1 2 Previous Next 50 Replies Latest reply on Aug 2, 2013 2:11 PM by GraphiteGal636
    Audio Out of Sync - Why and How to Correct
    martinv2012
      I nested two 90 minute clips from 2 separate cameras which were both shot in AVCHD. I am using Premiere CS 5.5 . As a former FCP editor, whenever audio went out of sync, a message in FCP came up immediately and told you the audio was out of sync and it was an easy fix. How come Premiere is minus such an important feature?
      I shoot stage productions where there may be music but no dialogue so chercking sync becomes rather difficult. After finishing a 2 hour video, I found the audio was out of sync in the nested sequences. Is there any way to auto resync the audio automatically?
      Seems to me that Premiere Pro is a sub Pro App if simple audio sync is so hard to maintain in nested sequences. Makes nesting a sequence a waste of time if you have to redo the edit as a reslut of audio out of sync.
        • 1. Re: Audio Out of Sync - Why and How to Correct
          martinv2012 Level 1
          Let me add this, if audio can be moved out of sync in Premiere Pro so easily without any notification, warning and abillity to move it back into sync easily as soon as it happen or provide a quick fix after the video has been editied using the original video clip to match the timecode for both video and audio in the nested Sequence  then Premiere Pro should be a free app. An app that can be freely shared, as it is not  professional editing software no matter how many other things it can do. Audio sync is at the very basics of video editing and Premiere Pro functions as though this is about as important as whether you used an upper case or lower case letter in part of a title. The whole point to editing is video and audio. If I wanted silent video then no problem. But that want out back in the 1920's. I think Adobe misleads the consumer.
          • 2. Re: Audio Out of Sync - Why and How to Correct
            martinv2012 Level 1
            If there is no response to this, then I will assume this is an Adobe "dirty little secret". A problem everyone runs into but Adobe is silent  about.
            • 3. Re: Audio Out of Sync - Why and How to Correct
              I edit AVCHD and do not have that problem
              Do be aware (in case you are not... ignore if you are) that the "approved" way to get AVCHD from camera to hard drive is to copy the entire folder, not just the files
              Read http://forums.adobe.com/thread/1015001?tstart=0 for more information
              • 4. Re: Audio Out of Sync - Why and How to Correct
                martinv2012 Level 1
                Thanks John, but I know that you have to copy the entire file folders out not the individual AVCHD files. I read up on editng AVCHD files before tackling Premiere. So whether I copy the files from my Panasonic AC130 or my Canon cam, the entire folder system gets copied not files. So far, unless someone can specify the fix or how to resync audio in a nested sequence, I have gone back to editng the FCP way. Sync the two cams based on video (can't use audio in Premiere as the audio channel graphic waveform is not as well defined as in FCP - another Adobe minus) in the timeline and then reduce the opacity of Video track 2 to 45% and then use the Razor Tool to cut the clips you need. Of course the audio channels shouuld be locked to avoid cutting the audio up as well.
                You know John, maybe after I finish editing my projects, I should compile all my work arounds and list the Premiere problems and how to deal with them. Good thing you Adobe guys have us FCP editors here not to clean up the Adobe mess. Imagine how worse things would have gotten here in Premiere Amateur Editing software if the Apple people didn't chase the money and dump FCP for better iPhones and iPads, etc to boost revenue.
                • 5. Re: Audio Out of Sync - Why and How to Correct
                  >you Adobe guys
                  Not me... I'm just another user trying to help on this user to user forum... Adobe employees are identified with either Employee or Staff next to their name... where you and I have the word Member
                  • 6. Re: Audio Out of Sync - Why and How to Correct
                    martinv2012 Level 1
                    Thanks John. All I meant was that the Adobe users are lucky to have FCP editors here to help out. Since I can compare both apps, Adobe is going to have to do a hard sell to convince me they have a better project. Maybe I should edit AVCHD in Premiere and then encode to mpeg2 and import back to DVD Studio Pro.
                    • 7. Re: Audio Out of Sync - Why and How to Correct
                      shooternz Level 6
                      Well Adobe does have the better "project" ( product) bcause your beloved FCP is no longer a  product.
                      Nothing stopping you continuing to use your original FCP7 though!
                      As regards your issue (and assumeably you are on a Mac)...why not see if other Mac users confirm "Adobes dirty little secret" before you go on the "fcp is perfect why cant PPRO also be so" rant.
                      In the interest of more information...what have you done about trouble shooting this your self?
                      Have you tried a sequence without nesting anything?
                      Is it OOS in the sequence and the export?
                      BTW: Generally an OOS indicator comes up when you unlink audio / video.
                      In your edit are you using the linked audio or an external recorded piece?  (You mabe experiencing device drift)
                      For the record - on a PC with AVCHD...I do not experience your issue.
                      • 8. Re: Audio Out of Sync - Why and How to Correct
                        martinv2012 Level 1
                        Well I am on Win 7 64 bit. Apple will probably trash their Workstations soon as well. So the audio was from the AVCHD file same as the video. Very simple setup. I placed my cam #1 file with video and audio on the timeline then found a sync point - photo flash frame from camera one and matched it to cam #2. Placed cam # 2 video and audio on Video 2 and Audio 2.  Then selected the video 1 and 2 and nested them. Used Multicam Monitor. First 1/3 of edit was fine. After that the video was out of sync.
                        Seems pretty straight forward. Would have been even more so if Premiere warned me that a specific action put the audio out of sync. Then gave me a way to resync the nested files. Didn't find the sync issue out until I played the DVD back after authoring in Encore. I do have a quick fix for resetting Encore files that I used in DVD Studio Pro and works in Encore as well.
                        The purpose of video editng is to edit a video and get paid for the work, not trouble shoot the software. If I wanted to do that I would have gotten a degree in software engineering. If I have to trouble shoot the software then some software engineer goofed and created a bug or an issue that interferes with video editing. Listen
                        • 9. Re: Audio Out of Sync - Why and How to Correct
                          shooternz Level 6
                          Prior to working in Multicam mode did you check to see if the audio video was in synch?
                          • 10. Re: Audio Out of Sync - Why and How to Correct
                            martinv2012 Level 1
                            The audio and video was in sync, that is why the first 1/3 of the edit was fine. It was nesting that caused the sync issue.
                            Listen shooternz, I expect video editing software to work correctly 100% of the time. I am not a software engineer and should not have to trouble shoot the app. If you bought a TV set would you expect it to work 100% of the time? You wouldn't try to open the set and fix it. I paid for video editing software and I expect it to work correctly 100% of the time.
                            • 11. Re: Audio Out of Sync - Why and How to Correct
                              shooternz Level 6
                              Ignoring your condescending "listen shooternz"  and the lecturing analogy...but trying to help you at the same time.
                              Somehow you have established that it goes out of synch in the nest
                              You did not say if the original time lines  were fine past 1/3 before you nested them. (ie did you check near the end)
                              How have you eliminated Multicam (and maybe the way you use it) from the OOS issue?
                              If you create and then playback  either edit as a nest ( before multicam) ..do both streams maintain synch?
                              • 12. Re: Audio Out of Sync - Why and How to Correct
                                martinv2012 Level 1
                                Sorry not trying to annoy you shooternz, Yes the original timeline is fine up to about 1/3 into the video. Somehow after that point the audio is out of sync. Now I have redited from the nested sequence that was in sync on using the following method. I lay in cam #1 (video & audio) into video 1 in the Sequence. Then I find a sync point in cam #2 and reference it to the same point in cam #1. I then place cam #2 in video and audio track 2. I lower the opacity in video 2 to 48% and proceed to edit using the razor tool and placing video from cam#2 onto video 1 in the sequence. Audio channels are locked so they don't get cut up. Everything is in sync. So yes to your laast question.
                                BTW why would the OS (WIN 7) have issues with Multicam? If Adobe  products have issues with the OS then they shouldn't be selling them and advertising them as Pro apps.
                                My complaint is that Premiere does not have a safe guard to alert you when audio goes out of sync. I wasted a few hours editing to recoup the out of sync video.
                                • 13. Re: Audio Out of Sync - Why and How to Correct
                                  Jim_Simon Level 8
                                  Actually, it does.  You'll see a +/- time indicator on both the audio and video portion of clips that are out of sync.
                                  • 14. Re: Audio Out of Sync - Why and How to Correct
                                    shooternz Level 6
                                    So you are actually saying that original edit sequence goes out of synch after 1/3.
                                    (ie. 1 camera with continuous single stream of  video/ audio is OOS. after 1/3 progress and assumeably the other camera is doing exactly the same thing)
                                    That means the multicam nest will be out as well.
                                    What camera, what codec, what project setings?
                                    • 15. Re: Audio Out of Sync - Why and How to Correct
                                      martinv2012 Level 1
                                      Cam 1 Panasonic Ag Ac130 Cam 2 Canon XA10 both shot in AVCHD max settings ,Sequence settings 1080i/30
                                      • 16. Re: Audio Out of Sync - Why and How to Correct
                                        shooternz Level 6
                                        1080i  ...not a progressive project setting? Did you match the project to the source footage?  (How?)
                                        Have you actually confirmed (to us forum readers) that the original sequence from either or both cameras is in synch all the way thru?
                                        Was it a continuous camera roll on each camera or have you edited it from stop start source footage?
                                        • 17. Re: Audio Out of Sync - Why and How to Correct
                                          martinv2012 Level 1
                                          Jim I checked the Sequence Timeline and there is no +/- indicating the audio is out of sync. Yet it is out of sync - I checked it against the original footage from the cams. Where there is a speech you can definitly tell it is out of sync. In FCP this is a no brainer but not as clear cut in Adobe.
                                          • 18. Re: Audio Out of Sync - Why and How to Correct
                                            martinv2012 Level 1
                                            Yes shooternz, I went back and checked the original footage from both cams and played back in the source Monitor they are in sync. Where there is a speech at the end of the video the lips are in sync.The Sequence settings was taken from the footage, I did not specify the seetings but let Premiere set it up based on the Properties of the cam footage files.
                                            The footage for both cams was continuous roll for 2 hours without a stop.
                                            • 19. Re: Audio Out of Sync - Why and How to Correct
                                              martinv2012 Level 1
                                              One more thing shooternz and the rest of this forum's viewers. If Adobe or any company puts a product out their for sale, it should work as advertised. Car manufacturers do not get a free ride if one of their vehicle models has an inherrent problem that causes accidents such as the exploding Ford Pinto or more recently the gas peddle problem with Toyota cars. As far as I am concerned if Adobe or Apple puts a product on the market (especially if it is advertised as a Pro App), then we the consumers should have zero tolerance for errors, bugs or problems. Our jobs are to edit not trouble shoot the product. I can see if the user is not familiar with the product but as some one in the Encore forum told me ,"Encore is a buggy App". Well Adobe FIX THE PROBLEM. How about every time a certified bug is found in the program, Adobe refunds every user $10 (and that is being conservative). If one of my videos has a problem because of a bug in the program I stand to lose more then $10.
                                              How about it Adobe Techs - can anyone deduce why nested audio goes out of sync without warning?
                                              • 20. Re: Audio Out of Sync - Why and How to Correct
                                                shooternz Level 6
                                                Its always interesting when some one has an issue and others dont chime in and say ....."me too"., "me too"...me as well"
                                                Maybe they will do this yet... but mean time you are on your own.  (hmmmm)
                                                Your rants arent helping anyone trouble shoot this with you.
                                                Now...it is possible that you have run into a spanned clips known issue due to the long recording time.  I am not sure where that is at the moment.  Do a search.
                                                How much OOS is the footage at the end of each camera anyway?
                                                Tell us what happens if you swap  the audio from one camera to the other in the timeline?  Try to establish consistency in the recording against the video.
                                                • 21. Re: Audio Out of Sync - Why and How to Correct
                                                  Jim_Simon Level 8
                                                  Well...they never have for me.  Your situation is certainly not the norm.
                                                  • 22. Re: Audio Out of Sync - Why and How to Correct
                                                    martinv2012 Level 1
                                                    That may be but what puzzles me Jim, is that Premiere did not give me a warning and the ability to correct the misaligned audio with the nested sequence. In FCP not only is there a red flag but it tells you how many frames or seconds you are misaligned by. A right click on either the video or audio gives you the option to slip them into alignment. There doesn't appear to be any comparable ability in Premiere. There are a few things Premiere does have that surpasses FCP, especially in the titling, but this sync issue is a major one.
                                                    I did not nest the audio tracks when I nested the video since I wasn't sure which audio track I preferred i.e. Cam #1 or Cam #2. Would that have made a difference? Is there any way to have a default transition applied in a nested sequence so that one can cross fade from one clip to another? In FCP you can right click on a cut and apply a default cross fade for either video or audio.
                                                    Although some of my posts may seem to be bashing Adobe, I believe that products should work as advertised. It is one thing to ask for info if one is unfamiliar with an app, it is another for an app to lack key editing features or contain a bug in the programming.
                                                    • 23. Re: Audio Out of Sync - Why and How to Correct
                                                      SimonHy Level 2
                                                      I edited with FCP for many years, and thought it was a great piece of software, but the idea that it was 100% bug free is utterly ridiculous!
                                                      When you say that the audio doesn't show as being out of sync, are you looking at the nested sequence in your cut timeline, or WITHIN the nested sequence? Because if you move something within the nest you have to look inside it to see it, the nest itself won't show whether audio is in or out of sync.
                                                      • 24. Re: Audio Out of Sync - Why and How to Correct
                                                        shooternz Level 6
                                                        I am more and more convinced that unfamiliarity with PPRO (understandeable as a new user)  and general editing experience is playing a part in  your issue.
                                                        This here below  makes no sense and remains unanswered no matter what I ask...or suggest!
                                                        Example
                                                        • 25. Re: Audio Out of Sync - Why and How to Correct
                                                          Jim_Simon Level 8
                                                          That's because what you're seeing is not normal program operation.  It's a glitch in your system, or with your media, or with your sequence, or with your project.
                                                          When things go out of sync in a normal fashion, PP does give you the indicator
                                                          • 26. Re: Audio Out of Sync - Why and How to Correct
                                                            martinv2012 Level 1
                                                            I'll let you know if I see it. Right now I am editng the FCP way. Using Razor tool I cut my in point and out point on the Video 1 & 2 layers and audio layers then select those segments hit delete then ripple delete. This way I am assured the audio is in sync and not subject to the quirks of the Nesting option.
                                                            • 27. Re: Audio Out of Sync - Why and How to Correct
                                                              josephs51576386 Level 3
                                                              I edit multicam constantly in Premiere using AVCHD files and haven't ever experinced the issue you desribe. Very Interesting
                                                              • 28. Re: Audio Out of Sync - Why and How to Correct
        jabra27 Level 1
        After reading this entire post, I still don't see the answer from martinv2012 about the original sequence.
        Is the original sequence in sync all the way through? Meaning, if you go to the last 10 seconds of the original sequence, is the audio in sync or out.
        If you are here to ask for help on an issue, please give the information asked for.
        Also, (this is really starting to bug me) stop comparing PPro to FCP! Premier is not perfect, I can admit that since I've been using it for the last 6 years. However, I can also say that Final Cut Pro is not perfect either, since I used it for 4 years.
        If you think FCP was/is the superior product, why are you here? Go back to what you like. Otherwise, ask your questions to find the answers to what you don't understand, and realize that Premier Pro is NOT FCP and accept the differences.
        • 29. Re: Audio Out of Sync - Why and How to Correct
        fsuarez
        I've had issues with nested comps before.
        Im not sure if this is a bug in PPRO or not, but I have had this problem occur on and off.  After some troubleshooting, I found a workaround that worked for me in my specific situation.
        It seems when you NEST audio files not linked to video files (it may happen even if they are linked, but I have not tried it), PPRO will replace your clips with the nested composition but will offset the time.  Let me give you an example to illustrate.
        Say I have have audio clips that start at 10 seconds into my sequence and I nest them.  PPRO will nest them and show me the nested comp starting at 10 seconds, but it will really not play there, it starts to play exactly 10 seconds later.  Solution? Drag my nested composition back to 0 in the timeline.  Again this worked for me and it may be a work around.
        If Im doing something incorrectly, please someone point it out.
        Thanks.
        • 30. Re: Audio Out of Sync - Why and How to Correct
        martinv2012 Level 1
        Hi Frank,
        I saw your post just as I was checking a DVD I edited 5 months ago. I used the Nest tool in PPro and good thing I checked the DVD before duplication as half way through the video, the audio was out of sync. This was another example of what I originally posted.  There should not be, I REPEAT FOR THE ADOBE STAFF, "SHOULD NOT BE" THE NEED FOR WORK AROUNDS, PERIOD.
        Those who comment " well it could be your system, your set up, etc" STOP DEFENDING A FLAW IN THE SOFTWARE. Would you buy a car that catches on fire when you start it up? I think not. The reason FCP became the leading software for 80% of the editing houses out there was its consistency and smooth workflow. If Adobe wants the same market share, they should examine the problem determine the causes and then inform the user as to work arounds and updates and fixes for this problem. It is not the job of the customer to fix the product. Jason, I appreciate your comments. Apple sank FCP because they make more $$$ from iPhones and iPads.
        Fixing the software is not our job. Editing is our job. This forum should be for an exchange of ideas and help from other users. BUT, when an issue arises and is confirmed by other users, the Adobe staff should jump on it within a week at the most. We should not be referred to their library of instructions on how to use PPro as a solution.
        I like PPro for the most part. If some one had referred me to an exact cause of the audio problem and I was able to see it and correct my timeline, then no problem.
        BTW Jason the audio goes out of sync about half way through the Timeline in the affected projects. Also, Simon, I realized that if I adjusted a nested part of the timeline the audio would go out of sync. My process was to sync up two cameras (2 layers of video and audio) then followed the Adobe Help instructions to nest them. Once done. I simply cut back and forth between shots in the Nested Sequence Window. Nothing else was done to the Timeline or the Nested components.
        Shooternz, guess some one else chimed in.
        • 31. Re: Audio Out of Sync - Why and How to Correct
        ahernpaul Level 1
        Hey Martin,
        I totally agree with you that the software should just work, independent of someone's system!  I just started a small corporate documentary project and found your post while trying to figure out how to solve this mysterious sync problem.  I don't have any nested sequences; just multiple clips of talking heads, some of which have literally randomly out-of-sync audio/video.
        Finding no solution in the software for troubleshooting this problem, I have resorted to manually un-linking the audio and video of clips, manually sync-ing the video to the audio by eye, and then re-linking them.  This was the first time I saw the +/- indicator Mr Jim Simon spoke of, because it's now showing me how out-of-sync I have MANUALLY made them, which is not the problem!  I KNOW how out of sync they are, NOW...!
        Sorry to sound like I'm shouting, I'm just frustrated that I've had to spend so much time futzing with this when I could have been further along in the project by now.  Martin, I just wanted to say that it is not your system and your problem is not unique.
        -Paul
        • 32. Re: Audio Out of Sync - Why and How to Correct
        tmztv1960
        Hello Everyone,
        Has anyone found a solution to this BUG?
        This happens to me all the time with Adobe Premier CS6.
        It is an obvious Software BUG that needs to be corrected. I am a TV show editor.
        I have had this happen to me 4 different times. You don't have to do anything special. The video with sound runs perfectly with any other product on your computer..but goes out of sync in Premier. I have tried cleaning up the Media Cache .cfa and .pek waveforms. No joy. I have tried relinking the media. No joy. I have tried moving the project and renaming and relinking. No joy. Rendering No joy. Setting the media cache to local area. No joy.
        If this had happened to me just once, I would say, I have done something wrong. It has happened now in 4 different projects on four different shows. I have produced and released over 100 shows to TV.
        I have checked everything, I have reloaded footage off camera. I have checked and bought new cables. I have checked codecs, frame rates, loaded into other products. All fine. I just wish Adobe engineers would do this same type of debugging of their software.
        I use to work for Hewlett Packard Software division.  We were taught to alfa test, beta test and not release until bug rates
        were at certain levels. Some bugs just have get through or you never get to release. But this bug really hits your productivity in a major way. You have to resync BY HAND each cut... all your sound after hours and days and weeks of getting it perfect. Then in a split second. FFFFDDDDDDDDD
        I have been editing with Premier for 6 years.... It only seems to be since I have upgraded to CS6.  And I have to re-link by hand to correct the problem.  I sync on electronic clapper board number and sound - almost impossibe not to sync. I will be working away happily, cut out some footage go to my next grab..BANG out of sync. That simple.
        All I know is that it happens and for ADOBE to really be a true professional editing suite in the the TV/Movie world.... This is just not on. By any chance have they released a patch or bug fix to repair this. I have spent over 3 weeks edting a television show again .......needing to go to air in less than three weeks and all of a sudden between one cut and delete.. the sound is out of sync across the whole interview. JUST NOT ON. I have spent 4 hours now..none productive hours trying to resync the sound, find solutions on the website via forums. Some ideas have been really good and I have tried them. None have worked. Still unsynced. Almost completed show I now have to re-sync by hand. At this point, I am thinking FCP is looking good. I cannot stand this loss of productivity and time.
        This is not the only forum complaining about this..that should tell you something.
        • 33. Re: Audio Out of Sync - Why and How to Correct
        martinv2012 Level 1
        Again thanks tmztv and the rest of you. I thought I was a bit of an amateur having this problem. Nice to know it's the product not me.
        • 34. Re: Audio Out of Sync - Why and How to Correct
        Jim_Simon Level 8
        I don't know if Adobe even has this logged as a bug.  It's not a problem I'm seeing from a great many people.  It's also not a problem I'm able to reproduce with my own footage.
        If anyone cares to upload some problem footage and post the steps taken to cause the error, I can test here.
        https://www.depositfiles.com/uploader_flash.html
        • 35. Re: Audio Out of Sync - Why and How to Correct
        tmztv1960 Level 1
        Happy to when I get this series finished..I am have three more shows to go. I have lots of information from web for potential work arounds, but
        So far no joy. So in September, I will pack up some samples and shoot them to you. It has happened to me about 4 different times now in four different projects.
        • 36. Re: Audio Out of Sync - Why and How to Correct
        nickdbomb
        I've had intermittent synch issues when editing MPEG4 video within nested sequences. They were not multicam related. My solution was to rebuild the sequence without nesting.  At times I deleted the file I had imported onto my RAID and replaced it with my back-up from my archive and this solved some issues.
        Are you running 6.0.3?  After I updated to this most of the bug issues like the one above were solved? I own my software but have heard that pirated versions of CS6 are not stable.
        Adobe can't ask you to solve software bug but you do need to have someone qualified to set-up and maintain a smooth running editing workflow. Premiere Pro CS6 needs a properly configured fast system .
        I am not saying you have a hardware issue but I have had some quirky issues when I did not have my system configured correctly. Especially with AVCHD, your configuration is very important. When setup correctly my system is amazing. This is a good document to read about optimizing your editing system.
        http://www.adobe.com/content/dam/Adobe/en/products/creativesuite/production/cs6/pdfs/adobe -hardware-performance-whitepaper.pdf
        In in order of importance:
        8GB RAM minimum
        1 system drive with ONLY the Adobe applications. (No Media, No cache)
        1 Fast RAID for Video and Audio. Minimum 2 drives striped RAID 0 internal or external using a protocol USB 3.0 or Thunderbolt.
        TIP: I use a 2 drive external RAID USB 3.0 drive for A / V and store my program file on a SDHC card so I can swap them from my desktop to my laptop when I need to edit in a clients location. I have a much better graphics card on the desktop so After Effects is much faster but the quad i7 laptop works well for rough cuts, minor effects and simple graphics.
        Optional: Add another drive for cache files. I noticed an improvement in response by using an internal drive on my desktop and a USB 3.0 drive flash memory drive on my laptop.
        There was a noticeable improvement in the interface response time when I switched the dick drive on my desktop to a SSD. My laptop is OK with a spinning 7200 RPM disk.
        • 37. Re: Audio Out of Sync - Why and How to Correct
        nickdbomb Level 1
        Weird coincidence? When I opened Premiere Pro CS6.0.3 today a notice of an update to the Event Manager or something like that popped up and I updated, I opened a same project  that I was working on a week ago that I was having no issues with. Using the media browser, I double clicked on a XDCAM video file. The video was seen in the sorce monitor. The video played OK but the audio was out of synch and skipping ahead. Normally I make a I/O selection in the source monitor and drag it to the timeline. Doing this imports it into the project. I rebooted, No Luck. I deleted the problem files on my RAID and transferred the same files back to the RAID from the archive, No Luck. I was investigating my settings and found what I think was the problem at least it solved it for now. The settings found under Edit / Preferences / Media / Media Cache Files and Media cache Database were set to my C: system drive. I switched the settings to the folded I'm using on my RAID and Premiere asked if I wanted to transfer my cache files to the new location, I selected yes. This almost solved the problem. First the Adobe Premiere Pro CS6 program stopped working. The message popped up titled: Premiere Pro Debug Event with the message Premiere Pro has encountered an error  [..\..\Src\FileCache.cpp-1027] at the bottom of the popup window was a button labeled Continue clicking it another popup Save Project the My computer froze crashed and I had to manually push the power button until it turned off. Upon rebooting and loading PP I ran SpyBot just incase some malware had affected my system. There were 16 items found by Spybot that I deleted.  I checked my Preferences and they were correct. I opened the media browser and selected the same clip that was out of synch then a message I'd never seen before popped up saying the video was being imported. After a few seconds to import, the video and audio played in synch. Making an I/O selection and dragging to the timeline worked. I just wasted 4 hours trouble shooting this hope it helps someone.
        • 38. Re: Audio Out of Sync - Why and How to Correct
        SFL46 Level 3
        regarding Premiere signalling with the +/-  It is my observation that this only appears when the user drags either the audio ir video out of alignment.  It doesn't work if the audio and video were out of sync when captured.  I have input video fram camtasia and occasionally the audo and video go out of sync on a longer clip.  There is no way for Premiere to know these are out of sync.  The only way I've found to resolve is to cut the clip and manually nudge one of the clips back and forth until it looks correct.
        You said the sequence properties and the video properties align.  Is this on both the sequence you laid out an cut the captured video, and the sequence you placed the nested sequence on?
        • 39. Re: Audio Out of Sync - Why and How to Correct
        martinv2012 Level 1
        True, if the audio and video are out of sync on import or imported separately then it would be out of sync. The problem is, as described above, when Premiere allows them to go out of sync whitout any warning. This includes using multi camera editing. If more then one person has experienced this problem in various forms, then Adobe should respond. I am thinking Sony Vegas or some other system might have been better editing solution to FCP.
        BTW with Steve Jobs gone, Apple will float about - but Adobe must have the vision Jobs did to move its product to the top of the editing systems.
        1 2 Previous Next
