2 Replies Latest reply on Jul 6, 2012 1:47 AM by HeikoSpallek
    Change Parameters for Default Transition
    HeikoSpallek
      any idea how to change the default settings for a transition? Not on a single instance basis--I know that, but when I use the "Apply default transition" menu item under "Sequence" a Push gets applied in my case--I have defined push as my default video transition. But, it is always applied with 1 second as length for the transition, but I ALWAYS want to have it 8 frames only. How do I avoid having to go through the entire timeline and change each single instance to 8 frames?
      Thanks for any real solution or work around!
      CU
      Heiko
