10 Replies Latest reply on Jul 3, 2012 3:34 AM by Velprakash
    how to find the tables only placed on pages.
    Velprakash Level 1
      Hi experts,
            I'm finding all the tables in the .indd document (Non XML Indd file.) In that there are some number of tables. And a table in Master page also there. Now I'm trying to get only the tables except the master page. How can I got it?
      I used the following code. But it's not working properly.
      var myTables=app.activeDocument.stories.everyItem().tables;
      app.select(myTables[0]);
      var myTableCount=myTables.length;
      alert(myTableCount);
      for(var i=0;i<myTableCount;i++){
      var myTableObj=myTables[i];
      alert(myTableObj.parent);
      try
      var xxx = myTableObj.parent.parentPage.name;
      if(xxx.match("^[0-9]+$"))
           alert("Table");
          myTableObj.label="table"+(i+1);
      else
         alert("Master-Page Table");
      catch(e)
          alert(e.message);
      Always throwing catch loop...
      Can anyone guide me.................................!
      Thanks and Regards,
      Vel.
        • 1. Re: how to find the tables only placed on pages.
          Peter Kahrel Adobe Community Professional & MVP
          The parent of a document page is a Spread, that of a master page is a MasterSpread. Therefore:
          if (myTable.storyOffset.parentTextFrames[0].parentPage.parent.constructor.name != 'MasterSpread')
               $.writeln ('Not on a master page);
          else
               $.alert ('On a master page');
          This is in CS5 and later. Earlier versions don't have the parentPage property, andthe parenthood of pages is a bit different in those earlier versions.
          Peter
          • 2. Re: how to find the tables only placed on pages.
            Velprakash Level 1
            Hi Peter,
                   Thank you for your reply........... I used the above codes. But It throws an error, "Undefined is not an Object" in the line,
            if (myTables[i].storyOffset.parentTextFrames[0].parentPage.parent.constructo r.name != 'MasterSpread')
            I've table in master page also. But what I've to do is, I've to find all other tables in document pages, except Master page & assign Label...
            I used the below codes.
            var myTables=myDocument.stories.everyItem().tables;
                if (myTables[i].storyOffset.parentTextFrames[0].parentPage.parent.constructor.name != 'MasterSpread')
                    alert("Master Page");
            var myTableObj=myTables.item(i);
            I'm struggling in this issue for a long time. Can u help!!!
            With thanks and Regards,
            Vel.
            • 3. Re: how to find the tables only placed on pages.
              There's a space in constr uctor (which I managed to put there, sorry). That's probably the problem.
              Peter
              • 4. Re: how to find the tables only placed on pages.
                Velprakash Level 1
                ya, I noticed it earlier while pasting your codes in my script. But it's showing error...
                If i select manually the table in master page, I run only your codes, it works fine. But If i used it on my codes, error occurs.
                I think there is a error in getting the tables...
                If I used alert(myTables[0]); it shows [Object Table]. But if I tried to select it with, app.select(myTables[0]); then it shows error, Expected selectable items, but received (Table, Table). Even i mentioned only myTables[0] Index"0".
                Once again Thanks a lot for ur reply Peter....
                With Regards,
                Vel.
                • 5. Re: how to find the tables only placed on pages.
                  Velprakash Level 1
                  Hi Peter,
                          At last, I complete it by the below codes. It make me to struggle a lot.....................
                  var pagelen = app.activeDocument.pages.length;
                  alert(pagelen);
                  for(var i=0;i<pagelen;i++)
                      var pageitemlen = app.activeDocument.pages[i].pageItems.length;
                      for(var j=0;j<pageitemlen;j++)
                          var v = app.activeDocument.pages[i].pageItems[j].tables;
                          //alert(v.length);
                          for(var x=0;x<v.length;x++)
                              app.select(v[x]);                                                      //here, I can select it.
                              app.selection[0].label = "table"+count;
                              count++;
                              myTables.push(v[i]);
                  Peter, I thank u a lot for spending ur Golden time for my issue.......
                  With Regards,
                  Vel.
                  • 6. Re: how to find the tables only placed on pages.
                    There's no need to select anything. Instead of this:
                    app.select(v[x]);
                    do this:
                    v[x].label = "table"+count;
                    Peter
                    • 7. Re: how to find the tables only placed on pages.
                      Velprakash Level 1
                      S......... You're right peter... Thanks.
                      Thanks andRegards,
                      Vel.
                      • 8. Re: how to find the tables only placed on pages.
                        Velprakash Level 1
                        Hi Peter,
                             Can u tell me the code to get the parent page in cs4? In cs5 the below code works fine. but throws error in cs4.
                        app.activeWindow.activePage = app.selection[0].parentTextFrames[0].parentPage;
                        Is the following is right?
                        app.activeWindow.activePage = app.selection[0].parentTextFrames[0].parent;
                        Thanks and regards,
                        Vel.
                        • 9. Re: how to find the tables only placed on pages.
                          Google is your friend: http://forums.adobe.com/thread/615381
                          Dave Saunders's function there works in all versions of InDesign (from CS3 anyway).
                          Peter
                          • 10. Re: how to find the tables only placed on pages.
                            Velprakash Level 1
                            Yes... I got it... Thanks a lot peter.....................
                            Vel.
