6 Replies Latest reply on Jun 28, 2012 4:54 AM by Phoenix89MR
    Error Message for Camera Raw
    Phoenix89MR Level 1
      I used the Update function several times for PS  12.0.4 and it always says Camera Raw failed to install.  What's going wrong?  How can I tell whether i have the current (6.7?) camera raw version?
        • 1. Re: Error Message for Camera Raw
          ssprengel Adobe Community Professional & MVP
          Photoshop / Help / About Plug-in… / Camera Raw…
          • 2. Re: Error Message for Camera Raw
            Level 5
            …or, if you happen to be on a Mac:
            Photoshop menu > About Plug-in > Camera Raw…
            • 3. Re: Error Message for Camera Raw
              Level 5
              …and if you're on Mac, please say so.  I may be able to help you on a Mac; if you're on Windows, you're in excellent hands with ssprengel.
              • 4. Re: Error Message for Camera Raw
                Ashutosh.Nigam Adobe Employee
                ACR update should be 6.7 otherwise Please provide us with Camera Raw installer log file at
                For Mac:
                "Library/Logs/Adobe",
                For Win:
                Program Fies(x86)\Common Files\Adobe\Installers
                This would help us in resolving the issue.
                Please mail it to asnigam@adobe.com.
                Ashutosh
                • 5. Re: Error Message for Camera Raw
                  Phoenix89MR Level 1
                  Thanks, station_two.  I am on a Mac, and the menu confirms 6.7.0.339.  I'm not sure why I got the error message.  After the "failed" installation attempts, I was able to open and view NEF files from my new Nikon D800 (couldn't prior to update).  So I guess the "failed" message was an error.
                  • 6. Re: Error Message for Camera Raw
                    Phoenix89MR Level 1
                    Here are the install logs:
                    Visit http://www.adobe.com/go/loganalyzer/ for more information
                    START - Installer Session
                    RIBS version: 3.0.121.0
                    OSX version: 10.6.8
                    ::START TIMER:: [Total Timer]
                    CHECK: Single instance running
                    CHECK : Credentials
                    Load Deployment File
                    deploymentFile option not given
                    Create Required Folders
                    Assuming install mode
                    Looking up install source path
                    Sync Media DB ...
                    ::START TIMER:: [Sync Media DB]
                    Pre check media db sync
                    End of Pre check media db sync. Exit code: 0
                    :: END TIMER :: [Sync Media DB] took 190 miliseconds (0.19 seconds) DTR = 1073.68 KBPS (1.04852 MBPS)
                    Ready to initialize session to start with ...
                    ::START TIMER:: [CreatePayloadSession]
                    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                    Updated source path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.7.040
                    Updating media info for: {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE}
                    Ignoring original data since install source is local
                      Type: 0, Volume Order: 1, Media Name: AdobeCameraRaw-6.7-mul-AdobeUpdate
                      Path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.7.040/payloads/Ado beCameraRaw6.0All-200412075813/AdobeCameraRaw6.0All-200412075813.dmg
                    Updating media info for: {CC43F132-5096-41FC-A5C2-69E4202AC114}
                      Path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.7.040/payloads/Ado beCameraRawProfile6.0All-200412075904/AdobeCameraRawProfile6.0All-200412075904.dmg
                    --------------------  END  - Updating Media Sources -  END  --------------------
                    Supported RIBS version range: [0.0.66.0,3.0.121.0]
                    ----------------- CreatePayloadSession: machine is x86 ---------------
                    ______ Verify Dependency Subscribers ______
                    Overwrite property "extensionsOnly" to: 1
                    Overwrite property "mode" to: silent
                    Overwrite property "patchesOnly" to: 1
                    Overwrite property "workflow" to: updater
                    Found payload actions:
                    Deciding what installer mode to use...
                    BEGIN Setting requested payload actions
                    Value returned on lookup of payload: {2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All is: true
                    Action string for  {2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All  is install
                    Selection of payload {2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All is forbidden by the policy.
                    Value returned on lookup of payload: {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All is: true
                    Action string for  {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All  is install
                    Selection of payload {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All is forbidden by the policy.
                    Value returned on lookup of payload: {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All is: false
                    Action string for  {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All  is install
                    Value returned on lookup of payload: {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All is: false
                    Action string for  {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All  is install
                    Selection of payload {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All is forbidden by the policy.
                    END Setting requested payload actions
                    Collected advanced path check information for INSTALLDIR
                    INSTALLDIR is a well-formed path
                    INSTALLDIR is not the root path
                    INSTALLDIR is on a local volume
                    INSTALLDIR is on a writable volume
                    INSTALLDIR is not on a case sensitive volume
                    INSTALLDIR passed path basic path validation: /Library/Application Support/Adobe/Plug-Ins/CS5/File Formats
                    [       0] Wed Jun 27 19:18:21 2012  WARN
                    Payload:{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All has newer update. The patch will be uninstalled now.
                    Payload:{2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All has newer update. The patch will be uninstalled now.
                    [       0] Wed Jun 27 19:18:21 2012  INFO
                    Payloads passed preflight validation.
                    Call PreSession Custom Hook
                    Calling the custom action code for pre-remove for payload {2F595448-AD13-4615-820A-15F141F762E8}
                    ::START TIMER:: [Payload Operation :{2F595448-AD13-4615-820A-15F141F762E8}]
                    [       1] Wed Jun 27 19:18:21 2012  INFO
                    Installer Operation: PayloadUninstaller
                    Session {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} modify request for AdobeCode: {2F595448-AD13-4615-820A-15F141F762E8}
                    Effective AdobeCode for: {2F595448-AD13-4615-820A-15F141F762E8} is {2F595448-AD13-4615-820A-15F141F762E8}
                    CustomizedPatch property not found in database
                    Beginning un-installation for payload at /Library/Application Support/Adobe/Uninstall/{2F595448-AD13-4615-820A-15F141F762E8}.db
                    Completing un-installation for payload at /Library/Application Support/Adobe/Uninstall/{2F595448-AD13-4615-820A-15F141F762E8}.db
                    Physical payload uninstall result:0
                    [       0] Wed Jun 27 19:18:22 2012  INFO
                    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
                    :: END TIMER :: [Payload Operation :{2F595448-AD13-4615-820A-15F141F762E8}] took 1001 miliseconds (1.001 seconds) DTR = 43776.2 KBPS (42.7502 MBPS)
                    User specified overrideFile:
                    Calling the custom action code for post-remove for payload {2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All
                    Calling the custom action code for pre-remove for payload {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}
                    ::START TIMER:: [Payload Operation :{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}]
                    [       1] Wed Jun 27 19:18:22 2012  INFO
                    Session {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} modify request for AdobeCode: {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}
                    Effective AdobeCode for: {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} is {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}
                    Beginning un-installation for payload at /Library/Application Support/Adobe/Uninstall/{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}.db
                    [       1] Wed Jun 27 19:18:29 2012  INFO
                    Completing un-installation for payload at /Library/Application Support/Adobe/Uninstall/{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}.db
                    [       1] Wed Jun 27 19:18:30 2012  INFO
                    [       0] Wed Jun 27 19:18:30 2012  INFO
                    :: END TIMER :: [Payload Operation :{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559}] took 8067 miliseconds (8.067 seconds) DTR = 20419 KBPS (19.9404 MBPS)
                    Calling the custom action code for post-remove for payload {1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All
                    Calling the custom action code for pre-install for payload {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE}
                    ::START TIMER:: [Payload Operation :{4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE}]
                    [       2] Wed Jun 27 19:18:30 2012  INFO
                    Installer Operation: PayloadInstaller
                    Request to install payload
                    [       2] Wed Jun 27 19:18:32 2012  INFO
                    Beginning installation for payload at /private/tmp/.tempdirjAnJgx6O/Install.db
                    [       2] Wed Jun 27 19:18:33 2012  INFO
                    Evaluating condition# 1
                    Condition failed
                    Condition failed
                    [       2] Wed Jun 27 19:18:34 2012  INFO
                    Completing installation for payload at /private/tmp/.tempdirjAnJgx6O/Install.db
                    UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE}.db
                    [       0] Wed Jun 27 19:18:34 2012  INFO
                    :: END TIMER :: [Payload Operation :{4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE}] took 4002 miliseconds (4.002 seconds) DTR = 14852.6 KBPS (14.5045 MBPS)
                    [       0] Wed Jun 27 19:18:35 2012  INFO
                    Updating driver data - Action: Add driver entry
                    Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                    Calling the custom action code for post-install for payload {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All
                    Calling the custom action code for pre-install for payload {CC43F132-5096-41FC-A5C2-69E4202AC114}
                    ::START TIMER:: [Payload Operation :{CC43F132-5096-41FC-A5C2-69E4202AC114}]
                    [       1] Wed Jun 27 19:18:35 2012  INFO
                    [       1] Wed Jun 27 19:18:36 2012  INFO
                    Beginning installation for payload at /private/tmp/.tempdir8czMnmpG/Install.db
                    [       1] Wed Jun 27 19:18:59 2012  INFO
                    Completing installation for payload at /private/tmp/.tempdir8czMnmpG/Install.db
                    UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{CC43F132-5096-41FC-A5C2-69E4202AC114}.db
                    [       0] Wed Jun 27 19:19:00 2012  INFO
                    :: END TIMER :: [Payload Operation :{CC43F132-5096-41FC-A5C2-69E4202AC114}] took 25087 miliseconds (25.087 seconds) DTR = 11230.7 KBPS (10.9675 MBPS)
                    Calling the custom action code for post-install for payload {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All
                    No operation.  We're done:
                    Updating driver data - Action: Remove driver entry
                    Updating driver data successful. Driver entry was added. ARP estimated size 513882KB
                    [       0] Wed Jun 27 19:19:02 2012  INFO
                    Successfully installed 2 components:
                    - Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All
                    - Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All
                    Total components repaired: 0
                    Successfully removed 2 components:
                    - Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All
                    - Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All
                    Call PostSession Custom Hook
                    :: END TIMER :: [Total Timer] took 42118 miliseconds (42.118 seconds) DTR = 3200.25 KBPS (3.12524 MBPS)
                    -------------------------------------- Summary --------------------------------------
                    - 0 fatal error(s), 0 error(s), 4 warning(s)
                    WARNING: Payload:{1F32F9AB-8B7F-4926-9B58-04DDC0FD2559} Camera Profiles Installer_6.6_AdobeCameraRawProfile6.0All has newer update. The patch will be uninstalled now.
                    WARNING: Payload:{2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All has newer update. The patch will be uninstalled now.
                    Search the same string above to find when the error occured.
                    Exit Code: 0 - No error
                    END - Installer Session
                    OSX version: 10.6.8
                    CHECK : Credentials
                    Sync Media DB ...
                    :: END TIMER :: [Sync Media DB] took 149 miliseconds (0.149 seconds) DTR = 805.369 KBPS (0.786493 MBPS)
                    Updated source path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.5.067
                    Updating media info for: {1A726E43-1269-42D5-9915-54FF4BC5F3D1}
                      Type: 0, Volume Order: 1, Media Name: AdobeCameraRaw-6.5-mul-AdobeUpdate
                      Path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.5.067/payloads/Ado beCameraRawProfile6.0All-160911135008/AdobeCameraRawProfile6.0All-160911135008.dmg
                    Updating media info for: {45957BDB-6D3A-45A9-821A-488D388A1943}
                      Path: /Users/Rich27/Library/Caches/Adobe/AAMUpdater/PhotoshopCameraRaw-6.0/6.5.067/payloads/Ado beCameraRaw6.0All-160911134919/AdobeCameraRaw6.0All-160911134919.dmg
                    Value returned on lookup of payload: {1A726E43-1269-42D5-9915-54FF4BC5F3D1} Camera Profiles Installer_6.5_AdobeCameraRawProfile6.0All is: true
                    Action string for  {1A726E43-1269-42D5-9915-54FF4BC5F3D1} Camera Profiles Installer_6.5_AdobeCameraRawProfile6.0All  is install
                    Selection of payload {1A726E43-1269-42D5-9915-54FF4BC5F3D1} Camera Profiles Installer_6.5_AdobeCameraRawProfile6.0All is forbidden by the policy.
                    [       0] Wed Jun 27 19:18:16 2012  WARN
                    Error setting action for {1A726E43-1269-42D5-9915-54FF4BC5F3D1} Camera Profiles Installer_6.5_AdobeCameraRawProfile6.0All:
                    [       0] Wed Jun 27 19:18:16 2012  INFO
                    Value returned on lookup of payload: {45957BDB-6D3A-45A9-821A-488D388A1943} Photoshop Camera Raw_6.5_AdobeCameraRaw6.0All is: true
                    Action string for  {45957BDB-6D3A-45A9-821A-488D388A1943} Photoshop Camera Raw_6.5_AdobeCameraRaw6.0All  is install
                    Error setting action for {45957BDB-6D3A-45A9-821A-488D388A1943} Photoshop Camera Raw_6.5_AdobeCameraRaw6.0All:
                    Some payload actions specified in the deployment file could not be applied.
                    [       0] Wed Jun 27 19:18:16 2012 ERROR
                    Payload actions could not be set. Search the log for "BEGIN Setting requested payload actions" for details.
                    :: END TIMER :: [Total Timer] took 740 miliseconds (0.74 seconds) DTR = 702.703 KBPS (0.686233 MBPS)
                    - 0 fatal error(s), 1 error(s), 3 warning(s)
                    WARNING: Error setting action for {1A726E43-1269-42D5-9915-54FF4BC5F3D1} Camera Profiles Installer_6.5_AdobeCameraRawProfile6.0All:
                    WARNING: Error setting action for {45957BDB-6D3A-45A9-821A-488D388A1943} Photoshop Camera Raw_6.5_AdobeCameraRaw6.0All:
                    WARNING: Some payload actions specified in the deployment file could not be applied.
                    ERROR: Payload actions could not be set. Search the log for "BEGIN Setting requested payload actions" for details.
                    Exit Code: 7 - Unable to complete Silent workflow
                    OSX version: 10.6.8
                    CHECK : Credentials
                    Sync Media DB ...
                    :: END TIMER :: [Sync Media DB] took 22 miliseconds (0.022 seconds) DTR = 181.818 KBPS (0.177557 MBPS)
                    [       0] Wed Jun 27 19:21:51 2012  WARN
                    [       0] Wed Jun 27 19:21:51 2012  INFO
                    [       0] Wed Jun 27 19:21:51 2012 ERROR
                    :: END TIMER :: [Total Timer] took 397 miliseconds (0.397 seconds) DTR = 20.1511 KBPS (0.0196788 MBPS)
