1 Reply Latest reply on Apr 23, 2008 8:29 PM by Captiv8r
    Options under Edit | Windows don't usually do anything
    vaprocura
      The options found in the Windows Properties dialog box, (e.g., under Edit | Windows), don't work consistently. Sometimes, they work, but usually they just don't.
      For example, if I specify that the tabs display on the left, instead of at the top, they still display at the top. If I check the Home checkbox, no Home button displays. If I check the Glossary checkbox, no Glossary tab displays. Etc. It's like the .apj file is not initializing.
      Now I have the browse sequence displaying and I can't get it to disappear. Very frustrating.
        • 1. Re: Options under Edit | Windows don't usually do anything
          Hi vaprocura
          Sometimes the Window definition becomes horked and you are better off defining a new window with the settings you want. As for the Home button, did you also enter a filename or URL the button would link to? If not, that would explain why it isn't showing. It's simply not linked to anything. Same for the Glossary. Have you defined a Glossary?
          Cheers... Rick
