0 Replies Latest reply on Jul 4, 2012 8:12 AM by MikkM
    Presenter vid and audio don't play in a Shared Connect Window
    MikkM Level 1
      Used Adobe Presenter 7.06 to add audio to a PowerPoint 2010 deck, and successfully published to a Connect 8 Content library.  The slides are meant to change after every 5 secs, unless there is audio on a slide, in which  case the time may be longer. The first slide does not have audio.
      If I Share the content in a window, and attempt to play, the slides change and the audio can be heard my end - but if I press the Play button on the Presenter share at the audience end the slides stay still, and no audio is heard.
      If I manually click the Advance Slide Forward button the Presenter share, then each slide does move at the audience end.
      Any ideas? Thanks
