1. Re: Where do I update to RAW 6.1?
Curt Y Jul 8, 2012 8:42 AM (in response to I Cast)You want to update to last version of 6.x which I believe is 6.7.
Click on Adobe above and go to downloads.
You can also update by clicking on Updates in PS Help. PS may also need an update.
2. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 9:03 AM (in response to Curt Y)Curt:
I think I didn’t pose my question correctly. I’m looking for the RAW processing software inside CS5.
3. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 9:11 AM (in response to Curt Y)In my version of CS5 RAW I donot have the following options:
Bridge Lens Corrections: no pull down options
Crop: no Crop Constrain to Image option
4. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 8, 2012 9:13 AM (in response to I Cast)Curt's advice is correct.
As stated, do one of the following things:
- Help - Updates in Photoshop, and have it automatically update you to Camera Raw 6.7 (which is the latest 6.x version, and you do want the latest).
- If the above doesn't work, visit one of these pages, depending on whether you have a PC or Mac:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5373
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5372
-Noel
5. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 10:03 AM (in response to Noel Carboni)I tried that download and got the error message: "windows can't open that zip file' ???
6. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 10:32 AM (in response to I Cast)Third attempt same error message????????
Photoshop Camera Raw 6.7 Update
Update is not applicable. Error Code: U44M2P28
7. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 8, 2012 10:46 AM (in response to I Cast)Clear your browser cache and try the download again. I just downloaded it and there's no problem with the zip file on the Adobe site.
Why your system should tell you the update is not applicable is beyond me. Have you succeeded installing the update at one time in the past?
What do you see when, in Photoshop, you choose Help - About Plug-in...? Do you see only one entry for Camera Raw?
-Noel
8. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 3:05 PM (in response to Noel Carboni)Clear your browser cache and try the download again. I just downloaded it and there's no problem with the zip file on the Adobe site.
No luck??????????
Only one plug in….6.0.0.170
NO.
9. Re: Where do I update to RAW 6.1?
Curt Y Jul 8, 2012 3:12 PM (in response to I Cast)You can go to Program Files/COMMON Files/Adobe/Plug-ins/CSx/File Formats which gives you Camera Raw.8bi
Delete the .8bi file and try downloading 6.7 again.
Do you have the latest version of CS5? Download locatons in previous posts.
10. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 7:03 PM (in response to Curt Y)I copied this from CS5 system info pull down
Adobe Photoshop Version: 12.0 (12.0x20100115) X64
Operating System: Windows NT
Version: 6.1 Service Pack 1
Camera Raw 6.0
I’ll try your recommendation on deleting .8bi file.
11. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 6:59 PM (in response to Curt Y)I deleted the .8bi file and try to run 6.7 and got the same error message.
I purchased my Adobe PS CS5 Extended from an eBay seller. The CD box has a 2010 date.
It states that some of the GPU accelerated features require Shader Model 3.0 and OpenGL2.0 graphics support, whatever that is??
I running Windows 7 with 64 bit.
Mystified.
12. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 8, 2012 7:19 PM (in response to I Cast)Oh lord. There are almost no legitimate Photoshop sales on eBay.
-Noel
13. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 7:31 PM (in response to Noel Carboni)Noel:
Would you please expand on your statement. I wanted to move up from CS4 so I could work with Cannon G11 & G12 raw files and Nikon NEF raw files.
The CS5 install went through as the key was still usuable. Are there older versions of CS5 that do not have RAW 6.1 on the CD? Does that explain why some functions found in the Kelby CS5 book are not in my CS5 operating system?
Just trying to get by on my retirement budget.
14. Re: Where do I update to RAW 6.1?
station_two Jul 8, 2012 7:33 PM (in response to I Cast)I Cast wrote:
…Adobe Photoshop Version: 12.0 (12.0x20100115) X64…
Oh, brother! No one, absolutely no one should be running that version of Photoshop. You should be in either version 12.0.4 or 12.1.
Before you update Photoshop and fix that, there's no point in your messing around with ACR.
15. Re: Where do I update to RAW 6.1?
station_two Jul 8, 2012 7:40 PM (in response to I Cast)Forget about ACR 6.1 already! The version that gets installed by default from a legitimate Photoshop install DVD is ACR 6.0, and that is obsolete from the get go. ACR 6.1 has been obsolete for years too. You need to update ACR to version 6.7, and nothing else.
Before you can do that, though, you need to update Photoshop to 12.0.4 or 12.1, no ifs or buts.
16. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 7:46 PM (in response to station_two)PS 12.0.4 or 12.1 OK, thanks for that info. How do I accomplish that upgrade?
17. Re: Where do I update to RAW 6.1?
station_two Jul 8, 2012 7:48 PM (in response to I Cast)Through the Updates or Check for Updates menu item in the Help menu in Photoshop.
18. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 7:55 PM (in response to station_two)Tried that and the only update was Adobe Extension Manager CS5 5.0 Update
19. Re: Where do I update to RAW 6.1?
I Cast Jul 8, 2012 7:59 PM (in response to I Cast)downloaded 12.0.4 and the install failed after extracting the .exe file.
20. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 8, 2012 7:59 PM (in response to I Cast)What's got me worried is the possibility that this is an illegitimate version of Photoshop CS5, which can't properly be updated by the online updates Adobe has published.
I don't really know how to check, outside of verifying your serial number with the Adobe customer support people.
-Noel
21. Re: Where do I update to RAW 6.1?
station_two Jul 8, 2012 8:02 PM (in response to Noel Carboni)Noel Carboni wrote:
What's got me worried is the possibility that this is an illegitimate version of Photoshop CS5, which can't properly be updated by the online updates Adobe has published…
That's very possible.
22. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 8, 2012 8:06 PM (in response to I Cast)There is one possibility for you to get a recent version of Camera Raw.8bi into the proper location (from where you deleted it)...
See this thread for where to find the files within the Camera Raw updater package that become Camera Raw.8bi on your system. With Windows XP you'll only be interested in the 32 bit one:
http://forums.adobe.com/message/4491476
-Noel
23. Re: Where do I update to RAW 6.1?
station_two Jul 8, 2012 8:07 PM (in response to I Cast)I Cast,
Does your copy of Photoshop say either "Portable" or "Lite" anywhere on it? If so, it's an illegal copy.
24. Re: Where do I update to RAW 6.1?
PECourtejoie Jul 9, 2012 2:03 AM (in response to I Cast)Hello, if you constantly get bad ZIPs or EXEs, try to use another browser for your downloads.
Disable your download accelerator software if you use any.
Try to use another Zip expander, like stuffit, 7zip, or . (Wich one are you using?)
25. Re: Where do I update to RAW 6.1?
I Cast Jul 9, 2012 6:43 AM (in response to Noel Carboni)The DVD packaging wrapper and the DVD label look legit. Suposively this DVD came from a graphics company which had deregistered the software.
I pasted the Camera Raw.8bi into an external hard drive before I deleted that file. When that idea failed and I reinserted the file back into it's proper folder.
I'll try your next suggestion and get back to you.
Thanks for all the help.
26. Re: Where do I update to RAW 6.1?
I Cast Jul 10, 2012 7:51 AM (in response to Noel Carboni)I followed your instruction until I got to the part where you "copy the numbered resource file inside to the appropriate Camera raw .8bi file." When I try to open the .8bi file by dbl clk it opens PS. How do you get inside the .8bi file to insert the 1002 file?
I also downloaded Adobe Camera raw-6.7- mul-AdobeUpdate.zip. When I bblclk on the AdobePatchInstaller.exe I got the message that the message that all files had to be unzipped first, which I did. So what did I just accomplish to fix the Camera Raw 6.1 problem?
Confused again
27. Re: Where do I update to RAW 6.1?
ssprengel Jul 10, 2012 8:58 AM (in response to I Cast)What are you doing? There is nothing about copying a file from inside a zip to a location on your hard-drive that involves double-clicking on a Camera Raw.8bi file, and there is nothing in Noel’s linked instructions that says to double-click on the AdobePatchInstaller.exe, especially when it is inside the zip-file, still, which is what the error message is telling you not to do. If you want to run the Adobe Patch Installer you need to extract all the files from that update zip into a folder of your choosing and then run the patch installer exe.
If you still want to try Noel’s process for manually placing the new ACR from within the updater zip to its proper location on your hard drive, here is my versions of the instructions, with the double-clicks explicitly stated:
Double-click on the AdobeCameraRaw-6.7-mul-AdobeUpdate.zip to open it in Windows Explorer.
Double-click on the payloads folder inside the zip to show its contents in Windows Explorer.
Double-click on the first folder you see under payloads, the one without x64 and without Profile in the name, this is for the 32-bit version of Camera RAW.8bi
Within that folder you’ll see an Assets2_1.zip.
Right-click on Assets2_1.zip and choose Copy.
Go to your Desktop and create a new folder, then open that folder and paste the Assets2_1.zip into that folder.
From within that new folder, double-click on Assets2_1.zip to open it in Windows Explorer.
Within that zip file, find the 1003 file that is a little over 20MB in size, much larger than anything else.
Right-click on it and choose Copy.
Open a new Windows Explorer window and navigate to the folder in Noel’s instructions:
C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
Right-click in that folder and choose Paste.
You should now see a 1003 file in that folder.
If you already have a Camera Raw.8bi file, rename it changing the .8bi to .bak.
Rename the 1003 file to Camera Raw.8bi.
Now the 32-bit version of Camera Raw.8bi has been updated to 6.7.
Return to your original ZIP file and now click down into the folder under payloads that has an x64 in the name.
Follow the same steps for unzipping the Assets2_1.zip and such, just copy the 1002 file into 64-bit version of Camera Raw.8bi, which Noel says is:
C:\Program Files\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
That should be it.
It would be preferable to get the Adobe Patch Installer to run and complete successfully because it will also install the lens and camera profiles for your camera, but without those you’ll still have the basic raw conversion occurring and the Adobe Standard profile.
Since you purchased your PS-CS5 from eBay, the packaging may be original from Adobe and never opened—you can download the software as a trial for free and it will be basically the same thing as on the DVD, but the serial number is really the only important thing, and if Adobe has never certified that serial number as being shipped or solder or Adobe finds out the package was stolen or any number of other things that could have happened that aren’t a normal sale from Adobe to the customer, then Adobe could eventually blacklist the serial number and PS will eventually just stop working with a message that it is not a legit.
28. Re: Where do I update to RAW 6.1?
Curt Y Jul 10, 2012 9:00 AM (in response to I Cast)Did you delete the old .8bi file before downloading the 6.7 file? Believe the process should install in correct spot. If not you will have to copy un-zipped file to the Program Files/COMMON Files/Adobe/Plug-ins/CSx/File Formats location.
This is location for 64 bit version. THere should also be a 32 bit version, but that goes in the 32 bit location, same address but (X86)
29. Re: Where do I update to RAW 6.1?
I Cast Jul 10, 2012 9:38 AM (in response to Curt Y)I did not delete the .8bi file, I moved it to my external hard drive in case I needed it in case a MURPHY arrived.
30. Re: Where do I update to RAW 6.1?
I Cast Jul 10, 2012 10:18 AM (in response to ssprengel)Thank you for your technical help. Worked like a charm. As you have guessed, I'm a rank amatuer working inside the "tree." I never tresspass there unless desperate for a repair, etc.
This is agreat forum and my hat is off to ya'll.
31. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 10, 2012 10:30 AM (in response to I Cast)I take it you can now see the functions you need in Camera Raw - that's great news! Thank you for following up and letting us know you got it working.
-Noel
32. Re: Where do I update to RAW 6.1?
I Cast Jul 13, 2012 6:58 AM (in response to ssprengel)RATS!!! When I open a file in RAW it reverts to Camera Raw 6.0. I tried rebooting but no go. Should I go back into the tree and delete the file I renamed .8bak ?
33. Re: Where do I update to RAW 6.1?
Noel Carboni Jul 13, 2012 7:45 AM (in response to I Cast)As we discussed before, if you are seeing the file open in Camera Raw 6.0, you have another copy of Camera Raw.8bi on your system somewhere that Photoshop is finding. There is no other way this could occur.
-Noel
34. Re: Where do I update to RAW 6.1?
Curt Y Jul 13, 2012 8:21 AM (in response to I Cast)You should do a search for "camera raw.8bi"
Click on Start type in phrase, then click more results and search computer. You should get several hits as you have both 64 and 32 bit ACR, and may have more than one CS version. So look at it closely and see if there are any duplicates as it will not list the version (ACR 6.0)
