2 Replies Latest reply on Jul 2, 2012 9:14 PM by Vj Cheshire
    After Effects 11.0 Quit Unexpectedly
    Vj Cheshire Level 1
      I was rendering a video and AE Cs 6 quit right in the middle.
      I tried re-opening the file and it errors out with multiple errors starting with "Auto Color" Error.  Here is the Problem Details and System Configuration:
      Process:         After Effects [885]
      Path: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
      Identifier: com.adobe.AfterEffects
      Version: 11.0.1 (11.0)
      Code Type: X86-64 (Native)
      Parent Process: launchd [130]
      Date/Time: 2012-07-02 19:33:17.874 -0700
      OS Version:      Mac OS X 10.7.4 (11E53)
      Report Version:  9
      Interval Since Last Report:          361817 sec
      Crashes Since Last Report:           3
      Per-App Interval Since Last Report:  370558 sec
      Per-App Crashes Since Last Report:   1
      Anonymous UUID: 5F5DD3E9-82CA-4C0B-AF0D-5AB2FA654531
      Crashed Thread: 0  Dispatch queue: com.apple.main-thread
      Exception Type: EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000158
      VM Regions Near 0x158:
          __TEXT 0000000100000000-0000000100004000 [ 16K] r-x/rwx SM=COW /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
      Application Specific Information:
      objc[885]: garbage collection is OFF
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   BEE.dylib                           0x0000000101106661 BEE_CompToLayerTime(BEE_Layer const*, T_Time const*, T_Time*) + 17
      1   BEE.dylib                           0x0000000100fe7fac BEE_CompToLayerSpan(BEE_Layer const*, T_TimeSpan const&) + 60
      2   BEE.dylib                           0x00000001011046e7 BEE_GetEffectParamIndexFromPath(BEE_Layer const*, TDB_StreamIDPath const&) + 1191
      3   TDB.dylib                          0x00000001020b20b2 TDB_ParamLayerStream::GetRenderGuid(TDB_RenderOptionsBase const&) const + 18
      4   TDB.dylib                          0x00000001020b460a TDB_NamedStreamGroup::GetRenderGuid(TDB_RenderOptionsBase const&) const + 256
      5   FLT.dylib                           0x000000010176c535 FLT_FCSeqSpec::GetRenderGuid(TDB_RenderOptionsBase const&) const + 237
      6   BEE.dylib                           0x0000000100f97e23 BEE_AVLayer::GetRenderGuidWithRO(BEE_LayerRenderOptions const&) const + 4569
      7   BEE.dylib                           0x0000000100fe657f BEE_CompItem::GetRenderGuidWithRO(BEE_ItemRenderOptions const&) const + 2427
      8   BEE.dylib                           0x0000000100f99493 BEE_AVLayer::GetRenderGuidWithRO(BEE_LayerRenderOptions const&) const + 10313
      9   BEE.dylib                           0x0000000101080bd3 BEE_MaskParade::BEE_MaskParade(TDB_MatchName const*) + 431
      10  BEE.dylib                         0x0000000101080dcc BEE_GetEffectParamState(BEE_Layer*, FLT_FCSeqSpec*, int, T_Time const*, T_Time const*) + 284
      11  BEE.dylib                         0x0000000101081080 BEE_GetEffectParamState(BEE_Layer*, FLT_FCSeqSpec*, int, T_Time const*, T_Time const*) + 976
      12  FLT.dylib                         0x000000010177e497 FLT_SeqLockParams(FLT_FCSeqSpec const*, PF_ParamDef***) + 51031
      13 com.adobe.AfterEffects.AutoColor       0x000000012faa61a4 main + 14612
      14 com.adobe.AfterEffects.AutoColor       0x000000012faa2eb4 main + 1572
      15  FLT.dylib                         0x0000000101787ac2 FLTp_ReadyFilter(FLT_FCSpec*) + 5410
      16  FLT.dylib                         0x000000010178604d FLT_RegisterPseudoEffect(char const*, char const*, std::vector<PF_ParamDef, std::allocator<PF_ParamDef> > const&) + 5277
      17  FLT.dylib                         0x000000010176e736 FLT_SeqSetName(FLT_FCSeqSpec*, char const*) + 662
      18  FLT.dylib                         0x00000001017474d7 FLT_SeqDoDialog(FLT_FCSeqSpec*, T_Time const*, int*) + 631
      19  FLT.dylib                         0x000000010175622f FLT_FCSeqSpec::MakeIndependent(bool) + 81
      20  FLT.dylib                         0x0000000101757519 FLT_FCSeqSpec::Write(SLU_File*) const + 1859
      21  TDB.dylib                         0x00000001020b992d TDB_StreamGroup::Write(SLU_File*) const + 927
      22  TDB.dylib                         0x00000001020b992d TDB_StreamGroup::Write(SLU_File*) const + 927
      23  BEE.dylib                         0x00000001010eae7c BEE_Layer::WritePlus(SLU_File*, BEEp_FileInfo*) + 162
      24  BEE.dylib                         0x00000001010eacf7 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const*, BEE_Project*) + 12309
      25  BEE.dylib                         0x00000001010e3a5e BEE_RegisterPresetLocalizationString(char const*, char const*) + 2574
      26  BEE.dylib                         0x0000000101047e24 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 1044
      27  BEE.dylib                         0x00000001010ece44 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set<BEE_Item*, std::less<BEE_Item*>, std::allocator<BEE_Item*> > const*, FILE_Spec*) + 4484
      28 com.adobe.AfterEffectsLib.framework            0x00000001007f4444 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 356
      29 com.adobe.AfterEffectsLib.framework            0x00000001007f5166 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 3718
      30 com.adobe.AfterEffectsLib.framework            0x00000001007f3a72 CTopicArray::~CTopicArray() + 59154
      31 com.adobe.AfterEffectsLib.framework            0x000000010048c535 GetMetaPanelSuite + 9061
      32 com.adobe.AfterEffectsLib.framework            0x000000010048bfe7 GetMetaPanelSuite + 7703
      33  U.dylib                              0x0000000102b57081 U_Die + 241
      34  U.dylib                              0x0000000102b7714d U_LoadFrameworkBundle + 557
      35 com.adobe.dvacore.framework            0x0000000102fc9535 _ZN12_GLOBAL__N_1L13SignalHandlerEiP9__siginfoPv + 261
      36 libsystem_c.dylib                         0x00007fff812b0cfa _sigtramp + 26
      37  BEE.dylib                         0x0000000101106661 BEE_CompToLayerTime(BEE_Layer const*, T_Time const*, T_Time*) + 17
      38  BEE.dylib                         0x0000000100fe7fac BEE_CompToLayerSpan(BEE_Layer const*, T_TimeSpan const&) + 60
      39  BEE.dylib                         0x00000001011046e7 BEE_GetEffectParamIndexFromPath(BEE_Layer const*, TDB_StreamIDPath const&) + 1191
      40  TDB.dylib                         0x00000001020b20b2 TDB_ParamLayerStream::GetRenderGuid(TDB_RenderOptionsBase const&) const + 18
      41  TDB.dylib                         0x00000001020b460a TDB_NamedStreamGroup::GetRenderGuid(TDB_RenderOptionsBase const&) const + 256
      42  FLT.dylib                         0x000000010176c535 FLT_FCSeqSpec::GetRenderGuid(TDB_RenderOptionsBase const&) const + 237
      43  BEE.dylib                         0x0000000100f97e23 BEE_AVLayer::GetRenderGuidWithRO(BEE_LayerRenderOptions const&) const + 4569
      44  BEE.dylib                         0x0000000100fe657f BEE_CompItem::GetRenderGuidWithRO(BEE_ItemRenderOptions const&) const + 2427
      45  BEE.dylib                         0x0000000100f99493 BEE_AVLayer::GetRenderGuidWithRO(BEE_LayerRenderOptions const&) const + 10313
      46  BEE.dylib                         0x0000000101080bd3 BEE_MaskParade::BEE_MaskParade(TDB_MatchName const*) + 431
      47  BEE.dylib                         0x0000000101080dcc BEE_GetEffectParamState(BEE_Layer*, FLT_FCSeqSpec*, int, T_Time const*, T_Time const*) + 284
      48  BEE.dylib                         0x0000000101081080 BEE_GetEffectParamState(BEE_Layer*, FLT_FCSeqSpec*, int, T_Time const*, T_Time const*) + 976
      49  FLT.dylib                         0x000000010177e497 FLT_SeqLockParams(FLT_FCSeqSpec const*, PF_ParamDef***) + 51031
      50 com.adobe.AfterEffects.AutoColor       0x000000012faa61a4 main + 14612
      51 com.adobe.AfterEffects.AutoColor       0x000000012faa2eb4 main + 1572
      52  FLT.dylib                         0x0000000101787ac2 FLTp_ReadyFilter(FLT_FCSpec*) + 5410
      53  FLT.dylib                         0x000000010178604d FLT_RegisterPseudoEffect(char const*, char const*, std::vector<PF_ParamDef, std::allocator<PF_ParamDef> > const&) + 5277
      54  FLT.dylib                         0x000000010176e736 FLT_SeqSetName(FLT_FCSeqSpec*, char const*) + 662
      55  FLT.dylib                         0x00000001017474d7 FLT_SeqDoDialog(FLT_FCSeqSpec*, T_Time const*, int*) + 631
      56  FLT.dylib                         0x000000010176aca6 FLT_ParadeResolveLayers(FLT_Parade*, int (*)(unsigned char, FLT_FCSeqSpec*, void*, void**, void**), void*) + 294
      57  BEE.dylib                         0x00000001010dff2d BEE_ReverseEngineerZStringFromPresetString(std::string const&) + 4125
      58  BEE.dylib                         0x00000001010dfb6c BEE_ReverseEngineerZStringFromPresetString(std::string const&) + 3164
      59  BEE.dylib                         0x0000000101047d4a BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 826
      60  BEE.dylib                         0x00000001010efa47 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set<BEE_Item*, std::less<BEE_Item*>, std::allocator<BEE_Item*> > const*, FILE_Spec*) + 15751
      61  BEE.dylib                         0x00000001010f0161 BEE_LoadProject(FILE_Spec*, BEE_FolderItem*, unsigned char, unsigned char, unsigned char*, BEE_ActiveItemInfo*, unsigned int*, BEE_Project*) + 193
      62  BEE.dylib                         0x000000010100af0b BEE_TimeDisplayFormat2T_TimeFormatInfo(BEE_TimeDisplayFormat const*, T_TimeFormatInfo*) + 491
      63  BEE.dylib                         0x000000010119eb7e BEE_UndoRedoCount(int*, int*) + 110
      64  BEE.dylib                         0x000000010100d051 BEE_DoCommand(short, BEE_CommandInfo*) + 449
      65 com.adobe.AfterEffectsLib.framework            0x00000001007f586b CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 5515
      66  com.adobe.AfterEffectsLib.framework            0x000000010042a28a CEggApp::OpenDocument(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 404
      67 com.adobe.AfterEffectsLib.framework            0x00000001002d3f33 0x1002a1000 + 208691
      68 com.adobe.AfterEffectsLib.framework            0x00000001004572ca CEggApp::IEggApp(bool, bool) + 1688
      69 com.adobe.AfterEffectsLib.framework            0x000000010042cc75 CEggApp::CEggApp(bool, bool, int) + 1005
      70 com.adobe.AfterEffectsLib.framework            0x000000010045bd85 SetAPETerminateFunc(boost::function<void ()()> const&) + 709
      71 com.adobe.AfterEffectsLib.framework            0x000000010045c5fd EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 61
      72 com.adobe.AfterEffects              0x0000000100003aad main + 1677
      73 com.adobe.AfterEffects              0x000000010000340c start + 52
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0 libsystem_kernel.dylib                 0x00007fff862497e6 kevent + 10
      1 libdispatch.dylib               0x00007fff8bbaa78a _dispatch_mgr_invoke + 923
      2 libdispatch.dylib               0x00007fff8bba931a _dispatch_mgr_thread + 54
      Thread 2:
      0 libsystem_kernel.dylib                 0x00007fff86248bca __psynch_cvwait + 10
      1 libsystem_c.dylib              0x00007fff81260274 _pthread_cond_wait + 840
      2 com.apple.CoreServices.CarbonCore    0x00007fff89965a5e TSWaitOnCondition + 106
      3 com.apple.CoreServices.CarbonCore    0x00007fff898f7ea6 TSWaitOnConditionTimedRelative + 127
      4 com.apple.CoreServices.CarbonCore    0x00007fff8993ce81 MPWaitOnQueue + 181
      5 com.adobe.dvacore.framework             0x0000000102f43ce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()()> > >&, int) + 200
      6 com.adobe.dvacore.framework             0x0000000102f40fe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
      7 com.adobe.dvacore.framework             0x0000000102f3e6d3 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadP riorityERKNS4_8functionIFvvEEESE_ + 163
      8 com.adobe.boost_threads.framework   0x0000000109196ace thread_proxy + 158
      9 libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      10  libsystem_c.dylib                         0x00007fff8125fb75 thread_start + 13
      Thread 3:
      Thread 4:
      1 libsystem_c.dylib              0x00007fff812602a6 _pthread_cond_wait + 890
      2 com.apple.CoreServices.CarbonCore    0x00007fff898f7ec4 TSWaitOnConditionTimedRelative + 157
      3 com.apple.CoreServices.CarbonCore    0x00007fff8993ce81 MPWaitOnQueue + 181
      4 com.adobe.dvacore.framework             0x0000000102f43ce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()()> > >&, int) + 200
      5 com.adobe.dvacore.framework             0x0000000102f40fe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
      6 com.adobe.dvacore.framework             0x0000000102f3e6d3 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadP riorityERKNS4_8functionIFvvEEESE_ + 163
      7   com.adobe.boost_threads.framework   0x0000000109196ace thread_proxy + 158
      8 libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      9 libsystem_c.dylib              0x00007fff8125fb75 thread_start + 13
      Thread 5:
      Thread 6:
      5   com.adobe.ACE                            0x000000010a1262c9 0x10a0ed000 + 234185
      6   com.adobe.ACE                            0x000000010a1255da 0x10a0ed000 + 230874
      7 com.apple.CoreServices.CarbonCore    0x00007fff8993dce6 PrivateMPEntryPoint + 58
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      5 com.adobe.ASLFoundation.framework 0x0000000105c01320 _ZN3ASL12_GLOBAL__N_1L8TaskProcEPv + 160
      6 com.apple.CoreServices.CarbonCore    0x00007fff8993dce6 PrivateMPEntryPoint + 58
      7 libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      8 libsystem_c.dylib              0x00007fff8125fb75 thread_start + 13
      Thread 14:
      Thread 15:
      Thread 16:
      Thread 17:
      1 com.adobe.dvatransport.framework     0x0000000108e21f12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 240
      2 com.adobe.dvatransport.framework     0x0000000108e2c0da boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock<boost::asio ::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
      3 com.adobe.dvatransport.framework     0x0000000108e2c467 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
      4 com.adobe.dvatransport.framework     0x0000000108e18fbd SkyConnectionEnv::MainLoop() + 129
      5 com.adobe.dvatransport.framework     0x0000000108e1903b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      6 com.adobe.boost_threads.framework   0x0000000109196ace thread_proxy + 158
      Thread 18:
      2 com.adobe.dvatransport.framework     0x0000000108e2c04b boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock<boost::asio ::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
      4 com.adobe.dvatransport.framework     0x0000000108e19c2a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
      5 com.adobe.dvatransport.framework     0x0000000108e1cc33 boost_asio_detail_posix_thread_function + 19
      6 libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      7 libsystem_c.dylib              0x00007fff8125fb75 thread_start + 13
      Thread 19:: com.apple.audio.IOThread.client
      0 libsystem_kernel.dylib                 0x00007fff8624767a mach_msg_trap + 10
      1 libsystem_kernel.dylib                 0x00007fff86246d71 mach_msg + 73
      2 com.apple.audio.CoreAudio        0x00007fff84530eb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
      3 com.apple.audio.CoreAudio        0x00007fff84530f05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
      4 com.apple.audio.CoreAudio        0x00007fff8452a568 HALC_ProxyIOContext::IOWorkLoop() + 888
      5 com.apple.audio.CoreAudio        0x00007fff8452a151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
      6 com.apple.audio.CoreAudio        0x00007fff8452a00c HALB_IOThread::Entry(void*) + 78
      Thread 20:
      2 com.adobe.AfterEffects.MThread          0x000000011b768017 main + 27303
      3 com.adobe.AfterEffects.MThread          0x000000011b7680ce main + 27486
      4 com.adobe.dvacore.framework             0x0000000102f3e6d3 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadP riorityERKNS4_8functionIFvvEEESE_ + 163
      5 com.adobe.boost_threads.framework   0x0000000109196ace thread_proxy + 158
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      Thread 25:
      Thread 26:
      Thread 27:
      Thread 28:
      2 com.adobe.AfterEffects.OpenEXR          0x0000000125b11484 IlmThread::Semaphore::wait() + 100
      3 com.adobe.AfterEffects.OpenEXR          0x0000000125b10546 IlmThread::(anonymous namespace)::WorkerThread::run() + 182
      4 libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      5 libsystem_c.dylib              0x00007fff8125fb75 thread_start + 13
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:
      Thread 34:
      Thread 35:
      Thread 36:: Dispatch queue: com.apple.root.default-priority
      0 com.mainconcept.mc.dec.aac      0x000000013180abfe open_AACin_Audio_stream + 112078
      1 com.mainconcept.mc.dec.aac      0x000000013180b983 open_AACin_Audio_stream + 115539
      2 com.mainconcept.mc.dec.aac      0x0000000131806779 open_AACin_Audio_stream + 94537
      3 com.mainconcept.mc.dec.aac      0x000000013180c4c8 open_AACin_Audio_stream + 118424
      4 com.mainconcept.mc.dec.aac      0x00000001317eed2f AACin_Audio_GetAPIExt + 303
      5 com.mainconcept.mc.mfimport              0x00000001187667ea mpegInGetNextSample + 2522
      6 com.mainconcept.mc.mfimport              0x00000001187662eb mpegInGetNextSample + 1243
      7 com.adobe.ImporterMPEG.framework 0x00000001186cde99 ImporterMPEG::ImporterMPEG::ReadAudioData(AudioHandler&, long long, unsigned int, char*, int&) + 231
      8 com.adobe.ImporterMPEG.framework 0x00000001186cead2 AudioHandler::TransferToAudioBuffer(long long, void*) + 94
      9 com.adobe.ImporterMPEG.framework 0x00000001186ce09f ImporterMPEG::ImporterMPEG::OnImportAudio7(void*, imImportAudioRec7*) + 421
      10 com.adobe.ImporterMPEG.framework            0x00000001186d3c91 PrImportModule<ImporterMPEG::ImporterMPEG>::ImportEntry(ASL::ResourceCollection const&, int, imStdParms*, void*, void*) + 635
      11 com.adobe.ImporterMPEG.framework            0x00000001186d3788 xImportEntry + 88
      12 com.adobe.ImporterHost.framework  0x0000000107c3b104 ML::LocalImporterModule::CallImportModuleGuarded(int, void*, void*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 138
      13 com.adobe.ImporterHost.framework  0x0000000107c3b579 ML::LocalImporterModule::CallImportModule(int, void*, void*) + 825
      14  com.adobe.ImporterHost.framework  0x0000000107c3c315 ML::LocalImporterModule::CallImportModuleInstance(MF::BinaryData const&, int, void*, void*, dvacore::utility::Guid, unsigned long) + 327
      15 com.adobe.ImporterHost.framework  0x0000000107c30067 ML::ImporterInstance::CallModule(MF::BinaryData const&, int, void*, dvacore::utility::Guid, unsigned long) + 407
      16 com.adobe.ImporterHost.framework  0x0000000107bd79c6 ML::AudioImporterStream::GetNextAudio(MF::BinaryData const&, AR::AudioBuffer&, bool) + 890
      17 com.adobe.ImporterHost.framework  0x0000000107c790cf ML::ConformedAudioSourceFile::Process(int, ASL::ImmutableString const&) + 5169
      18 com.adobe.ImporterHost.framework  0x0000000107c72d97 ML::AudioSourceQueue::DoSingleProcess(ASL::InterfaceRef<ML::AudioSourceImpl, AR::IAudioSourceFile> const&) + 445
      19 com.adobe.ImporterHost.framework  0x0000000107c729eb ML::AudioSourceQueue::Process() + 771
      20 com.adobe.ImporterHost.framework  0x0000000107c74582 void boost::_mfi::mf0<void, ML::AudioSourceQueue>::call<ASL::InterfaceRef<ML::AudioSourceQueue, ML::IAudioSourceQueue> >(ASL::InterfaceRef<ML::AudioSourceQueue, ML::IAudioSourceQueue>&, void const*) const + 54
      21 com.adobe.dvacore.framework            0x0000000102f316ea dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function<void ()()> const&) + 52
      22 com.adobe.dvacore.framework            0x0000000102f2fbcd dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymo us namespace)::SubExecutorImpl> const&) + 267
      23 com.adobe.dvacore.framework            0x0000000102f44156 dvacore::threads::(anonymous namespace)::WrapGCDAsyncCall(void*) + 54
      24 libdispatch.dylib              0x00007fff8bba9965 _dispatch_worker_thread2 + 255
      25  libsystem_c.dylib                         0x00007fff8125e3da _pthread_wqthread + 316
      26 libsystem_c.dylib                         0x00007fff8125fb85 start_wqthread + 13
      Thread 37:
      0 libsystem_kernel.dylib                 0x00007fff86248e42 __semwait_signal + 10
      1 libsystem_c.dylib              0x00007fff81212dea nanosleep + 164
      2 com.adobe.AfterEffects.Scripting           0x0000000128df73eb zcalloc + 188043
      3 com.adobe.AfterEffects.Scripting           0x0000000128dde069 zcalloc + 84745
      4 com.adobe.AfterEffects.Scripting           0x0000000128df7736 zcalloc + 188886
      5   libsystem_c.dylib              0x00007fff8125c8bf _pthread_start + 335
      6 libsystem_c.dylib              0x00007fff8125fb75 thread_start + 13
      Thread 38:
      2 com.adobe.ape.engine                 0x0000000129a32c0d APXGetHostAPI + 2516093
      3 com.adobe.ape.engine                 0x00000001297e0ec1 APXGetHostAPI + 83761
      4 com.adobe.ape.engine                 0x0000000129a32cd1 APXGetHostAPI + 2516289
      5 com.adobe.ape.engine                 0x0000000129a32d4a APXGetHostAPI + 2516410
      6 com.adobe.ape.engine                 0x0000000129a32e79 APXGetHostAPI + 2516713
      Thread 39:
      Thread 40:
      Thread 41:
      Thread 42:
      2 com.apple.CoreFoundation        0x00007fff8bc5050c __CFRunLoopServiceMachPort + 188
      3 com.apple.CoreFoundation        0x00007fff8bc58c74 __CFRunLoopRun + 1204
      4 com.apple.CoreFoundation        0x00007fff8bc58486 CFRunLoopRunSpecific + 230
      5 com.apple.CoreMediaIO              0x00007fff8c297fe9 CMIO::DAL::RunLoop::OwnThread(void*) + 159
      6 com.apple.CoreMediaIO              0x00007fff8c28e15a CAPThread::Entry(CAPThread*) + 98
      Thread 43:
      2 com.adobe.ape.engine                 0x0000000129a32bd0 APXGetHostAPI + 2516032
      3 com.adobe.ape.engine                 0x0000000129a4addb APXGetHostAPI + 2614859
      Thread 44:
      3 com.adobe.ape.engine                 0x0000000129bc52c3 APXGetHostAPI + 4164403
      Thread 45:
      3   com.apple.CoreServices.CarbonCore    0x00007fff898f7c9b TSWaitOnSemaphoreCommon + 358
      4 com.apple.CoreServices.CarbonCore    0x00007fff8992b6d6 AsyncFileThread(void*) + 219
      Thread 46:
      2 libsystem_c.dylib              0x00007fff81212c2c sleep + 61
      3 com.redgiantsoftware.Looks3_AE         0x000000013021c7dd RGSerialEnableLicensing(_struct_rgs_product_descriptor*, char const*) + 8381
      4 com.redgiantsoftware.Looks3_AE         0x000000013021e1ea RGSerialEnableLicensing(_struct_rgs_product_descriptor*, char const*) + 15050
      Thread 47:
      3 com.TrapCode.AfterEffects.Particular   0x0000000130be664b RGS::SerialServer::ThreadProcess() + 33
      4   com.TrapCode.AfterEffects.Particular   0x0000000130be8058 RGS::ThreadObject::ThreadFunc(void*) + 10
      Thread 48:
      3 com.Redgiant.AfterEffects.Trapcode.Form       0x0000000130d9e353 RGS::SerialServer::ThreadProcess() + 33
      4 com.Redgiant.AfterEffects.Trapcode.Form       0x0000000130d9fd60 RGS::ThreadObject::ThreadFunc(void*) + 10
      Thread 49:
      3 com.redgiantsoftware.trapcode.Shine   0x0000000130f37625 RGS::SerialServer::ThreadProcess() + 33
      4 com.redgiantsoftware.trapcode.Shine   0x0000000130f39032 RGS::ThreadObject::ThreadFunc(void*) + 10
      Thread 50:
      0 libsystem_kernel.dylib                 0x00007fff86249192 __workq_kernreturn + 10
      1 libsystem_c.dylib              0x00007fff8125e594 _pthread_wqthread + 758
      2 libsystem_c.dylib              0x00007fff8125fb85 start_wqthread + 13
      Thread 51:
      Thread 52:
      2 com.mainconcept.mc.bc.dec.avc             0x000000013235e9bd h264in_Video_GetAPIExt + 238429
      3 com.mainconcept.mc.bc.dec.avc             0x00000001322ddfc5 open_h264in_Video_stream + 335301
      Thread 53:
      Thread 54:
      Thread 55:
      Thread 56:
      Thread 57:
      Thread 58:
      Thread 59:
      Thread 60:
      Thread 61:
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x00000258ff9d1f80  rbx: 0x00007fff5fbf66b0  rcx: 0x0000025800000000  rdx: 0x00007fff5fbf66b0
        rdi: 0x0000000000000020  rsi: 0x00007fff5fbf67c0  rbp: 0x00007fff5fbf66a0  rsp: 0x00007fff5fbf6670
         r8: 0x0000000113d25610   r9: 0x00000001020e1a70  r10: 0x00007fff5fbf6698  r11: 0x0000000113d25610
        r12: 0x0000000113d25610  r13: 0x00007fff5fbf6d08  r14: 0x0000000000000020  r15: 0x00007fff5fbf68d0
        rip: 0x0000000101106661  rfl: 0x0000000000010202  cr2: 0x0000000000000158
      Logical CPU: 4
      Binary Images:
             0x100000000 -        0x100003fff +com.adobe.AfterEffects (11.0.1 - 11.0) <992257AE-47B1-AD42-7179-C8A1FA9397B2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
             0x100008000 -        0x100034ff7 +libtbb.dylib (??? - ???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbb.dylib
             0x10004b000 -        0x100059ff3 +libtbbmalloc.dylib (??? - ???) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10006d000 -        0x100079fff +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.339847) <1DAE296F-47E5-264E-B40C-EE2D685D91BD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x100091000 -        0x100094fff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.339847) <DCA7A410-AA8D-D8C8-9005-ECC1C1ACF561> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x10009a000 -        0x1000a1fff +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.339847) <72F2FC39-C6E1-0AD8-88D6-EFA559AA74E1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x1000bc000 -        0x1001b8ff7 +hydra_filters (??? - ???) <39EBE3E3-E526-751C-63BC-524CC68F530C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
             0x100257000 -        0x100271fff +image_runtime (??? - ???) <DF99730C-DD39-142E-793E-865129A6EAC8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
             0x10029d000 -        0x10029eff7 +ALOG.dylib (??? - ???) <D97DDFB7-20B4-BE1B-CF0E-BE3D04F7A467> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ALOG.dylib
             0x1002a1000 -        0x100d12fe7 +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 - 1.0) <68A0A3C0-5B44-F9D9-08B9-933085901725> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
             0x100f6f000 -        0x100f6ffff +AEFX.dylib (??? - ???) <C9EB7459-B453-232F-3A37-C6BB69C00CDE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AEFX.dylib
             0x100f72000 -        0x10144ffff +BEE.dylib (??? - ???) <C06E340F-7ACB-4685-63AF-230FD03ED3EC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEE.dylib
             0x10164c000 -        0x10165afef +BEZ.dylib (??? - ???) <6AB999D0-A612-F121-21A6-44B576BEDD24> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEZ.dylib
             0x10165f000 -        0x101669ff7 +BM.dylib (??? - ???) <F456ED6B-AE94-77D0-E3FA-D86F131DB44F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BM.dylib
             0x101671000 -        0x1016befff +COR.dylib (??? - ???) <5D29FF6A-5EFD-EF28-8764-BF064D89FC3F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/COR.dylib
             0x1016e1000 -        0x101702fff +FILE.dylib (??? - ???) <97239C29-9967-8DC0-7C67-81CD69524A6E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FILE.dylib
             0x101712000 -        0x10173cfff +FLO.dylib (??? - ???) <CB88111C-ECEE-0094-309C-5DC98C0C4539> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLO.dylib
             0x101741000 -        0x1017d5fff +FLT.dylib (??? - ???) <C6204326-2A5D-3399-D30C-C80C8829DE6B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLT.dylib
             0x101833000 -        0x101839ff7 +LIST.dylib (??? - ???) <B9E3DF3A-76B5-392E-79AE-5992D95B50A1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LIST.dylib
             0x10183d000 -        0x101857ff7 +M.dylib (??? - ???) <3A77069F-07DE-2DCC-1B85-82A3E5A13C45> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/M.dylib
             0x10185f000 -        0x101880fff +MC.dylib (??? - ???) <3F9BA4CA-60B9-5943-1779-86194726796B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MC.dylib
             0x101892000 -        0x1018f1fff +MSK.dylib (??? - ???) <E5C4860A-DBB9-8A96-3138-B694CEFB7F3A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MSK.dylib
             0x101904000 -        0x101950fff +OM.dylib (??? - ???) <16E72DD9-519A-5CEF-5027-342F5A9E3E38> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/OM.dylib
             0x101967000 -        0x10198bfef +P.dylib (??? - ???) <10872288-99DF-A634-942E-E7ECB780FA57> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/P.dylib
             0x101994000 -        0x101c53ff7 +PF.dylib (??? - ???) <D975E13B-7160-68E1-E10F-70438CA1AD1E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PF.dylib
             0x101c7c000 -        0x101ef0fff +PIN.dylib (??? - ???) <FD0E9EF2-1F73-7973-640C-557AB44F892D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PIN.dylib
             0x101f5c000 -        0x101f76fff +PLUG.dylib (??? - ???) <370151D3-71F1-FCC6-AB5B-68A85168427A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PLUG.dylib
             0x101f83000 -        0x101f99fe7 +PR.dylib (??? - ???) <8B96ADC7-74A9-6B69-7F72-4F335AD88D86> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PR.dylib
             0x101fa2000 -        0x101fa8fff +PREF.dylib (??? - ???) <11CC47C3-6742-3637-6379-0E9C2BB3A697> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREF.dylib
             0x101fad000 -        0x101fc9fff +RG.dylib (??? - ???) <987F6E58-E74F-C73C-DCF9-73ED901D8314> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RG.dylib
             0x101fd5000 -        0x101fd7ff7 +RI.dylib (??? - ???) <A08338CA-CBEA-2716-4DEB-35584752C4D7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RI.dylib
             0x101fda000 -        0x101fdbfff +RND.dylib (??? - ???) <E2C0F5DC-B612-407B-CE73-18FF32631943> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RND.dylib
             0x101fe2000 -        0x102042fef +SLU.dylib (??? - ???) <A56BC56B-3D6A-069B-671B-E5381B7E56FD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SLU.dylib
             0x102067000 -        0x102088ff7 +SND.dylib (??? - ???) <5FABD954-B3F1-BB27-F11A-BBF94C16EE5C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SND.dylib
             0x102092000 -        0x102094fff +STR.dylib (??? - ???) <38C368A4-CBED-9E4D-A574-FE5915E48F0A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/STR.dylib
             0x102098000 -        0x10209bfff +T.dylib (??? - ???) <CBFB1D28-BA98-713C-A032-61FAC2455752> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/T.dylib
             0x10209f000 -        0x1020e0ff7 +TDB.dylib (??? - ???) <2B1E1476-C4C5-5D09-493B-273902FE9E81> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TDB.dylib
             0x1020f4000 -        0x102826fff +TXT.dylib (??? - ???) <2DBA295C-3CD1-740A-3FAF-93CCEAFF71AD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TXT.dylib
             0x102b53000 -        0x102b9efef +U.dylib (??? - ???) <4F807A20-4959-B0F4-C009-7BC3D67C703A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/U.dylib
             0x102bba000 -        0x102bbefff +VAL.dylib (??? - ???) <30ED6142-F0C0-28B2-A3AB-6052985FAE63> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VAL.dylib
             0x102bc1000 -        0x102c93ff7 +com.adobe.exo.framework (6.0.0 - 6.0.0.339847) <CDAB2A73-32D8-017D-D5E0-A3C2FC8E17E6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x102df7000 -        0x102e1dfff +PREM.dylib (??? - ???) <3C4A9298-E480-64B7-765F-17683DEF5545> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREM.dylib
             0x102e31000 -        0x102e85ff7 +FRP.dylib (??? - ???) <8D342B97-66B2-2BA9-5961-CEBABFB9DCF7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FRP.dylib
             0x102ea4000 -        0x103073fff +com.adobe.dvacore.framework (6.0.0 - 6.0.0.339847) <68174838-DAC0-0702-62CB-3C0EA3A1ABDA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x103280000 -        0x1036e8fff +com.adobe.dvaui.framework (6.0.0 - 6.0.0.339847) <18BA5926-F5ED-F8BB-2ED2-9A73C0EA41DC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x103c59000 -        0x103d11ff7 +com.adobe.dvaworkspace.framework (6.0.0 - 6.0.0.339847) <F6B28D51-3446-DA89-A595-2681B2FE29C2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x103e1e000 -        0x103e42fef +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.339847) <311C23D0-4ED1-3046-43DA-D778C205E17B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x103e86000 -        0x103ef5ff7 +aif_core (??? - ???) <ADE40D99-884E-C6A0-94CE-16DFFAE7EBDC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
             0x103f4a000 -        0x104187ff7 +aif_ogl (??? - ???) <C0B5E2E6-6792-22FC-88E3-C26002215DFB> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
             0x104355000 -        0x1043adfff +data_flow (??? - ???) <C40D9B1B-AEE8-455C-8513-AF05C0492592> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
             0x104490000 -        0x104d95fef +image_compiler (??? - ???) <A17AF37F-C2CC-CD3D-160A-9665637BD009> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
             0x105605000 -        0x10568cff7 +image_flow (??? - ???) <754653E9-121B-6DA2-A721-44CBE50CD23B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
             0x105735000 -        0x10577afff +com.adobe.dynamiclinkui.framework (6.0.0 - 6.0.0.339847) <3638A5DA-EB94-2253-46E3-FB2D6209B3A3> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x1057e8000 -        0x1059d0fff +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.339847) <1C003F6D-A049-1512-9347-56AB7B43A06A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x105bd7000 -        0x105c39ff7 +com.adobe.ASLFoundation.framework (6.0.0 - 6.0.0.0) <CEE7FF6C-0854-36DD-8853-2CA0C3940A40> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x105d2f000 -        0x105d4cfff +com.adobe.ASLMessaging.framework (6.0.0 - 6.0.0.0) <E14F1634-3111-B1AD-414B-96891BA74D9D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x105d7a000 -        0x105d89fff +com.adobe.ASLUnitTesting.framework (6.0.0 - 6.0.0.0) <29DD454E-3F8C-C02A-BF2D-7A1C431A7B4F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x105da4000 -        0x105dc7fff +com.adobe.AudioFilterHost.framework (6.0.0 - 6.0.0.0) <00749410-E891-02F8-85D3-E7317F121A13> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x105df5000 -        0x105e3bfff +com.adobe.AudioFilters.framework (6.0.0 - 6.0.0.0) <E5C48C9F-7420-F1CE-115B-60EF4FA35907> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x105e98000 -        0x105f44ff7 +com.adobe.AudioRenderer.framework (6.0.0 - 6.0.0.0) <1C10A388-4727-602B-6C59-B226537BA72B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x106002000 -        0x106045fff +com.adobe.AudioSupport.framework (6.0.0 - 6.0.0.0) <3D9B4821-B9A0-24AE-9913-A7941A9CB89E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x10608f000 -        0x106ec2ff7 +com.adobe.Backend.framework (6.0.0 - 6.0.0.0) <38AAED9E-566B-6B62-BD83-C47AE48A9792> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x107943000 -        0x107a86ff7 +com.adobe.ImageRenderer.framework (6.0.0 - 6.0.0.0) <5DB11121-1F1C-8388-74E0-DE29786562AD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x107ba5000 -        0x107d34ff7 +com.adobe.ImporterHost.framework (6.0.0 - 6.0.0.0) <89D673BB-8CA8-D6F4-2E2D-3FEADE9C9F10> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x107eb2000 -        0x107f18ff7 +com.adobe.MediaFoundation.framework (6.0.0 - 6.0.0.0) <4C130514-56DB-C94A-D5CE-5F240C77318D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x107fa0000 -        0x107fa3fff +com.adobe.MediaUtils.framework (6.0.0 - 6.0.0.0) <13257FF0-4C6D-798D-D109-55E76E3B3357> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x107faa000 -        0x107fabfff +com.adobe.Memory.framework (6.0.0 - 6.0.0.0) <7CE434A1-0331-98E6-8D45-C014EF2AFE8D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x107fb2000 -        0x107ffbff7 +com.adobe.MLFoundation.framework (6.0.0 - 6.0.0.0) <7533F19F-8BCA-74FE-65EA-A280A689E6CC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x10806b000 -        0x1080a7fff +com.adobe.PluginSupport.framework (6.0.0 - 6.0.0.0) <B1518564-FB7C-10AE-ED3C-4EEEB55910C3> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x1080ed000 -        0x1080eeff7 +com.adobe.PRM.framework (6.0.0 - 6.0.0.0) <A637471E-7FAB-C27D-691B-4CFDE15800C0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x1080f4000 -        0x108120ff7 +com.adobe.SweetPeaSupport.framework (6.0.0 - 6.0.0.0) <047A72A2-FC23-0B4A-18BD-CF15EEF16588> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x108158000 -        0x1081acff7 +com.adobe.VideoFrame.framework (6.0.0 - 6.0.0.0) <E02C08C1-C4D4-58CD-42D5-69B5942A29F1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x1081fc000 -        0x108350fff +com.adobe.VideoRenderer.framework (6.0.0 - 6.0.0.0) <D8E4630A-7A80-D886-0B56-5CAEE091FC90> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x108466000 -        0x108535fff +com.adobe.dvaeve.framework (6.0.0 - 6.0.0.339847) <8085BE1D-8D4C-5E40-0D3D-A1BFFF23C4AF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x1086a8000 -        0x10872dff7 +com.adobe.PlayerHost.framework (6.0.0 - 6.0.0.0) <152F89E5-1ABD-0070-4648-6CBC4D4DBF4A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x1087c2000 -        0x1088b3ff7 +com.adobe.VideoFilterHost.framework (6.0.0 - 6.0.0.0) <29FAE0DF-C6E2-F726-DB21-789DAC2D8018> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x108972000 -        0x108a1cfe7 +libicucnv.40.0.dylib (40.0.0 - compatibility 40.0.0) <768D99C5-46B9-B849-2834-B5BF541856D1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
             0x108a43000 -        0x108ab0ff7 +libicudata.40.0.dylib (40.0.0 - compatibility 40.0.0) <1FC741E8-F498-4185-7677-42701BF39611> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
             0x108ab3000 -        0x108b0dff7 +com.adobe.dvametadata.framework (6.0.0 - 6.0.0.339847) <AFD308AA-1DA0-76AC-95E0-8D8414236CE1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x108baa000 -        0x108c3eff7 +com.adobe.dvametadataUI.framework (6.0.0 - 6.0.0.339847) <6F6B2B81-E5D9-768E-B4A7-C7BD703CE22C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x108d14000 -        0x108d6bfff +com.adobe.dvatemporalxmp.framework (6.0.0 - 6.0.0.339847) <534129F7-D4E7-2D92-B554-36404D31863B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x108d9f000 -        0x108dc9ff7 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.339847) <3DF961A1-7F7D-194E-8E3A-8D1CEE877DEC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x108dfc000 -        0x108e62ff7 +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.339847) <26DF5878-A0E4-E488-3AAA-A343B1F84A16> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x108ee2000 -        0x108f1efff +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.339847) <093D0803-5317-7962-6525-4E53D12AD5EE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x108fb0000 -        0x108fc8fff +com.adobe.ProjectSupport.framework (6.0.0 - 6.0.0.0) <B92E70D2-586E-312D-3488-4744F517F04D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x108ff0000 -        0x109056fff +com.adobe.DynamicLinkMedia.framework (6.0.0 - 6.0.0.0) <3257F074-8276-2CFD-2FA6-2793920F802B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x109106000 -        0x10910aff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x109110000 -        0x109110fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
             0x109113000 -        0x10913ffff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
             0x109162000 -        0x109168fff  com.apple.agl (3.2.0 - AGL-3.2.0) <AB0B5D3F-BA2A-3366-830A-EF9258C18276> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x10916f000 -        0x10918efff +com.adobe.BIB (AdobeBIB 1.2.02.19553 - 1.2.02.19553) <D665D6DB-849A-B75A-87A3-BCDBE502C146> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x109195000 -        0x1091a4fff +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.339847) <CF283D53-486D-1691-D549-B95AB48A0B93> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x1091c5000 -        0x109233fef +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x109287000 -        0x10935efff +filter_graph (??? - ???) <9A5DAD81-87EB-CB16-DD09-53C9F25A530D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
             0x109472000 -        0x1094d2ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.146227) <96B43AA1-300E-B6DF-415F-8E90D70DDE48> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x1094dc000 -        0x109593fe7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 50 - 66.146227) <F8BA4F7C-7F22-D01C-C931-E4E7EF70958C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x1095c6000 -        0x109674fef +com.adobe.AdobeScCore (ScCore 4.2.13 - 4.2.13.20553) <1DA959D4-4E63-75C8-E550-D69BEEB0989E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x1096b1000 -        0x10976eff7 +com.adobe.AdobeExtendScript (ExtendScript 4.2.13 - 4.2.13.20553) <AA2C8A06-198D-499A-4667-36000B393EF2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x1097b8000 -        0x1098b2fe7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
             0x109956000 -        0x109cb7fef +com.adobe.CoolType (AdobeCoolType 5.10.31.19553 - 5.10.31.19553) <EBBA5B24-2AD8-B793-4DC2-ADCAA2342B06> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x109d04000 -        0x10a081fff +com.adobe.AGM (AdobeAGM 4.26.18.19553 - 4.26.18.19553) <BE1F8ECC-FDD3-A308-3E75-A641D4D0869F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x10a0ed000 -        0x10a266fff +com.adobe.ACE (AdobeACE 2.19.18.19553 - 2.19.18.19553) <B2CC095C-33A0-7782-7A51-0F2C2567DDE8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x10a279000 -        0x10a2a1ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <4D68A67D-F390-33AB-6036-5CE76A3067E7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10a2a8000 -        0x10a36dfff +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x10a3ba000 -        0x10a3fcff7 +com.adobe.ARE (AdobeARE 1.5.02.19553 - 1.5.02.19553) <33F16AE8-11E3-1B04-1B26-6761897DB125> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x10a404000 -        0x10a84aff7 +com.adobe.MPS (AdobeMPS 5.8.0.19673 - 5.8.0.19673) <E63AFCA8-3E74-1745-8C74-8B0A78073BE5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x10a8c6000 -        0x10a8f2ff7 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.7.101.18636 - 3.7.101.18636) <6BC56AE6-E5FE-956E-B7BA-9D4DEEDD1A48> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
             0x10a915000 -        0x10ba13fef +com.adobe.psl (AdobePSL 13.0.0.19655 - 13.0.0.19655) <8029DA17-402C-301F-02E9-D0EC8DF48BE8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x10bbd3000 -        0x10bd20ff7 +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10bd94000 -        0x10be86fef +com.adobe.ExporterHost.framework (6.0.0 - 6.0.0.0) <389D584C-CB84-6B27-984F-365174E19096> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x10bf76000 -        0x10bff0fef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x10bfff000 -        0x10c0e3fe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10c0f4000 -        0x10c10eff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x10c117000 -        0x10c8ebfe7 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.19598) <D1204626-3571-3CED-36D9-DF063196C7C2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
             0x10c9a3000 -        0x10c9c6fef +SegMatServices.dylib (??? - ???) <C75054F9-21F7-D2B6-1A61-5A31F2EADD42> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SegMatServices.dylib
             0x10c9da000 -        0x10c9daff7 +SAM.dylib (??? - ???) <EDC4BA0A-BA4A-1205-A5DF-014D706BAF7E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SAM.dylib
             0x10c9dd000 -        0x10ca39fff +TDL.dylib (??? - ???) <3B812E8F-102B-97F7-F2C0-1D0B41B2AC6F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TDL.dylib
             0x10ca4e000 -        0x10ca78fff +com.adobe.dvacaptioning.framework (6.0.0 - 6.0.0.339847) <666CDCF7-186D-9691-E3C9-9564AE532FE6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
             0x10caae000 -        0x10cd86fe6 +libxerces-c-3.0.dylib (??? - ???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x10cf00000 -        0x10cf24fe7 +com.mainconcept.mc.enc.dv (9.1 - 9.1.6.4544) <842421AD-DB61-E7AA-8398-1AB75D600CC0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
             0x10cf38000 -        0x10cfa7fff +com.adobe.QT32Client.framework (6.0.0 - 6.0.0.0) <50FE5A12-4B86-65FB-7820-90957CF77A93> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x10d03d000 -        0x110a5df47 +liboptix.1.dylib (3.0.0 - compatibility 1.0.0) <3DAE3DDD-98C8-89C1-6167-12394F8A908B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/liboptix.1.dylib
             0x110f65000 -        0x110fcdff7 +libcudart.dylib (4.0.0 - compatibility 1.1.0) <C0981A05-13B2-1E88-B190-6E207CDB7424> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libcudart.dylib
             0x110fd3000 -        0x110fd4fff +libtlshook.dylib (4.0.0 - compatibility 1.1.0) <1D1C35CB-E17F-79E0-7DAE-988625AB57F9> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtlshook.dylib
             0x110fd7000 -        0x1110a2ff7 +com.adobe.AMEWrapper.framework (6.0.0 - 6.0.0.0) <33E93427-392B-E60F-C187-E194CAEC75BA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
             0x11116c000 -        0x11126aff7 +com.adobe.EncoderHost.framework (6.0.0 - 6.0.0.0) <8F8E593F-088E-C2A4-0D99-62656EAA78BE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x11135f000 -        0x111555fff +com.adobe.SettingsUI.framework (6.0.0 - 6.0.0.0) <1B4517A0-112B-3029-D4C0-8C4BD1FC473E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x1117b2000 -        0x1117defff +com.adobe.amefoundation.framework (6.0.0 - 6.0.0.0) <7726A983-6A59-48F7-0B88-ADDB0E8D3CBF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
             0x111822000 -        0x111853ff7 +com.adobe.ameproperties.framework (6.0.0 - 6.0.0.0) <4CEE6A33-5203-0BAC-7C26-2A9E0348C613> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
             0x11189e000 -        0x1118baff7 +com.adobe.AMEAppFoundation.framework (6.0.0 - 6.0.0.0) <147F5FFE-D2B2-CC98-4928-93D31740B2CE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x1118ef000 -        0x111914fff +com.adobe.PostEncodeHost.framework (6.0.0 - 6.0.0.0) <04696AE7-1AFD-433E-4E06-8F55DDA55999> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
             0x11197a000 -        0x11197cfff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x111c72000 -        0x111c73fff  ATSHI.dylib (??? - ???) <8EBE46C6-AD0E-3F64-A24D-DC284976DCB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
             0x111c7a000 -        0x111c7efff  com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <D4D40031-05D5-3D8B-A9A5-490D9483E188> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
             0x111c83000 -        0x111c88fff  com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x111cb9000 -        0x111cbeff7 +com.adobe.ExporterCoreAudio.framework (6.0.0 - 6.0.0.0) <66FF2B31-4064-A830-860D-3CB4DA539DB2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
             0x111f07000 -        0x111f15ff7 +com.adobe.AudioConverter.framework (6.0.0 - 6.0.0.0) <DCD23903-7AE0-F679-A9F4-21142BD29C6D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x1137fa000 -        0x1137fdff7 +com.adobe.AfterEffects.Durer (??? - ???) <C66CEAAF-F359-5872-A062-F71E719843D7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
             0x1157ac000 -        0x1157c0ff7 +com.adobe.QTParser.framework (6.0.0 - 6.0.0.0) <BD523A6E-CFEE-4246-D241-2071661B8693> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x1157eb000 -        0x1157efff7  libFontRegistryUI.dylib (??? - ???) <36269A17-78FE-371A-B108-D71764661281> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
             0x1185fb000 -        0x118641fe7 +com.adobe.pip (??? - 6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x11864e000 -        0x118694fff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
             0x1186ae000 -        0x118700ff7 +com.adobe.ImporterMPEG.framework (6.0.0 - 6.0.0.0) <DCA94927-3178-0E21-68D3-BC8D66DE7F80> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
             0x118754000 -        0x118806fe3 +com.mainconcept.mc.mfimport (9.1 - 9.1.6.4544) <6DC978A7-B198-F022-69FA-20B7EA9679FE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimport
             0x11880f000 -        0x118847ff7 +libMOG_Framework.dylib.2.2.4 (??? - ???) <7A97623B-F09F-CA33-B9EA-1202FA569605> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMOG_Framework.dylib.2.2.4
             0x118866000 -        0x11886fff7 +libMXF_SDK_GenericContainer_AES3.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3.dyl ib.4.4.3
             0x118877000 -        0x118881fff +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3_S30 2M.dylib.4.4.3
             0x11888a000 -        0x118890fff +libMXF_SDK_GenericContainer_AVI.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_AVI.dyli b.4.4.3
             0x118895000 -        0x1188a1ff7 +libMXF_SDK_GenericContainer_D10.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_D10.dyli b.4.4.3
             0x1188a9000 -        0x1188c3fef +libMXF_SDK_GenericContainer_DV.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_DV.dylib .4.4.3
             0x1188d5000 -        0x1188e3fff +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_JPEG2000 .dylib.4.4.3
             0x1188ef000 -        0x1188f9fe7 +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_ESA udio.dylib.4.4.3
             0x118902000 -        0x118912fff +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPE G2Video.dylib.4.4.3
             0x11891f000 -        0x118932ff7 +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPE G4.dylib.4.4.3
             0x11893d000 -        0x118946fff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPE GPS.dylib.4.4.3
             0x11894d000 -        0x118958fff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPE GTS.dylib.4.4.3
             0x118960000 -        0x118969fff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_SystemSc heme1.dylib.4.4.3
             0x118972000 -        0x118983fff +libMXF_SDK_GenericContainer_Wave.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_Wave.dyl ib.4.4.3
             0x118993000 -        0x11899efff +libMXF_SDK_Metadata_RP224.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_Metadata_RP224.dylib.4.4. 3
             0x1189a5000 -        0x1189b1ffa +libMXF_SDK_XMLUtils.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_XMLUtils.dylib.4.4.3
             0x118cca000 -        0x118cf8ff7  GLRendererFloat (??? - ???) <E33704BC-AA25-3279-A585-ABC6B3176D3E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x118f02000 -        0x118f5dfff +com.adobe.AfterEffects.TIFFIO (??? - ???) <1322320C-4AD6-31A0-DA28-806C1F45E9DF> /Applications/Adobe After Effects CS6/*/TIFF.plugin/Contents/MacOS/TIFFIO
             0x118f69000 -        0x118f6efff +com.trapcode.TrapcodeOBJ (??? - ???) <74AA1AEF-CC6D-4A4D-425A-2FD9D0E87503> /Applications/Adobe After Effects CS6/*/TrapcodeOBJ.plugin/Contents/MacOS/TrapcodeOBJ
             0x118f71000 -        0x118f7cfff +com.adobe.AfterEffects.Analyzer (??? - ???) <E628E66B-3D35-8FE6-B145-B405BB6AF2C4> /Applications/Adobe After Effects CS6/*/Analyzer.plugin/Contents/MacOS/Analyzer
             0x118fed000 -        0x118ff5fff +com.cycoresystems.CCfx.LightRays (1.0 - ???) <3263B480-6791-0377-7D6B-9E98AAD7070E> /Applications/Adobe After Effects CS6/*/LightRays.plugin/Contents/MacOS/LightRays
             0x118ffc000 -        0x118ffdfff +com.adobe.AfterEffects.Paint (??? - ???) <F7461457-D755-D8ED-9503-8FB7F971B257> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
             0x119911000 -        0x119aaafff  GLEngine (??? - ???) <61484217-C41D-3A65-86BD-397ACC0D069F> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x119ade000 -        0x119bd7fff  libGLProgrammability.dylib (??? - ???) <7396EE13-5FA6-3E78-88D0-2502CFE79A97> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
             0x119bfd000 -        0x119ec5ff7  com.apple.ATIRadeonX3000GLDriver (7.18.18 - 7.1.8) <337EB117-0CB0-3C9E-AEE8-76BCB3CB9371> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
             0x119f10000 -        0x11a31bff7 com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.18.18 - 7.1.8) <20ACFA77-6847-3053-A3D8-498150E8FC62> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD3000GraphicsGLDriver
             0x11a537000 -        0x11a552ff7 +com.adobe.AfterEffects.PS3Export (??? - ???) <31A74DE6-065F-E3D1-07DB-A1F12ED71A05> /Applications/Adobe After Effects CS6/*/PS Layer Export.plugin/Contents/MacOS/PS3Export
             0x11a55f000 -        0x11a586fff +com.adobe.AfterEffects.PS3Import (??? - ???) <C89809FA-A19E-F41B-8496-E9551B789CC6> /Applications/Adobe After Effects CS6/*/PS Layer Import.plugin/Contents/MacOS/PS3Import
             0x11a596000 -        0x11a59aff7 +com.adobe.AfterEffects.EasyEase (??? - ???) <92F3AE88-6BF5-7B0E-7F8F-10459FBBA4FB> /Applications/Adobe After Effects CS6/*/EasyEase.plugin/Contents/MacOS/EasyEase
             0x11a59e000 -        0x11a5a3ff7 +com.adobe.AfterEffects.ExpScale (??? - ???) <1AA6AD61-55EC-B56E-821A-BF397F009E6A> /Applications/Adobe After Effects CS6/*/ExpScale.plugin/Contents/MacOS/ExpScale
             0x11a5a7000 -        0x11a5aeff7 +com.adobe.AfterEffects.Sequence (??? - ???) <9FE2B7E1-2625-87CF-9F73-BF4CE1B81C06> /Applications/Adobe After Effects CS6/*/Sequence.plugin/Contents/MacOS/Sequence
             0x11a5e3000 -        0x11a5e7ff7 +com.adobe.AfterEffects.TRKeys (??? - ???) <A3A8F51E-C328-786D-D506-D2541F76CC2C> /Applications/Adobe After Effects CS6/*/TRKeys.plugin/Contents/MacOS/TRKeys
             0x11a5f2000 -        0x11a5f7fff +com.adobe.AfterEffects.RPFImport (??? - ???) <15C2AA23-61D9-BFEE-D9CE-FD055AEF41E5> /Applications/Adobe After Effects CS6/*/RPFImport.plugin/Contents/MacOS/RPFImport
             0x11a5fb000 -        0x11a5fdff7 +com.adobe.AfterEffects.ChangeToColor (??? - ???) <EAB0E755-1D3D-1D67-C251-0D1809095ED0> /Applications/Adobe After Effects CS6/*/ChangeToColor.plugin/Contents/MacOS/ChangeToColor
             0x11b75f000 -        0x11b76ffff +com.adobe.AfterEffects.MThread (??? - ???) <91999BFC-5DD6-9958-DA99-ACF04C634155> /Applications/Adobe After Effects CS6/*/Mthread.plugin/Contents/MacOS/MThread
             0x11b778000 -        0x11b77cff7 +com.adobe.AfterEffects.Find_Edges (??? - ???) <BEC7E510-0090-A01A-22F3-9E289A8A5786> /Applications/Adobe After Effects CS6/*/Find_Edges.plugin/Contents/MacOS/Find_Edges
             0x12313d000 -        0x12316afff +com.adobe.ExporterQuickTimeHost.framework (6.0.0 - 6.0.0.0) <983B8701-2534-4C00-359F-3223FBDECB14> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
             0x1231a9000 -        0x1231c5ff7 +com.adobe.AfterEffects.AudioPal (??? - ???) <2686A69B-6503-8CC0-60FB-F3FC86F53562> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
             0x1231d9000 -        0x1231e5fff +com.adobe.AfterEffects.LocalizePresets (??? - ???) <F784D30F-7274-1020-DA6F-F5B8C7FA0103> /Applications/Adobe After Effects CS6/*/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
             0x1231ed000 -        0x1231fcfff +com.adobe.AfterEffects.MayaImport (??? - ???) <7EBE5E15-4A7A-90AB-A4D5-7CB5F05882F1> /Applications/Adobe After Effects CS6/*/MayaImport.plugin/Contents/MacOS/MayaImport
             0x123300000 -        0x1234e1ff7  com.apple.audio.codecs.Components (2.2 - 2.2) <1DF409FA-F561-31C5-900A-42F41B2C1856> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x123549000 -        0x12358aff7 +com.adobe.ImporterQuickTime.framework (6.0.0 - 6.0.0.0) <09E110CB-FD6D-8821-7237-F372C0CE8D52> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
             0x1235f4000 -        0x1235f8ff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x123700000 -        0x1237a4fff +com.adobe.IPPMPEGDecoder.framework (6.0.0 - 6.0.0.0) <C27E554D-7F92-EF25-515B-B56D9C87451C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
             0x1237fa000 -        0x1237fbff7 +com.adobe.AfterEffects.Gpg (??? - ???) <D1F260D4-C070-E03D-B22D-AF4750BDA7E4> /Applications/Adobe After Effects CS6/*/Gpg.plugin/Contents/MacOS/Gpg
             0x123f5f000 -        0x123fc4fff +com.adobe.AfterEffects.Escher (??? - ???) <9F6D80CF-B6BD-2505-A594-C0F5607BD929> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
             0x12508f000 -        0x125115fe7 +com.adobe.AfterEffects.AEGPDriver (??? - ???) <B750323D-FC23-0E1A-98A2-A26F26E48622> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
             0x125142000 -        0x1251d6ff7 +com.adobe.AfterEffects.AEDynamicLinkServer (??? - ???) <D006E2D5-1681-B082-1D4B-BFDC24E35E8F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
             0x12529d000 -        0x1252ccfe7 +com.adobe.AfterEffects.BrushPal (??? - ???) <9CACEFA3-4DAA-D2B5-A651-5F57F27AAE9E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
             0x1252e4000 -        0x125325fe7 +com.adobe.AfterEffects.CharPal (??? - ???) <A3F3C7B7-F8D5-EBF6-2C81-73FBAF5CEF63> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
             0x125345000 -        0x12536bfff +com.adobe.AfterEffects.InfoPal (??? - ???) <85351C02-6A8E-1191-3212-A43C28BD6A88> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
             0x125380000 -        0x1253aafff +com.adobe.AfterEffects.PaintPal (??? - ???) <D168C8D1-C96C-359B-71D5-0E9E507B1D6C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
             0x1253c2000 -        0x1253e3ff7 +com.adobe.AfterEffects.ParaPal (??? - ???) <E9FEEA9A-FC21-3568-2BBD-B4302BFFCE16> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
             0x1253f8000 -        0x125475fff +com.adobe.AfterEffects.Picasso (??? - ???) <35C1CD7D-75AA-1731-2304-21C95AC89019> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Picasso.plugin/Contents/MacOS/Picasso
             0x1254aa000 -        0x1255f4fff +com.adobe.AfterEffects.SnapCut (??? - ???) <274CC9B9-5F33-B4F7-1E9C-631535EF50B0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
             0x125622000 -        0x125646ff7 +com.adobe.AfterEffects.TimePal (??? - ???) <44361128-586F-F46F-777F-A03635333E5A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
             0x12565e000 -        0x1256a5fff +com.adobe.AfterEffects.ToolPal (??? - ???) <7B1A4A29-7796-7814-A4D1-D19A9FDA1E37> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
             0x1256ca000 -        0x1256eafff +com.adobe.AfterEffects.TrackerPal (??? - ???) <77C94AF7-6E8F-0FD4-6D29-BF17F8E3D9AA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
             0x1256fd000 -        0x1257e0fff  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <358B5B40-43B2-3F92-9FD3-DAA68806E1FF> /usr/lib/libcrypto.0.9.7.dylib
             0x125836000 -        0x1258abff7 +com.adobe.AfterEffects.Renoir (??? - ???) <696FD53F-CC73-9452-B832-5C0D68F97EC6> /Applications/Adobe After Effects CS6/*/Renoir.plugin/Contents/MacOS/Renoir
             0x125a53000 -        0x125ad6ff7 +com.adobe.AfterEffects.FlashExporter (??? - ???) <2E5E0C80-ED1A-65FC-5968-667644EF6F4A> /Applications/Adobe After Effects CS6/*/FlashExporter.plugin/Contents/MacOS/FlashExporter
             0x125afe000 -        0x125c63ff7 +com.adobe.AfterEffects.OpenEXR (??? - ???) <6D94A565-94B4-B5DE-482C-F0AA739AFFBA> /Applications/Adobe After Effects CS6/*/OpenEXR.plugin/Contents/MacOS/OpenEXR
             0x1260d6000 -        0x12610afff +com.adobe.AfterEffects.PNGIO (??? - ???) <59DF0273-80FC-A5A7-B277-A8C0AB54FF06> /Applications/Adobe After Effects CS6/*/PNGIO.plugin/Contents/MacOS/PNGIO
             0x126118000 -        0x1261f8ff7 +com.adobe.AfterEffects.PremiereProImport (??? - ???) <E959A62C-57D4-478F-64BF-CC8943327EE3> /Applications/Adobe After Effects CS6/*/PremiereProImport.plugin/Contents/MacOS/PremiereProImport
             0x126215000 -        0x126271ff7 +com.adobe.MediaCoreUI.framework (6.0.0 - 6.0.0.0) <74EE58B7-122A-6E0D-2D86-778115C608E9> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x1262dd000 -        0x1270b1ff7 +com.imagineersystems.mochashapeconverter4ae (1.0.1 - 1.0.1f3516) <2898A2EF-E33A-E726-01BD-6250AF940EF7> /Applications/Adobe After Effects CS6/*/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
             0x12727e000 -        0x12824bfff +com.imagineersystems.mochashapeconverter4ae (2.0.0 - 2.0.0f4627) <8D80F2BF-5E6D-972D-B7EA-73811721E5D8> /Applications/Adobe After Effects CS6/*/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
             0x1283dc000 -        0x12883ffe9 +com.adobe.ProImportAE (Pro Import AE version 6.00 - 6.00) <E9D54936-8C08-E083-BEA3-A6F0F577E250> /Applications/Adobe After Effects CS6/*/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
             0x1289e1000 -        0x128aacfef +com.adobe.AfterEffects.Vic (??? - ???) <1C935F63-CBD7-F4E7-E15E-910833E17845> /Applications/Adobe After Effects CS6/*/Vector Output.plugin/Contents/MacOS/Vic
             0x128afb000 -        0x128b18ff7 +com.adobe.AfterEffects.Align (??? - ???) <F1EA3FCB-A5C4-6C11-E3D4-BF1E38C8CCDA> /Applications/Adobe After Effects CS6/*/Align.plugin/Contents/MacOS/Align
             0x128b29000 -        0x128b40fff +com.adobe.AfterEffects.MetaPal (??? - ???) <E194C1C7-9168-DDC8-215B-6912EE361731> /Applications/Adobe After Effects CS6/*/MetaPal.plugin/Contents/MacOS/MetaPal
             0x128b56000 -        0x128b82fe7 +com.adobe.AfterEffects.Moka (??? - ???) <D76921D5-4FC5-B8B0-9366-6EF0A94F3525> /Applications/Adobe After Effects CS6/*/Moka.plugin/Contents/MacOS/Moka
             0x128b93000 -        0x128ba8fff +com.adobe.AfterEffects.MotionSketch (??? - ???) <2915C94E-C2D5-8C30-1369-570D1905B074> /Applications/Adobe After Effects CS6/*/MotionSketch.plugin/Contents/MacOS/MotionSketch
             0x128bb8000 -        0x128fa6ff7 +com.adobe.AfterEffects.Scripting (??? - ???) <5A49CF06-D07D-0F41-2E91-327BC1748189> /Applications/Adobe After Effects CS6/*/Scripting.plugin/Contents/MacOS/Scripting
             0x1290dd000 -        0x1291cefff +com.adobe.AdbeScriptUIFlex (ScriptUIFlex 6.2.29 - 6.2.29.20553) <0CB5E114-8871-D53C-3EC0-BE1E93CC9E7B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
             0x129252000 -        0x129278ff7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
             0x1292ec000 -        0x1292fbff7  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D30A4333-0953-394D-BB26-739937ED0BD8> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
             0x129798000 -        0x12a71dfd7 +com.adobe.ape.engine (3.3.8.19346 - 3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS/adbea peengine
             0x12bb76000 -        0x12bba0ff7  com.apple.cmio.DAL.VDC_4 (212.0 - 3199.1.1) <143A9719-FB00-3476-9863-F4D9E3769A42> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
             0x12ce42000 -        0x12ce5dfff  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <59FCE9C0-27E6-34CE-89E5-3A83B843B36C> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
             0x12ce62000 -        0x12ce83fff  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <25FF31F5-9D1E-35EB-8085-F0AC25C38DAC> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
             0x12ce87000 -        0x12ce99ff7  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <66A3625A-6918-3C14-8DF3-2F4924C389EA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
             0x12d1ec000 -        0x12d202fff +com.adobe.AfterEffects.Smoother (??? - ???) <7E5A5AE6-91CA-42AE-E88A-AFDB58D34C3F> /Applications/Adobe After Effects CS6/*/Smoother.plugin/Contents/MacOS/Smoother
             0x12d212000 -        0x12d229fff +com.adobe.AfterEffects.Wiggler (??? - ???) <6E2423F6-77BE-4BB4-F9D3-4F2E7DD3F2E2> /Applications/Adobe After Effects CS6/*/Wiggler.plugin/Contents/MacOS/Wiggler
             0x12d23a000 -        0x12d27bff7 +com.digitalanarchy.BoxCreator (1.4.1 - 1.4.1) <101DB7AF-74B8-04F1-C41A-CB26A5077979> /Library/Application Support/Adobe/*/BoxCreator.plugin/Contents/MacOS/BoxCreator
             0x12d2d6000 -        0x12d317fff +com.digitalanarchy.BoxCreator_Lite (1.4.1 - 1.4.1) <825647BB-437C-0B5D-17B2-CE83BCF02CEC> /Library/Application Support/Adobe/*/BoxCreator_Lite.plugin/Contents/MacOS/BoxCreator_Lite
             0x12d372000 -        0x12d3b1ff7 +com.digitalanarchy.CubicDistribution (1.4.1 - 1.4.1) <A7AF900A-C4AE-6E98-835C-DC6F4F2062E2> /Library/Application Support/Adobe/*/CubicDistribution.plugin/Contents/MacOS/CubicDistribution
             0x12d40b000 -        0x12d44afff +com.digitalanarchy.CubicDistribution_Lite (1.4.1 - 1.4.1) <3D4BBE12-04B9-6B0D-958E-1C3D1A49B72F> /Library/Application Support/Adobe/*/CubicDistribution_Lite.plugin/Contents/MacOS/CubicDistribution_Lite
             0x12d4a4000 -        0x12d4e6fff +com.digitalanarchy.CylinderCreator (1.4.1 - 1.4.1) <F2241273-E0DE-A2E6-C143-C49CD1201A3C> /Library/Application Support/Adobe/*/CylinderCreator.plugin/Contents/MacOS/CylinderCreator
             0x12d540000 -        0x12d582fff +com.digitalanarchy.CylinderCreator_Lite (1.4.1 - 1.4.1) <64AD2607-ED26-07D9-5E3F-803E1E7B9DBD> /Library/Application Support/Adobe/*/CylinderCreator_Lite.plugin/Contents/MacOS/CylinderCreator_Lite
             0x12d5dc000 -        0x12d61cfff +com.digitalanarchy.CylinderDistribution (1.4.1 - 1.4.1) <4B4F44F9-3FE7-2CE3-838D-20B554FF201D> /Library/Application Support/Adobe/*/CylinderDistribution.plugin/Contents/MacOS/CylinderDistribution
             0x12d676000 -        0x12d6b5fff +com.digitalanarchy.LinearAssistant (1.4.1 - 1.4.1) <78132806-DD05-0245-471B-71052A3794EE> /Library/Application Support/Adobe/*/LinearAssistant.plugin/Contents/MacOS/LinearAssistant
             0x12d70f000 -        0x12d74eff7 +com.digitalanarchy.LinearAssistant_Lite (1.4.1 - 1.4.1) <5D715E9B-9749-45BE-3E8B-E47D6706D8A6> /Library/Application Support/Adobe/*/LinearAssistant_Lite.plugin/Contents/MacOS/LinearAssistant_Lite
             0x12d7a8000 -        0x12d7e6fff +com.digitalanarchy.MatrixCreator (1.4.1 - 1.4.1) <C1C81F0A-12EF-5B6A-3AB1-DEB5E91770EC> /Library/Application Support/Adobe/*/MatrixCreator.plugin/Contents/MacOS/MatrixCreator
             0x12d83f000 -        0x12d87dff7 +com.digitalanarchy.MatrixCreator_Lite (1.4.1 - 1.4.1) <CF8DB8F0-9105-25A2-3B6E-E3C372705B7E> /Library/Application Support/Adobe/*/MatrixCreator_Lite.plugin/Contents/MacOS/MatrixCreator_Lite
             0x12d8d6000 -        0x12d914ff7 +com.digitalanarchy.PlanarAssistant (1.4.1 - 1.4.1) <BD26CEB5-0631-68D8-9D8F-5949BC5BE320> /Library/Application Support/Adobe/*/PlanarAssistant.plugin/Contents/MacOS/PlanarAssistant
             0x12d96d000 -        0x12d9adff7 +com.digitalanarchy.PyramidDistribution (1.4.1 - 1.4.1) <F4EA0CDA-2AB8-F6AE-0819-1DE2A4789AD3> /Library/Application Support/Adobe/*/PyramidDistribution.plugin/Contents/MacOS/PyramidDistribution
             0x12da07000 -        0x12da4cfff +com.digitalanarchy.SpheroidCreator (1.4.1 - 1.4.1) <4EB7B828-2706-FB85-D154-AA5953767CF5> /Library/Application Support/Adobe/*/SpheroidCreator.plugin/Contents/MacOS/SpheroidCreator
             0x12daa7000 -        0x12daecfff +com.digitalanarchy.SpheroidCreator_Lite (1.4.1 - 1.4.1) <ABC44CED-97D7-C74F-9BF0-1853C8145849> /Library/Application Support/Adobe/*/SpheroidCreator_Lite.plugin/Contents/MacOS/SpheroidCreator_Lite
             0x12db47000 -        0x12db89fff +com.digitalanarchy.SpheroidDistribution (1.4.1 - 1.4.1) <6E02107C-F2A1-09D1-28D0-B507EC56AC8F> /Library/Application Support/Adobe/*/SpheroidDistribution.plugin/Contents/MacOS/SpheroidDistribution
             0x12de00000 -        0x12de0ffef +com.adobe.AfterEffects.FreePin (??? - ???) <7BB7FD13-9589-EB93-D7AA-ADA1AFFDC9D5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
             0x12de14000 -        0x12de1afff +libMXF_SDK_GenericContainer_Binary.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_Binary.d ylib.1.3.3
             0x12de29000 -        0x12de35fff +libMXF_SDK_GenericContainer_Blind.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_Blind.dy lib.1.3.3
             0x12dec0000 -        0x12decfff7 +libMXF_SDK_GenericContainer_AIFF.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_AIFF.dyl ib.1.3.3
             0x12e331000 -        0x12e342ff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_MetaMetadata_BinaryLoader .dylib.4.4.3
             0x12e352000 -        0x12e36affb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader.dy lib.4.4.3
             0x12e37b000 -        0x12e39dff8 +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader2.d ylib.4.4.3
             0x12e3b5000 -        0x12e3e2ff8 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVC .dylib.1.3.3
             0x12e5e7000 -        0x12e6d7fe7 +com.adobe.AfterEffects.RefineMatte (??? - ???) <44B509DA-7B4B-5AF0-9353-D24B1EF76B0B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
             0x12e6f9000 -        0x12e8e5fef +libMXF_SDK.dylib.4.4.3 (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK.dylib.4.4.3
             0x12ea67000 -        0x12ea75fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MP4 .dylib.1.3.3
             0x12ea7e000 -        0x12ea8cfff +libMXF_SDK_GenericContainer_VC3.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_GenericContainer_VC3.dyli b.1.3.3
             0x12ea98000 -        0x12ea9dfff +libMXF_SDK_Modules_DataIO.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_Modules_DataIO.dylib.1.3. 3
             0x12eaa2000 -        0x12ead3ff3 +libMXF_SDK_XMLBuilder.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) <73E5E3AE-A51C-D3F8-B036-433778DB90BD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_XMLBuilder.dylib.1.3.3
             0x12eaf7000 -        0x12edc3ff6 +libxerces-c-3.0.dylib (??? - ???) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxerces-c-3.0.dylib
             0x12ef59000 -        0x12f32efef +libxqilla.5.dylib (6.0.0 - compatibility 6.0.0) /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxqilla.5.dylib
             0x12f5f5000 -        0x12f5f8ff7 +com.adobe.AfterEffects.B-c-2 (??? - ???) <0CE174B7-6FD2-795E-9E32-78FD8B3CFB39> /Applications/Adobe After Effects CS6/*/B-c-2.plugin/Contents/MacOS/B-c-2
             0x12f900000 -        0x12f91dff7 +com.adobe.AfterEffects.TurbulentDisplace (??? - ???) <A9A32918-617A-5317-2A17-9A1E60BDAE11> /Applications/Adobe After Effects CS6/*/TurbulentDisplace.plugin/Contents/MacOS/TurbulentDisplace
             0x12f928000 -        0x12f939ff7 +com.adobe.AfterEffects.Levels2 (??? - ???) <0C133290-05B6-984D-C147-144BB3F39E5B> /Applications/Adobe After Effects CS6/*/Levels2.plugin/Contents/MacOS/Levels2
             0x12f983000 -        0x12f98efe7 +com.adobe.AfterEffects.Glow (??? - ???) <7366FC4F-7DE1-0FC6-4B49-67AC5795CA27> /Applications/Adobe After Effects CS6/*/Glow.plugin/Contents/MacOS/Glow
             0x12f9b5000 -        0x12f9c4ff7 +com.adobe.AfterEffects.Curves (??? - ???) <4960F071-92C7-478A-CC63-D65D1484DFE8> /Applications/Adobe After Effects CS6/*/Curves.plugin/Contents/MacOS/Curves
             0x12f9ca000 -        0x12f9cefff +com.cycoresystems.CCfx.CrossBlur (1.0 - ???) <020A22D4-7A53-C2C4-6122-574B594C10DF> /Applications/Adobe After Effects CS6/*/CrossBlur.plugin/Contents/MacOS/CrossBlur
             0x12f9e6000 -        0x12f9f0ff7 +com.cycoresystems.CCfx.VectorBlur (1.0 - ???) <CCEA9439-52EB-CD85-5977-9BCA72D2A21C> /Applications/Adobe After Effects CS6/*/VectorBlur.plugin/Contents/MacOS/VectorBlur
             0x12fa38000 -        0x12fa4aff7 +com.adobe.AfterEffects.FractalNoise (??? - ???) <DDF64B92-2A60-C123-C4AF-3F4FF0B2B212> /Applications/Adobe After Effects CS6/*/FractalNoise.plugin/Contents/MacOS/FractalNoise
             0x12fa56000 -        0x12fa86ff7 +com.adobe.ImporterMP3.framework (6.0.0 - 6.0.0.0) <BC813528-7AC5-5361-0DA0-57E7130CDA17> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ImporterMP3.bundle/Contents/MacOS/ImporterMP3
             0x12faa1000 -        0x12fab2fff +com.adobe.AfterEffects.AutoColor (??? - ???) <2E306FE6-6A75-10E3-06D4-B54C5D7C392D> /Applications/Adobe After Effects CS6/*/AutoColor.plugin/Contents/MacOS/AutoColor
             0x12fbc1000 -        0x12fbd2fff +com.adobe.AfterEffects.AutoContrast (??? - ???) <74F4B546-F430-9683-D80B-B643DFB28770> /Applications/Adobe After Effects CS6/*/AutoContrast.plugin/Contents/MacOS/AutoContrast
             0x12ff81000 -        0x12ffe3fef +com.mainconcept.mc.demux.mp4 (9.1 - 9.1.6.4544) <2633ED80-8B39-04F6-ADA4-898432497C94> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_demux_mp4.framework/mc_demux_mp4
             0x130206000 -        0x130237ff7 +com.redgiantsoftware.Looks3_AE (2.0.7 - 2.0.7) <8B68E8AC-159D-51DE-B31A-8E0FD81B6AB0> /Library/Application Support/Adobe/*/Looks3_AE10.plugin/Contents/MacOS/Looks3_AE10
             0x130400000 -        0x13076bfef +com.redgiantsoftware.MBLooksRenderLibCPU (2.0.7 - 2.0.7) <59AB6618-2ADD-763F-6EE2-72864111A551> /Library/Frameworks/LS3RendererCPU.framework/Versions/A/LS3RendererCPU
             0x130839000 -        0x130842fe7 +com.adobe.AfterEffects.Exposure (??? - ???) <0EA52980-4D36-9EBF-7CAF-45DFE61CA178> /Applications/Adobe After Effects CS6/*/Exposure.plugin/Contents/MacOS/Exposure
             0x130b00000 -        0x130c07fff +com.TrapCode.AfterEffects.Particular (2.1.2 - 2.1.2) <3027BAEA-9821-F9D5-B0C9-B2E061327197> /Library/Application Support/Adobe/*/Particular.plugin/Contents/MacOS/Particular
             0x130c8c000 -        0x130dc2fff +com.Redgiant.AfterEffects.Trapcode.Form (2.0.2 - 2.0.2) <58B3EE54-EE57-4013-B076-EFE53ED8EE94> /Library/Application Support/Adobe/*/Form.plugin/Contents/MacOS/Form
             0x130ec6000 -        0x130f50fff +com.redgiantsoftware.trapcode.Shine (1.6.1 - 1.6.1) <2C70D5DE-02DC-4A72-90F1-9176D86712D7> /Library/Application Support/Adobe/*/Shine.plugin/Contents/MacOS/Shine
             0x131036000 -        0x131074ff7 +com.adobe.ImporterXDCAMEX.framework (6.0.0 - 6.0.0.0) <D96DC716-E4E8-5A29-FB4E-C2E349736E5A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ImporterXDCAMEX.bundle/Contents/MacOS/ImporterXDCAM EX
             0x1317ed000 -        0x131824fff +com.mainconcept.mc.dec.aac (9.1 - 9.1.6.4544) <DDD61465-8EDD-42FF-B016-4F4F936186E1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_dec_aac.framework/mc_dec_aac
             0x132280000 -        0x13256afef +com.mainconcept.mc.bc.dec.avc (9.1 - 9.1.6.4544) <EA9E11F8-635B-86EA-B4FD-17649FD2C75E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_bc_dec_avc.framework/mc_bc_dec_avc
          0x7fff67b88000 -     0x7fff67bbcbaf  dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
          0x7fff80af1000 -     0x7fff80af5fff  libdyld.dylib (195.5.0 - compatibility 1.0.0) <380C3F44-0CA7-3514-8080-46D1C9DF4FCD> /usr/lib/system/libdyld.dylib
          0x7fff80af6000 -     0x7fff80d69fff  com.apple.CoreImage (7.98 - 1.0.1) <73485E4E-1407-3913-AB3C-B54986A3E01C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
          0x7fff80d6a000 -     0x7fff80d6afff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
          0x7fff80df0000 -     0x7fff8120dff7  com.apple.SceneKit (125.3 - 125.4) <12AD6DBE-F3A3-34D6-BA01-B211BEAFD48F> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
          0x7fff8120e000 -     0x7fff812ebfef  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
          0x7fff812ec000 -     0x7fff813b3ff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <7E2E109C-A438-3EDC-A6EB-3EF634A1B28B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
          0x7fff813b4000 -     0x7fff813bffff com.apple.CommonAuth (2.2 - 2.0) <77E6F0D0-85B6-30B5-B99C-F57104DD2EBA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff813c0000 -     0x7fff81420fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff81436000 -     0x7fff814baff7  com.apple.ApplicationServices.ATS (317.11.0 - ???) <082DEAFE-8A93-3AF2-B4E5-30012E725929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff814bb000 -     0x7fff814c1fff  libGFXShared.dylib (??? - ???) <8A61FA67-EB3C-319D-AE3C-64936FB26BAC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff814c2000 -     0x7fff814edfff  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
          0x7fff814ff000 -     0x7fff81506fff  com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff81507000 -     0x7fff81542fff  libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
          0x7fff81546000 -     0x7fff815cbff7  com.apple.Heimdal (2.2 - 2.0) <FF0BD9A4-6FB0-31E3-ABFB-563FBBEC45FC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff816dd000 -     0x7fff817e4fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
          0x7fff817ef000 -     0x7fff81843fff  libFontRegistry.dylib (??? - ???) <822DD341-C735-36C9-9521-E8E98807D09D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff81891000 -     0x7fff8189efff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <528BAA66-C38C-3093-84B5-92A7832CE7BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x7fff8189f000 -     0x7fff818a1fff  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <0EBF714B-4B69-3E1F-9A7D-6BBC2AACB310> /usr/lib/system/libquarantine.dylib
          0x7fff818a2000 -     0x7fff818eeff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff818ef000 -     0x7fff818f4fff  com.apple.OpenDirectory (10.7 - 146) <A674AB55-6E3D-39AE-9F9B-9865D0193020> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff81be4000 -     0x7fff81cabff7  com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff81d1f000 -     0x7fff81e03fff  com.apple.CoreServices.OSServices (478.46 - 478.46) <70BEE269-8F4D-3FDC-B1AD-A591C0CB37E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff81e9c000 -     0x7fff81e9dff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
          0x7fff81e9e000 -     0x7fff81ef6fff  libTIFF.dylib (??? - ???) <A0FF68DE-2935-30E7-B61C-4D9D70E14AD0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x7fff81ef7000 -     0x7fff82165ff7  com.apple.QuartzComposer (5.0 - 236.7) <D556126B-3D67-3E37-82E0-D06532DE0C89> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff8217c000 -     0x7fff821deff7  com.apple.Symbolication (1.3 - 91) <B072970E-9EC1-3495-A1FA-D344C6E74A13> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fff822da000 -     0x7fff822e1fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
          0x7fff822e2000 -     0x7fff8234dff7  com.apple.framework.IOKit (2.0 - ???) <6C604894-7F61-3130-8499-20791D14577F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff8234e000 -     0x7fff8277bfff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff8277c000 -     0x7fff827bbfff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff827bc000 -     0x7fff827e2fff  com.apple.framework.familycontrols (3.0 - 300) <93828BC1-3D83-3A93-99A5-F0E7951AFC6C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff827e3000 -     0x7fff827e9fff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
          0x7fff827ea000 -     0x7fff833f0ff7  com.apple.AppKit (6.7.3 - 1138.47) <CAF5783F-F80B-30E7-929F-BBA6D96C5C44> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff834dc000 -     0x7fff834ddfff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
          0x7fff8384c000 -     0x7fff8394cfff  com.apple.QuickLookUIFramework (3.2 - 500.16) <0BACF8C4-5A7B-31EE-B4AA-3CCF8615C9A8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff8394d000 -     0x7fff8394dfff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x7fff8394e000 -     0x7fff83c37ff7  com.apple.security (7.0 - 55148.1) <E9C46204-1336-3D90-BC67-5162FC7079D2> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff84154000 -     0x7fff841eaff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff841eb000 -     0x7fff841f6ff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
          0x7fff84235000 -     0x7fff8423aff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
          0x7fff8423b000 -     0x7fff84244ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
          0x7fff84288000 -     0x7fff8438dfff  libFontParser.dylib (??? - ???) <759645F2-8CB1-358C-AF41-BA3797CD0F60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff84489000 -     0x7fff844c2fe7  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
          0x7fff844c3000 -     0x7fff84503ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <5328C0AB-F169-3786-A3EC-9E82E960CAAF> /usr/lib/libcups.2.dylib
          0x7fff84504000 -     0x7fff8456cff7  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <DFD8F4DE-3B45-3A2E-9CBE-FD8D5DD30923> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff8456d000 -     0x7fff8456dfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff8456e000 -     0x7fff845b0ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
          0x7fff845b1000 -     0x7fff8461afff  com.apple.coreui (1.2.2 - 165.10) <F427BF39-3E01-3DC6-A63D-BFC50FE6C72E> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff84637000 -     0x7fff84638fff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
          0x7fff84810000 -     0x7fff8486cff7  com.apple.HIServices (1.21 - ???) <9645CFA8-63BE-3A0D-A636-56D9827E6C8C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff84873000 -     0x7fff84b95fe7  com.apple.JavaScriptCore (7534.56 - 7534.56.6) <675725F8-37C4-3B80-ADB0-7B6AE908A908> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff84b96000 -     0x7fff8517afff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff8517b000 -     0x7fff85305fff  com.apple.QTKit (7.7.1 - 2330) <4B5363D4-4854-342F-8B95-DE6559075B46> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff8603e000 -     0x7fff8609bff7  com.apple.QuickLookFramework (3.2 - 500.16) <46017A4B-9E2B-329C-A8D9-2C11DE6C1A47> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff860e2000 -     0x7fff860f8ff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <BF4EC1CC-C998-3529-A69F-765774C66A6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff860f9000 -     0x7fff86107ff7  libkxld.dylib (??? - ???) <C2FC894F-3716-32C3-967E-6AD5E2697045> /usr/lib/system/libkxld.dylib
          0x7fff8611d000 -     0x7fff86122fff  libGIF.dylib (??? - ???) <8763F67F-A881-30B6-B20E-D395B4D9FD58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x7fff8615c000 -     0x7fff8619cfff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
          0x7fff8619d000 -     0x7fff8622fff7  com.apple.CorePDF (3.1 - 3.1) <F81F99A9-7FF6-3A6A-92C7-78C76BA35777> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff86230000 -     0x7fff86231fff  libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
          0x7fff86232000 -     0x7fff86252fff  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <1DDC0B0F-DB2A-34D6-895D-E5B2B5618946> /usr/lib/system/libsystem_kernel.dylib
          0x7fff862ae000 -     0x7fff86353fff  com.apple.ink.framework (1.4 - 110) <F93B76B3-E57C-3805-B20D-03717A3F91DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff863ab000 -     0x7fff86426ff7  com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff86427000 -     0x7fff86529fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
          0x7fff8652a000 -     0x7fff8653eff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff8656b000 -     0x7fff8661eff7  com.apple.CoreText (220.20.0 - ???) <0E979362-15E4-3955-BF54-B5961361D1CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x7fff8661f000 -     0x7fff86624fff  libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
          0x7fff86644000 -     0x7fff86660ff7  com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff86668000 -     0x7fff8666efff  IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff8668b000 -     0x7fff866d1fff  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
          0x7fff86726000 -     0x7fff8673cfff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff8673d000 -     0x7fff8684afff  libJP2.dylib (??? - ???) <5BE8CFA7-00C2-3BDE-BC20-5FF6DC18B415> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
          0x7fff86c27000 -     0x7fff86c2afff  libCoreVMClient.dylib (??? - ???) <934D0D11-C34F-3C06-A352-21BB8FFE9774> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff86c2b000 -     0x7fff86c56ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
          0x7fff86c57000 -     0x7fff86c5cfff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
          0x7fff86c89000 -     0x7fff86cfffff  libc++.1.dylib (28.1.0 - compatibility 1.0.0) <DA22E4D6-7F20-3BEA-9B89-2FBA735C2EE1> /usr/lib/libc++.1.dylib
          0x7fff86d00000 -     0x7fff86d04fff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <2B1215A0-1B43-39C3-B4F4-392D71D08FFA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff86d05000 -     0x7fff86d35ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <3FC86118-7553-38F7-8916-B329D2E94476> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff86e33000 -     0x7fff86e36fff  com.apple.AppleSystemInfo (1.0 - 1) <111B6F69-3FBD-3860-BCF8-1DF02D9BED28> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff86e37000 -     0x7fff86f1be5f  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
          0x7fff86f1c000 -     0x7fff86f45fff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x7fff86f46000 -     0x7fff86f6ffff  com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff86f70000 -     0x7fff86f73fff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x7fff86f78000 -     0x7fff87291fff  com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff87292000 -     0x7fff87296fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
          0x7fff87297000 -     0x7fff872a9ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
          0x7fff87345000 -     0x7fff8738cff7  com.apple.CoreMedia (1.0 - 705.78) <F6EA2328-FD3E-3057-80C7-C9845837F863> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff8738d000 -     0x7fff874c3fff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff876fe000 -     0x7fff87c07ff7  com.apple.RawCamera.bundle (3.14.0 - 646) <75A96BFC-1832-808B-F430-C4C9379C5A98> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff87c08000 -     0x7fff87c33ff7  com.apple.CoreServicesInternal (113.17 - 113.17) <B1DF81C3-9C23-3BAE-9DE8-21EAFEEB97B8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff87c34000 -     0x7fff87c39fff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
          0x7fff883b2000 -     0x7fff883e7fff  com.apple.securityinterface (5.0 - 55022.4) <09EC371E-0B6E-3849-A6C9-F8E9DB17BBCD> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff885eb000 -     0x7fff8865bfff  com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff8865c000 -     0x7fff8865ffff  com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff88712000 -     0x7fff88724ff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
          0x7fff8882e000 -     0x7fff88841ff7  libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
          0x7fff88842000 -     0x7fff888c5fef  com.apple.Metadata (10.7.0 - 627.32) <38735923-2EB5-3133-BE36-BDD65A7E47DB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff888c6000 -     0x7fff889a5ff7  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <FFA7532B-336A-3F0B-9AB9-2A35B56ED887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x7fff889ed000 -     0x7fff88a28fff  com.apple.LDAPFramework (3.2 - 120.2) <A2675243-9122-308D-A5C8-9C1C4FE7639D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff88a5a000 -     0x7fff88e8dff7  com.apple.VideoToolbox (1.0 - 705.78) <7F115540-88CF-3087-951A-7073F7D58F4D> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff88e8e000 -     0x7fff89090fff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
          0x7fff890a0000 -     0x7fff893ccff7  com.apple.HIToolbox (1.9 - ???) <B7D2A06B-7BE5-3355-BF7D-8139100B9B97> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff893cd000 -     0x7fff8940efff  com.apple.QD (3.40 - ???) <47674D2C-BE88-388E-B1B0-03F08BFFE5FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff8941c000 -     0x7fff89423ff7  com.apple.CommerceCore (1.0 - 17) <3894FE48-EDCE-30E9-9796-E2F959D92704> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x7fff8942c000 -     0x7fff895cbff7  com.apple.QuartzCore (1.7 - 270.4) <97E20A5F-652B-3E85-8C46-DCB777248ECD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff895cc000 -     0x7fff89841ff7  com.apple.imageKit (2.1.2 - 1.0) <5BAA52A9-F359-31E4-8109-74EBCEB626B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff8986c000 -     0x7fff898abff7  libGLImage.dylib (??? - ???) <49BB4404-68F1-3839-A5C9-983405B59F52> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff898ac000 -     0x7fff898acfff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff898ad000 -     0x7fff898b3fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff898b4000 -     0x7fff89bd0fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <6F99A26B-788F-37B9-860F-508906EC06D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff89bd3000 -     0x7fff89bdbfff  libsystem_dnssd.dylib (??? - ???) <D9BB1F87-A42B-3CBC-9DC2-FC07FCEF0016> /usr/lib/system/libsystem_dnssd.dylib
          0x7fff89bdc000 -     0x7fff89bdeff7  com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff89bdf000 -     0x7fff89befff7  com.apple.opengl (1.7.7 - 1.7.7) <0CA11278-746C-353A-923B-BCC0047190C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff89bf0000 -     0x7fff89c1dff7  com.apple.opencl (1.50.69 - 1.50.69) <57939F7D-3626-30E2-883D-8A7CCB3F8763> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff89c1e000 -     0x7fff89c35fff  com.apple.CFOpenDirectory (10.7 - 146) <E71AE4A2-F72B-35F2-9043-9F45CF75F11A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff89c36000 -     0x7fff8a3cafef  com.apple.CoreAUC (6.16.11 - 6.16.11) <3D40FEA5-AFE7-3752-A52E-D0F80304320A> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff8a3cb000 -     0x7fff8a4d7fff  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff8a4d8000 -     0x7fff8a52aff7  libGLU.dylib (??? - ???) <E2EF0336-3A5F-3532-AEB0-6CCF04851B72> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff8a537000 -     0x7fff8a5d8ff7  com.apple.LaunchServices (480.33 - 480.33) <45EF2044-3396-3910-9B5B-C8F7777D5F56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff8a5d9000 -     0x7fff8a673ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff8a674000 -     0x7fff8a691fff  libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
          0x7fff8a7d5000 -     0x7fff8a7e3fff  com.apple.NetAuth (3.1 - 3.1) <FE7EC4D7-5632-3B8D-9094-A0AC8D60EDEE> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fff8a7f4000 -     0x7fff8a842fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
          0x7fff8a84f000 -     0x7fff8a852ff7 com.apple.securityhi (4.0 - 1) <7146CB8E-B754-3B0E-A74E-77E9138A81C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff8a853000 -     0x7fff8a8a7ff7  com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
          0x7fff8a8a8000 -     0x7fff8a8a8fff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8a8a9000 -     0x7fff8a8aaff7  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
          0x7fff8a8dd000 -     0x7fff8ac86fef  com.apple.MediaToolbox (1.0 - 705.78) <A4DF8258-0CB9-3244-BF12-3AD02B1952B0> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff8ac93000 -     0x7fff8ac97ff7  com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff8ad0c000 -     0x7fff8ad66ff7  com.apple.ImageCaptureCore (3.0.3 - 3.0.3) <12C722EE-3A13-3937-ABDF-EDC922F4C299> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff8ae39000 -     0x7fff8af92fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <0AD8197C-1BA9-30CD-98F1-4CA2C6559BA8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff8af93000 -     0x7fff8afb7fff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff8afc1000 -     0x7fff8b95ec9f  com.apple.CoreGraphics (1.600.0 - ???) <1DB9C92C-DFA8-36ED-B513-998134462148> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x7fff8b95f000 -     0x7fff8b961fff  libCVMSPluginSupport.dylib (??? - ???) <1C73D331-6F6C-3872-A011-1C41FBF49F2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff8b962000 -     0x7fff8b962fff  com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff8b963000 -     0x7fff8b9f6ff7  com.apple.PDFKit (2.6.3 - 2.6.3) <49BF9CDC-E902-3CAC-9C04-3302545907D5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff8b9f7000 -     0x7fff8b9f8fff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fff8b9f9000 -     0x7fff8ba1dfff  com.apple.RemoteViewServices (1.4 - 44.1) <EA3837DF-A3A3-37FF-AE11-D50048D5F21A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fff8ba1e000 -     0x7fff8ba3efff  libPng.dylib (??? - ???) <F4D84592-C450-3076-88E9-8E6517C7EF33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x7fff8ba3f000 -     0x7fff8bba6fff  com.apple.CFNetwork (520.4.3 - 520.4.3) <31D7A595-375E-341A-8E97-21E73CC62E4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x7fff8bba7000 -     0x7fff8bbb5fff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
          0x7fff8bc20000 -     0x7fff8bdf4ff7  com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff8bdf5000 -     0x7fff8bdf5fff  com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff8bdf6000 -     0x7fff8bf0ffff  com.apple.DesktopServices (1.6.3 - 1.6.3) <20812ECE-CACC-3D44-8108-025EF6B45C14> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff8bf10000 -     0x7fff8bf2dff7  com.apple.openscripting (1.3.3 - ???) <BDCCCBA9-F440-30BD-8378-FAB5AF685A5D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff8bf2e000 -     0x7fff8bf38ff7  liblaunch.dylib (392.38.0 - compatibility 1.0.0) <6ECB7F19-B384-32C1-8652-2463C1CF4815> /usr/lib/system/liblaunch.dylib
          0x7fff8bf39000 -     0x7fff8bf3fff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
          0x7fff8bf40000 -     0x7fff8bf7afe7  com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff8c006000 -     0x7fff8c059fff  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <E3FE9B47-2276-3316-B2D2-85784AD2D9B3> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff8c05a000 -     0x7fff8c0d0fff  com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff8c0e0000 -     0x7fff8c0e0fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff8c199000 -     0x7fff8c199fff  com.apple.Carbon (153 - 153) <C1A30E01-E113-38A0-95CA-99360F92A37A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff8c19a000 -     0x7fff8c1b4fff  com.apple.CoreMediaAuthoring (2.0 - 891) <C7A92C52-AD9F-3CF1-86D5-C0714118935C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff8c1b5000 -     0x7fff8c1e8ff7  com.apple.GSS (2.2 - 2.0) <971395D0-B9D0-3FDE-B23F-6F9D0A2FB95F> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff8c1e9000 -     0x7fff8c28bfff  com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff8c28c000 -     0x7fff8c2ddff7  com.apple.CoreMediaIO (212.0 - 3199.1.1) <D8C364AF-A1E8-3215-ABF5-188B50A80B18> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff8c2de000 -     0x7fff8c2f3fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff8c2f4000 -     0x7fff8c30bfff  com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff8c30c000 -     0x7fff8c30cfff  com.apple.quartzframework (1.5 - 1.5) <2C13AE76-C86B-3D48-A583-121689190F74> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff8c30d000 -     0x7fff8c318ff7  com.apple.DisplayServicesFW (2.5.4 - 323.3) <5E7F7A88-9313-3C31-87BD-80F3361DA338> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff8c486000 -     0x7fff8c487ff7  libsystem_sandbox.dylib (??? - ???) <96D38E74-F18F-3CCB-A20B-E8E3ADC4E166> /usr/lib/system/libsystem_sandbox.dylib
          0x7fff8cb75000 -     0x7fff8cc6afff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
          0x7fff8cf9c000 -     0x7fff8cfa7ff7  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff8cfc5000 -     0x7fff8d038fff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
          0x7fff8d09c000 -     0x7fff8d0aeff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
          0x7fff8d0af000 -     0x7fff8d0cefff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
          0x7fff8d0cf000 -     0x7fff8d0f7fff  com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fff8d0f8000 -     0x7fff8d5bffff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
          0x7fff8d5c0000 -     0x7fff8d5edfff  com.apple.quartzfilters (1.7.0 - 1.7.0) <CE1EDD58-7273-38F9-AD33-871A8BA7ABF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff8d614000 -     0x7fff8d621ff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <3373D310-3B10-3DD1-B754-B7B138CD448D> /usr/lib/libbz2.1.0.dylib
          0x7fff8d622000 -     0x7fff8d84cfe7  com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff8d84d000 -     0x7fff8d84ffff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff8d850000 -     0x7fff8d894ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <22B2A10A-34B5-3787-88C9-B2722FE79504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff8d895000 -     0x7fff8d992ff7  com.apple.avfoundation (2.0 - 180.40) <ED3DCB15-7E88-34FD-9E56-4ECAD10A6E7E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff8d993000 -     0x7fff8d9c0fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <7BEBB139-50BB-3112-947A-F4AA168F991C> /usr/lib/libSystem.B.dylib
          0x7fff8d9c1000 -     0x7fff8d9d0ff7  libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 8
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 2475
          thread_create: 1
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=578.2M resident=328.6M(57%) swapped_out_or_unallocated=249.6M(43%)
      Writable regions: Total=326.1M written=92.4M(28%) resident=164.0M(50%) swapped_out=0K(0%) unallocated=162.1M(50%)
      REGION TYPE                      VIRTUAL
      (null) (reserved)                   128K        reserved VM address space (unallocated)
      ATS (font support)                 32.1M
      CG backing stores                  6388K
      CG image                             28K
      CG raster data 320K
      CG shared images                   3416K
      CoreGraphics                         16K
      CoreServices                       3112K
      IOKit                              3432K
      IOKit (reserved)                     64K        reserved VM address space (unallocated)
      MALLOC                            124.6M
      MALLOC guard page                    48K
      Memory tag=240                     32.0M
      Memory tag=242                       12K
      Memory tag=243                       12K
      Memory tag=249                      156K
      Memory tag=251                        8K
      OpenGL GLSL                        1372K
      OpenGL GLSL (reserved)              128K        reserved VM address space (unallocated)
      STACK GUARD                        56.2M
      Stack                              39.0M
      VM_ALLOCATE                        89.7M
      __CI_BITMAP                          80K
      __DATA                             44.0M
      __IMAGE                             528K
      __LINKEDIT                        136.2M
      __NV_CUDA                             4K
      __RC_CAMERAS                        248K
      __TEXT                            442.0M
      __UNICODE                           544K
      mapped file                       108.2M
      shared memory                       560K
      TOTAL                               1.1G
      TOTAL, minus reserved VM space      1.1G
      Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.4 GHz, 8 GB, SMC 1.69f3
      Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 1024 MB
      Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
      Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334448302D4348392020
      Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334448302D4348392020
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.4.20)
      Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
      Network Service: Wi-Fi, AirPort, en1
      Serial ATA Device: Hitachi HTS727575A9E362, 750.16 GB
      Serial ATA Device: MATSHITADVD-R   UJ-8A8
      USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
      USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
      USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
      USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
      USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 4
      USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
      USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
