current_paragraph,the_document.paragraphStyles.item(0),1);
                          created_style.name = "AutoStyle"+auto_pstyle_number;
                          current_paragraph.applyParagraphStyle(created_style,false);
                      counter_3 = 0;
                      do {
                          var current_character = current_paragraph.characters.item(counter_3);
                          if(current_character.styleOverridden == true) {
                              counter_4 = 0;
                              do {
                                  cstyle_is_applied = 0;
                                  var created_style = cstylePropertyDifferences(current_character,current_paragraph.appliedParagraphStyle,1);
                                  if(cstylePropertyDifferences(created_style,the_document.characterStyles.item(counter_4),0) != 1) {
                                      current_character.applyCharacterStyle(the_document.characterStyles.item(counter_4));
                                      counter_4 = the_document.characterStyles.length;
                                      cstyle_is_applied = 1;
                                  created_style.remove();
                              counter_4++;
                              } while (counter_4 < the_document.characterStyles.length);
                              if(cstyle_is_applied == 0) {
                                  auto_cstyle_number++;
                                  created_style.name = "AutoStyle"+auto_cstyle_number;
                                  current_character.applyCharacterStyle(created_style);
                      counter_3++;
                      } while (counter_3 < current_paragraph.characters.length);
                      counter++;
                  } while (counter < the_story.paragraphs.length);
                  function pstylePropertyDifferences(the_text,the_style,create_style){
                      if(create_style == 1) {
                          var temporary_style = the_document.paragraphStyles.add({name:"TempStyle"});
                      } else {
                          var the_difference = 0;
                      if (the_text.alignToBaseline != the_style.alignToBaseline) { if(create_style != 0) { temporary_style.alignToBaseline = the_text.alignToBaseline; } else { the_difference = 1; } }
                      if (the_text.appliedFont != the_style.appliedFont) { if(create_style != 0) { temporary_style.appliedFont = the_text.appliedFont; } else { the_difference = 1; } }
                      if (the_text.appliedLanguage != the_style.appliedLanguage) { if(create_style != 0) { temporary_style.appliedLanguage = the_text.appliedLanguage; } else { the_difference = 1; } }
                      if (the_text.appliedNumberingList != the_style.appliedNumberingList) { if(create_style != 0) { temporary_style.appliedNumberingList = the_text.appliedNumberingList; } else { the_difference = 1; } }
                      if (the_text.autoLeading != the_style.autoLeading) { if(create_style != 0) { temporary_style.autoLeading = the_text.autoLeading; } else { the_difference = 1; } }
                      if (the_text.balanceRaggedLines != the_style.balanceRaggedLines) { if(create_style != 0) { temporary_style.balanceRaggedLines = the_text.balanceRaggedLines; } else { the_difference = 1; } }
                      if (the_text.baselineShift != the_style.baselineShift) { if(create_style != 0) { temporary_style.baselineShift = the_text.baselineShift; } else { the_difference = 1; } }
                      if (the_text.bulletsAlignment != the_style.bulletsAlignment) { if(create_style != 0) { temporary_style.bulletsAlignment = the_text.bulletsAlignment; } else { the_difference = 1; } }
                      if (the_text.bulletsAndNumberingListType != the_style.bulletsAndNumberingListType) { if(create_style != 0) { temporary_style.bulletsAndNumberingListType = the_text.bulletsAndNumberingListType; } else { the_difference = 1; } }
                      if (the_text.bulletsCharacterStyle != the_style.bulletsCharacterStyle) { if(create_style != 0) { temporary_style.bulletsCharacterStyle = the_text.bulletsCharacterStyle; } else { the_difference = 1; } }
                      if (the_text.bulletsTextAfter != the_style.bulletsTextAfter) { if(create_style != 0) { temporary_style.bulletsTextAfter = the_text.bulletsTextAfter; } else { the_difference = 1; } }
                      if (the_text.capitalization != the_style.capitalization) { if(create_style != 0) { temporary_style.capitalization = the_text.capitalization; } else { the_difference = 1; } }
                      if (the_text.composer != the_style.composer) { if(create_style != 0) { temporary_style.composer = the_text.composer; } else { the_difference = 1; } }
                      if (the_text.desiredGlyphScaling != the_style.desiredGlyphScaling) { if(create_style != 0) { temporary_style.desiredGlyphScaling = the_text.desiredGlyphScaling; } else { the_difference = 1; } }
                      if (the_text.desiredLetterSpacing != the_style.desiredLetterSpacing) { if(create_style != 0) { temporary_style.desiredLetterSpacing = the_text.desiredLetterSpacing; } else { the_difference = 1; } }
                      if (the_text.desiredWordSpacing != the_style.desiredWordSpacing) { if(create_style != 0) { temporary_style.desiredWordSpacing = the_text.desiredWordSpacing; } else { the_difference = 1; } }
                      if (the_text.dropCapCharacters != the_style.dropCapCharacters) { if(create_style != 0) { temporary_style.dropCapCharacters = the_text.dropCapCharacters; } else { the_difference = 1; } }
                      if (the_text.dropCapLines != the_style.dropCapLines) { if(create_style != 0) { temporary_style.dropCapLines = the_text.dropCapLines; } else { the_difference = 1; } }
                      if (the_text.dropCapStyle != the_style.dropCapStyle) { if(create_style != 0) { temporary_style.dropCapStyle = the_text.dropCapStyle; } else { the_difference = 1; } }
                      if (the_text.dropcapDetail != the_style.dropcapDetail) { if(create_style != 0) { temporary_style.dropcapDetail = the_text.dropcapDetail; } else { the_difference = 1; } }
                      if (the_text.fillColor != the_style.fillColor) { if(create_style != 0) { temporary_style.fillColor = the_text.fillColor; } else { the_difference = 1; } }
                      if (the_text.fillTint != the_style.fillTint) { if(create_style != 0) { temporary_style.fillTint = the_text.fillTint; } else { the_difference = 1; } }
                      if (the_text.firstLineIndent != the_style.firstLineIndent) { if(create_style != 0) { temporary_style.firstLineIndent = the_text.firstLineIndent; } else { the_difference = 1; } }
                      if (the_text.fontStyle != the_style.fontStyle) { if(create_style != 0) { temporary_style.fontStyle = the_text.fontStyle; } else { the_difference = 1; } }
                      if (the_text.horizontalScale != the_style.horizontalScale) { if(create_style != 0) { temporary_style.horizontalScale = the_text.horizontalScale; } else { the_difference = 1; } }
                      if (the_text.hyphenWeight != the_style.hyphenWeight) { if(create_style != 0) { temporary_style.hyphenWeight = the_text.hyphenWeight; } else { the_difference = 1; } }
                      if (the_text.hyphenateAcrossColumns != the_style.hyphenateAcrossColumns) { if(create_style != 0) { temporary_style.hyphenateAcrossColumns = the_text.hyphenateAcrossColumns; } else { the_difference = 1; } }
                      if (the_text.hyphenateAfterFirst != the_style.hyphenateAfterFirst) { if(create_style != 0) { temporary_style.hyphenateAfterFirst = the_text.hyphenateAfterFirst; } else { the_difference = 1; } }
                      if (the_text.hyphenateBeforeLast != the_style.hyphenateBeforeLast) { if(create_style != 0) { temporary_style.hyphenateBeforeLast = the_text.hyphenateBeforeLast; } else { the_difference = 1; } }
                      if (the_text.hyphenateCapitalizedWords != the_style.hyphenateCapitalizedWords) { if(create_style != 0) { temporary_style.hyphenateCapitalizedWords = the_text.hyphenateCapitalizedWords; } else { the_difference = 1; } }
                      if (the_text.hyphenateLadderLimit != the_style.hyphenateLadderLimit) { if(create_style != 0) { temporary_style.hyphenateLadderLimit = the_text.hyphenateLadderLimit; } else { the_difference = 1; } }
                      if (the_text.hyphenateLastWord != the_style.hyphenateLastWord) { if(create_style != 0) { temporary_style.hyphenateLastWord = the_text.hyphenateLastWord; } else { the_difference = 1; } }
                      if (the_text.hyphenateWordsLongerThan != the_style.hyphenateWordsLongerThan) { if(create_style != 0) { temporary_style.hyphenateWordsLongerThan = the_text.hyphenateWordsLongerThan; } else { the_difference = 1; } }
                      if (the_text.hyphenation != the_style.hyphenation) { if(create_style != 0) { temporary_style.hyphenation = the_text.hyphenation; } else { the_difference = 1; } }
                      if (the_text.hyphenationZone != the_style.hyphenationZone) { if(create_style != 0) { temporary_style.hyphenationZone = the_text.hyphenationZone; } else { the_difference = 1; } }
                      if (the_text.ignoreEdgeAlignment != the_style.ignoreEdgeAlignment) { if(create_style != 0) { temporary_style.ignoreEdgeAlignment = the_text.ignoreEdgeAlignment; } else { the_difference = 1; } }
                      if (the_text.justification != the_style.justification) { if(create_style != 0) { temporary_style.justification = the_text.justification; } else { the_difference = 1; } }
                      if (the_text.keepAllLinesTogether != the_style.keepAllLinesTogether) { if(create_style != 0) { temporary_style.keepAllLinesTogether = the_text.keepAllLinesTogether; } else { the_difference = 1; } }
                      if (the_text.keepFirstLines != the_style.keepFirstLines) { if(create_style != 0) { temporary_style.keepFirstLines = the_text.keepFirstLines; } else { the_difference = 1; } }
                      if (the_text.keepLastLines != the_style.keepLastLines) { if(create_style != 0) { temporary_style.keepLastLines = the_text.keepLastLines; } else { the_difference = 1; } }
                      if (the_text.keepLinesTogether != the_style.keepLinesTogether) { if(create_style != 0) { temporary_style.keepLinesTogether = the_text.keepLinesTogether; } else { the_difference = 1; } }
                      if (the_text.keepRuleAboveInFrame != the_style.keepRuleAboveInFrame) { if(create_style != 0) { temporary_style.keepRuleAboveInFrame = the_text.keepRuleAboveInFrame; } else { the_difference = 1; } }
                      if (the_text.keepWithNext != the_style.keepWithNext) { if(create_style != 0) { temporary_style.keepWithNext = the_text.keepWithNext; } else { the_difference = 1; } }
                      if (the_text.kerningMethod != the_style.kerningMethod) { if(create_style != 0) { temporary_style.kerningMethod = the_text.kerningMethod; } else { the_difference = 1; } }
                      if (the_text.lastLineIndent != the_style.lastLineIndent) { if(create_style != 0) { temporary_style.lastLineIndent = the_text.lastLineIndent; } else { the_difference = 1; } }
                      if (the_text.leading != the_style.leading) { if(create_style != 0) { temporary_style.leading = the_text.leading; } else { the_difference = 1; } }
                      if (the_text.leftIndent != the_style.leftIndent) { if(create_style != 0) { temporary_style.leftIndent = the_text.leftIndent; } else { the_difference = 1; } }
                      if (the_text.ligatures != the_style.ligatures) { if(create_style != 0) { temporary_style.ligatures = the_text.ligatures; } else { the_difference = 1; } }
                      if (the_text.maximumGlyphScaling != the_style.maximumGlyphScaling) { if(create_style != 0) { temporary_style.maximumGlyphScaling = the_text.maximumGlyphScaling; } else { the_difference = 1; } }
                      if (the_text.maximumLetterSpacing != the_style.maximumLetterSpacing) { if(create_style != 0) { temporary_style.maximumLetterSpacing = the_text.maximumLetterSpacing; } else { the_difference = 1; } }
                      if (the_text.maximumWordSpacing != the_style.maximumWordSpacing) { if(create_style != 0) { temporary_style.maximumWordSpacing = the_text.maximumWordSpacing; } else { the_difference = 1; } }
                      if (the_text.minimumGlyphScaling != the_style.minimumGlyphScaling) { if(create_style != 0) { temporary_style.minimumGlyphScaling = the_text.minimumGlyphScaling; } else { the_difference = 1; } }
                      if (the_text.minimumLetterSpacing != the_style.minimumLetterSpacing) { if(create_style != 0) { temporary_style.minimumLetterSpacing = the_text.minimumLetterSpacing; } else { the_difference = 1; } }
                      if (the_text.minimumWordSpacing != the_style.minimumWordSpacing) { if(create_style != 0) { temporary_style.minimumWordSpacing = the_text.minimumWordSpacing; } else { the_difference = 1; } }
                      if (the_text.noBreak != the_style.noBreak) { if(create_style != 0) { temporary_style.noBreak = the_text.noBreak; } else { the_difference = 1; } }
                      if (the_text.numberingAlignment != the_style.numberingAlignment) { if(create_style != 0) { temporary_style.numberingAlignment = the_text.numberingAlignment; } else { the_difference = 1; } }
                      if (the_text.numberingApplyRestartPolicy != the_style.numberingApplyRestartPolicy) { if(create_style != 0) { temporary_style.numberingApplyRestartPolicy = the_text.numberingApplyRestartPolicy; } else { the_difference = 1; } }
                      if (the_text.numberingCharacterStyle != the_style.numberingCharacterStyle) { if(create_style != 0) { temporary_style.numberingCharacterStyle = the_text.numberingCharacterStyle; } else { the_difference = 1; } }
                      if (the_text.numberingContinue != the_style.numberingContinue) { if(create_style != 0) { temporary_style.numberingContinue = the_text.numberingContinue; } else { the_difference = 1; } }
                      if (the_text.numberingExpression != the_style.numberingExpression) { if(create_style != 0) { temporary_style.numberingExpression = the_text.numberingExpression; } else { the_difference = 1; } }
                      if (the_text.numberingFormat != the_style.numberingFormat) { if(create_style != 0) { temporary_style.numberingFormat = the_text.numberingFormat; } else { the_difference = 1; } }
                      if (the_text.numberingLevel != the_style.numberingLevel) { if(create_style != 0) { temporary_style.numberingLevel = the_text.numberingLevel; } else { the_difference = 1; } }
                      if (the_text.numberingStartAt != the_style.numberingStartAt) { if(create_style != 0) { temporary_style.numberingStartAt = the_text.numberingStartAt; } else { the_difference = 1; } }
                      if (the_text.otfContextualAlternate != the_style.otfContextualAlternate) { if(create_style != 0) { temporary_style.otfContextualAlternate = the_text.otfContextualAlternate; } else { the_difference = 1; } }
                      if (the_text.otfDiscretionaryLigature != the_style.otfDiscretionaryLigature) { if(create_style != 0) { temporary_style.otfDiscretionaryLigature = the_text.otfDiscretionaryLigature; } else { the_difference = 1; } }
                      if (the_text.otfFigureStyle != the_style.otfFigureStyle) { if(create_style != 0) { temporary_style.otfFigureStyle = the_text.otfFigureStyle; } else { the_difference = 1; } }
                      if (the_text.otfFraction != the_style.otfFraction) { if(create_style != 0) { temporary_style.otfFraction = the_text.otfFraction; } else { the_difference = 1; } }
                      if (the_text.otfHistorical != the_style.otfHistorical) { if(create_style != 0) { temporary_style.otfHistorical = the_text.otfHistorical; } else { the_difference = 1; } }
                      if (the_text.otfLocale != the_style.otfLocale) { if(create_style != 0) { temporary_style.otfLocale = the_text.otfLocale; } else { the_difference = 1; } }
                      if (the_text.otfMark != the_style.otfMark) { if(create_style != 0) { temporary_style.otfMark = the_text.otfMark; } else { the_difference = 1; } }
                      if (the_text.otfOrdinal != the_style.otfOrdinal) { if(create_style != 0) { temporary_style.otfOrdinal = the_text.otfOrdinal; } else { the_difference = 1; } }
                      if (the_text.otfSlashedZero != the_style.otfSlashedZero) { if(create_style != 0) { temporary_style.otfSlashedZero = the_text.otfSlashedZero; } else { the_difference = 1; } }
                      if (the_text.otfStylisticSets != the_style.otfStylisticSets) { if(create_style != 0) { temporary_style.otfStylisticSets = the_text.otfStylisticSets; } else { the_difference = 1; } }
                      if (the_text.otfSwash != the_style.otfSwash) { if(create_style != 0) { temporary_style.otfSwash = the_text.otfSwash; } else { the_difference = 1; } }
                      if (the_text.otfTitling != the_style.otfTitling) { if(create_style != 0) { temporary_style.otfTitling = the_text.otfTitling; } else { the_difference = 1; } }
                      if (the_text.overprintFill != the_style.overprintFill) { if(create_style != 0) { temporary_style.overprintFill = the_text.overprintFill; } else { the_difference = 1; } }
                      if (the_text.overprintStroke != the_style.overprintStroke) { if(create_style != 0) { temporary_style.overprintStroke = the_text.overprintStroke; } else { the_difference = 1; } }
                      if (the_text.pointSize != the_style.pointSize) { if(create_style != 0) { temporary_style.pointSize = the_text.pointSize; } else { the_difference = 1; } }
                      if (the_text.position != the_style.position) { if(create_style != 0) { temporary_style.position = the_text.position; } else { the_difference = 1; } }
                      if (the_text.positionalForm != the_style.positionalForm) { if(create_style != 0) { temporary_style.positionalForm = the_text.positionalForm; } else { the_difference = 1; } }
                      if (the_text.rightIndent != the_style.rightIndent) { if(create_style != 0) { temporary_style.rightIndent = the_text.rightIndent; } else { the_difference = 1; } }
                      if (the_text.ruleAbove != the_style.ruleAbove) { if(create_style != 0) { temporary_style.ruleAbove = the_text.ruleAbove; } else { the_difference = 1; } }
                      if (the_text.ruleAboveColor != the_style.ruleAboveColor) { if(create_style != 0) { temporary_style.ruleAboveColor = the_text.ruleAboveColor; } else { the_difference = 1; } }
                      if (the_text.ruleAboveGapColor != the_style.ruleAboveGapColor) { if(create_style != 0) { temporary_style.ruleAboveGapColor = the_text.ruleAboveGapColor; } else { the_difference = 1; } }
                      if (the_text.ruleAboveGapOverprint != the_style.ruleAboveGapOverprint) { if(create_style != 0) { temporary_style.ruleAboveGapOverprint = the_text.ruleAboveGapOverprint; } else { the_difference = 1; } }
                      if (the_text.ruleAboveGapTint != the_style.ruleAboveGapTint) { if(create_style != 0) { temporary_style.ruleAboveGapTint = the_text.ruleAboveGapTint; } else { the_difference = 1; } }
                      if (the_text.ruleAboveLeftIndent != the_style.ruleAboveLeftIndent) { if(create_style != 0) { temporary_style.ruleAboveLeftIndent = the_text.ruleAboveLeftIndent; } else { the_difference = 1; } }
                      if (the_text.ruleAboveLineWeight != the_style.ruleAboveLineWeight) { if(create_style != 0) { temporary_style.ruleAboveLineWeight = the_text.ruleAboveLineWeight; } else { the_difference = 1; } }
                      if (the_text.ruleAboveOffset != the_style.ruleAboveOffset) { if(create_style != 0) { temporary_style.ruleAboveOffset = the_text.ruleAboveOffset; } else { the_difference = 1; } }
                      if (the_text.ruleAboveOverprint != the_style.ruleAboveOverprint) { if(create_style != 0) { temporary_style.ruleAboveOverprint = the_text.ruleAboveOverprint; } else { the_difference = 1; } }
                      if (the_text.ruleAboveRightIndent != the_style.ruleAboveRightIndent) { if(create_style != 0) { temporary_style.ruleAboveRightIndent = the_text.ruleAboveRightIndent; } else { the_difference = 1; } }
                      if (the_text.ruleAboveTint != the_style.ruleAboveTint) { if(create_style != 0) { temporary_style.ruleAboveTint = the_text.ruleAboveTint; } else { the_difference = 1; } }
                      if (the_text.ruleAboveType != the_style.ruleAboveType) { if(create_style != 0) { temporary_style.ruleAboveType = the_text.ruleAboveType; } else { the_difference = 1; } }
                      if (the_text.ruleAboveWidth != the_style.ruleAboveWidth) { if(create_style != 0) { temporary_style.ruleAboveWidth = the_text.ruleAboveWidth; } else { the_difference = 1; } }
                      if (the_text.ruleBelow != the_style.ruleBelow) { if(create_style != 0) { temporary_style.ruleBelow = the_text.ruleBelow; } else { the_difference = 1; } }
                      if (the_text.ruleBelowColor != the_style.ruleBelowColor) { if(create_style != 0) { temporary_style.ruleBelowColor = the_text.ruleBelowColor; } else { the_difference = 1; } }
                      if (the_text.ruleBelowGapColor != the_style.ruleBelowGapColor) { if(create_style != 0) { temporary_style.ruleBelowGapColor = the_text.ruleBelowGapColor; } else { the_difference = 1; } }
                      if (the_text.ruleBelowGapOverprint != the_style.ruleBelowGapOverprint) { if(create_style != 0) { temporary_style.ruleBelowGapOverprint = the_text.ruleBelowGapOverprint; } else { the_difference = 1; } }
                      if (the_text.ruleBelowGapTint != the_style.ruleBelowGapTint) { if(create_style != 0) { temporary_style.ruleBelowGapTint = the_text.ruleBelowGapTint; } else { the_difference = 1; } }
                      if (the_text.ruleBelowLeftIndent != the_style.ruleBelowLeftIndent) { if(create_style != 0) { temporary_style.ruleBelowLeftIndent = the_text.ruleBelowLeftIndent; } else { the_difference = 1; } }
                      if (the_text.ruleBelowLineWeight != the_style.ruleBelowLineWeight) { if(create_style != 0) { temporary_style.ruleBelowLineWeight = the_text.ruleBelowLineWeight; } else { the_difference = 1; } }
                      if (the_text.ruleBelowOffset != the_style.ruleBelowOffset) { if(create_style != 0) { temporary_style.ruleBelowOffset = the_text.ruleBelowOffset; } else { the_difference = 1; } }
                      if (the_text.ruleBelowOverprint != the_style.ruleBelowOverprint) { if(create_style != 0) { temporary_style.ruleBelowOverprint = the_text.ruleBelowOverprint; } else { the_difference = 1; } }
                      if (the_text.ruleBelowRightIndent != the_style.ruleBelowRightIndent) { if(create_style != 0) { temporary_style.ruleBelowRightIndent = the_text.ruleBelowRightIndent; } else { the_difference = 1; } }
                      if (the_text.ruleBelowTint != the_style.ruleBelowTint) { if(create_style != 0) { temporary_style.ruleBelowTint = the_text.ruleBelowTint; } else { the_difference = 1; } }
                      if (the_text.ruleBelowType != the_style.ruleBelowType) { if(create_style != 0) { temporary_style.ruleBelowType = the_text.ruleBelowType; } else { the_difference = 1; } }
                      if (the_text.ruleBelowWidth != the_style.ruleBelowWidth) { if(create_style != 0) { temporary_style.ruleBelowWidth = the_text.ruleBelowWidth; } else { the_difference = 1; } }
                      if (the_text.singleWordJustification != the_style.singleWordJustification) { if(create_style != 0) { temporary_style.singleWordJustification = the_text.singleWordJustification; } else { the_difference = 1; } }
                      if (the_text.skew != the_style.skew) { if(create_style != 0) { temporary_style.skew = the_text.skew; } else { the_difference = 1; } }
                      if (the_text.spaceAfter != the_style.spaceAfter) { if(create_style != 0) { temporary_style.spaceAfter = the_text.spaceAfter; } else { the_difference = 1; } }
                      if (the_text.spaceBefore != the_style.spaceBefore) { if(create_style != 0) { temporary_style.spaceBefore = the_text.spaceBefore; } else { the_difference = 1; } }
                      if (the_text.startParagraph != the_style.startParagraph) { if(create_style != 0) { temporary_style.startParagraph = the_text.startParagraph; } else { the_difference = 1; } }
                      if (the_text.strikeThroughColor != the_style.strikeThroughColor) { if(create_style != 0) { temporary_style.strikeThroughColor = the_text.strikeThroughColor; } else { the_difference = 1; } }
                      if (the_text.strikeThroughGapColor != the_style.strikeThroughGapColor) { if(create_style != 0) { temporary_style.strikeThroughGapColor = the_text.strikeThroughGapColor; } else { the_difference = 1; } }
                      if (the_text.strikeThroughGapOverprint != the_style.strikeThroughGapOverprint) { if(create_style != 0) { temporary_style.strikeThroughGapOverprint = the_text.strikeThroughGapOverprint; } else { the_difference = 1; } }
                      if (the_text.strikeThroughGapTint != the_style.strikeThroughGapTint) { if(create_style != 0) { temporary_style.strikeThroughGapTint = the_text.strikeThroughGapTint; } else { the_difference = 1; } }
                      if (the_text.strikeThroughOffset != the_style.strikeThroughOffset) { if(create_style != 0) { temporary_style.strikeThroughOffset = the_text.strikeThroughOffset; } else { the_difference = 1; } }
                      if (the_text.strikeThroughOverprint != the_style.strikeThroughOverprint) { if(create_style != 0) { temporary_style.strikeThroughOverprint = the_text.strikeThroughOverprint; } else { the_difference = 1; } }
                      if (the_text.strikeThroughTint != the_style.strikeThroughTint) { if(create_style != 0) { temporary_style.strikeThroughTint = the_text.strikeThroughTint; } else { the_difference = 1; } }
                      if (the_text.strikeThroughType != the_style.strikeThroughType) { if(create_style != 0) { temporary_style.strikeThroughType = the_text.strikeThroughType; } else { the_difference = 1; } }
                      if (the_text.strikeThroughWeight != the_style.strikeThroughWeight) { if(create_style != 0) { temporary_style.strikeThroughWeight = the_text.strikeThroughWeight; } else { the_difference = 1; } }
                      if (the_text.strikeThru != the_style.strikeThru) { if(create_style != 0) { temporary_style.strikeThru = the_text.strikeThru; } else { the_difference = 1; } }
                      if (the_text.strokeColor != the_style.strokeColor) { if(create_style != 0) { temporary_style.strokeColor = the_text.strokeColor; } else { the_difference = 1; } }
                      if (the_text.strokeTint != the_style.strokeTint) { if(create_style != 0) { temporary_style.strokeTint = the_text.strokeTint; } else { the_difference = 1; } }
                      if (the_text.strokeWeight != the_style.strokeWeight) { if(create_style != 0) { temporary_style.strokeWeight = the_text.strokeWeight; } else { the_difference = 1; } }
                      if (the_text.tracking != the_style.tracking) { if(create_style != 0) { temporary_style.tracking = the_text.tracking; } else { the_difference = 1; } }
                      if (the_text.underline != the_style.underline) { if(create_style != 0) { temporary_style.underline = the_text.underline; } else { the_difference = 1; } }
                      if (the_text.underlineColor != the_style.underlineColor) { if(create_style != 0) { temporary_style.underlineColor = the_text.underlineColor; } else { the_difference = 1; } }
                      if (the_text.underlineGapColor != the_style.underlineGapColor) { if(create_style != 0) { temporary_style.underlineGapColor = the_text.underlineGapColor; } else { the_difference = 1; } }
                      if (the_text.underlineGapOverprint != the_style.underlineGapOverprint) { if(create_style != 0) { temporary_style.underlineGapOverprint = the_text.underlineGapOverprint; } else { the_difference = 1; } }
                      if (the_text.underlineGapTint != the_style.underlineGapTint) { if(create_style != 0) { temporary_style.underlineGapTint = the_text.underlineGapTint; } else { the_difference = 1; } }
                      if (the_text.underlineOffset != the_style.underlineOffset) { if(create_style != 0) { temporary_style.underlineOffset = the_text.underlineOffset; } else { the_difference = 1; } }
                      if (the_text.underlineOverprint != the_style.underlineOverprint) { if(create_style != 0) { temporary_style.underlineOverprint = the_text.underlineOverprint; } else { the_difference = 1; } }
                      if (the_text.underlineTint != the_style.underlineTint) { if(create_style != 0) { temporary_style.underlineTint = the_text.underlineTint; } else { the_difference = 1; } }
                      if (the_text.underlineType != the_style.underlineType) { if(create_style != 0) { temporary_style.underlineType = the_text.underlineType; } else { the_difference = 1; } }
                      if (the_text.underlineWeight != the_style.underlineWeight) { if(create_style != 0) { temporary_style.underlineWeight = the_text.underlineWeight; } else { the_difference = 1; } }
                      if (the_text.verticalScale != the_style.verticalScale) { if(create_style != 0) { temporary_style.verticalScale = the_text.verticalScale; } else { the_difference = 1; } }
                          return temporary_style;
                      } else {
                          return the_difference;
                  function cstylePropertyDifferences(the_text,the_style,create_style){
                          var temporary_style = the_document.characterStyles.add({name:"TempStyle"});
                      } else {
                      } else {
                  alert("Done!");
                  • 6. Re: Define/Redefine styles
                    Jump_Over Level 5
                    Yes Trevor, You got me now. Thanks for a monk_Thomas_ready_to_be_copied_job.
                    I was just wondering, that there some way to use - i.e. -  app.selection[0].paragraphs[0].properties.toSource() and eval this to define a new para style, but I am completely not familiar with that. So... lets go to the monk room
                    • 7. Re: Define/Redefine styles
                      csm_phil Level 4
                      Hi Jump,
                      Why you not using the "Menu Actions" way i feel it is easy to achieve the menu actions way.
                      thx
                      csm_phil
                      • 8. Re: Define/Redefine styles
                        Hi Phil
                        I couldn't get the menuactions to work.
                        myMenuAction = app.menuActions.item("$ID/New Paragraph Style...");
                        myMenuAction.invoke();
                        gives an error message
                        the following script could be a good lead and someone a bit more knolagable than be should be able to do something with it.
                        it give a list of the propeties and their values
                        myDoc= myDoc = app.activeDocument;
                        ns=app.selection[0].paragraphs[0].properties.toSource()
                        myPropName=[]
                        myPropValue=[]
                        st=""
                        myPropNameMatch = /[^,]+(?=:)/g;
                        myPropValueMatch = /((([^:]+(?=,))|((?<=:)[^:]+$)))/g;
                        myPropName=ns.match(myPropNameMatch);
                        myPropValue=ns.match(myPropValueMatch);
                        myPropName[0]=myPropName[0].slice(2);
                        (myDoc.paragraphStyles.item("Oh").isValid) ? newst = myDoc.paragraphStyles.item("Oh") : myDoc.paragraphStyles.add({name:"Oh"});
                        for (c=0; c<myPropName.length; c++)
                            st+=c+"\t"+myPropName[c]+" = "+myPropValue[c]+";\r"
                            z=myPropName[c]
                            y= myPropValue[c]
                            newst.properties = {z:y}
                        alert(st)
                        //with (newst) st;
                        • 9. Re: Define/Redefine styles
                          Hi Jump_Over,
                          Two selfmade non copied scripts
                          They work for paragraph styles object styles need a bit of thought ..........
                          The first one which is the one to use I thought of second one first, oh well
                          The first script is obviously much better than the second script.
                          I am including the second script here because it has some nice methods.
                          I converts the string you get from the toSource() into a string that you can use as a properties = {......} by use of regex
                          It works but go for the first one!!!!!!!!!!!
                          The piccy show the reults
                          Regards
                          Trevor
                          Script 1: The Good
                          myNewStyleName =  "Created or Redefined Style";
                          try {
                              myProperties=mySelection.paragraphs[0].properties;
                              newStyle = (myDoc.paragraphStyles.item(myNewStyleName).isValid) ?  myDoc.paragraphStyles.item(myNewStyleName) : myDoc.paragraphStyles.add({name:myNewStyleName});
                              newStyle.properties=myProperties;
                              // As the bulletChar is read only & has to be split into it's elelments easiest if done manually
                              newStyle.bulletChar.bulletsFont = mySelection.bulletChar.bulletsFont;
                              newStyle.bulletChar.bulletsFontStyle = mySelection.bulletChar.bulletsFontStyle;
                              newStyle.bulletChar.characterType = mySelection.bulletChar.characterType;
                              newStyle.bulletChar.characterValue = mySelection.bulletChar.characterValue;
                              // sort out tablist problem
                              newStyle.tabList = mySelection.tabList;
                              // there might be other values that need to be returned in this way
                          catch (selectionDosentHaveParaStyle) {alert("Select some text")}
                          Script 2: The Bad
                          #target indesign
                          // THE MUCH MUCH MUCH BETTER WAY OFF DOING THIS IS THE ABOVE
                          // SCRIPT .  USE THAT ONE
                          // Script by Trevor to Create Redefine Paragraph Style base on selected paragraph properties
                          // function uses regex expresions to convert paragraphs.properties.toSource() to a string of properties
                          // The string is then run as a doScript
                          app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Create Redefine Paragraph Style");
                          function main()
                          n=app.selection[0].paragraphs[0]
                          ns=n.properties.toSource()
                          newStyleName = "Created Redefined Paragraph Style";
                          newParaStyle = (myDoc.paragraphStyles.item(newStyleName).isValid) ?  myDoc.paragraphStyles.item(newStyleName) : myDoc.paragraphStyles.add({name:newStyleName});
                          // Check if selected paragraph has style applied to it with no overrides
                          // if so then just duplicate the style and remove newStyleName replacing with the duplicated style
                          // it is worth considering whether or not to make a new style even if there is an overide
                          if (n.appliedParagraphStyle.isValid && n.styleOverridden==0)
                          saps=n.appliedParagraphStyle
                          app.activeDocument.paragraphStyles.item(newStyleName).remove (tempPS);
                          tempPS.name=newStyleName;
                          return false;
                          // remove contents property so as not to mess up future grep searches
                          con=n.contents
                          // change the paragraph contents result to the toSource result format so it can be removed from there
                          find=/\\/g
                          change='\\\\'
                          var con=con.replace (find, change)
                          find=/\"/g
                          change='\\\"'
                          con=', contents:\"'+con+'\"'
                          change =''
                          ns=ns.replace (con, change)
                          // remove Tab list from toSource (has subproperties) will apply them at the end
                          find ="tabList:"+n.tabList.toSource()+",";
                          ns=ns.replace (find, change)
                          // change enums ({}) that are not given in toSource into a true numeric value
                          myPropValueMatch = /[^,]+?:\(\{\}\)/g; //   finds  properties that have enums that need to be coverted
                          myPropNameMatch = /[^,]+?(?=:\(\{\}\))/g; // property name of above finds
                          myPropName=myPropValue=[];
                          newStyle = (myDoc.paragraphStyles.item(newStyleName).isValid) ?  myDoc.paragraphStyles.item(newStyleName) : myDoc.paragraphStyles.add({name:newStyleName});
                              schange = "n."+myPropName[c];
                              // use doScript to check for the property value can't do n.myPropName[c] without that
                              nchange=app.doScript(schange);
                              change=myPropName[c]+":"+nchange*1;
                              ns=ns.replace (myPropValue[c], change)
                          // change the toSource () into a command string newParaStyle.properties = ({blah:0, blah:"fred", ...})
                          ns="newParaStyle.properties = "+ns;
                          // Run The command
                          app.doScript(ns);
                          // Now for the monks work!!
                          newParaStyle.bulletChar.bulletsFont = n.bulletChar.bulletsFont;
                          newParaStyle.bulletChar.bulletsFontStyle = n.bulletChar.bulletsFontStyle;
                          newParaStyle.bulletChar.characterType = n.bulletChar.characterType;
                          newParaStyle.bulletChar.characterValue = n.bulletChar.characterValue;
                          newParaStyle.tabList=n.tabList;
                          • 10. Re: Define/Redefine styles
                            corrected the "Good Script"
