2 Replies Latest reply on Mar 31, 2008 8:26 AM by maniac9999
    Deleting stylesheets in RH X5
    maniac9999 Level 1
      Does anyone know if I can delete a stylesheet in RH HTML X5? I've been importing some HTML files that automatically "grab" an existing stylesheet - one for each file. Once the stylesheet is in the project, I can change the topic properties to "link" to a different stylesheet and topic template, but I'm not able to remove the stylesheet that came in with the import.
      Jim
        • 1. Re: Deleting stylesheets in RH X5
          Hi Jim
          Once you change the association, the style sheet should no longer be listed in the project. Unless, of course, something else is using it.
          If you simply want to delete it from the disk, you will need to open Windows Explorer and kill it from there.
          Cheers... Rick
          • 2. Re: Deleting stylesheets in RH X5
            maniac9999 Level 1
            Thanks Rick,
            Right after I posted my topic, I went in and noticed just what you stated - that as soon as I changed the association, the stylesheet "disappeared" in RoboHelp.
            Do you know if there's any way to edit the import parameters so that RH does NOT grab the associated stylesheet during an import?
            Thanks again,
            Jim
