0 Replies Latest reply on Jul 9, 2012 2:07 AM by Vincent Choy
    Flashbuilder 4.6 failed to start
    Vincent Choy Level 1
      After splash screen, there is error message window show up to ask to check '.log' file. Below please find the details of log file.
      Background:
      OS: Windows 7 sp 1 (64 bits)
      RAM: 4GB
      !SESSION 2012-07-09 17:03:22.082 -----------------------------------------------
      eclipse.buildId=I20100608-0911
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.core.resources 2 10035 2012-07-09 17:03:24.307
      !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
      !ENTRY org.eclipse.equinox.preferences 4 2 2012-07-09 17:03:26.294
      !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
      !STACK 0
      java.lang.ExceptionInInitializerError
                at com.zend.php.ui.preferences.PreferenceKeys.b(PreferenceKeys.java)
                at com.zend.php.ui.preferences.PreferenceInitializer.initializeDefaultPreferences(Preference Initializer.java)
                at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceSer viceRegistryHelper.java:281)
                at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(Pref erenceServiceRegistryHelper.java:284)
                at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefault s(PreferenceServiceRegistryHelper.java:130)
                at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(Preferences Service.java:369)
                at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPref erences.java:166)
                at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:237 )
                at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:3 07)
                at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences. java:543)
                at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669 )
                at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
                at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:67)
                at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceSt ore.java:250)
                at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore .java:285)
                at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:4 75)
                at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:38 7)
                at com.zend.php.ui.ZendPhpUiPlugin.f(ZendPhpUiPlugin.java)
                at com.zend.php.ui.ZendPhpUiPlugin.d(ZendPhpUiPlugin.java)
                at com.zend.php.ui.ZendPhpUiPlugin$1.run(ZendPhpUiPlugin.java)
                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
      Caused by: org.eclipse.swt.SWTException: Invalid thread access
                at org.eclipse.swt.SWT.error(SWT.java:4083)
                at org.eclipse.swt.SWT.error(SWT.java:3998)
                at org.eclipse.swt.SWT.error(SWT.java:3969)
                at org.eclipse.swt.widgets.Display.error(Display.java:1249)
                at org.eclipse.swt.widgets.Display.checkDevice(Display.java:755)
                at org.eclipse.swt.widgets.Display.getSystemFont(Display.java:2412)
                at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:84)
                ... 22 more
      !ENTRY org.eclipse.ui 2 0 2012-07-09 17:03:28.552
      !MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
      !SUBENTRY 1 org.eclipse.ui 2 0 2012-07-09 17:03:28.552
      !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
      !ENTRY org.eclipse.osgi 4 0 2012-07-09 17:03:29.287
      !MESSAGE Application error
      !STACK 1
      java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.preference.PreferenceConverter
                at org.eclipse.ui.internal.themes.ThemeElementHelper.installFont(ThemeElementHelper.java:103 )
                at org.eclipse.ui.internal.themes.ThemeElementHelper.populateRegistry(ThemeElementHelper.jav a:59)
                at org.eclipse.ui.internal.Workbench$36.runWithException(Workbench.java:1665)
                at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
                at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
                at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                at java.lang.reflect.Method.invoke(Unknown Source)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
      !ENTRY com.adobe.flexbuilder.editorcore 4 0 2012-07-09 17:03:29.638
      !MESSAGE
      !STACK 0
      org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.editorcore.FlexBuilderEditorCore.stop() of bundle com.adobe.flexbuilder.editorcore.
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:86 3)
                at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:501)
                at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:550)
                at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1097)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java :597)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:257)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.jav a:215)
                at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundl e.java:266)
                at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:690)
                at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:588)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:415)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:198)
      Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
                at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
                at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
                at org.eclipse.core.internal.events.ResourceChangeListenerList.remove(ResourceChangeListener List.java:146)
                at org.eclipse.core.internal.events.NotificationManager.removeListener(NotificationManager.j ava:305)
                at org.eclipse.core.internal.resources.Workspace.removeResourceChangeListener(Workspace.java :1934)
                at com.adobe.flexbuilder.editorcore.editor.LiveErrorHighlightManager.stopManager(LiveErrorHi ghlightManager.java:290)
                at com.adobe.flexbuilder.editorcore.FlexBuilderEditorCore.stop(FlexBuilderEditorCore.java:54 )
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:8 43)
                at java.security.AccessController.doPrivileged(Native Method)
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:83 6)
                ... 18 more
      Root exception:
      !ENTRY org.eclipse.dltk.core.index.sql 4 0 2012-07-09 17:03:30.079
      !MESSAGE An exception has occurred while creating database factory
      !STACK 1
      org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.dltk.core.index.sql.h2" was unable to instantiate class "org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory".
                at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrat egyOSGI.java:194)
                at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:186)
                at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionR egistry.java:904)
                at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:243)
                at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(C onfigurationElementHandle.java:55)
                at org.eclipse.dltk.core.index.sql.DbFactory.getInstance(DbFactory.java:54)
                at org.eclipse.dltk.internal.core.index.sql.SqlIndexer.<init>(SqlIndexer.java:53)
                at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
                at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
                at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
                at java.lang.reflect.Constructor.newInstance(Unknown Source)
                at java.lang.Class.newInstance0(Unknown Source)
                at java.lang.Class.newInstance(Unknown Source)
                at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:184)
                at org.eclipse.dltk.internal.core.index2.IndexerManager.getIndexer(IndexerManager.java:77)
                at org.eclipse.dltk.internal.core.index2.SourceModulesRequest.run(SourceModulesRequest.java: 54)
                at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob.java:76)
                at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobManager.java:467)
                at java.lang.Thread.run(Unknown Source)
      Caused by: java.lang.NullPointerException
                at org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory.<init>(H2DbFactory.java:50)
                ... 20 more
      !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-07-09 17:03:30.081
      !MESSAGE Plug-in "org.eclipse.dltk.core.index.sql.h2" was unable to instantiate class "org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory".
      !STACK 0
