Hello.
I'm using ColdFusion 9 and openejb 4.0.0. Have a problem with calling ejb from cfm page. Stuck at hello world : )
Code:
<CFOBJECT
action=create
name=ctx
type="JAVA"
class="javax.naming.Context">
<!--- Create the Properties object and call an explicit constructor--->
<CFOBJECT
action=create
name=prop
type="JAVA"
class="java.util.Properties">
<!--- Call the init method (provided by cfobject)
to invoke the Properties object constructor. --->
<cfset prop.init()>
<!--- Specify the properties These are required for a remote server only --->
<cfset prop.put(ctx.INITIAL_CONTEXT_FACTORY, "org.apache.openejb.client.RemoteInitialContextFactory")>
<cfset prop.put(ctx.PROVIDER_URL, "localhost:4201")>
<CFOBJECT
action=create
name=initContext
type="JAVA"
class="javax.naming.InitialContext">
<cfset initContext.init(prop)>
<cfset home = initContext.lookup("HelloBeanRemote")>
initContext.lookup causes an unknown error, browser just shows HTTP 500 (Internal Server Error)
However, this code on java works just perfect:
package org.acme;
import java.util.Properties;
import javax.naming.InitialContext;
import javax.naming.Context;
import javax.rmi.PortableRemoteObject;
public class HelloClient
public static void main(String[] args) throws Exception
Properties props = new Properties();
props.put(Context.INITIAL_CONTEXT_FACTORY,"org.apache.openejb.client.RemoteInitialContextFactory");
props.put(Context.PROVIDER_URL,"127.0.0.1:4201");
Context ctx = new InitialContext(props);
Object ref = ctx.lookup("HelloBeanRemote");
Hello h = (Hello)PortableRemoteObject.narrow(ref,Hello.class);
String result = h.sayHello();
int summa = h.sum(37, 5);
System.out.println(result);
System.out.println(summa);
So I created a java class named HelloInterface which does the whole thing and returns string recieved from bean. Tested it with java, works fine, but calling it from CF gets to HTTP 500 too. Code:
<cfobject
action="create"
type="java"
class="org.acme.HelloInterface"
name="hello">
<cfset msg = hello.getHello()>
[<cfoutput>#msg#</cfoutput>]
Message was edited by: Blackmore111
Solved. Should've added one more library to CF Classpath - javax.ejb.jar
Please kindly mark it as solved. Just might be of help to somebody else.
