4 Replies Latest reply on Jun 29, 2012 1:32 PM by Silly-V
    How do I Select all the items in a document based on SpotColor?
    alexthebake Level 1
      I'm trying to select every object with the color "CutContour"
      So far I've been trying:
      myDoc.selection = myDoc.spots.getByName("CutContour");
      I guess this obviouslly wouldn't work though because myDoc.selection is looking for an array of objects.
      However, I can't figure out how to loop through all the objects in the document and check to see if they contain the SpotColor.
      Any help would be incredibly appreciated!
      EDIT:
      I want to use the Select > Same > Stroke Color , but I heard that using that in Javascript isn't available unless you have CS6 (which I currently don't). Is it true that accessing menu items through scripting is a feature in CS6?
        • 1. Re: How do I Select all the items in a document based on SpotColor?
          Muppet Mark Level 5
          Yes you can't do this as straight forward as you hoped… In script probably the same as is done in those app/plug-in's you will need to loop through all the art items and test each in turn… Depending upon your art in question this can become a very complex routine… Why are you trying to select this stuff?
          doc.selection = [ wants an array of objects ]
          myDoc.spots.getByName("CutContour") is only going to find an object reference to a spot swatch in the document swatches panel if it exists…
          You can't put these together like you have done…
          To your edit Yes its a new thing with CS6… I don't have this either… boo
          • 2. Re: How do I Select all the items in a document based on SpotColor?
            alexthebake Level 1
            Thanks for clearing some of that up for me!
            I only need to select path items, and I see that if I do something along the lines of:
            var objects = myDoc.pageItems;
            I can get an array of all the items in my document. However, I'm trying to figure out where to go from here, but the process seems overly complex. I want to loop through objects and see if they are pathitems, and then check to see if they have the color I'm looking for, but I can't find the strokeColor property in the Javascript reference. Also, what about compoundPathItems (closed paths)? If I check for PathItems, will I also get CompoundPathItems?
            EDIT:
            This is what I have so far, however, it is not working correctly /:
            var myColor = myDoc.spots.getByName("CutContour");
            var arrObj = [];
            for (var i = 0; i <objects.length; i++) {
              if (objects[i].typename == "PathItem" && objects[i].fillColor == myColor) {
                arrObj.push(objects[i]);
                objects[i].move(layer_Cut, ElementPlacement.PLACEATBEGINNING);
            See, the whole goal is to move all objects with the color "CutContour" to
            • 3. Re: How do I Select all the items in a document based on SpotColor?
              Muppet Mark Level 5
              pageItems is a super class like swatches It covers a few common/shared properties but under each are sub-classes that contain more specific properties…
              getting pageItems will return an array but it could be mix of [ pathItem, textItem, groupItem etc. ]
              getting swatches could return [ spot, rgb, cmyk, gradient etc. ]
              If you are wanting to access only pathItems then access that collection at what ever object level you want to deal with… e.g.
              var a = doc.pathItems;
              You can check the collections length property and create a loop…
              For each item you can test the pathItem for it's .fillcolor & .strokecolor properties
              • 4. Re: How do I Select all the items in a document based on SpotColor?
                Silly-V Adobe Community Professional
                Wow you use the CutCountour for Roland printer?  is it 100% cyan?
                Ok I had a similar need and I figured out:
                if(objects[i].fillColor.typename == "SpotColor"){
                     if(objects[i].fillColor.spot.name =="CutContour"){
                          //process the objects[i]
