This content has been marked as final.
Show 4 replies
1. Re: CFSELECT with 1000 options?? Ajax??
Dan Bracuk Feb 12, 2008 12:16 PM (in response to yoman)use a series of checkboxes for the dates. that will get you started. -
2. Re: CFSELECT with 1000 options?? Ajax??
yoman Feb 12, 2008 12:30 PM (in response to Dan Bracuk)I probably didn't make myself clear. The problem isn't the date. The problem is that every date would include a cfselect box with 1000 options, one for each band. The code would look like below.
3. Re: CFSELECT with 1000 options?? Ajax??
Newsgroup_User Feb 12, 2008 1:09 PM (in response to Dan Bracuk)Have either an A-Z series of links (followed by fine-tuning from thee) or a
search.
I recommend you investigate how popular directories (eg: Yahoo!) do it, and
emulate that sort of thing, unless you can come up with anything better.
Hint: big companies spend big bucks on UI design, so they will probably do
it better than the likes of you or I could come up with.
One concept could be - as you touch on - emulating a combo box idea using
an input, and some sort of multiple select / div sort of arrangement, and
having an AJAX call back to populate the multi-select thing with
appropriate filtered data as the user types. Google does it.
There's quite possible already a CF-friendly solution out there (maybe even
with CFFORM controls? Never use CFFORM meself).
Adam -
4. Re: CFSELECT with 1000 options?? Ajax??
Steve Sommers Feb 13, 2008 8:41 AM (in response to yoman)I would rethink how you're presenting the information to the user, much like what Adam said. Research similar sites. Having a select box, or multiple boxes with thousands of options each would be very cumbersome and virtually useless to the average web surfer.
