15 Replies Latest reply on Jul 5, 2012 12:47 PM by itisdesign
    why is cfreturn null?
    ion Level 1
      i proxied a call to a cfc which does an ftp get to a local temp file. Then it reads the file and is  supposed to return the file content as a cfreturn string. i know the code works, when i pull it out of cfc into a regular cfm file it does exactly what is expected
      however, in my proxy callBackHandler, the cfc return is null.
      <cfajaxproxy cfc="ftpfunc" jsclassname="jsobj" />
      function getFTP() {
      var instance = new jsobj();
      instance.setCallbackHandler(ftpSuccess);
      instance.setErrorHandler(ftpError);
      instance.setReturnFormat('plain');
      instance.getJCL(lpar,remoteFile,userName,password);
      function ftpSuccess(ftpReturn)
          if (ftpReturn.length==0)
      // error thrown right here: "ftpReturn is Null"
                  alert("Your FTP Get returned a blank file");
        • 1. Re: why is cfreturn null?
          BKBK Adobe Community Professional & MVP
          function getFTP() {
          Shouldn't lpar ,remoteFile, userName, password also be arguments of getFTP?
          • 2. Re: why is cfreturn null?
            ion Level 1
            they are, i didn't include the first part of the func, which gets those values from some form fields.
            that part works, i know that because if i comment out the line  instance.setCallbackHandler(ftpSuccess) i can see in fireBug, under the http\Response tab the actual file content, which is "test"
            that's why i don't get the "null" error, looks like there is some particular syntax that must be used in order to handle the return inside the proxy
            • 3. Re: why is cfreturn null?
              The intention seems to have been
                if (ftpReturn.length != 0) alert ('OK');
              Or, to cover both eventualities,
              if(ftpReturn.length==0)
                   alert("FTP Get returned blank file");
              else
                   alert("FTP Get returned non-blank file");
              Edited by BKBK
              • 4. Re: why is cfreturn null?
                ion Level 1
                thanks, but actually no, the intention is to dispaly the file content as the innerHTML of a div, obviously not possible since the function gets a null, which means, it doesn't even get the cfreturn (blank or no blank, it just doesn't get anything)
                • 5. Re: why is cfreturn null?
                  ion Level 1
                  just to make sure everything else is ok, i've added a cfinvoke statement on my page, invoking the same function and passing the same parameters. it behaves exactly as expected, the return string from cfc gets displayed on the page using a cfoutput. it's strictly a proxy thing, the way that callbackhandler is supposed to work
                  • 6. Re: why is cfreturn null?
                    Your post has until now made it seem otherwise. You made it seem, to me at least, that the problem is that you were failing to get the alert! So, let me ask. Does the alert appear as expected?
                    • 7. Re: why is cfreturn null?
                      Did you do something like this?
                      <script>
                          document.getElementById('result').innerHTML = ftpReturn;
                      </script>
                      <!--- Within body of page --->
                      <div id="result"></div>
                      If so, what was the result?
                      • 8. Re: why is cfreturn null?
                        ion Level 1
                        sorry if i confused things. the callBackHandler function never gets to the alert (or setting the innerHTML) because it throws the null object error on the if(ftpReturn.length==0)  condition, which means it doesn't even see the cfreturn object coming from the cfc.
                        if i remove the conditional and simply try to set the innerHTML, i get a http array with 2 elements:
                        0  null
                        1  undefined (and of course is not setting the innerHTML)
                        thanks
                        • 9. Re: why is cfreturn null?
                          itisdesign Most Valuable Participant
                          0  null
                          Hi ion,
                          I'm confused.  Could you please run the following app, and let us know the JS alert message?
                          Application.cfc
                          component {THIS.name = "TestCFAjaxproxyCFC";}
                          text.txt
                          my text
                          MyCFC.cfc
                          component {remote string function myCFCFunction() {return fileRead(expandPath("./text.txt"));}}
                          index.cfm
                          <cfajaxproxy cfc="MyCFC" jsclassname="myCFCJSObj" />
                            function myCallbackHandler(result) {
                                alert(result.length);
                            function myErrorHandler(statusCode, statusMsg) {
                                alert('Status: ' + statusCode + ', ' + statusMsg);
                            function myJSFunction() {
                                var instance = new myCFCJSObj();
                                instance.setCallbackHandler(myCallbackHandler);
                                instance.setErrorHandler(myErrorHandler);
                                instance.myCFCFunction();
                            myJSFunction();
                          </script>
                          -Aaron
                          • 10. Re: why is cfreturn null?
                            The lights flickered when I read this again. I was reminded of a recommendation I had seen somewhere to use the following function syntax instead:
                            var getFTP = function() {}
                            var ftpSuccess = function(ftpReturn) {}
                            Could that be the solution?
                            • 11. Re: why is cfreturn null?
                              ion Level 1
                              it works Aaron, alert returns the correct result.length, 7
                              is this my problem, the syntax used inside the cfc?
                              thanks a lot
                              • 12. Re: why is cfreturn null?
                                ion Level 1
                                i think i understand what happens, but i'm not really happy about it. The reason it works is you call the function right after you declare it. I guess this is kind of a substitute for the ajaxonload function. My problem is, i don't want the function to execute onLoad, because it needs some user selected values from the form, to pass as parameters to the cfc
                                if i do the same thing (call the function after declaring it), i get another "Null" error, this time about the form fields that haven't been set by user yet. after that, the function will work
                                can i prevent it from executing onLoad?
                                thanks again
                                • 13. Re: why is cfreturn null?
                                  Hi ion,
                                  You're welcome, and yes.  Can you please try this:
                                  Application.cfc
                                  text.txt
                                  my text
                                  MyCFC.cfc
                                  component {remote string function myCFCFunction(required string myArg) {return fileRead(expandPath("./text.txt")) & '-' & ARGUMENTS.myArg;}}
                                  index.cfm
                                        alert(result);
                                        instance.myCFCFunction(document.getElementById("myfield").value);
                                    //myJSFunction();
                                  </script>
                                  <cfform>
                                    <cfinput type="text" name="myfield" value="foobar" />
                                    <cfinput type="button" name="mybutton" value="submit" onclick="javascript:myJSFunction()" />
                                  </cfform>
                                  Clicking 'submit' should alert "my text-foobar".
                                  -Aaron
                                  • 14. Re: why is cfreturn null?
                                    ion Level 1
                                    many thanks Aaron, works fine. although now i'm a little confused: i've kind of ended up with the same code i started with, didn't figure out yet what i was doing wrong
                                    the only thing i've added is an error trap in the js function, like:
                                    if (lpar != '' && remoteFile != '' && userName != '' && password != '')
                                         ... set the proxy ...
                                    } else { alert("Missing fields!"); }
                                    and another one in the cfc, if the file returned is, for some reason, blank. If that happens, then the "null" message is actually correct:
                                    <cfset ftpReturn = fileRead(tempFile)>
                                    <cfif trim(ftpReturn) eq ''>
                                        <cfset ftpReturn="FTP get operation returned a Blank file">
                                    </cfif>
                                    thanks again everybody for your help, best regards
                                    ion
                                    • 15. Re: why is cfreturn null?
                                      Very cool, glad it's working now!
