3 Replies Latest reply on Jun 28, 2012 6:34 PM by Production Monkey
    goToNetPage fails on Mac Safari and FF
    zedascouve
      Hi all
      I'm trying to open a local html file with the old and good goToNetPage which alaways works pretty well on Windows but I can't get it to work on the Mac.
      i have Safari as my default browser on Mac and the following behavior attached on a sprite
      on mouseUp me
      goToNetPage "htms/myfile.htm"
      end
      gives me this error: Safari can't find the server. Safari can't open the page "http://htms/myfile.ht" because Safari can't find the server "htms".
      In short Safari isn't treating the html as a local one  and is apending the http instead of file:///
      I also tried this:
      on mouseUp me
      goToNetPage the MoviePath & "htms/myfile.htm"
      end
      and now i have this in my address bar
      Macintosh%20HD:Users:wilsoncortezribeiro:Desktop:Nova%20pasta:Root:htms/myfile.htm
      but got another error:
      Safari can't open "Macintosh%20HD:Users:wilsoncortezribeiro:Desktop:Nova%20pasta:Root:htms/myfile.htm" because the first character of its  addres is not valid
      I have this behavior in my first frame:
      on startMovie
      global gPlatform, gDelimiter
      if the platform contains "Windows" then
        gPlatform="win"
        gDelimiter="\"
      else if the platform contains "Macintosh" then
        gPlatform="mac"
        gDelimiter=":"
      else
        gPlatform="none"
        gDelimiter="none"
      end if
      end
      as i need this project to run in both win and mac but no way. If i set Firefox as my default browser (Mac) things get worse..... firefox doesn't open at all.
      So, what you guys could tell me to try? I'm near a deadline and stucked :-(
      BTW I also ttried with the Budy Api
      set OK = baOpenURL( "htms/myfile.htm" , "maximised" )    and this prints the error regarding not being able to find "htms server" along with a very weird bunch of characters like %00%00%00 appended to the address (path) of the file.
      Director 11.5 Mac OS Lion 10.7.4
        • 1. Re: goToNetPage fails on Mac Safari and FF
          Production Monkey
          You need a function that will convert your relative path into a valid full path that the browser understands.  I wrote up the function below to get you started. I don't have a mac to test it on, but on my windows box it seems to produce the correct result.
          on convertToMacFullLocalUrl  RelativePath
            LocalUrl =  "file:///Volumes/"
            Delim = "/"
            _player.itemDelimiter = ":"
            FullPath = _movie.path & RelativePath
            -- Pull out all the path info minus the delimiter
            Tokens=[]
            repeat with index = 1 to FullPath.items.count
              Tokens.append(FullPath.item[index])
            end repeat
            -- reassemble the path in a local URL format
            repeat with Tok in Tokens
              LocalUrl = LocalUrl & Tok & Delim
            end repeat
            -- remove delimiter at end of string
            delete  LocalUrl.char[LocalUrl.char.count]
            return LocalUrl
          end convertToMacFullLocalUrl
          • 2. Re: goToNetPage fails on Mac Safari and FF
            zedascouve Level 1
            Thank you very much for your time :-)
            Well I've resolved this with buddyApi Xtra using baOpenFile and not baOpenURl as i was used to.
            So the straight forward "OK = baOpenFile( the moviePath & "myfile.htm" , "maximised" )" did the trick
            Anyway could you tell me where i need to put this nice function you've kindy wrote? I' d like to try It out.
            Once again, thank You.
            • 3. Re: goToNetPage fails on Mac Safari and FF
              Production Monkey Level 3
              I would do something like:
              LocalUrl = convertToMacFullLocalUrl("myfile.htm")
              Okay =  baOpenURL(LocalUrl , "normal")
              if Not(Okay) then
                  alert "There was a problem connecting with the web page. "
              end if
