1. Re: Why would an AS 3 File cause Flash to crash?
Suhas Yogin Jul 10, 2012 2:22 AM (in response to nana2841084)Hello,
Request you to provide us more information per the FAQ here to help investigate your issue further.
Regards,
Suhas Yogin
2. Re: Why would an AS 3 File cause Flash to crash?
nana2841084 Jul 10, 2012 8:33 AM (in response to Suhas Yogin)Hi Suhas,
Here is the crash report. Running Flash 5 Professional on an IMac 8,1 10.6.8. All of the current Flash Updates are installed and there are no problems with any other aspects of Flash or any other application. As I mentioned Flash will allow the initial save of a new .as document, but any attempt to overwrite results in a crash. A "save-as" with another name does not. I do not recall doing anything out of the ordinary or making any big changes before this started happening.
Thank you for your help.
Process: Adobe Flash CS5 [373] Path: /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5 Identifier: com.adobe.flash Version: 11.0.2.489 (11.0.2) Code Type: X86 (Native) Parent Process: launchd [131]
Date/Time: 2012-07-10 11:27:36.162 -0400 OS Version: Mac OS X 10.6.8 (10K549) Report Version: 6
Interval Since Last Report: 83981 sec Crashes Since Last Report: 5 Per-App Interval Since Last Report: 41953 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: 46F4CA55-B07C-45DD-9332-33D31F0B559F Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000010
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0000000000c83d64
Java VM: Java HotSpot(TM) Client VM (20.8-b03-424 mixed mode macosx-x86)
Current thread (000000003b801c00): JavaThread "main" [_thread_in_native, id=-1608452800, stack(00000000bf800000,00000000c0000000)]
Stack: [00000000bf800000,00000000c0000000]
Java Threads: ( => current thread )
000000003b89e800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1319268352, stack(00000000b14d9000,00000000b15d9000)]
000000003b89d800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1320325120, stack(00000000b13d7000,00000000b14d7000)]
000000003b89c800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1321381888, stack(00000000b12d5000,00000000b13d5000)]
000000003b89b800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1326518272, stack(00000000b0def000,00000000b0eef000)]
0000000041015800 JavaThread "Finalizer" daemon [_thread_blocked, id=-1327575040, stack(00000000b0ced000,00000000b0ded000)]
0000000041014800 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1328631808, stack(00000000b0beb000,00000000b0ceb000)]
=>000000003b801c00 JavaThread "main" [_thread_in_native, id=-1608452800, stack(00000000bf800000,00000000c0000000)]
Other Threads:
0000000041012000 VMThread [stack: 00000000b0936000,00000000b0a36000] [id=-1331470336]
000000003b8a8000 WatcherThread [stack: 00000000b15db000,00000000b16db000] [id=-1318211584]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14784K, used 5904K [000000005c860000, 000000005d860000, 000000005d860000)
eden space 13184K, 44% used [000000005c860000, 000000005ce24360, 000000005d540000)
from space 1600K, 0% used [000000005d540000, 000000005d540000, 000000005d6d0000)
to space 1600K, 0% used [000000005d6d0000, 000000005d6d0000, 000000005d860000)
concurrent mark-sweep generation total 49152K, used 0K [000000005d860000, 0000000060860000, 0000000064860000)
concurrent-mark-sweep perm gen total 12288K, used 4425K [0000000064860000, 0000000065460000, 0000000068860000)
Code Cache [000000003de3f000, 000000003ded8000, 000000003fe3f000)
total_blobs=204 nmethods=83 adapters=65 free_code_cache=32934912 largest_free_block=0
Virtual Machine Arguments:
JVM Args: -Djava.awt.headless=true -Xmx128m
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 4096M, Free = 1458M
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.adobe.flash 0x00c83d64 drover::dialogs::SmoothCurvesEveDialog::~SmoothCurvesEveDialog() + 5052 1 com.adobe.flash 0x00c85e23 JNIBridge::InitBridge() + 6025 2 com.adobe.flash 0x005d9341 CScriptMDIFrame::GetRuntimeClass() const + 9523 3 com.adobe.flash 0x00d5fc95 std::vector<CPropertyPage*, std::allocator<CPropertyPage*> >::push_back(CPropertyPage* const&) + 5161 4 com.adobe.flash 0x005da4b9 CScriptMDIFrame::GetRuntimeClass() const + 13995 5 com.adobe.flash 0x00d5f28a std::vector<CPropertyPage*, std::allocator<CPropertyPage*> >::push_back(CPropertyPage* const&) + 2590 6 com.adobe.flash 0x005d7551 CScriptMDIFrame::GetRuntimeClass() const + 1859 7 com.adobe.flash 0x00d35ddb CMiniFrameWnd::~CMiniFrameWnd() + 993 8 com.adobe.flash 0x00d5ef4c std::vector<CPropertyPage*, std::allocator<CPropertyPage*> >::push_back(CPropertyPage* const&) + 1760 9 com.adobe.flash 0x00d12d13 non-virtual thunk to CButtonOwnerDrawImpl::~CButtonOwnerDrawImpl() + 9541 10 com.adobe.flash 0x00d7dfd4 non-virtual thunk to CStdioFile::~CStdioFile() + 20822 11 com.adobe.flash 0x00d7d283 non-virtual thunk to CStdioFile::~CStdioFile() + 17413 12 com.adobe.flash 0x00d79d2b non-virtual thunk to CStdioFile::~CStdioFile() + 3757 13 com.adobe.flash 0x00d79bf6 non-virtual thunk to CStdioFile::~CStdioFile() + 3448 14 com.adobe.flash 0x00f1af5d CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::~CList() + 4453 15 com.adobe.flash 0x00d7d283 non-virtual thunk to CStdioFile::~CStdioFile() + 17413 16 com.adobe.flash 0x00102667 non-virtual thunk to CFlashDocTemplate::ActivateAccelerators(TAcceleratorVector) + 3787 17 com.adobe.flash 0x00d79d2b non-virtual thunk to CStdioFile::~CStdioFile() + 3757 18 com.adobe.flash 0x00d79bf6 non-virtual thunk to CStdioFile::~CStdioFile() + 3448 19 com.adobe.flash 0x002f992a non-virtual thunk to CCustomizeAcceleratorsDialog::ListenToMessage(long, void*) + 6198 20 com.adobe.flash 0x001025fb non-virtual thunk to CFlashDocTemplate::ActivateAccelerators(TAcceleratorVector) + 3679 21 com.adobe.flash 0x00d8b883 CDC::~CDC() + 6255 22 com.adobe.flash 0x00d66ceb non-virtual thunk to CScrollViewImpl::ListenToMessage(long, void*) + 2961 23 com.adobe.flash 0x00e083de non-virtual thunk to LCarbonApp::MakeSelfSpecifier(AEDesc&, AEDesc&) const + 698 24 com.apple.HIToolbox 0x99039c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 25 com.apple.HIToolbox 0x99038ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 26 com.apple.HIToolbox 0x99038d55 SendEventToEventTargetWithOptions + 58 27 com.apple.HIToolbox 0x9906d60b ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1957 28 com.apple.HIToolbox 0x9903a080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 29 com.apple.HIToolbox 0x99038ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 30 com.apple.HIToolbox 0x9905b7f3 SendEventToEventTarget + 52 31 com.apple.HIToolbox 0x991e4c17 ToolboxEventDispatcher + 86 32 com.apple.HIToolbox 0x991e4d4f RunApplicationEventLoop + 243 33 com.adobe.flash 0x00d6f4fe non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302 34 com.adobe.flash 0x00d45d1f CTimerImpl::~CTimerImpl() + 297 35 com.adobe.flash 0x00d45dcb CTimerImpl::~CTimerImpl() + 469 36 com.adobe.flash 0x00003716 0x1000 + 10006 Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x91904382 kevent + 10 1 libSystem.B.dylib 0x91904a9c _dispatch_mgr_invoke + 215 2 libSystem.B.dylib 0x91903f59 _dispatch_queue_invoke + 163 3 libSystem.B.dylib 0x91903cfe _dispatch_worker_thread2 + 240 4 libSystem.B.dylib 0x91903781 _pthread_wqthread + 390 5 libSystem.B.dylib 0x919035c6 start_wqthread + 30 Thread 2:
0 libSystem.B.dylib 0x918ddb42 semaphore_wait_signal_trap + 10 1 libSystem.B.dylib 0x9190b6f8 _pthread_cond_wait + 1089 2 libSystem.B.dylib 0x9195405f pthread_cond_wait + 48 3 com.adobe.amt.services 0x1fcfc126 AMTConditionLock::LockWhenCondition(int) + 46 4 com.adobe.amt.services 0x1fcf4db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116 5 com.adobe.amt.services 0x1fcfc18c AMTThread::Worker(void*) + 24 6 libSystem.B.dylib 0x9190b259 _pthread_start + 345 7 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 3:
0 libSystem.B.dylib 0x9190baa2 __semwait_signal + 10 1 libSystem.B.dylib 0x9190b75e _pthread_cond_wait + 1191 2 libSystem.B.dylib 0x9190d3f8 pthread_cond_wait$UNIX2003 + 73 3 ...ple.CoreServices.CarbonCore 0x9113f21e TSWaitOnCondition + 126 4 ...ple.CoreServices.CarbonCore 0x9112ab68 TSWaitOnConditionTimedRelative + 202 5 ...ple.CoreServices.CarbonCore 0x91126533 MPWaitOnQueue + 250 6 AdobeACE 0x0533b6f1 0x5301000 + 239345 7 AdobeACE 0x0533b0ed 0x5301000 + 237805 8 ...ple.CoreServices.CarbonCore 0x9110a54a PrivateMPEntryPoint + 68 9 libSystem.B.dylib 0x9190b259 _pthread_start + 345 10 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 4: com.apple.CFSocket.private
0 libSystem.B.dylib 0x918fcac6 select$DARWIN_EXTSN + 10 1 com.apple.CoreFoundation 0x95992c53 __CFSocketManager + 1091 2 libSystem.B.dylib 0x9190b259 _pthread_start + 345 3 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 5:
0 libSystem.B.dylib 0x9191b0d6 recvfrom$UNIX2003 + 10 1 libSystem.B.dylib 0x9193aeab recv$UNIX2003 + 54 2 ServiceManager-Launcher.dylib 0x21f976cf Invoke + 54887 3 ServiceManager-Launcher.dylib 0x21f9676e Invoke + 50950 4 ServiceManager-Launcher.dylib 0x21f9561f Invoke + 46519 5 ServiceManager-Launcher.dylib 0x21f95671 Invoke + 46601 6 ServiceManager-Launcher.dylib 0x21f956fb Invoke + 46739 7 ServiceManager-Launcher.dylib 0x21f8fafe Invoke + 23190 8 ServiceManager-Launcher.dylib 0x21f8fce7 Invoke + 23679 9 ServiceManager-Launcher.dylib 0x21f908c7 Invoke + 26719 10 ServiceManager-Launcher.dylib 0x21f909c5 Invoke + 26973 11 ServiceManager-Launcher.dylib 0x21f93db0 Invoke + 40264 12 ServiceManager-Launcher.dylib 0x21f94059 Invoke + 40945 13 ServiceManager-Launcher.dylib 0x21f94687 Invoke + 42527 14 ServiceManager-Launcher.dylib 0x21f94884 Invoke + 43036 15 ServiceManager-Launcher.dylib 0x21f86826 Login + 1654 16 ServiceManager-Launcher.dylib 0x21f87c71 Login + 6849 17 ServiceManager-Launcher.dylib 0x21f94df3 Invoke + 44427 18 ServiceManager-Launcher.dylib 0x21f97341 Invoke + 53977 19 libSystem.B.dylib 0x9190b259 _pthread_start + 345 20 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 6: Java: Exception Handler Thread
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libSystem.B.dylib 0x91949c78 mach_msg_server + 520 3 libjvm.dylib 0x2eebc430 jio_snprintf + 45031 4 libjvm.dylib 0x2eebc2b7 jio_snprintf + 44654 5 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 6 libSystem.B.dylib 0x9190b259 _pthread_start + 345 7 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 7: Java: Gang worker#0 (Parallel GC Threads)
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2eebb29c jio_snprintf + 40531 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebac6b jio_snprintf + 38946 7 libjvm.dylib 0x2eed2719 jio_vsnprintf + 405 8 libjvm.dylib 0x2eed2603 jio_vsnprintf + 127 9 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 10 libSystem.B.dylib 0x9190b259 _pthread_start + 345 11 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 8: Java: Gang worker#1 (Parallel GC Threads)
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2eebb29c jio_snprintf + 40531 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebac6b jio_snprintf + 38946 7 libjvm.dylib 0x2eed2719 jio_vsnprintf + 405 8 libjvm.dylib 0x2eed2603 jio_vsnprintf + 127 9 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 10 libSystem.B.dylib 0x9190b259 _pthread_start + 345 11 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 9: Java: Concurrent Mark-Sweep GC Thread
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb56a jio_snprintf + 41249 3 libjvm.dylib 0x2eed907e jio_vsnprintf + 27386 4 libjvm.dylib 0x2eebb2b8 jio_snprintf + 40559 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebac6b jio_snprintf + 38946 7 libjvm.dylib 0x2efe47d1 JVM_GetMethodIxExceptionTableEntry + 2242 8 libjvm.dylib 0x2efe473f JVM_GetMethodIxExceptionTableEntry + 2096 9 libjvm.dylib 0x2eed8e99 jio_vsnprintf + 26901 10 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 11 libSystem.B.dylib 0x9190b259 _pthread_start + 345 12 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 10: Java: VM Thread
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb56a jio_snprintf + 41249 3 libjvm.dylib 0x2eed907e jio_vsnprintf + 27386 4 libjvm.dylib 0x2eebb2b8 jio_snprintf + 40559 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebac6b jio_snprintf + 38946 7 libjvm.dylib 0x2ef5357a JVM_Lseek + 200643 8 libjvm.dylib 0x2ef53223 JVM_Lseek + 199788 9 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 10 libSystem.B.dylib 0x9190b259 _pthread_start + 345 11 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 11: Java: Reference Handler
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2ef62144 JVM_MonitorWait + 3799 5 libjvm.dylib 0x2ef61646 JVM_MonitorWait + 985 6 libjvm.dylib 0x2ef61338 JVM_MonitorWait + 203 7 libjvmlinkage.dylib 0x222d3e75 JVM_MonitorWait + 69 8 ??? 0x3de499d9 0 + 1038391769 9 ??? 0x3de41e31 0 + 1038360113 10 ??? 0x3de41e31 0 + 1038360113 11 ??? 0x3de3f374 0 + 1038349172 12 libjvm.dylib 0x2ef548b3 JVM_Lseek + 205564 13 libjvm.dylib 0x2ef54627 JVM_Lseek + 204912 14 libjvm.dylib 0x2ef60fe9 JVM_StartThread + 3022 15 libjvm.dylib 0x2ef60e79 JVM_StartThread + 2654 16 libjvm.dylib 0x2ef60df7 JVM_StartThread + 2524 17 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 18 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 19 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 20 libSystem.B.dylib 0x9190b259 _pthread_start + 345 21 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 12: Java: Finalizer
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2ef62144 JVM_MonitorWait + 3799 5 libjvm.dylib 0x2ef61646 JVM_MonitorWait + 985 6 libjvm.dylib 0x2ef61338 JVM_MonitorWait + 203 7 libjvmlinkage.dylib 0x222d3e75 JVM_MonitorWait + 69 8 ??? 0x3de499d9 0 + 1038391769 9 ??? 0x3de41e31 0 + 1038360113 10 ??? 0x3de41f97 0 + 1038360471 11 ??? 0x3de41f97 0 + 1038360471 12 ??? 0x3de3f374 0 + 1038349172 13 libjvm.dylib 0x2ef548b3 JVM_Lseek + 205564 14 libjvm.dylib 0x2ef54627 JVM_Lseek + 204912 15 libjvm.dylib 0x2ef60fe9 JVM_StartThread + 3022 16 libjvm.dylib 0x2ef60e79 JVM_StartThread + 2654 17 libjvm.dylib 0x2ef60df7 JVM_StartThread + 2524 18 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 19 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 20 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 21 libSystem.B.dylib 0x9190b259 _pthread_start + 345 22 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 13: Java: Surrogate Locker Thread (Concurrent GC)
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2eebb29c jio_snprintf + 40531 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebabae jio_snprintf + 38757 7 libjvm.dylib 0x2ef7288c JVM_IsPrimitiveClass + 3268 8 libjvm.dylib 0x2ef727d0 JVM_IsPrimitiveClass + 3080 9 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 10 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 11 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 12 libSystem.B.dylib 0x9190b259 _pthread_start + 345 13 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 14: Java: Signal Dispatcher
0 libSystem.B.dylib 0x918ddb36 semaphore_wait_trap + 10 1 libjvm.dylib 0x2ef73172 JVM_IsPrimitiveClass + 5546 2 libjvm.dylib 0x2ef72b50 JVM_IsPrimitiveClass + 3976 3 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 4 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 5 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 6 libSystem.B.dylib 0x9190b259 _pthread_start + 345 7 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 15: Java: C1 CompilerThread0
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2eebb29c jio_snprintf + 40531 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebabae jio_snprintf + 38757 7 libjvm.dylib 0x2ef7aa26 JVM_Write + 426 8 libjvm.dylib 0x2ef74348 JVM_IsPrimitiveClass + 10112 9 libjvm.dylib 0x2ef740f2 JVM_IsPrimitiveClass + 9514 10 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 11 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 12 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 13 libSystem.B.dylib 0x9190b259 _pthread_start + 345 14 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 16: Java: Low Memory Detector
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb49a jio_snprintf + 41041 3 libjvm.dylib 0x2eebb3d6 jio_snprintf + 40845 4 libjvm.dylib 0x2eebb29c jio_snprintf + 40531 5 libjvm.dylib 0x2eebade1 jio_snprintf + 39320 6 libjvm.dylib 0x2eebac6b jio_snprintf + 38946 7 libjvm.dylib 0x2ef75030 JVM_IsPrimitiveClass + 13416 8 libjvm.dylib 0x2ef60c51 JVM_StartThread + 2102 9 libjvm.dylib 0x2ef60a8f JVM_StartThread + 1652 10 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 11 libSystem.B.dylib 0x9190b259 _pthread_start + 345 12 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 17: Java: VM Periodic Task Thread
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 libjvm.dylib 0x2eebb56a jio_snprintf + 41249 3 libjvm.dylib 0x2efef4be JVM_MonitorNotify + 1109 4 libjvm.dylib 0x2ef77a06 JVM_IsPrimitiveClass + 24126 5 libjvm.dylib 0x2eebad40 jio_snprintf + 39159 6 libSystem.B.dylib 0x9190b259 _pthread_start + 345 7 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 18:
0 libSystem.B.dylib 0x9190baa2 __semwait_signal + 10 1 libSystem.B.dylib 0x919379c5 nanosleep$UNIX2003 + 188 2 com.adobe.flash.flbridge 0x221efd4b ScObjects::Thread::sleep(unsigned int) + 59 3 com.adobe.flash.flbridge 0x221ea2d3 ScObjects::BridgeTalkThread::run() + 163 4 com.adobe.flash.flbridge 0x221efe58 ScObjects::Thread::go(void*) + 168 5 libSystem.B.dylib 0x9190b259 _pthread_start + 345 6 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 19:
0 libSystem.B.dylib 0x918ddb42 semaphore_wait_signal_trap + 10 1 libSystem.B.dylib 0x9190b6f8 _pthread_cond_wait + 1089 2 libSystem.B.dylib 0x9195405f pthread_cond_wait + 48 3 ...ia.Flash Player.authplaylib 0x2133531f 0x20f12000 + 4338463 4 ...ia.Flash Player.authplaylib 0x20f2b6ef 0x20f12000 + 104175 5 ...ia.Flash Player.authplaylib 0x2133540c 0x20f12000 + 4338700 6 ...ia.Flash Player.authplaylib 0x21335450 0x20f12000 + 4338768 7 ...ia.Flash Player.authplaylib 0x2133553b 0x20f12000 + 4339003 8 libSystem.B.dylib 0x9190b259 _pthread_start + 345 9 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 20:
0 libSystem.B.dylib 0x918ddb42 semaphore_wait_signal_trap + 10 1 libSystem.B.dylib 0x9190b6f8 _pthread_cond_wait + 1089 2 libSystem.B.dylib 0x9195405f pthread_cond_wait + 48 3 ...ia.Flash Player.authplaylib 0x2133531f 0x20f12000 + 4338463 4 ...ia.Flash Player.authplaylib 0x20f2b6ef 0x20f12000 + 104175 5 ...ia.Flash Player.authplaylib 0x2133540c 0x20f12000 + 4338700 6 ...ia.Flash Player.authplaylib 0x21335450 0x20f12000 + 4338768 7 ...ia.Flash Player.authplaylib 0x2133553b 0x20f12000 + 4339003 8 libSystem.B.dylib 0x9190b259 _pthread_start + 345 9 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 21:
0 libSystem.B.dylib 0x9190baa2 __semwait_signal + 10 1 libSystem.B.dylib 0x919379c5 nanosleep$UNIX2003 + 188 2 com.adobe.flash 0x00ce2a0b dvaui::controls::UI_StaticText* dvaui::sharedui::DVAAboutDlog::GetTypedControlForID<dvaui::controls::UI_StaticText>(std:: basic_string<unsigned char, std::char_traits<unsigned char>, std::allocator<unsigned char> > const&) + 99183 3 com.adobe.flash 0x00cddca3 dvaui::controls::UI_StaticText* dvaui::sharedui::DVAAboutDlog::GetTypedControlForID<dvaui::controls::UI_StaticText>(std:: basic_string<unsigned char, std::char_traits<unsigned char>, std::allocator<unsigned char> > const&) + 79367 4 com.adobe.flash 0x00ce2b18 dvaui::controls::UI_StaticText* dvaui::sharedui::DVAAboutDlog::GetTypedControlForID<dvaui::controls::UI_StaticText>(std:: basic_string<unsigned char, std::char_traits<unsigned char>, std::allocator<unsigned char> > const&) + 99452 5 libSystem.B.dylib 0x9190b259 _pthread_start + 345 6 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 22:
0 libSystem.B.dylib 0x918ddafa mach_msg_trap + 10 1 libSystem.B.dylib 0x918de267 mach_msg + 68 2 com.apple.CoreFoundation 0x959532df __CFRunLoopRun + 2079 3 com.apple.CoreFoundation 0x959523c4 CFRunLoopRunSpecific + 452 4 com.apple.CoreFoundation 0x95958304 CFRunLoopRun + 84 5 com.apple.DesktopServices 0x98ec8b3d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643 6 ...ple.CoreServices.CarbonCore 0x9110a54a PrivateMPEntryPoint + 68 7 libSystem.B.dylib 0x9190b259 _pthread_start + 345 8 libSystem.B.dylib 0x9190b0de thread_start + 34 Thread 23:
0 libSystem.B.dylib 0x91903412 __workq_kernreturn + 10 1 libSystem.B.dylib 0x919039a8 _pthread_wqthread + 941 2 libSystem.B.dylib 0x919035c6 start_wqthread + 30 Thread 24:
0 libSystem.B.dylib 0x91903412 __workq_kernreturn + 10 1 libSystem.B.dylib 0x919039a8 _pthread_wqthread + 941 2 libSystem.B.dylib 0x919035c6 start_wqthread + 30 Thread 25: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
0 libSystem.B.dylib 0x918dddd8 _sysenter_trap + 0 1 com.apple.DesktopServices 0x98ec87a4 TDSMutex::Acquire() + 46 2 com.apple.DesktopServices 0x98ed2811 TNode::HandleSyncStarted(unsigned long) + 205 3 com.apple.DesktopServices 0x98ed2926 TNode::HandleSync(unsigned long) + 148 4 com.apple.DesktopServices 0x98ed285e TNode::HandleSync(TCountedPtr<TNodeTask> const&, TNodePtr const&) + 56 5 com.apple.DesktopServices 0x98f254ea TNode::HandleNodeRequest(TCountedPtr<TNodeTask> const&, TCountedPtr<TVolumeSyncThread> const&) + 1154 6 com.apple.DesktopServices 0x98ed0cbd __PostNodeTaskRequest_block_invoke_2 + 94 7 libSystem.B.dylib 0x91911a24 _dispatch_call_block_and_release + 16 8 libSystem.B.dylib 0x9190448c _dispatch_queue_drain + 249 9 libSystem.B.dylib 0x91903ee8 _dispatch_queue_invoke + 50 10 libSystem.B.dylib 0x91903cfe _dispatch_worker_thread2 + 240 11 libSystem.B.dylib 0x91903781 _pthread_wqthread + 390 12 libSystem.B.dylib 0x919035c6 start_wqthread + 30 Thread 26:
0 libSystem.B.dylib 0x91903412 __workq_kernreturn + 10 1 libSystem.B.dylib 0x919039a8 _pthread_wqthread + 941 2 libSystem.B.dylib 0x919035c6 start_wqthread + 30 Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00000000 ecx: 0x3acd3f0c edx: 0x00000000
edi: 0x2502b510 esi: 0x3acd3ec4 ebp: 0xbfffea18 esp: 0xbfffe9e0
ss: 0x0000001f efl: 0x00010282 eip: 0x00c83d64 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000010
Binary Images:
0x1000 - 0x17c5fe0 +com.adobe.flash 11.0.2.489 (11.0.2) <BA9CB7ED-F0D3-CB9D-BF54-610852BE1D35> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5 0x20e9000 - 0x2261ffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x2305000 - 0x23d2fe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x2441000 - 0x24d2ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
0x24f1000 - 0x25beff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
0x2621000 - 0x26fbfef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
0x273b000 - 0x30ebfff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
0x30ee000 - 0x30f9fef +libChar16.dylib ??? (???) <816B48D0-ACE3-4B7F-17E6-5185148CE7AD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libChar16.dylib
0x3102000 - 0x3119fe0 +libCoreTypes.dylib ??? (???) <D471DE81-0710-AAD8-3508-B6DAD42630CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libCoreTypes.dylib
0x3136000 - 0x3145fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/ZLib.dylib
0x314a000 - 0x3345ff7 com.apple.carbonframeworktemplate 1.0 (1.0) <F87C62DE-492B-35ED-C61D-A0A5B374F556> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
0x35e9000 - 0x35edff7 com.apple.JavaVM 13.8.0 (13.8.0) <1D84B672-517F-BB1B-D568-376B11437721> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x35f5000 - 0x4380fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
0x5165000 - 0x51a9fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
0x520c000 - 0x5252fff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
0x52c7000 - 0x52c7fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
0x52cb000 - 0x52e7ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x5301000 - 0x5415fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x5438000 - 0x593afef +AdobeAGM ??? (???) <5B8478AC-5DD0-F116-5B3E-45596CF551C6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x5a76000 - 0x5ab1fff +AdobeARE ??? (???) <CEE507DA-9B96-FAF9-7894-445C427C3D7A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x5aba000 - 0x5ad4fff +AdobeBIB ??? (???) <5533CDC7-676C-0CF0-97B7-8EDD26837FFC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x5add000 - 0x5afeff7 +AdobeBIBUtils ??? (???) <726B8463-9301-CE6C-0F2C-5CA81795A4CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x5b0a000 - 0x5dfcff7 +AdobeCoolType ??? (???) <2BF62C8A-D715-FDE8-650C-1984CFFCE33C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x5e84000 - 0x625cff7 +AdobeMPS ??? (???) <272DAEDE-FC7E-B412-7C97-CF47FF6BF242> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x638b000 - 0x6469fef +AdobePDFPort ??? (???) <324E65FD-0011-F93F-9B92-FB4E17968181> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
0x649f000 - 0x6ad3feb +AdobePDFL ??? (???) <1A619F3E-A9D4-A99C-791E-92B564F64609> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x6bff000 - 0x6c25ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
0x6c36000 - 0x6c5dfed +AdobeAXE16SharedExpat ??? (???) <66F4E782-C848-AD92-686D-5A479A4B333A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
0x6c6f000 - 0x6cc7ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x6cd6000 - 0x6d43fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x6d5e000 - 0x6efdfe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x6f66000 - 0x7ca9fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x7fe8000 - 0x81ceff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x825c000 - 0x8260ffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x8267000 - 0x8520fe7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <57D1FDBA-5078-CD9A-B0B7-5C49C585628B> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x8823000 - 0x8978fef +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <7683205C-9FB0-4B02-07FD-A0728595821E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x8ace000 - 0x8de3fe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <F31A0210-3BBC-3553-6BF4-A28FB1C135B9> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x92ab000 - 0x9311ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x9341000 - 0x9394ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x93dc000 - 0x93eefff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
0x93f7000 - 0x952ffe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x9571000 - 0x9577fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <DD573159-092B-2B14-D713-BA30CC9D3CA1> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x9588000 - 0x9593ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <1C9DE884-5C67-6B47-7B92-9DA0DB4E21EE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x95a7000 - 0x9625fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <4B652D39-CE3F-F75B-C66F-43A0404406EA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x9689000 - 0x9693fff +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <DA6570C5-E79F-C09F-6D45-8DFD4AB7C8BC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x96a6000 - 0x96a8ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <729D158C-F2FE-6E9F-0F01-9DE51747B0B6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x96b0000 - 0x96b7ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <10C7464D-4125-F64B-8902-933188B5A81A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x96c7000 - 0x9858ff3 +aflamingo ??? (???) <C4136948-FE16-15C4-F1B9-040E014AF2CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
0x9a1b000 - 0x9a1eff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x9a24000 - 0x9b1cff7 +FlashIK Framework ??? (1.0) <4A9B1E4F-8135-F5C1-8184-28C9FFEB273D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
0x9bb3000 - 0x9bf3ffb +PFF Framework ??? (1.0) <887EDD54-93B3-A045-E1FB-72330380EA50> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
0x9c20000 - 0xa61cfef +aflame ??? (???) <B07806FD-0449-CBC6-FB92-0745A6D914D5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
0xa7df000 - 0xa7e4ff7 JavaLaunching ??? (???) <11B268E7-103B-C849-8921-C924AF7D2A55> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0xa7ec000 - 0xa82cff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
0xa845000 - 0xa8fafe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
0xa9c9000 - 0xa9caff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xaf85000 - 0xaf8dfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0xaff2000 - 0xaff3ff7 ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
0x1fcd7000 - 0x1fd3efea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
0x1fd7d000 - 0x1fdedfeb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x20349000 - 0x20357fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <B408E41B-D90F-4A04-DB72-D61C8C52BFBC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x2035b000 - 0x2035bfff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <640221C0-063B-CB9E-01D0-5987BAFD813D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
0x20375000 - 0x203e7fff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x204f8000 - 0x204faffd +com.macromedia.Flash.FLfile 11.0.0.485 (11.0.0) <5DA72BFA-D78D-94E0-0F0F-9EAC705646C6> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
0x20808000 - 0x2081aff7 libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <EA696A00-4054-6F65-0F86-7901EAB5969F> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x2081e000 - 0x20822ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
0x20827000 - 0x2082dff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
0x20c80000 - 0x20c83ffc +eu.willmore.UnifyCamino UnifyCamino v1.0 (1.9) <0178D6C8-4331-C6A6-E965-902CEFDB50A8> /Library/InputManagers/UnifyCamino/UnifyCamino.bundle/Contents/MacOS/UnifyCamino
0x20c8f000 - 0x20ca3ff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x20ca9000 - 0x20cd2feb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <F3239526-C171-AD3C-835E-FC9998EEFB28> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
0x20d24000 - 0x20d38ffb +com.yourcompany.PointGrid ??? (1.0) <97938B0E-FD0E-BC24-12A5-90D33523249D> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
0x20f12000 - 0x21861ff3 +com.macromedia.Flash Player.authplaylib 10.1.52.14 (1.0.1d333) <23ED9968-F20E-1132-26B1-0BC42DC14A05> /Applications/Adobe Flash CS5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
0x21f30000 - 0x21f69ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
0x21f84000 - 0x21fa7fe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
0x22191000 - 0x221b0ffb +com.adobe.flash.anemoi 11.0.0.489 (11.0.0) <8BB54C8B-E2F3-CD18-FAAF-D7D424E8E02E> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Air2_0.bundle/Contents/MacOS/Air2_0
0x221c5000 - 0x221caff7 libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
0x221cf000 - 0x2220dffb +com.adobe.flash.flbridge 11.0.0.485 (11.0.0) <10AA8563-6870-61EE-1CEE-0FB603AD2BE4> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
0x222d3000 - 0x222daffb libjvmlinkage.dylib ??? (???) <40E32914-14BE-2928-DA0B-AE59EA90565A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
0x22392000 - 0x22399ff7 libverify.dylib 1.0 (1.0) <289A64EE-949B-9FDB-F252-3126CE028AB0> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
0x2373d000 - 0x23745ff7 JavaNativeFoundation ??? (???) <AB90991B-6C86-F62D-301C-9B279C492E99> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
0x23b3f000 - 0x23b5bff7 libjava.jnilib ??? (???) <B108E226-F715-2E51-4119-33C2844027A8> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
0x23b6d000 - 0x23b76ff7 com.apple.java.JavaRuntimeSupport 13.8.0 (13.8.0) <40760075-9468-7E0E-94B3-0EB816F63894> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.fram ework/Versions/A/JavaRuntimeSupport
0x23b84000 - 0x23b90ff7 libzip.jnilib ??? (???) <80DA5D91-29BF-E82C-1A97-BC1FCD13FBBB> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
0x27f00000 - 0x27f67ffb +com.yourcompany.Brush ??? (1.0) <25E6C744-6FCC-CF39-C01F-C14BAA743519> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
0x2bdb2000 - 0x2be3dfeb +com.yourcompany.Collision ??? (1.0) <258F5AD8-2C92-833F-1076-105635401C53> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
0x2e500000 - 0x2e609ff7 +com.yourcompany.Stroke ??? (1.0) <42A62A75-F5EB-27E7-47B3-B14FEABA4693> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
0x2eeac000 - 0x2f20fff7 libjvm.dylib ??? (???) <2E40F1F1-346E-24EA-A0D2-4CF2180B8AEF> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm. dylib
0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <EF392886-5A95-6A96-C95D-43DA0322925C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
0x90003000 - 0x9012bfe7 com.apple.WebKit 6534.57 (6534.57.2) <4CB86278-4657-3503-8042-074628222DF3> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9012c000 - 0x901d8fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
0x90206000 - 0x9020fff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x90210000 - 0x90255ff7 com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x9026e000 - 0x90275ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <37255DC6-9FD1-45CC-AC80-A84FD2B5450A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x90276000 - 0x90283ff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9038b000 - 0x9048bfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
0x9048c000 - 0x90507fff com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x90556000 - 0x9057cffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
0x9057d000 - 0x909cefef com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x909cf000 - 0x909f6ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
0x909f7000 - 0x90a3aff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x90a3b000 - 0x90a49fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x90a4a000 - 0x90a4dffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
0x90a94000 - 0x90a9afe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
0x90ab5000 - 0x90ad4ff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x90ad5000 - 0x90e40ff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90e41000 - 0x90e7cffb libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
0x91085000 - 0x91085ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x91086000 - 0x910e3ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x910e4000 - 0x91404ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
0x91405000 - 0x914a0fe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
0x91604000 - 0x91619fff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
0x91626000 - 0x9166dffb com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
0x916a4000 - 0x916abff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
0x916ae000 - 0x91708fe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x9170c000 - 0x9170ffe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x917be000 - 0x9180eff7 com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9180f000 - 0x918cbfff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
0x918cc000 - 0x918dcff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x918dd000 - 0x91a84ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x91a85000 - 0x91ae9ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
0x91aea000 - 0x91c17ffb com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x91c26000 - 0x91c29ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
0x91c2a000 - 0x91c30fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
0x91cbc000 - 0x91ceffff libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
0x91cf0000 - 0x91cf5ff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x91cf6000 - 0x91cfaff7 IOSurface ??? (???) <F9E6DFC1-8DD9-7C7E-CA85-B80735586E05> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x91cfb000 - 0x91d3eff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
0x91d72000 - 0x91d94fef com.apple.DirectoryService.Framework 3.6 (621.14) <A24C9308-4EB3-456D-1691-43DDB6F9A79F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x91d95000 - 0x91ed8fef com.apple.QTKit 7.7 (1790) <95F7C69A-1D24-A96A-E95D-1DF8CCD03FB3> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91ed9000 - 0x91eddff7 libGIF.dylib ??? (???) <5D29E5F4-30B9-5A24-55E7-BCBA30499093> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
0x91ede000 - 0x92109ff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
0x9210a000 - 0x921c3fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x921c9000 - 0x9311cffb com.apple.QuickTimeComponents.component 7.6.6 (1790) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
0x9311d000 - 0x93163ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x93164000 - 0x9318cff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
0x934fa000 - 0x94272fe7 com.apple.WebCore 6534.57 (6534.57.2) <6AF29D9A-F549-5BE7-3842-CFF75FC46360> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
0x94274000 - 0x942defe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x942f6000 - 0x942f6ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x942f7000 - 0x947b2ff7 com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x947b3000 - 0x94861ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
0x94862000 - 0x94862ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x9488a000 - 0x94a63fff libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
0x94a64000 - 0x94ad2ff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
0x94b8a000 - 0x94b90ff7 libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x94b91000 - 0x94bd5fe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
0x94bd6000 - 0x94fecff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
0x94fed000 - 0x94ff8ff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94ff9000 - 0x9525fff7 com.apple.security 6.1.2 (55002) <E999CCEF-B769-4355-3E68-6003FCF6FE2B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9543d000 - 0x9543fff7 com.apple.securityhi 4.0 (36638) <FC01BFC4-04DB-96F3-2412-A86CC4F94CB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
0x95440000 - 0x9547dff7 com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x954b3000 - 0x9555bffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
0x95575000 - 0x95655fe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
0x95681000 - 0x95695ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
0x95696000 - 0x956ecff7 com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
0x956ed000 - 0x9586ffe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
0x95916000 - 0x95a91fe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95a97000 - 0x95ad1ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
0x96132000 - 0x961fdfef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
0x961fe000 - 0x9626dff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
0x9626e000 - 0x96278ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
0x96279000 - 0x96284ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
0x96285000 - 0x96448feb com.apple.ImageIO.framework 3.0.5 (3.0.5) <87750C2B-193F-56A6-AB97-0842A2D02092> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
0x96449000 - 0x9644aff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x9645c000 - 0x9658afe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9658b000 - 0x9658bff7 com.apple.Carbon 150 (152) <BFDDA394-0F01-A3A3-A226-ED3A45975A56> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9658c000 - 0x9668efef com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
0x9668f000 - 0x966a3fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x966a4000 - 0x966c0fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
0x966c1000 - 0x966c1ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x966c2000 - 0x966ffff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96700000 - 0x9680cfe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
0x96922000 - 0x96923ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
0x96924000 - 0x96977ff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
0x969b9000 - 0x969dafe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x969db000 - 0x969deff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x969df000 - 0x96bc1fff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
0x96bc2000 - 0x96c04ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
0x96c75000 - 0x96c99ff7 libJPEG.dylib ??? (???) <5F2343E4-C268-B9AE-1BC3-466F5A614648> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
0x96c9a000 - 0x96d9cfe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x96e47000 - 0x96e53ff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x96e54000 - 0x97737ff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x97738000 - 0x97b6dff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
0x97b6e000 - 0x97bbdfe7 libTIFF.dylib ??? (???) <D0EB31DC-40E6-9A97-64D3-9867605DC3DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
0x97bbe000 - 0x97bc0ff7 libRadiance.dylib ??? (???) <98EC06D5-1A02-EDEF-BF9D-2C986761AD54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
0x97bc1000 - 0x97c0efeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x97c0f000 - 0x97ebdfe7 com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9804b000 - 0x9806bfe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x980ea000 - 0x9819afe3 com.apple.QuickTimeImporters.component 7.6.6 (1790) <F2F9FAA1-3B6D-722B-3ECA-2395588D3B20> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x9819b000 - 0x9822dfe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
0x9822e000 - 0x98286fe7 com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
0x9843d000 - 0x9847eff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
0x9847f000 - 0x984f9fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x984fa000 - 0x985b2feb libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
0x985b3000 - 0x985b3ff7 com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x985d6000 - 0x985e0fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
0x985ed000 - 0x98631ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x98632000 - 0x9876ffe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x98770000 - 0x987aeff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x987af000 - 0x98823fef com.apple.CoreSymbolication 2.0 (23) <8A04EA5F-83F8-5E15-B2E0-8A727C9C4E8B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
0x9893c000 - 0x989d4fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x989dd000 - 0x989deff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x989df000 - 0x989fdfe7 libPng.dylib ??? (???) <45185287-25AD-C239-AA58-8FA53DF55B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
0x989fe000 - 0x98a80ffb SecurityFoundation ??? (???) <BFE377A4-C830-3ECA-E69F-8A8094CDA0A6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x98a8c000 - 0x98a8cff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
0x98a8d000 - 0x98a9fff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
0x98aa0000 - 0x98aaeff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x98ad5000 - 0x98ae5ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x98ae6000 - 0x98b16ff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x98b17000 - 0x98b78fe7 com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
0x98b79000 - 0x98e73fef com.apple.QuickTime 7.6.6 (1790) <A5B2CDA8-47C9-F1AE-ED54-625B0FAB426F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x98e74000 - 0x98e8cff7 com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
0x98e8d000 - 0x98e8dff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98ec7000 - 0x98fa1fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
0x99012000 - 0x9901aff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x9901b000 - 0x9902cff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
0x9902d000 - 0x99031ff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x99032000 - 0x99356fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
0x99357000 - 0x9938aff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
0x9938b000 - 0x993c6fe7 com.apple.DebugSymbols 1.1 (70) <05013716-CFCF-801E-5535-D0643869BDCD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x994a3000 - 0x99714fef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x99733000 - 0x99764ff7 libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x99765000 - 0x99859ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x9999b000 - 0x99a1bfeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
0x99a1c000 - 0x9a097ff7 com.apple.CoreAUC 6.11.03 (6.11.03) <42B31B0F-18F9-29D2-A67C-7B81A47F6D67> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9a098000 - 0x9a887557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
0x9a888000 - 0x9a888ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9a9ec000 - 0x9aa65ff7 com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
0x9aa66000 - 0x9ab13fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x9ab14000 - 0x9abb1fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba916ff7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <A6FD4184-1017-59F6-990E-785BDF6202BE> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7 libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <59936EB5-5FA4-EEEB-9858-E9BF50AB1776> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
3. Re: Why would an AS 3 File cause Flash to crash?
meetiwari3 Jul 11, 2012 12:55 AM (in response to nana2841084)Hi,
Could you please provide any sample file, that is causing the crash ? This would help us to investigate the issue further.
Meenakshi
4. Re: Why would an AS 3 File cause Flash to crash?
nana2841084 Jul 11, 2012 10:38 AM (in response to meetiwari3)Every .as file causes the crash. There is no capability to overwrite without a crash. I can create a new .as file, name it anything, place it anywhere and it saves. If I open it and try to take out a line space and save, it crashes Flash without any code except for what Flash provides when you start a new .as file. All of the files I was working on have been removed from the machine and I did all of the maitenence I mentioned above. If I "save as" there is no trouble. If I open the .as file in text edit and save, there is no problem and it will work with Flash. This is why the issue is so frustrating...it doesn't seem to have anything to do with any files I created.
5. Re: Why would an AS 3 File cause Flash to crash?
meetiwari3 Jul 23, 2012 9:29 PM (in response to nana2841084)Hi,
I verified the issue on CS6 on Mac OS X (10.7.3), but was unable to reproduce the crash.
Thanks and Regards,
Meenakshi
