1. Re: Datefield does not work with cflayoutarea
Aaron Neff Jul 2, 2012 11:08 PM (in response to userCold9)userCold9 wrote:
<cfajaximport tags="CFINPUT-DATEFIELD, CFAJAXPROXY, CFINPUT-AUTOSUGGEST, CFPOD, CFTOOLTIP, CFSPRYDATASET-JSON, CFTEXTAREA, CFDIV, CFLAYOUT-TAB, CFFORM ">[...]
</cfajaximport>Hi Mike,
The closing </cfajaximport> is unnecessary and can be removed.
userCold9 wrote:
As soon as the cflayoutarea is inserted, the code does not run. Below is the code for the cflayoutarea.
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">
Two issues:
1) The <cflayoutarea /> tag must be within a <cflayout /> tag.
2) The <cflayoutarea /> tag requires an end tag. (ex: either close it w/ " />" or w/ "</cflayoutarea>") Please try this:
<cflayout type="tab">
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left" source="my_content.cfm" />
</cflayout>
or
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">my content</cflayoutarea>
</cflayout>
(depending on which way you want to include the contents)
(you could also change type="tab" to type="accordion")
Resources:
-Aaron
2. Re: Datefield does not work with cflayoutarea
userCold9 Jul 3, 2012 6:53 AM (in response to Aaron Neff)I tried the recommended solutions and the datefield still does not work inside a table.
Mike
3. Re: Datefield does not work with cflayoutarea
Aaron Neff Jul 3, 2012 9:56 PM (in response to userCold9)Hi Mike,
Could you please post your opening cflayout tag? I wrapped your code (minus the cfajaximport, b/c it's unneeded here) w/ a cflayout tag having a height, and the datefield was then fully visible. The cflayout's height needs to be tall enough to display the datefield. Could you try this:
<cflayout type="tab" height="300">
<CFOUTPUT>
<cfform name="Five" ACTION="formaction.cfm" METHOD="post">
<TABLE>
<TR>
<TD>
date
</TD>
<TD><P> </P><P> </P><P> </P>
<CFINPUT TYPE="datefield" NAME="start" ><P> </P><P> </P><P> </P>
</TD>
</TR>
</TABLE>
<cfinput type="submit" name="Save" value="Save">
</CFFORM>
</CFOUTPUT>
</cflayoutarea>
</cflayout>
-Aaron
4. Re: Datefield does not work with cflayoutarea
userCold9 Jul 5, 2012 6:52 AM (in response to Aaron Neff)Below is the cflayout tag
<cflayout type="tab" height="800" >
Mike
5. Re: Datefield does not work with cflayoutarea
userCold9 Jul 5, 2012 9:04 AM (in response to userCold9)If I place the code in a single tab and the code is not in a module being called using the cfinclude, it works.
But if there are more than one cflayoutarea under the cflayout it does not work or if the code is placed in another module that is called, it does not work.
Mike
6. Re: Datefield does not work with cflayoutarea
Hi Mike,
Could you try this?
<cflayout type="tab" height="800">
<cfinclude template="myfile.cfm" />
</cflayoutarea>
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility2" overflow = "auto" selected="false" title="Service 2" align="left">
Tab 2
</cflayoutarea>
</cflayout>
where myfile.cfm contains this:
<CFOUTPUT>
<TABLE>
<TR>
<TD> date </TD>
<TD><P> </P>
<P> </P>
<P> </P>
<P> </P>
<P> </P>
<P> </P></TD>
</TR>
</TABLE>
</CFFORM>
</CFOUTPUT>
I'm seeing the datefield fine. Perhaps there is some other code contributing to the issue? Could you post a full example that we can try?
-Aaron
7. Re: Datefield does not work with cflayoutarea
userCold9 Jul 10, 2012 6:31 AM (in response to Aaron Neff)I got the code to work with three tabs being accessed with a link in the menu on the life side of the screen. I am trying to get the next three tabs to work with the second link in the menu.
Mike
