4 Replies Latest reply on Jul 16, 2012 7:24 AM by Studio1540
    Change fonts using AppleScript
    Studio1540
      I want to change every occurance of a typeface to another. In QuarkXPress, the syntax was:
      set the font of every character of every text box where font is "Zapf Dingbats" to "Times"
      I've tried the same logic and the find/change commands but have not had any luck ... can anyone guide me on this one?
        • 1. Re: Change fonts using AppleScript
          Muppet Mark Level 5
          You need to look for applied font
          tell application "Adobe InDesign CS5"
            activate
            --get name of fonts
                    set someFont to some font
                    tell the active document
                              set applied font of every character of every story to someFont
                    end tell
          end tell
          • 2. Re: Change fonts using AppleScript
            Studio1540 Level 1
            Hi Mark,
            Thanks for the reply, but this doesn't do what I'm looking for. In this example, every font of every story is changed. What I'm looking to do is change only the fonts where the applied font is "Zapf Dingbats" to "Times" ...
            I'm sure this is possible, but for the life if me, I can't figure it out.
            Here's what I've tried, with some degree of success:
            tell application "Adobe InDesign CS5.5"
                activate
                if not (exists active document) then
                    display dialog "No document is open." with icon 2
                else
                    set myDocument to active document
                    set myClass to class of active spread of layout window 1 of myDocument as string
                    if myClass is "master spread" then
                        display dialog "This script does not work on master pages. Switch to a regular layout page and try again." buttons {"Cancel"} default button 1 with icon 2
                    else
                        set user interaction level of script preferences to never interact
                        set find text preferences to nothing
                        set change text preferences to nothing
                        set find grep preferences to nothing
                        set change grep preferences to nothing
                        set find object preferences to nothing
                        set find glyph preferences to nothing
                        set change glyph preferences to nothing
                        set properties of find glyph preferences to {applied font:"Zapf Dingbats", font style:"Regular", glyph ID:"81"}
                        set properties of change glyph preferences to {applied font:"Times", font style:"Regular", glyph ID:"81"}
                        change glyph
                        set user interaction level of script preferences to interact with all
                    end if
                end if
            end tell
            During runtime, I get an AppleScript error that states: "Adobe InDesign CS5.5 got an error: Invalid Find Glyph"
            Here's the kicker ... if I set all my options in the Find/Change dialog window and comment out the following lines, it works, so I must be close:
            • 3. Re: Change fonts using AppleScript
              SuperMacGuy Level 2
              Your glyph ID can't be text, it has to be a number, so no quote marks.
              {applied font:"Times", font style:"Regular", glyph ID:81}
              • 4. Re: Change fonts using AppleScript
                Studio1540 Level 1
                ah ha! That did the trick, and I should have realized that I was using a string and not an integer ... thanks, Guy
