4 Replies Latest reply on Jul 3, 2012 8:09 AM by sadensmol
    List dataprovider refresh
    sadensmol Level 1
      Hello. I faced an issue on  AIR3.3. Is it bug? Please help me and advise.
      Very simple application for test
      <fx:Script>
                          <![CDATA[
                                    import mx.collections.ArrayCollection;
                                    import mx.events.FlexEvent;
                                    import spark.collections.Sort;
                                    private var testCollection:ArrayCollection = new ArrayCollection();
                                    protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void {
                                                        testCollection.addItem("111");
                                                        testCollection.addItem("222");
                                                        testCollection.addItem("333");
                                                        var sort:Sort = new Sort();
                                                        sort.compareFunction = compareFunctionSort;
                                                        testCollection.sort = sort;
                                    private function compareFunctionSort (obj1:Object, obj2:Object,fields:Array = null) :int {
                                              return 0;
                                    protected function button1_clickHandler(event:MouseEvent):void {
                                              testCollection.refresh();
      </fx:Script>
      <s:layout>
        <s:VerticalLayout/>
        </s:layout>
                <s:List dataProvider="{testCollection}" itemRenderer="TestItemRenderer">
        <s:layout>
                                    <s:TileLayout id="usersListLayout" horizontalGap="5" verticalGap="5" horizontalAlign="left" verticalAlign="top" />
        </s:layout>
        </s:List>
                <s:Button label="1" click="button1_clickHandler(event)"/>
      Here is an item renderer:
      <s:BorderContainer >
        <s:layout>
        <s:VerticalLayout/>
        </s:layout>
                          <s:Label text="{data}"/>
                          <s:Label text="{DebugUtils.getObjectMemoryHash(videoC)}"/>
        <mx:UIComponent id="videoC"/>
      </s:BorderContainer>
      After clicking on Button collection going to refresh. But always 0 returns from sort function!!!
      And what i see ( please check images )
      Initially:
      After click:
      wtf?
        • 1. Re: List dataprovider refresh
          tinylion_uk Level 2
          Your sort function isn’t doing anything.
          You aren’t actually doing a compare in there
          You need to compare the inputs and return a value dependant on the code in the method. You are telling it to do nothing.
          You need to follow the following rules
          Return value
          -1, if a should appear before b in the sorted sequence
          0, if a equals b
          1, if a should appear after b in the sorted sequence
          • 2. Re: List dataprovider refresh
            tinylion_uk Level 2
            And before writing WTF, try writing ‘google’
            Just do a search for arrayCollection compareFunction
            Lots of examples of how the compareFunction works.
            • 3. Re: List dataprovider refresh
              sadensmol Level 1
              Thank you for quick answer.
              Sorry for that hasty expression but there is not clearly behaivor.
              If i invoke collection.refresh() and no sort is needed for my collection it returns 0 in any combinations of items. So i get the same result incorrect visualisation of list.
              Going to ask google about arrayCollection compareFunction...
              • 4. Re: List dataprovider refresh
                sadensmol Level 1
                So Ive rewritten my sort function in according with first result from google
                http://stackoverflow.com/questions/1602385/sorting-an-arraycollection-in-flex
                                              private function compareFunctionSort (a:Object, b:Object,fields:Array = null) :int {
                                                        var cmpArray:Array = ["111", "222", "333"];
                                                        var aValue:Number = cmpArray.indexOf(a);
                                                        var bValue:Number = cmpArray.indexOf(b);
                                                        if(aValue == bValue)
        return 0;
                                                        if(aValue > bValue)
        return 1;
                                                        return -1;
                but got the same result. Visualization works incorrectly!!!
                Please have a look at the attached video
