1 Reply Latest reply on May 3, 2008 12:47 AM by Gregory Lafrance
    Newby Questions with HTTPService / Flex 3
    Developer504 Level 1
      Hi folks. I am a pretty experienced database programmer, I work with a software called Magic eDev, but I'm a newby in Flex.
      I am trying to use Flex 3 to create a web / client interface for an application written in Magic eDev. I am still trying to get my head around Flex, (Magic is a completely different programming paradigm) and I've made a very simple Flex App to read an XML file generated by another application written in a third party software (Magic eDev 9.4) via HTTPService. I think I have the HTTPService request part figured out, This little Application does not cause any errors. However, I am not seeing my data in the display. If I manually try the URL query to the Magic App, I do get the XML file with the data in it, but Flex doesn't seem to see anything.
      I just want to get two fields via the HTTPService data and display them, but I'm not getting any result. I can't even tell if Flex is actually querying Magic or not. Can anyone explain what I'm doing wrong?
      Also, is there some way to monitor what the Flex app is doing when you run it, as you can in some other systems?
      Here is my code:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="vertical"
      verticalAlign="middle"
      backgroundColor="white">
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      private function serv_result(evt:ResultEvent):void {
      var resultObj:Object = evt.result;
      userName.text = resultObj.catalog.username;
      emailAddress.text = resultObj.catalog.emailaddress;
      private function serv_fault(evt:FaultEvent):void {
      error.text += evt.fault.faultString;
      error.visible = true;
      form.visible = false;
      </mx:Script>
      <mx:String id="XML_URL">album.xml</mx:String>
      <mx:HTTPService id="loginService"
      url=" http://localhost/magic94scripts/mgrqcgi94.exe"
      method="POST"
      result="{ResultEvent(event)}" fault="{FaultEvent(event)}">
      <mx:request>
      <appname>FlexDispatch</appname>
      <prgname>Test</prgname>
      <arguments>username,emailaddres</arguments>
      </mx:request>
      </mx:HTTPService>
      <mx:ApplicationControlBar dock="true">
      <mx:Label text="{XML_URL}" />
      </mx:ApplicationControlBar>
      <mx:Label id="error"
      color="red"
      fontSize="36"
      fontWeight="bold"
      visible="false"
      includeInLayout="{error.visible}"/>
      <mx:Form id="form"
      includeInLayout="{form.visible}">
      <mx:FormItem label="resultObj.catalog.username:">
      <mx:Label id="userName" />
      </mx:FormItem>
      <mx:FormItem label="resultObj.catalog.emailaddress:">
      <mx:Label id="emailAddress" />
      </mx:FormItem>
      </mx:Form>
      </mx:Application>
      This is what the XML file looks like:
      <?xml version="1.0" ?>
      - <catalog>
      <username>DaveID</username>
      <emailaddress>DaveName</emailaddress>
      </catalog>
        • 1. Re: Newby Questions with HTTPService / Flex 3
          Gregory Lafrance Level 6
          Man, I really thought I could nail this one, but alas I could not. The attached code simplifies yours, and in fact mine might have problems that would prevent data from displaying but notice these points:
          - you don't seem to call the send() method to actually send the request
          - I use trace statements to at least know something it happening
          creationComplete="trace('in creationComplete');loginService.send()">
          <mx:Script>
          <![CDATA[
          trace("got here");
          var resultObj:Array = loginService.lastResult.catalogs;
          userName.text = resultObj[0][0];
          emailAddress.text = resultObj[0][1];
          trace("oops, got here");
          </mx:Script>
          <mx:HTTPService id="loginService" resultFormat="array" url="file.xml"
          result="ResultEvent(event)" fault="FaultEvent(event)">
          </mx:HTTPService>
          <mx:Label id="userName" text="Greg"/>
          <mx:Label id="emailAddress" text="Greg@greg.com"/>
          <mx:Label id="error" text="error text"/>
          </mx:Application>
