8 Replies Latest reply on Aug 20, 2015 3:11 AM by Pickory
    Html snippet insertion
    _Seb_
      Im trying to insert some HTML code into a rectangle (a complex "<p>Hi</p>") via scripting. It works,... but I need to manually do an "edit HMTL" in Indesign interface in order to refresh the display.
      Any idea ?
      Thanks.
        • 1. Re: Html snippet insertion
          _Seb_ – I can confirm this problem.
          But you could set  the viewDisplaySetting to a different value and then again to the old value:
          myRectangle.htmlItems[0].htmlContent = "<b>New HTML</b>";
          app.documents[0].windows.everyItem().viewDisplaySetting = ViewDisplaySettings.OPTIMIZED;
          app.documents[0].windows.everyItem().viewDisplaySetting = ViewDisplaySettings.HIGH_QUALITY;
          Uwe
          • 2. Re: Html snippet insertion
            Or, maybe a better idea:
            //Set the visibility of the HtmlItem:
            myRectangle.htmlItems[0].visible = false;
            myRectangle.htmlItems[0].visible = true;
            Uwe
            • 3. Re: Html snippet insertion
              Harbs. Level 6
              I'm not seeing this on my end...
              • 4. Re: Html snippet insertion
                _Seb_ Level 1
                Try both solutions without success. But I perform this action with actionscript (CSExtensionBuilder) maybe I'll try with pure javascript.
                • 5. Re: Html snippet insertion
                  @_Seb_ – does the display refresh and showing the new HTML-preview, if you go to another page and come back?
                  Uwe
                  • 6. Re: Html snippet insertion
                    Pickory Level 3
                    Hello,
                    Did you solve this one? I seem to have the same problem. It works if I create the HTML item by hand.
                        if ( r.htmlItems.length == 0 )
                            r.htmlItems.add ( );
                        r.htmlItems[0].htmlContent = theHTML;
                        r.htmlItems[0].visible = false;
                        r.htmlItems[0].visible = true;
                    P.
                    • 7. Re: Html snippet insertion
                      Hi Pickory,
                      just tried again with CC 2014.2 where we can get a real good preview in the EPUB Interactivity Preview Panel.
                      The "preview" you are after, the one in the HTML frame, is no preview at all, I think, just a strange representation of rendered HTML.
                      Or not. I experimented a bit without success and finally thought, let's do it the UI way and came up with a strange example.
                      Somehow the contents of an already removed frame I did with ExtendScript or by UI (I can't remember exactly) travelled over partly to a new HTML frame I did in the UI.
                      I did not change its contents. It's just the default one as you can see in the EPUB Interactivity Preview Panel.
                      Uwe
                      • 8. Re: Html snippet insertion
                        Pickory Level 3
                        Hello Uwe
                        I haven’t fully test this.
                            r.contentType = ContentType.GRAPHIC_TYPE;
                        P.
