1 Reply Latest reply on Sep 3, 2006 10:13 PM by flexsavvy
    Buffer progress bar for streaming FLV
    clsimeone Level 1
      Hi All,
      I've been trying to create a "Buffering" progress bar for streaming FLV (via FMS) with the <mx:videoDisplay> component. But, the videoDisplay is not firing "progress" events for some odd reason. So I changed my strategy and started using the netStream object.
      The video is streaming via FMS, but the netStream "bytesLoaded" and "bytesTotal" properties are always zero. Any ideas what I may be doing wrong. The code's below.
      Also, it would be great if anyone can show how to pull this of with the <mx:videoDisplay> component as well!!!
      Thanks!
      Chris
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns="*" layout="vertical" horizontalAlign="left" creationComplete="onCreationComplete();">
      <mx:Script>
      <![CDATA[
      import mx.events.VideoEvent;
      import myComponents.*;
      import flash.events.*;
      import flash.net.*;
      import flash.media.Video;
      import mx.controls.*;
      import mx.core.UIComponent;
      private var nc:NetConnection;
      private var stream:NetStream;
      private var fmsUrl:String;
      private var flvName:String;
      private var video:Video;
      private var loaded_interval:Number;
      NetConnection.defaultObjectEncoding = flash.net.ObjectEncoding.AMF0;
      public function onCreationComplete():void
      nc = new NetConnection();
      configureListeners(nc);
      var videoHolder:UIComponent = new UIComponent();
      videoHolder.setActualSize(700, 525);
      video = new Video();
      configureListeners(video);
      videoHolder.addChild(video);
      video.x = 0;
      video.y = 0;
      fmsUrl = "rtmp://localhost/test_video";
      flvName = "testVideo";
      theBox.addChild(videoHolder);
      nc.connect(fmsUrl);
      private function configureListeners(dispatcher:IEventDispatcher):void
      dispatcher.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSecurityError);
      dispatcher.addEventListener(AsyncErrorEvent.ASYNC_ERROR, onAsyncError);
      dispatcher.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
      dispatcher.addEventListener(ProgressEvent.PROGRESS, onProgress);
      dispatcher.addEventListener(Event.ENTER_FRAME, onEnterFrame);
      private function connectStream():void
      if (stream)
      stream.close();
      stream = new NetStream(nc);
      configureListeners(stream);
      video.attachNetStream(stream);
      stream.bufferTime = 10;
      stream.play(flvName);
      stream.client = this;
      private function onNetStatus(event:NetStatusEvent):void
      trace("onNetStatus: " + event);
      switch (event.info.code)
      case "NetConnection.Connect.Success":
      trace("NetConnection.Connect.Success");
      connectStream();
      break;
      case "NetConnection.Connect.Failed":
      trace("NetConnection.Connect.Failed");
      break;
      case "NetStream.Buffer.Empty":
      trace("NetStream.Buffer.Empty");
      break;
      case "NetStream.Buffer.Full":
      trace("NetStream.Buffer.Full");
      break;
      case "NetStream.Play.StreamNotFound":
      trace("stream not found: " + flvName);
      break;
      private function onEnterFrame(event:Event):void
      if(stream == null) return;
      var loadpct:Number = stream.bytesLoaded / stream.bytesTotal * 100;
      trace("onEnterFrame: " + event + " Loaded: " + loadpct + "%");
      private function onProgress(event:ProgressEvent):void
      trace("onProgress: " + event);
      private function onSecurityError(event:SecurityErrorEvent):void
      trace("onSecurityError: " + event);
      private function onAsyncError(event:AsyncErrorEvent):void
      trace("onAsyncError: " + event);
      public function onMetaData(info:Object):void
      trace("metadata: duration=" + info.duration + " width=" + info.width + " height=" + info.height + " framerate=" + info.framerate);
      public function onCuePoint(info:Object):void
      trace("cuepoint: time=" + info.time + " name=" + info.name + " type=" + info.type);
      public function showMessage(msg:String):void
      trace("showMessage: " + msg + "\n");
      </mx:Script>
      <mx:HBox id="theBox" borderStyle="solid"></mx:HBox>
      </mx:Application>
