1 Reply Latest reply on Jul 3, 2012 7:19 AM by etune
    Buffer performance issue with MediaPlayer object and DynamicStreamingResource
    etune Level 1
        Steps to reproduce:
      1. Create two instances of MediaPlayerSprite.
      2. On the first one, use a single URLResource. On the other, use DynamicStreamingResource.
      3. When seeking to different points in the video, monitor the bufferLength property on MediaPlayer.
      Expected Results:
      I would expect the buffer to fill at the same rate.
      Actual Results:
      The buffer fills much slower when using DynamicStreamingResource as compared to URLResource.
      Here is an example: http://www.cecentral.com/tmp/presenter-osmf-dsr-test/
      The video on the left is a single stream, while the video on the right is a dynamic stream. As you play each video, click around the progress bar at the bottom. Take note of how long it takes for each buffer to fill.
      Any ideas?
        • 1. Re: Buffer performance issue with MediaPlayer object and DynamicStreamingResource
          etune Level 1
          Here is the relevant code for the example above:
          mps = new MediaPlayerSprite();
          mps.mediaPlayer.bufferTime = 8;
          if ( DYNAMIC_STREAM == false ) {
              mps.resource = new URLResource("rtmp://s2hpiuntp64m3.cloudfront.net:80/cfx/st/_definst_/ mp4:526/526-01-0750.f4v");
          } else {
              var resource:DynamicStreamingResource = new DynamicStreamingResource("rtmp://s2hpiuntp64m3.cloudfront.net:80/cfx/ st/_definst_/");
              var vector = new Vector.<DynamicStreamingItem>(3);
              vector [ 0 ] = new DynamicStreamingItem ( "mp4:526/526-01-0250.f4v" , 250 );
              vector [ 1 ] = new DynamicStreamingItem ( "mp4:526/526-01-0500.f4v" , 500 );
              vector [ 2 ] = new DynamicStreamingItem ( "mp4:526/526-01-0750.f4v" , 750 );
              resource.streamItems = vector;
              mps.resource = resource;
