• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cfgridupdate - does it really work?
Participant ,
Feb 12, 2008 Feb 12, 2008
I have had the hardest time getting cfgridupdate to work. Has anyone had success with it? I am using CF7.
The first error was due to not passing the primary key. I've done this with a display="no" option on the cfgridcolumn property of the primary key variable.
The, I started receiving errors that the data type does not match.
Is there another alternative to cfgrid/cfgridupdate? I like the way it displays all the data similar to a database output. It could potentially make modifications and inserts much easier - if it worked.
TOPICS
Advanced techniques
Views
344
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Feb 14, 2008 Feb 14, 2008
LATEST
You could try the Ajax approach ( I know you are on MX7 but that shouldnt stop you 🙂 )
Check out some of the examples on EXTJS there is also a custom tag implementation that a couple of different people have done that allows you to use the EXT library without having to have MX8 (or at least should)
I have done an updatable grid using the EXTJS library and it also looks good!
Votes
Translate
Translate
Report
Report
Resources
Documentation
