10 Replies Latest reply on Apr 1, 2013 1:16 PM by jangell2
    refine edge need some help
    capt marvy Level 1
      I am using cs5 and I can use most of the tools, but refine edge throws me for a loop, when I think I have it, it says bye bye. Is there a tutorial that explains what all the sliders are for and how to use it, at least get me some understanding and get me close
      Kas
        • 1. Re: refine edge need some help
          Noel Carboni Level 8
          This video gives a decent idea how to use it:
          http://tv.adobe.com/watch/the-russell-brown-show/masking-basics-in-photoshop-cs5/
          -Noel
          • 2. Re: refine edge need some help
            Trevor.Dennis Adobe Community Professional
            This video added something new for Refine Edge for me
            http://www.youtube.com/watch?v=ssJRkbkHAa4
            • 3. Re: refine edge need some help
              capt marvy Level 1
              Thanks for the input
              Kas
              • 4. Re: refine edge need some help
                jangell2
                I've reviewed various video tutorials for the refine edge/mask function in CS5 or CS6 (I have CSk6) and most of them use fairly easy to do photos.  There is high contrast and marked  color differences between the subject and the background.  Is there a tutorial out there that tackles  a difficult photo?  A photo in which there is less contrast and color difference between subject and background.
                I frequently photograph cats I'm usually snapping them where I find them.  I've got a picture of two black cats and a brown plastic basket.  I'd like to keep all that (and there fringes of their furr and their whiskers) and knock out the background which is darker but not totally black.  So far its tought going.
                I realize I'm asking a lot here, but perhaps there are techniques to improve the results?
                • 5. Re: refine edge need some help
                  Post a part of a representative photo at full resolution; perhaps that will elicit more specific guidance.
                  -Noel
                  • 6. Re: refine edge need some help
                    jangell2 Level 1
                    Ok, here's a portion of a photo.  I used photoshops Save for Web to cut down its size, but I think it still has plenty of detail.  I've done no processing on this.  I do plan on correcting things like under exposure.
                    • 7. Re: refine edge need some help
                      I guess the trick is to find the right balance of Refine Edge and post masking corrections/adjustments that gets you a result in fairly short order.
                      Would less than 10 minutes work be acceptable to achieve this level of result?  I don't have a good feel for what you're going to be putting behind the felines digitally in the end.
                      What went into this was Quick Select, then some adjustments to both the mask and the pixels that make up the cat doing things like Dodging and Burning, as well as a bit of touch up on the mask by painting white/black.
                      You can ultimately touch up the pixels around the edges to help make them blend into the background better, once you get it on the actual background it's going to go with.  That way fine hairs that have remnants of light backgrounds that look too light can be darkened.
                      As with most digital work, more prep time to get better data to start with usually results in easier editing.
                      2013-03-31 13:31:57 Photoshop launched
                        Reset Tool Presets of current application
                        Play action “New Image from Clipboard” of set “Hot Keys”
                        Select quick selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Quick Selection
                      Undo
                      Redo
                      Undo
                      Refine Edge
                        Refine Edge
                         Radius: 7.9 pixels
                         Contrast: 26%
                         Smooth: 0
                         Feather: 0 pixels
                         Shift Edge: 18%
                         With Smart Radius
                         Without Decontaminate Colors
                         Output: Selection
                      Refine Edge
                        Refine Edge
                         Radius: 0 pixels
                         Contrast: 0%
                         Smooth: 0
                         Feather: 0 pixels
                         Shift Edge: 0%
                         Without Smart Radius
                         Output: New Layer with Layer Mask
                        Select layer “Background”
                         Without Make Visible
                      New Gradient Fill Layer
                        Make fill layer
                         Using: fill layer
                         Type: gradient
                         Angle: 90°
                         Type: linear
                         Gradient: gradient
                         Form: custom stops
                         Interpolation: 4096
                         Colors: color stop list
                         color stop
                         Color: RGB color
                         Red: 151
                         Green: 70
                         Blue: 26
                         Type: user specified color
                         Midpoint: 50
                         color stop
                         Color: RGB color
                         Red: 251
                         Green: 215.914
                         Blue: 196.86
                         Midpoint: 50
                         color stop
                         Color: RGB color
                         Red: 108
                         Green: 46
                         Blue: 22
                         Midpoint: 50
                         color stop
                         Color: RGB color
                         Red: 239
                         Green: 219
                         Blue: 205
                         Midpoint: 60
                         Transparency: transparency stop list
                         transparency stop
                         Opacity: 100%
                         Midpoint: 50
                         transparency stop
                         Opacity: 100%
                         Midpoint: 50
                      Crop
                        Crop
                         To: rectangle
                         Top: 0 pixels
                         Left: 0 pixels
                         Bottom: 2446.2 pixels
                         Right: 1856 pixels
                         Angle: 0°
                         With Delete Cropped Pixels
                         <unknown>
                         false
                        Select burn
                        Select layer “Background copy”
                      Dodge Tool
                      Burn Tool
                        Select previous history state
                      Burn Tool
                        Select mask channel
                        Exchange Swatches
                        Select brush
                      Brush Tool
                      Brush Tool
                        Exchange Swatches
                      Brush Tool
                        Exchange Swatches
                        Select burn
                        Select dodge
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                        Select brush
                        Exchange Swatches
                      Brush Tool
                        Exchange Swatches
                      Brush Tool
                        Exchange Swatches
                      Brush Tool
                      Brush Tool
                      Brush Tool
                      Brush Tool
                      Brush Tool
                        Select dodge
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                        Exchange Swatches
                        Select brush
                      Brush Tool
                        Select dodge
                      Dodge Tool
                      Dodge Tool
                        Select burn
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      Burn Tool
                        Select dodge
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                      Dodge Tool
                        Select RGB channel
                        Select burn
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      Burn Tool
                      2013-03-31 13:40:34 File C:\TEMP\MaskedCat.jpg saved
                        Save
                         As: JPEG
                         Quality: 9
                         With Optimized
                         Matte: none
                         In: C:\TEMP\MaskedCat.jpg
                         1404
                         With Copy
                      2013-03-31 13:40:39 File  closed
                        Close
                         Saving: no
                      2013-03-31 13:40:41 Photoshop quit
                      -Noel
                      • 8. Re: refine edge need some help
                        jangell2 Level 1
                        10 minutes would be terrific to achieve what you did.  You also did what I plan on doing, putting a gradient behind the image.  I've being doing a quick select, a refine edge with output to a mask.  You did a refine edge with output to a selection.  Another refine edge (with default settings) to produce a mask.
                        Why not go to a mask out of the first refine edge?  Do you use the Refine Radius Tool?  Were the Dodge and Burn Tools used to lighten and darken edges?
                        • 9. Re: refine edge need some help
                          That was just an accident; I meant to output to a masked layer but mistakenly didn't change the setting in the Refine Edge dialog.
                          -Noel
                          • 10. Re: refine edge need some help
                            jangell2 Level 1
                            I wonder if making a high contrast copy of the image and using that for the refine edge process would improve the results?  BTW, do you use the Refine Radius Tool brush?
