7 Replies Latest reply on Aug 30, 2006 8:32 AM by Coldfusionstudent
    join/from/where/ combine queries
    Coldfusionstudent Level 1
      Hello I have this query in my cf program
      First query
      SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR, TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR,
      TLA_PROP.STR_FRAC_NBR_RNG_END, TLA_PROP.STR_DIR_CD, TLA_PROP.STR_NM, TLA_PROP.STR_SFX_CD, TLA_PROP.STR_SFX_DIR_CD,
      TLA_PROP.STR_UNIT_TYP_CD, TLA_PROP.UNIT_NBR, TLA_PROP.UNIT_NBR_RNG_END, TLA_PROP.ZIP_CD, TLA_PROP.ZIP_CD_SFX, TLA_PROP.CNCL_DIST_NBR,
      TLA_PROP.PLAN_AREA_NBR, TLA_PROP.ZONE_REG_CD, TAPLC.PROJ_DESC_TXT, TCASE.CASE_ID, TCASE.CASE_NBR, taplc.aplc_id
      FROM TLA_PROP INNER JOIN ((TAPLC INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID) INNER JOIN TLOC ON TAPLC.APLC_ID = TLOC.APLC_ID) ON TLA_PROP.PROP_ID = TLOC.LOC_ID
      WHERE TCASE.CASE_NBR Like '%HPOZ%' and TCASE.CASE_NBR = '#form.caseNbr#'
      '#form.caseNbr#' is the input field on my input box.
      I am a beginner and I am not used to joins and joins in the from class
      Second query
      In toad I use this query
      Select
      tcase.case_id
      ,Tcase.case_NBR
      ,tcntct.CNTCT_ID as ownerInformation
      ,tcntct.CO_BUSN_NM, tcntct.FRST_NM, tcntct. LST_NM
      ,tcntct_owner.cntct_id as repInformation
      ,tcntct_owner.CO_BUSN_NM
      , tcntct_owner. FRST_NM
      , tcntct_owner.LST_NM
      ,Tref_plan_area.plan_area_desc
      ,tcase_req.case_req_id
      ,tcase_req.case_req_typ_cd
      ,tcase_req.sys_user_id
      ,tla_prop.pin
      ,tla_prop.cncl_dist_nbr
      ,tla_prop.PLAN_AREA_NBR
      ,tla_prop.str_nbr
      ,tla_prop.STR_FRAC_NBR
      ,tla_prop.STR_DIR_CD
      ,tla_prop.str_nm
      ,tla_prop.STR_SFX_CD
      ,tla_prop.STR_SFX_DIR_CD
      ,tla_prop.STR_UNIT_TYP_CD
      ,tla_prop.UNIT_NBR
      ,tla_prop.ZIP_CD
      ,tla_prop.ASSR_PRCL_NBR
      ,TLA_PROP.ZONE_REG_CD
      from
      tloc, tla_prop , tcase, tref_plan_area, tcase_req,tcntct_aplc, tcntct, tcntct_aplc tcntct_aplc_owner, tcntct tcntct_owner /*tcntct_tla_prop,tcntct*/
      where
      tla_prop.prop_id = tloc.loc_id
      and
      tla_prop.plan_area_nbr = tref_plan_area .plan_area_NBR
      and
      tloc.aplc_id = tcase.aplc_id
      and
      tcase.case_id = tcase_req .case_id
      and
      tcase_req.CASE_req_typ_CD like '%HPOZ%'
      and
      tla_prop.prop_id = tcntct_tla_prop.PROP_ID(+)
      and
      tcntct_tla_prop.CNTCT_ID = tcntct.CNTCT_ID(+)
      and
      tcase.aplc_id = tcntct_aplc.APLC_ID(+)
      and
      tcntct_aplc.cntct_id = tcntct.cntct_id(+)
      and
      (tcntct_aplc.CNTCT_TYP_CD = 'A' or tcntct_aplc .cntct_typ_cd is null)
      and
      tcase.aplc_id = tcntct_aplc_owner .aplc_id(+)
      and
      tcntct_aplc_owner.cntct_id = tcntct_owner.cntct_id (+)
      and
      (tcntct_aplc_owner.cntct_typ_cd = 'R' or tcntct_aplc_owner.cntct_typ_cd is null)
      group by
      tcase.case_id,
      Tcase.case_NBR,
      ,tla_prop.pin
      ,tla_prop.str_nbr
      ,tla_prop.str_nm
      ,tla_prop.UNIT_NBR
      ,tla_prop.ZIP_CD
      ,tla_prop.ASSR_PRCL_NBR,
      tcntct.CO_BUSN_NM
      , tcntct.FRST_NM
      , tcntct.LST_NM,
      , tcntct_owner.FRST_NM
      order by
      to get
      Tref_plan_area.plan_area_desc or simply get plan_area_desc. This is done through a join tla_prop.plan_area_nbr = tref_plan_area .plan_area_NBR .
      I am still using the first query ( the very first query above) but there are joins in the from clause.
      My question here is I am still trying to get plan_area_desc and want to incorporate some syntax from the second query to the first query.
      What I did that was a mistake was ( error)
      Added the table from and put this tla_prop.plan_area_nbr = tref_plan_area .plan_area_NBR .
      In the where clause. It did not work. Can any one help me on how I can still get the tref_plan_area .plan_area_NBR .
      What do I add to the first query
        • 1. Re: join/from/where/ combine queries
          paross1 Level 2
          Did you try adding something like this to your first query?
          INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR
          plus the desired fields from this table in your SELECT?
          Phil
          • 2. Re: join/from/where/ combine queries
            to get the plan_area_nbr
            i need to join
            but to get the
            i need to join
            but to get the
            tloc.loc_id
            i need to join
            like the joins below in the 2nd query
            where
            and
            and
            and
            again ultimately, i need the Tref_plan_area.plan_area_desc
            is this all i need to join in the from clause in the first query to get Tref_plan_area.plan_area_desc
            as you indicated
            thanks
            again
            • 3. join/from/where/ combine queries
              I have added to this query below. But I got this error shown below. Can you help me with my query ??
              SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR, TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR,Tref_plan_area.plan_area_desc
              FROM TLA_PROP INNER JOIN ((TAPLC INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID) INNER JOIN TLOC ON TAPLC.APLC_ID = TLOC.APLC_ID) ON TLA_PROP.PROP_ID = TLOC.LOC_ID INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR
              In the select clause I have added
              And in the
              From clause I have added
              I got this error
              Error Executing Database Query.
              ORA-00923: FROM keyword not found where expected
              The error occurred in --------.cfm: line 10
              8 : <!----TLA_PROP INNER JOIN ((TAPLC INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID) INNER JOIN TLOC ON TAPLC.APLC_ID = TLOC.APLC_ID) ON TLA_PROP.PROP_ID = TLOC.LOC_ID----->9 : 10 : WHERE TCASE.CASE_NBR Like '%HPOZ%' and TCASE.CASE_NBR = '#form.caseNbr#'11 : </cfquery>12 :
              SQL SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR, TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR,Tref_plan_area.plan_area_desc TLA_PROP.STR_FRAC_NBR_RNG_END, TLA_PROP.STR_DIR_CD, TLA_PROP.STR_NM, TLA_PROP.STR_SFX_CD, TLA_PROP.STR_SFX_DIR_CD, TLA_PROP.STR_UNIT_TYP_CD, TLA_PROP.UNIT_NBR, TLA_PROP.UNIT_NBR_RNG_END, TLA_PROP.ZIP_CD, TLA_PROP.ZIP_CD_SFX, TLA_PROP.CNCL_DIST_NBR, TLA_PROP.PLAN_AREA_NBR, TLA_PROP.ZONE_REG_CD, TAPLC.PROJ_DESC_TXT, TCASE.CASE_ID, TCASE.CASE_NBR, taplc.aplc_id FROM TLA_PROP INNER JOIN ((TAPLC INNER JOIN TCASE ON TAPLC.APLC_ID = TCASE.APLC_ID) INNER JOIN TLOC ON TAPLC.APLC_ID = TLOC.APLC_ID) ON TLA_PROP.PROP_ID = TLOC.LOC_ID INNER JOIN tref_plan_area ON tla_prop.plan_area_nbr = tref_plan_area.plan_area_NBR WHERE TCASE.CASE_NBR Like '%HPOZ%' and TCASE.CASE_NBR = 'DIR-2004-4269-HPOZ-CCMP'
              DATASOURCE
              VENDORERRORCODE 923
              SQLSTATE 42000
              • 4. join/from/where/ combine queries
                And in the
                I got this error
                DATASOURCE
                VENDORERRORCODE 923
                SQLSTATE 42000
                Please try the following:
                • 5. Re: join/from/where/ combine queries
                  paross1 Level 2
                  Does this work, by any chance?
                  TCASE.CASE_NBR,
                  TLA_PROP.STR_NBR,
                  TLA_PROP.STR_NM,
                  TLA_PROP.UNIT_NBR,
                  TLA_PROP.ZIP_CD,
                  TCASE.CASE_ID,
                  TCASE.CASE_NBR,
                  taplc.aplc_id
                  FROM TLA_PROP
                  AND TCASE.CASE_NBR = 'DIR-2004-4269-HPOZ-CCMP'
                  Phil
                  • 6. Re: join/from/where/ combine queries
                    paross1 Level 2
                    ...or perhaps this?
                    TCASE.CASE_NBR,
                    TLA_PROP.STR_NBR,
                    TLA_PROP.STR_NM,
                    TLA_PROP.UNIT_NBR,
                    TLA_PROP.ZIP_CD,
                    TCASE.CASE_ID,
                    TCASE.CASE_NBR,
                    taplc.aplc_id
                    FROM TLA_PROP
                    INNER JOIN TLOC ON TLA_PROP.PROP_ID = TLOC.LOC_ID
                    INNER JOIN TAPLC ON TLOC.APLC_ID = TAPLC.APLC_ID
                    Phil
                    • 7. Re: join/from/where/ combine queries
                      thanks
                      it works great!!!!
                      just dont know if i really needed the parenthesis on the inner join part.
                      anyway thanks
                      you can reply again if you want to anser the ( parenthesis on the inner join part.
                      thanks
                      again
