1. Re: Can't open Dreamweaver CS4
Zabeth69 Jul 4, 2012 5:30 PM (in response to quality11)Check to see if Dreamweaver is still indicated as running in Processes when you reboot the computer. If there are leftover instances, it will not open again. This is all pseudo-knowledge. I have had programs that do this to me, though I can't remember it ever being DW. If you kill all the Dreamweaver Processes, shut down, then restart, Dreamweaver might launch for you.
2. Re: Can't open Dreamweaver CS4
quality11 Jul 4, 2012 7:18 PM (in response to Zabeth69)Thanks much for your reply. I actually restarted it several times after I ended the process from task manager. I just tried restarting it in Safe Mode > Networking then used Rkill to stop all programs from running except the OS ones and then ran Malabytes. Malabytes didn't find anything. I restarted in normal mode and DW is still not opening.
3. Re: Can't open Dreamweaver CS4
NanHarbison Sep 28, 2012 9:48 AM (in response to quality11)I just started having this same problem. I can't start it from start->programs. Then I could start it by opening a document that I had open recently in Dreamweaver. But I had to go into processes first and stop it. Sometimes I have to repeat this over and over again, try to open a DW document, it won't open, stop the process, try again. I just had to do it about 6 times before it would open..
5. Re: Can't open Dreamweaver CS4
quality11 Sep 28, 2012 11:46 AM (in response to puni100)I tried reinstalling it and that didn't work either.
