2 Replies Latest reply on Jul 4, 2012 4:11 AM by Peter Spier
    Indesign 5.5, 5 problems with plug ins
    jouelrie Level 1
      I've spent most of my evening trying to figure out how to open a file from a new client. I was told they were on CS5, which I have. However on receiving files today, I get an error that states I am missing sharedcontent.indesignplugin.
      Research indicates they really gave me 5.5 files. Even though get info shows the files as CS5. Is this true it can be 5.5 even though it is labeled CS5 and also I see the files need to be converted to idml. Well I planned to work on this tomorrow and it's the July 4th holiday. I don't know anyone with 5.5.
      If I try the CS6 trial, will the files be workable from 5.5 and then I need to backsave? Is this a good option or not suggested? To do this I have to borrow a computer with snow leopard or whatever the animal is after mine. So it involoves a lot of work. I don't want to try it if it's not a good working solution.
        • 1. Re: Indesign 5.5, 5 problems with plug ins
          John Hawkinson Level 5
          Hello, jouelrie!
          It is worth taking the time to write your sentences carefully. It's a little tough to interpret your core question:
          If your question if whether the Finder can say that a file is CS5 when it is not, then the answer is yes. The Finder will select an icon based on the file extension. (It may have additional information, but it may not.) The Finder's icons cannot be trusted for version determination.
          Also, this sentence question could be a lot more clear.
          If you are asking whether CS6 files are editable in CS5.5, the answer is no.
          Analagous to CS5 and CS5.5, if you wish to work between CS6 and CS5.5, you must save the file as IDML when working in CS6.
          I think few would call it "a good option."
          You haven't told us what version you are using, but presumably it's not Snow Leopard, so it is presumably either Tiger (10.4) or Leopard (10.5). Providing this information is a good idea.
          You should be able to install the CS5.5 trial by following the instructions at http://prodesigntools.com/adobe-cs5-5-direct-download-links.html.
          Read the "Very Important Instructions"; do not skip directly to the links.
          • 2. Re: Indesign 5.5, 5 problems with plug ins
            I'll convert a single file for you this morning if I get it in the next few hours. I'm sending you an upload link via PM.
