11 Replies Latest reply: Jul 11, 2012 6:40 AM by Ned Murphy RSS
    Issue with Combo box AS2
    BinaryBloke Community Member
      Hi.
      Please can someone advise me. I have two combo boxes on the timeline which on select go to a particular frame. One has an instance name of 'dropdownIN' the other 'dropdownIN2'. I am using the code below for event listner, but only the first combo box works. Both combo boxes have a change handler called 'onSelect'. How can I modify the code below so that I can have multiple combo boxes on my page.
      initData();
      function onSelect() {
      gotoAndStop(dropdownIN.getSelectedItem().data);
      } listenerObject = new Object();
      listenerObject.change = function(eventObject) {
      getURL(eventObject.target.value);
      dropdownIN.addEventListener("change" , listenerObject)
      initData1();
      gotoAndStop(dropdownIN2.getSelectedItem().data);
      listenerObject.change = function(eventObject){
      dropdownIN2.addEventListener("change2" , listenerObject) ;
        • 1. Re: Issue with Combo box AS2
          Ned Murphy MVP
          Write distinct code for each combobox.  You cannot have two functions named the same, only one can work (if either will... AS3 would not permit it at all) You cannot have two "listenerObject"s defined, again, only one will survive.  You can however have code shared.  See if the following works (I am not sure about the details, but I removed the onSelect function)...
          var listenerObject = new Object();
              gotoAndStop(eventObject.getSelectedItem().data);
          dropdownIN.addEventListener("change", listenerObject) ;
          dropdownIN2.addEventListener("change" , listenerObject) ;
          • 2. Re: Issue with Combo box AS2
            Thanks Ned. I am not sure what you mean. Are you saying I should have a separate function on two different layers eg:
            Combo Box 1 layer
            initData(); function onSelect() { gotoAndStop(dropdownIN2.getSelectedItem().data); } listenerObject = new Object(); listenerObject.change = function(eventObject){ getURL(eventObject.target.value); } dropdownIN2.addEventListener("change" , listenerObject) ;
            Combo Box 2 layer
            initData(); function onSelect() { gotoAndStop(dropdownIN.getSelectedItem().data); } listenerObject = new Object(); listenerObject.change = function(eventObject){ getURL(eventObject.target.value); } dropdownIN.addEventListener("change" , listenerObject) ;
            Tried this, but only one combo works to advance me to the specified frame label.
            I am quite stuck here if you could give me some examples I would very much appreciate it.
            • 3. Re: Issue with Combo box AS2
              Ned Murphy MVP
              I added some information to my original response if you want to check back there.
              Layers will not help.  I am saying you cannot define two "onSelect" functions in the same file... which one will the program choose?  Similarly, you cannot redefine the listenerObject as you do... the last definition is all that will survive... there will not /cannot be two different ones with the same name.
              • 4. Re: Issue with Combo box AS2
                Hi Ned really appreciate your input on this, thanks. This makes more sence and I understand the concept now. I replaced the code you suggested below:
                Neither of the combo boxes now advance onto the relevant frame.
                Just to confirm the set-up.
                I have several frames each with a stop() code. Each frame has an label name which corresponds to the data value in the corresponding combobox. On selection of an item from the combobox it should advance and stop at the relevant frame.
                If my ramblings do not make sence could I email you the file for further advice?
                • 5. Re: Issue with Combo box AS2
                  Ned Murphy MVP
                  What you should do now is place some traces in the change function to see if it is being executed.  You can trace the values that you are using within it to see what they are....
                     trace(eventObject.target.value);
                     trace(eventObject.getSelectedItem().data);
                  if the traces appear you know the function is executing, which means you know the listeners are working, you just need to see what the values you are trying to process are.  I cannot answer for them since I cannot see the data you are loading.
                  • 6. Re: Issue with Combo box AS2
                    Hi Ned. I have added the trace. This is the output I get. Just for reference I am not loading any data. I am just using the standard component with the 'data' property being PageYellow, PageBlue, Page Red for the 1st combo with PageGreen on the second combo. The code is not changing the dropdowns at all.
                    Objects:
                    COLOR=\"#000             000\" LETTERSPACING=\"0\" KERNING=\"0\">Page Red
                    "     Movie Clip: Frame=1 Target="_level0.superHolder20001.faderX" Label="enabled"       Movie Clip: Frame=1 Target="_level0.superHolder20001.faderX.boundingBox"         Shape:       Shape:
                    Variables
                    SIZE=\"12\" COLOR=\"#000000\" LETTERSPACING=\"0\" KERNING=\"0\">Page Red
                    ",     textHeight = 16 Movie Clip: Target="_level0.superHolder20001.faderX" Variable _level0.superHolder20001.faderX.component = [movieclip:_level0.superHolder20001] Movie Clip: Target="_level0.superHolder20001.faderX.boundingBox"
                    • 7. Re: Issue with Combo box AS2
                      Ned Murphy MVP
                      As per my previous reply, you now know the listeners are working.  You need to figure out what data it is that you are trying to get since that would appear to be the source of the problem.
                      I cannot tell what it should be, but if you take those trace outputs and try to run them in those getURL and gotoAndStop commands you aren't likely to get anywhere with them.  A getURL requires a URL to get, and a gotoAndStop requires a frame number or frame label.  None of what you show as the trace outputs qualifies.
                      • 8. Re: Issue with Combo box AS2
                        Hi Ned. A lot more data to show. Not sure what to make of it...
                        Objects:
                        Level #0: Frame=1   Movie Clip: Frame=1 Target="_level0.dropdownIN2"     Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset"       Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset"         Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc"           Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc"              Shape:       Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.superClassAsset"         Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.superClassAsset.dPAsset" Label="Symbol_354"         Movie Clip: Frame=1 Target="_level0.dropdownIN2.superClassAsset.superClassAsset.ItemAsset"     Movie Clip: Frame=1 Target="_level0.dropdownIN2.itemAsset"     Movie Clip: Frame=1 Target="_level0.dropdownIN2.proxyBox_mc" Label="enabled"       Movie Clip: Frame=1 Target="_level0.dropdownIN2.proxyBox_mc.boundingBox"         Shape:       Shape:     Movie Clip: Frame=1 Target="_level0.dropdownIN2.deadPreview"       Shape:     Movie Clip: Frame=1 Target="_level0.dropdownIN2.fLabel_mc"       Movie Clip: Frame=1 Target="_level0.dropdownIN2.fLabel_mc.highlight_mc" Label="enabled"         Movie Clip: Frame=1 Target="_level0.dropdownIN2.fLabel_mc.highlight_mc.highlight_mc"           Shape:       Movie Clip: Frame=1 Target="_level0.dropdownIN2.fLabel_mc.fLabel_mc" Label="Symbol_32"         Edit Text: Target="_level0.dropdownIN2.fLabel_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Choose Colour
                        "     Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow"       Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up"         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.face_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.arrow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.highlight_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.shadow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.darkshadow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN2.downArrow.up.highlight3D_mc"           Shape:   Movie Clip: Frame=1 Target="_level0.dropdownIN"     Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset"       Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.scrollBarAsset"         Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc"           Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc"              Shape:       Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.superClassAsset"         Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.superClassAsset.dPAsset" Label="Symbol_354"         Movie Clip: Frame=1 Target="_level0.dropdownIN.superClassAsset.superClassAsset.ItemAsset"     Movie Clip: Frame=1 Target="_level0.dropdownIN.itemAsset"     Movie Clip: Frame=1 Target="_level0.dropdownIN.proxyBox_mc" Label="enabled"       Movie Clip: Frame=1 Target="_level0.dropdownIN.proxyBox_mc.boundingBox"         Shape:       Shape:     Movie Clip: Frame=1 Target="_level0.dropdownIN.deadPreview"       Shape:     Movie Clip: Frame=1 Target="_level0.dropdownIN.fLabel_mc"       Movie Clip: Frame=1 Target="_level0.dropdownIN.fLabel_mc.highlight_mc" Label="enabled"         Movie Clip: Frame=1 Target="_level0.dropdownIN.fLabel_mc.highlight_mc.highlight_mc"           Shape:       Movie Clip: Frame=1 Target="_level0.dropdownIN.fLabel_mc.fLabel_mc" Label="Symbol_32"         Edit Text: Target="_level0.dropdownIN.fLabel_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Page Yellow
                        "     Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow"       Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up"         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.face_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.arrow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.highlight_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.shadow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.darkshadow_mc"           Shape:         Movie Clip: Frame=1 Target="_level0.dropdownIN.downArrow.up.highlight3D_mc"           Shape:   Edit Text: Target="_level0.instance1" Variable= Visible=true Text =
                        Start Page
                        "   Movie Clip: Frame=0 Target="_level0.superHolder20000"     Movie Clip: Frame=0 Target="_level0.superHolder20000.container"       Movie Clip: Frame=1 Target="_level0.superHolder20000.container.boundingBox_mc" Label="enabled"         Movie Clip: Frame=1 Target="_level0.superHolder20000.container.boundingBox_mc.boundingBox"           Shape:         Shape:       Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem0_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem0_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem0_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem0_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20000.container.fListItem0_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Choose Colour
                        "       Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem1_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem1_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem1_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20000.container.fListItem1_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20000.container.fListItem1_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Page Green
                        "     Movie Clip: Frame=1 Target="_level0.superHolder20000.faderX" Label="enabled"       Movie Clip: Frame=1 Target="_level0.superHolder20000.faderX.boundingBox"         Shape:       Shape:   Movie Clip: Frame=0 Target="_level0.superHolder20001"     Movie Clip: Frame=0 Target="_level0.superHolder20001.container"       Movie Clip: Frame=1 Target="_level0.superHolder20001.container.boundingBox_mc" Label="enabled"         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.boundingBox_mc.boundingBox"           Shape:         Shape:       Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem0_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem0_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem0_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem0_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20001.container.fListItem0_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Choose Colour
                        "       Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem1_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem1_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem1_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem1_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20001.container.fListItem1_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Page Yellow
                        "       Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem2_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem2_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem2_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem2_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20001.container.fListItem2_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Page Blue
                        "       Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem3_mc"         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem3_mc.highlight_mc" Label="enabled"           Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem3_mc.highlight_mc.highlight_mc"              Shape:         Movie Clip: Frame=1 Target="_level0.superHolder20001.container.fListItem3_mc.fLabel_mc" Label="Symbol_32"           Edit Text: Target="_level0.superHolder20001.container.fListItem3_mc.fLabel_mc.labelField" Variable= Visible=true Text =
                        Page Red
                        Variables:
                        Global Variables:   Variable _global.FLabelClass = [function 'FLabelClass'] {     prototype:[object #2, class 'MovieClip'] {       setLabel:[function 'setLabel'],       setSize:[function 'setSize'],       setEnabled:[function 'setEnabled'],       getLabel:[function 'getLabel'],       setColor:[function 'setColor']     }   }   Variable _global.DataProviderClass = [function 'DataProviderClass'] {     prototype:[object #9, class 'Object'] {       init:[function 'init'],       addView:[function 'addView'],       addItemAt:[function 'addItemAt'],       addItem:[function 'addItem'],       removeItemAt:[function 'removeItemAt'],       removeAll:[function 'removeAll'],       replaceItemAt:[function 'replaceItemAt'],       getLength:[function 'getLength'],       getItemAt:[function 'getItemAt'],       getItemID:[function 'getItemID'],       sortItemsBy:[function 'sortItemsBy'],       updateViews:[function 'updateViews']     }   }   Variable _global.FStyleFormat = [function 'FStyleFormat'] {     prototype:[object #23, class 'Object'] {       addListener:[function 'addListener'],       removeListener:[function 'removeListener'],       applyChanges:[function 'applyChanges'],       isAStyle:[function 'isAStyle']     }   }   Variable _global.globalStyleFormat = [object #28, class 'Object'] {     nonStyles:[object #29, class 'Object'] {       applyChanges:true,       nonStyles:true,       removeListener:true,       addListener:true,       isAStyle:true,       isGlobal:true,       listeners:true     },     listeners:[object #30, class 'Object'] {       _level0.dropdownIN2:[movieclip:_level0.dropdownIN2],       _level0.dropdownIN:[movieclip:_level0.dropdownIN]     },     isGlobal:true   }   Variable _global._focusControl = [object #31, class 'Object'] {     onSetFocus:[function 'onSetFocus']   }   Variable _global._popUpLevel = 20001 Level #0: Variable _level0.$version = "WIN 10,2,153,2" Variable _level0.FUIComponentClass = [function 'FUIComponentClass'] {     prototype:[object #34, class 'MovieClip'] {       init:[function 'init'],       setEnabled:[function 'setEnabled'],       getEnabled:[function 'getEnabled'],       setSize:[function 'setSize'],       setChangeHandler:[function 'setChangeHandler'],       invalidate:[function 'invalidate'],       cleanUI:[function 'onEnterFrame'],       cleanUINotSize:[function 'cleanUINotSize'],       drawRect:[function 'drawRect'],       pressFocus:[function 'pressFocus'],       drawFocusRect:[function 'drawFocusRect'],       myOnSetFocus:[function 'myOnSetFocus'],       myOnKillFocus:[function 'myOnKillFocus'],       executeCallBack:[function 'executeCallBack'],       updateStyleProperty:[function 'updateStyleProperty'],       setStyleProperty:[function 'setStyleProperty'],       registerSkinElement:[function 'registerSkinElement']     }   } Variable _level0.FPushButtonClass = [function 'FPushButtonClass'] {     prototype:[object #53, class 'MovieClip'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #54, class 'Object'] {         stub:true       },       styleTable:[object #55, class 'Array'] [],       init:[function 'init'],       setHitArea:[function 'setHitArea'],       setSize:[function 'setSize'],       arrangeLabel:[function 'arrangeLabel'],       getLabel:[function 'getLabel'],       setLabel:[function 'setLabel'],       getEnabled:[function 'getEnabled'],       setEnabled:[function 'setEnabled'],       txtFormat:[function 'txtFormat'],       drawFrame:[function 'drawFrame'],       setClickHandler:[function 'setClickHandler'],       executeCallBack:[function 'executeCallBack'],       initContentPos:[function 'initContentPos'],       setBtnState:[function 'setBtnState'],       getBtnState:[function 'getBtnState'],       myOnSetFocus:[function 'myOnSetFocus'],       onPress:[function 'onPress'],       onRelease:[function 'onRelease'],       onRollOver:[function 'onRollOver'],       onRollOut:[function 'onRollOut'],       onReleaseOutside:[function 'onReleaseOutside'],       onDragOut:[function 'onDragOut'],       onDragOver:[function 'onDragOver'],       myOnKeyDown:[function 'myOnKeyDown'],       myOnKeyUp:[function 'myOnKeyUp'],       get_accRole:[function 'get_accRole'],       get_accName:[function 'get_accName'],       get_accState:[function 'get_accState'],       get_accDefaultAction:[function 'get_accDefaultAction'],       accDoDefaultAction:[function 'accDoDefaultAction']     }   } Variable _level0.FSelectableListClass = [function 'FSelectableListClass'] {     prototype:[object #87, class 'MovieClip'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #88, class 'Object'] {         stub:true       },       styleTable:[object #89, class 'Array'] [],       init:[function 'init'],       addItemAt:[function 'addItemAt'],       addItem:[function 'addItem'],       removeItemAt:[function 'removeItemAt'],       removeAll:[function 'removeAll'],       replaceItemAt:[function 'replaceItemAt'],       sortItemsBy:[function 'sortItemsBy'],       getLength:[function 'getLength'],       getSelectedIndex:[function 'getSelectedIndex'],       getSelectedItem:[function 'getSelectedItem'],       getItemAt:[function 'getItemAt'],       getEnabled:[function 'getEnabled'],       getValue:[function 'getValue'],       setSelectedIndex:[function 'setSelectedIndex'],       setDataProvider:[function 'setDataProvider'],       setItemSymbol:[function 'setItemSymbol'],       setEnabled:[function 'setEnabled'],       updateControl:[function 'updateControl'],       setSize:[function 'setSize'],       modelChanged:[function 'modelChanged'],       measureItmHgt:[function 'measureItmHgt'],       selectItem:[function 'selectItem'],       isSelected:[function 'isSelected'],       clearSelected:[function 'clearSelected'],       selectionHandler:[function 'selectionHandler'],       moveSelBy:[function 'moveSelBy'],       clickHandler:[function 'clickHandler'],       releaseHandler:[function 'releaseHandler'],       myOnSetFocus:[function 'myOnSetFocus'],       myOnKillFocus:[function 'myOnKillFocus']     }   } Variable _level0.FScrollBarClass = [function] {     prototype:[object #121, class 'MovieClip'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #122, class 'Object'] {         stub:true       },       styleTable:[object #123, class 'Array'] [         scrollTrack:[object #124, class 'Object'] {           useGlobal:true,           coloredMCs:[object #125, class 'Object'] {             _level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc:[movieclip:_le vel0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc],             _level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc:[movieclip:_lev el0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc]           }         }       ],       setHorizontal:[function 'setHorizontal'],       setScrollProperties:[function 'setScrollProperties'],       getScrollPosition:[function 'getScrollPosition'],       setScrollPosition:[function 'setScrollPosition'],       setLargeScroll:[function 'setLargeScroll'],       setSmallScroll:[function 'setSmallScroll'],       setEnabled:[function 'setEnabled'],       setSize:[function 'setSize'],       scrollIt:[function 'scrollIt'],       startDragThumb:[function 'startDragThumb'],       dragThumb:[function 'dragThumb'],       stopDragThumb:[function 'stopDragThumb'],       startTrackScroller:[function 'startTrackScroller'],       scrollInterval:[function 'scrollInterval'],       trackScroller:[function 'trackScroller'],       stopScrolling:[function 'stopScrolling'],       startUpScroller:[function 'startUpScroller'],       startDownScroller:[function 'startDownScroller'],       setScrollTarget:[function 'setScrollTarget'],       callback:[function 'callback'],       onTextChanged:[function 'onTextChanged'],       executeCallBack:[function 'executeCallBack']     }   } Variable _level0.FScrollSelectListClass = [function 'FScrollSelectListClass'] {     prototype:[object #149, class 'FUIComponentClass'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #150, class 'Object'] {         stub:true       },       styleTable:[object #151, class 'Array'] [],       selected:[object #152, class 'Array'] [],       numDisplayed:0,       topDisplayed:0,       lastSelected:0,       tabChildren:false,       getScrollPosition:[function 'getScrollPosition'],       setScrollPosition:[function 'setScrollPosition'],       setAutoHideScrollBar:[function 'setAutoHideScrollBar'],       setEnabled:[function 'setEnabled'],       setSize:[function 'setSize'],       modelChanged:[function 'modelChanged'],       initScrollBar:[function 'initScrollBar'],       scrollHandler:[function 'scrollHandler'],       clickHandler:[function 'clickHandler'],       releaseHandler:[function 'releaseHandler'],       dragScroll:[function 'dragScroll'],       myOnKeyDown:[function 'myOnKeyDown'],       findInputText:[function 'findInputText'],       findString:[function 'findString']     }   } Variable _level0.FSelectableItemClass = [function 'FSelectableItemClass'] {     prototype:[object #168, class 'MovieClip'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #169, class 'Object'] {         stub:true       },       styleTable:[object #170, class 'Array'] [],       init:[function 'init'],       drawItem:[function 'drawItem'],       setSize:[function 'setSize'],       setEnabled:[function 'setEnabled'],       layoutContent:[function 'layoutContent'],       displayContent:[function 'displayContent'],       getItemIndex:[function 'getItemIndex'],       getItemModel:[function 'getItemModel'],       getHostDataProvider:[function 'getHostDataProvider'],       setHighlighted:[function 'setHighlighted']     }   } Variable _level0.FComboBoxClass = [function 'FComboBoxClass'] {     prototype:[object #182, class 'FSelectableListClass'] {       enable:true,       focused:false,       useHandCursor:false,       _accImpl:[object #183, class 'Object'] {         stub:true       },       styleTable:[object #184, class 'Array'] [],       selected:[object #185, class 'Array'] [],       numDisplayed:0,       topDisplayed:0,       lastSelected:0,       tabChildren:false,       modelChanged:[function 'modelChanged'],       removeAll:[function 'removeAll'],       setSize:[function 'setSize'],       setDataProvider:[function 'setDataProvider'],       getValue:[function 'getValue'],       getRowCount:[function 'getRowCount'],       setRowCount:[function 'setRowCount'],       setEditable:[function 'setEditable'],       setEnabled:[function 'setEnabled'],       setSelectedIndex:[function 'setSelectedIndex'],       setValue:[function 'setValue'],       pressHandler:[function 'onPress'],       clickHandler:[function 'clickHandler'],       highlightTop:[function 'highlightTop'],       myOnSetFocus:[function 'myOnSetFocus'],       drawFocusRect:[function 'drawFocusRect'],       myOnKillFocus:[function 'myOnKillFocus'],       setPopUpLocation:[function 'setPopUpLocation'],       openOrClose:[function 'openOrClose'],       fireChange:[function 'fireChange'],       releaseHandler:[function 'releaseHandler'],       moveSelBy:[function 'moveSelBy'],       myOnKeyDown:[function 'myOnKeyDown'],       findInputText:[function 'findInputText'],       onLabelFocus:[function 'onLabelFocus'],       buttonPressHandler:[function 'buttonPressHandler']     }   } Variable _level0.FComboBoxItemClass = [function 'FComboBoxItemClass'] {     prototype:[object #213, class 'FUIComponentClass'] {       highlighted:false,       setSize:[function 'setSize']     }   } Variable _level0.listenerObject = [object #215, class 'Object'] {     change:[function 'change']   } Variable _level0.fade = undefined Movie Clip: Target="_level0.dropdownIN2" Variable _level0.dropdownIN2.editable = false Variable _level0.dropdownIN2.labels = [object #217, class 'Array'] [     0:"Choose Colour",     1:"Page Green"   ] Variable _level0.dropdownIN2.data = [object #218, class 'Array'] [     0:"PageGreen"   ] Variable _level0.dropdownIN2.rowCount = 2 Variable _level0.dropdownIN2.changeHandler = "onSelect" Variable _level0.dropdownIN2.superHolder = [movieclip:_level0.superHolder20000] Variable _level0.dropdownIN2.itemSymbol = "FComboBoxItemSymbol" Variable _level0.dropdownIN2.enable = true Variable _level0.dropdownIN2.focused = false Variable _level0.dropdownIN2.useHandCursor = false Variable _level0.dropdownIN2._accImpl = [object #219, class 'Object'] {     stub:true   } Variable _level0.dropdownIN2.styleTable = [object #220, class 'Array'] [     background:[object #221, class 'Object'] {       useGlobal:true,       coloredMCs:[object #222, class 'Object'] {         _level0.superHolder20000.container.boundingBox_mc.boundingBox:[movieclip:_level0.superHol der20000.container.boundingBox_mc.boundingBox],         _level0.superHolder20000.faderX.boundingBox:[movieclip:_level0.superHolder20000.faderX.bo undingBox],         _level0.dropdownIN2.proxyBox_mc.boundingBox:[movieclip:_level0.dropdownIN2.proxyBox_mc.bo undingBox]       }     },     selection:[object #223, class 'Object'] {       useGlobal:true,       coloredMCs:[object #224, class 'Object'] {         _level0.superHolder20000.container.fListItem0_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20000.container.fListItem0_mc.highlight_mc.highlight_mc],         _level0.superHolder20000.container.fListItem1_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20000.container.fListItem1_mc.highlight_mc.highlight_mc],         _level0.dropdownIN2.fLabel_mc.highlight_mc.highlight_mc:[movieclip:_level0.dropdownIN2.fL abel_mc.highlight_mc.highlight_mc]       }     },     arrow:[object #225, class 'Object'] {       useGlobal:true,       coloredMCs:[object #226, class 'Object'] {         _level0.dropdownIN2.downArrow.up.arrow_mc:[movieclip:_level0.dropdownIN2.downArrow.up.arr ow_mc]       }     },     face:[object #227, class 'Object'] {       useGlobal:true,       coloredMCs:[object #228, class 'Object'] {         _level0.dropdownIN2.downArrow.up.face_mc:[movieclip:_level0.dropdownIN2.downArrow.up.face _mc]       }     },     shadow:[object #229, class 'Object'] {       useGlobal:true,       coloredMCs:[object #230, class 'Object'] {         _level0.dropdownIN2.downArrow.up.shadow_mc:[movieclip:_level0.dropdownIN2.downArrow.up.sh adow_mc]       }     },     darkshadow:[object #231, class 'Object'] {       useGlobal:true,       coloredMCs:[object #232, class 'Object'] {         _level0.dropdownIN2.downArrow.up.darkshadow_mc:[movieclip:_level0.dropdownIN2.downArrow.u p.darkshadow_mc]       }     },     highlight:[object #233, class 'Object'] {       useGlobal:true,       coloredMCs:[object #234, class 'Object'] {         _level0.dropdownIN2.downArrow.up.highlight_mc:[movieclip:_level0.dropdownIN2.downArrow.up .highlight_mc]       }     },     highlight3D:[object #235, class 'Object'] {       useGlobal:true,       coloredMCs:[object #236, class 'Object'] {         _level0.dropdownIN2.downArrow.up.highlight3D_mc:[movieclip:_level0.dropdownIN2.downArrow. up.highlight3D_mc]       }     }   ] Variable _level0.dropdownIN2.tabEnabled = true Variable _level0.dropdownIN2.focusEnabled = true Variable _level0.dropdownIN2.tabChildren = false Variable _level0.dropdownIN2.tabFocused = true Variable _level0.dropdownIN2.methodTable = [object #237, class 'Object'] {} Variable _level0.dropdownIN2.keyListener = [object #238, class 'Object'] {     controller:[movieclip:_level0.dropdownIN2],     onKeyDown:[function 'onKeyDown'],     onKeyUp:[function 'onKeyUp']   } Variable _level0.dropdownIN2.numDisplayed = 2 Variable _level0.dropdownIN2.topDisplayed = 0 Variable _level0.dropdownIN2.lastSelected = 0 Variable _level0.dropdownIN2.dataProvider = [object #241, class 'DataProviderClass'] {     items:[object #242, class 'Array'] [       0:[object #243, class 'Object'] {         data:"PageGreen",         label:"Choose Colour",         __ID__:0       },       1:[object #244, class 'Object'] {         data:undefined,         label:"Page Green",         __ID__:1       }     ],     uniqueID:2,     views:[object #245, class 'Array'] [       0:[movieclip:_level0.dropdownIN2]     ]   } Variable _level0.dropdownIN2.permaScrollBar = false Variable _level0.dropdownIN2.width = 160 Variable _level0.dropdownIN2.height = 34.1 Variable _level0.dropdownIN2.topLabel = [object #243, class 'Object'] Variable _level0.dropdownIN2.opened = false Variable _level0.dropdownIN2.textStyle = [object #246, class 'TextFormat'] {     getTextExtent:[function],     font:[getter/setter] null,     size:[getter/setter] null,     color:[getter/setter] null,     url:[getter/setter] null,     target:[getter/setter] null,     bold:[getter/setter] null,     italic:[getter/setter] null,     underline:[getter/setter] null,     align:[getter/setter] null,     leftMargin:[getter/setter] null,     rightMargin:[getter/setter] null,     indent:[getter/setter] null,     leading:[getter/setter] null,     blockIndent:[getter/setter] null,     tabStops:[getter/setter] null,     bullet:[getter/setter] null,     display:[getter/setter] "block"   } Variable _level0.dropdownIN2.itmHgt = 18.05 Variable _level0.dropdownIN2.container_mc = [movieclip:_level0.superHolder20000.container] Variable _level0.dropdownIN2.upward = false Variable _level0.dropdownIN2.boundingBox_mc = [movieclip:_level0.superHolder20000.container.boundingBox_mc] Variable _level0.dropdownIN2.scrollBar_mc = undefined Variable _level0.dropdownIN2.onPress = [function 'onPress'] Variable _level0.dropdownIN2.trackAsMenu = true Variable _level0.dropdownIN2.fader = [movieclip:_level0.superHolder20000.faderX] Variable _level0.dropdownIN2.handlerObj = [movieclip:_level0] Variable _level0.dropdownIN2.onUnload = [function 'onUnload'] Variable _level0.dropdownIN2.selected = [object #249, class 'Array'] [     0:[object #250, class 'Object'] {       sIndex:0     }   ] Variable _level0.dropdownIN2.value = Variable _level0.dropdownIN2.changeFlag = false Movie Clip: Target="_level0.dropdownIN2.superClassAsset" Movie Clip: Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset" Variable _level0.dropdownIN2.superClassAsset.scrollBarAsset._targetInstanceName = Variable _level0.dropdownIN2.superClassAsset.scrollBarAsset.horizontal = false Movie Clip: Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc" Variable _level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc.component = [movieclip:_level0.dropdownIN2.superClassAsset.scrollBarAsset] Movie Clip: Target="_level0.dropdownIN2.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc" Movie Clip: Target="_level0.dropdownIN2.superClassAsset.superClassAsset" Movie Clip: Target="_level0.dropdownIN2.superClassAsset.superClassAsset.dPAsset" Movie Clip: Target="_level0.dropdownIN2.superClassAsset.superClassAsset.ItemAsset" Movie Clip: Target="_level0.dropdownIN2.itemAsset" Movie Clip: Target="_level0.dropdownIN2.proxyBox_mc" Variable _level0.dropdownIN2.proxyBox_mc.component = [movieclip:_level0.dropdownIN2] Movie Clip: Target="_level0.dropdownIN2.proxyBox_mc.boundingBox" Movie Clip: Target="_level0.dropdownIN2.deadPreview" Movie Clip: Target="_level0.dropdownIN2.fLabel_mc" Variable _level0.dropdownIN2.fLabel_mc.itemNum = -1 Variable _level0.dropdownIN2.fLabel_mc.controller = [movieclip:_level0.dropdownIN2] Variable _level0.dropdownIN2.fLabel_mc.highlighted = false Variable _level0.dropdownIN2.fLabel_mc.onRollOver = undefined Variable _level0.dropdownIN2.fLabel_mc.width = 142.95 Variable _level0.dropdownIN2.fLabel_mc.oldFocus = false Movie Clip: Target="_level0.dropdownIN2.fLabel_mc.highlight_mc" Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.controller = [movieclip:_level0.dropdownIN2.fLabel_mc] Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.trackAsMenu = true Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.useHandCursor = false Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.dropdownIN2.fLabel_mc.highlight_mc.component = [movieclip:_level0.dropdownIN2] Movie Clip: Target="_level0.dropdownIN2.fLabel_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.dropdownIN2.fLabel_mc.fLabel_mc" Variable _level0.dropdownIN2.fLabel_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN2] Variable _level0.dropdownIN2.fLabel_mc.fLabel_mc.textStyle = [object #246, class 'TextFormat'] Variable _level0.dropdownIN2.fLabel_mc.fLabel_mc.enable = true Edit Text: Target="_level0.dropdownIN2.fLabel_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 84, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #254, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Choose Colour
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 13,     variable = null, restrict = null, selectable = false,     text = "Choose Colour",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.dropdownIN2.downArrow" Movie Clip: Target="_level0.dropdownIN2.downArrow.up" Variable _level0.dropdownIN2.downArrow.up.component = [movieclip:_level0.dropdownIN2] Movie Clip: Target="_level0.dropdownIN2.downArrow.up.face_mc" Movie Clip: Target="_level0.dropdownIN2.downArrow.up.arrow_mc" Movie Clip: Target="_level0.dropdownIN2.downArrow.up.highlight_mc" Movie Clip: Target="_level0.dropdownIN2.downArrow.up.shadow_mc" Movie Clip: Target="_level0.dropdownIN2.downArrow.up.darkshadow_mc" Movie Clip: Target="_level0.dropdownIN2.downArrow.up.highlight3D_mc" Movie Clip: Target="_level0.dropdownIN" Variable _level0.dropdownIN.editable = false Variable _level0.dropdownIN.labels = [object #255, class 'Array'] [     0:"Choose Colour",     1:"Page Yellow",     2:"Page Blue",     3:"Page Red"   ] Variable _level0.dropdownIN.data = [object #256, class 'Array'] [     0:"PageYellow",     1:"PageBlue",     2:"PageRed"   ] Variable _level0.dropdownIN.rowCount = 4 Variable _level0.dropdownIN.changeHandler = "onSelect" Variable _level0.dropdownIN.superHolder = [movieclip:_level0.superHolder20001] Variable _level0.dropdownIN.itemSymbol = "FComboBoxItemSymbol" Variable _level0.dropdownIN.enable = true Variable _level0.dropdownIN.focused = false Variable _level0.dropdownIN.useHandCursor = false Variable _level0.dropdownIN._accImpl = [object #257, class 'Object'] {     stub:true   } Variable _level0.dropdownIN.styleTable = [object #258, class 'Array'] [     background:[object #259, class 'Object'] {       useGlobal:true,       coloredMCs:[object #260, class 'Object'] {         _level0.superHolder20001.container.boundingBox_mc.boundingBox:[movieclip:_level0.superHol der20001.container.boundingBox_mc.boundingBox],         _level0.superHolder20001.faderX.boundingBox:[movieclip:_level0.superHolder20001.faderX.bo undingBox],         _level0.dropdownIN.proxyBox_mc.boundingBox:[movieclip:_level0.dropdownIN.proxyBox_mc.boun dingBox]       }     },     selection:[object #261, class 'Object'] {       useGlobal:true,       coloredMCs:[object #262, class 'Object'] {         _level0.superHolder20001.container.fListItem0_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20001.container.fListItem0_mc.highlight_mc.highlight_mc],         _level0.superHolder20001.container.fListItem1_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20001.container.fListItem1_mc.highlight_mc.highlight_mc],         _level0.superHolder20001.container.fListItem2_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20001.container.fListItem2_mc.highlight_mc.highlight_mc],         _level0.superHolder20001.container.fListItem3_mc.highlight_mc.highlight_mc:[movieclip:_le vel0.superHolder20001.container.fListItem3_mc.highlight_mc.highlight_mc],         _level0.dropdownIN.fLabel_mc.highlight_mc.highlight_mc:[movieclip:_level0.dropdownIN.fLab el_mc.highlight_mc.highlight_mc]       }     },     arrow:[object #263, class 'Object'] {       useGlobal:true,       coloredMCs:[object #264, class 'Object'] {         _level0.dropdownIN.downArrow.up.arrow_mc:[movieclip:_level0.dropdownIN.downArrow.up.arrow _mc]       }     },     face:[object #265, class 'Object'] {       useGlobal:true,       coloredMCs:[object #266, class 'Object'] {         _level0.dropdownIN.downArrow.up.face_mc:[movieclip:_level0.dropdownIN.downArrow.up.face_m c]       }     },     shadow:[object #267, class 'Object'] {       useGlobal:true,       coloredMCs:[object #268, class 'Object'] {         _level0.dropdownIN.downArrow.up.shadow_mc:[movieclip:_level0.dropdownIN.downArrow.up.shad ow_mc]       }     },     darkshadow:[object #269, class 'Object'] {       useGlobal:true,       coloredMCs:[object #270, class 'Object'] {         _level0.dropdownIN.downArrow.up.darkshadow_mc:[movieclip:_level0.dropdownIN.downArrow.up. darkshadow_mc]       }     },     highlight:[object #271, class 'Object'] {       useGlobal:true,       coloredMCs:[object #272, class 'Object'] {         _level0.dropdownIN.downArrow.up.highlight_mc:[movieclip:_level0.dropdownIN.downArrow.up.h ighlight_mc]       }     },     highlight3D:[object #273, class 'Object'] {       useGlobal:true,       coloredMCs:[object #274, class 'Object'] {         _level0.dropdownIN.downArrow.up.highlight3D_mc:[movieclip:_level0.dropdownIN.downArrow.up .highlight3D_mc]       }     }   ] Variable _level0.dropdownIN.tabEnabled = true Variable _level0.dropdownIN.focusEnabled = true Variable _level0.dropdownIN.tabChildren = false Variable _level0.dropdownIN.tabFocused = true Variable _level0.dropdownIN.methodTable = [object #275, class 'Object'] {} Variable _level0.dropdownIN.keyListener = [object #276, class 'Object'] {     controller:[movieclip:_level0.dropdownIN],     onKeyDown:[function 'onKeyDown'],     onKeyUp:[function 'onKeyUp']   } Variable _level0.dropdownIN.numDisplayed = 4 Variable _level0.dropdownIN.topDisplayed = 0 Variable _level0.dropdownIN.lastSelected = 0 Variable _level0.dropdownIN.dataProvider = [object #279, class 'DataProviderClass'] {     items:[object #280, class 'Array'] [       0:[object #281, class 'Object'] {         data:"PageYellow",         label:"Choose Colour",         __ID__:0       },       1:[object #282, class 'Object'] {         data:"PageBlue",         label:"Page Yellow",         __ID__:1       },       2:[object #283, class 'Object'] {         data:"PageRed",         label:"Page Blue",         __ID__:2       },       3:[object #284, class 'Object'] {         data:undefined,         label:"Page Red",         __ID__:3       }     ],     uniqueID:4,     views:[object #285, class 'Array'] [       0:[movieclip:_level0.dropdownIN]     ]   } Variable _level0.dropdownIN.permaScrollBar = false Variable _level0.dropdownIN.width = 160 Variable _level0.dropdownIN.height = 66.2 Variable _level0.dropdownIN.topLabel = [object #281, class 'Object'] Variable _level0.dropdownIN.opened = false Variable _level0.dropdownIN.textStyle = [object #286, class 'TextFormat'] {     getTextExtent:[function],     font:[getter/setter] null,     size:[getter/setter] null,     color:[getter/setter] null,     url:[getter/setter] null,     target:[getter/setter] null,     bold:[getter/setter] null,     italic:[getter/setter] null,     underline:[getter/setter] null,     align:[getter/setter] null,     leftMargin:[getter/setter] null,     rightMargin:[getter/setter] null,     indent:[getter/setter] null,     leading:[getter/setter] null,     blockIndent:[getter/setter] null,     tabStops:[getter/setter] null,     bullet:[getter/setter] null,     display:[getter/setter] "block"   } Variable _level0.dropdownIN.itmHgt = 18.05 Variable _level0.dropdownIN.container_mc = [movieclip:_level0.superHolder20001.container] Variable _level0.dropdownIN.upward = false Variable _level0.dropdownIN.boundingBox_mc = [movieclip:_level0.superHolder20001.container.boundingBox_mc] Variable _level0.dropdownIN.scrollBar_mc = undefined Variable _level0.dropdownIN.onPress = [function 'onPress'] Variable _level0.dropdownIN.trackAsMenu = true Variable _level0.dropdownIN.fader = [movieclip:_level0.superHolder20001.faderX] Variable _level0.dropdownIN.handlerObj = [movieclip:_level0] Variable _level0.dropdownIN.onUnload = [function 'onUnload'] Variable _level0.dropdownIN.selected = [object #289, class 'Array'] [     0:[object #290, class 'Object'] {       sIndex:0     }   ] Variable _level0.dropdownIN.value = Variable _level0.dropdownIN.changeFlag = false Movie Clip: Target="_level0.dropdownIN.superClassAsset" Movie Clip: Target="_level0.dropdownIN.superClassAsset.scrollBarAsset" Variable _level0.dropdownIN.superClassAsset.scrollBarAsset._targetInstanceName = Variable _level0.dropdownIN.superClassAsset.scrollBarAsset.horizontal = false Movie Clip: Target="_level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc" Variable _level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc.component = [movieclip:_level0.dropdownIN.superClassAsset.scrollBarAsset] Movie Clip: Target="_level0.dropdownIN.superClassAsset.scrollBarAsset.scrollTrack_mc.track_mc" Movie Clip: Target="_level0.dropdownIN.superClassAsset.superClassAsset" Movie Clip: Target="_level0.dropdownIN.superClassAsset.superClassAsset.dPAsset" Movie Clip: Target="_level0.dropdownIN.superClassAsset.superClassAsset.ItemAsset" Movie Clip: Target="_level0.dropdownIN.itemAsset" Movie Clip: Target="_level0.dropdownIN.proxyBox_mc" Variable _level0.dropdownIN.proxyBox_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.dropdownIN.proxyBox_mc.boundingBox" Movie Clip: Target="_level0.dropdownIN.deadPreview" Movie Clip: Target="_level0.dropdownIN.fLabel_mc" Variable _level0.dropdownIN.fLabel_mc.itemNum = -1 Variable _level0.dropdownIN.fLabel_mc.controller = [movieclip:_level0.dropdownIN] Variable _level0.dropdownIN.fLabel_mc.highlighted = false Variable _level0.dropdownIN.fLabel_mc.onRollOver = undefined Variable _level0.dropdownIN.fLabel_mc.width = 142.95 Variable _level0.dropdownIN.fLabel_mc.oldFocus = false Movie Clip: Target="_level0.dropdownIN.fLabel_mc.highlight_mc" Variable _level0.dropdownIN.fLabel_mc.highlight_mc.controller = [movieclip:_level0.dropdownIN.fLabel_mc] Variable _level0.dropdownIN.fLabel_mc.highlight_mc.trackAsMenu = true Variable _level0.dropdownIN.fLabel_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.dropdownIN.fLabel_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.dropdownIN.fLabel_mc.highlight_mc.useHandCursor = false Variable _level0.dropdownIN.fLabel_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.dropdownIN.fLabel_mc.highlight_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.dropdownIN.fLabel_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.dropdownIN.fLabel_mc.fLabel_mc" Variable _level0.dropdownIN.fLabel_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN] Variable _level0.dropdownIN.fLabel_mc.fLabel_mc.textStyle = [object #286, class 'TextFormat'] Variable _level0.dropdownIN.fLabel_mc.fLabel_mc.enable = true Edit Text: Target="_level0.dropdownIN.fLabel_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 84, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #294, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Choose Colour
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 13,     variable = null, restrict = null, selectable = false,     text = "Choose Colour",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.dropdownIN.downArrow" Movie Clip: Target="_level0.dropdownIN.downArrow.up" Variable _level0.dropdownIN.downArrow.up.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.dropdownIN.downArrow.up.face_mc" Movie Clip: Target="_level0.dropdownIN.downArrow.up.arrow_mc" Movie Clip: Target="_level0.dropdownIN.downArrow.up.highlight_mc" Movie Clip: Target="_level0.dropdownIN.downArrow.up.shadow_mc" Movie Clip: Target="_level0.dropdownIN.downArrow.up.darkshadow_mc" Movie Clip: Target="_level0.dropdownIN.downArrow.up.highlight3D_mc" Edit Text: Target="_level0.instance1"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 232, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #295, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Start Page
                        ",     textHeight = 29, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = true, length = 11,     variable = null, restrict = null, selectable = false,     text = "Start Page\r",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20000" Movie Clip: Target="_level0.superHolder20000.container" Variable _level0.superHolder20000.container.tabChildren = false Movie Clip: Target="_level0.superHolder20000.container.boundingBox_mc" Variable _level0.superHolder20000.container.boundingBox_mc.component = [movieclip:_level0.superHolder20000.container] Movie Clip: Target="_level0.superHolder20000.container.boundingBox_mc.boundingBox" Movie Clip: Target="_level0.superHolder20000.container.fListItem0_mc" Variable _level0.superHolder20000.container.fListItem0_mc.itemNum = 0 Variable _level0.superHolder20000.container.fListItem0_mc.controller = [movieclip:_level0.dropdownIN2] Variable _level0.superHolder20000.container.fListItem0_mc.highlighted = true Variable _level0.superHolder20000.container.fListItem0_mc.width = 160 Variable _level0.superHolder20000.container.fListItem0_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20000.container.fListItem0_mc.highlight_mc" Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.controller = [movieclip:_level0.superHolder20000.container.fListItem0_mc] Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20000.container.fListItem0_mc.highlight_mc.component = [movieclip:_level0.dropdownIN2] Movie Clip: Target="_level0.superHolder20000.container.fListItem0_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20000.container.fListItem0_mc.fLabel_mc" Variable _level0.superHolder20000.container.fListItem0_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN2] Variable _level0.superHolder20000.container.fListItem0_mc.fLabel_mc.textStyle = [object #246, class 'TextFormat'] Variable _level0.superHolder20000.container.fListItem0_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20000.container.fListItem0_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 84, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #299, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Choose Colour
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 16777215, multiline = false, length = 13,     variable = null, restrict = null, selectable = false,     text = "Choose Colour",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20000.container.fListItem1_mc" Variable _level0.superHolder20000.container.fListItem1_mc.itemNum = 1 Variable _level0.superHolder20000.container.fListItem1_mc.controller = [movieclip:_level0.dropdownIN2] Variable _level0.superHolder20000.container.fListItem1_mc.highlighted = false Variable _level0.superHolder20000.container.fListItem1_mc.width = 160 Variable _level0.superHolder20000.container.fListItem1_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20000.container.fListItem1_mc.highlight_mc" Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.controller = [movieclip:_level0.superHolder20000.container.fListItem1_mc] Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20000.container.fListItem1_mc.highlight_mc.component = [movieclip:_level0.dropdownIN2] Movie Clip: Target="_level0.superHolder20000.container.fListItem1_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20000.container.fListItem1_mc.fLabel_mc" Variable _level0.superHolder20000.container.fListItem1_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN2] Variable _level0.superHolder20000.container.fListItem1_mc.fLabel_mc.textStyle = [object #246, class 'TextFormat'] Variable _level0.superHolder20000.container.fListItem1_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20000.container.fListItem1_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 66, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #303, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Page Green
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 10,     variable = null, restrict = null, selectable = false,     text = "Page Green",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20000.faderX" Variable _level0.superHolder20000.faderX.component = [movieclip:_level0.superHolder20000] Movie Clip: Target="_level0.superHolder20000.faderX.boundingBox" Movie Clip: Target="_level0.superHolder20001" Movie Clip: Target="_level0.superHolder20001.container" Variable _level0.superHolder20001.container.tabChildren = false Movie Clip: Target="_level0.superHolder20001.container.boundingBox_mc" Variable _level0.superHolder20001.container.boundingBox_mc.component = [movieclip:_level0.superHolder20001.container] Movie Clip: Target="_level0.superHolder20001.container.boundingBox_mc.boundingBox" Movie Clip: Target="_level0.superHolder20001.container.fListItem0_mc" Variable _level0.superHolder20001.container.fListItem0_mc.itemNum = 0 Variable _level0.superHolder20001.container.fListItem0_mc.controller = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem0_mc.highlighted = true Variable _level0.superHolder20001.container.fListItem0_mc.width = 160 Variable _level0.superHolder20001.container.fListItem0_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20001.container.fListItem0_mc.highlight_mc" Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.controller = [movieclip:_level0.superHolder20001.container.fListItem0_mc] Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20001.container.fListItem0_mc.highlight_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.superHolder20001.container.fListItem0_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20001.container.fListItem0_mc.fLabel_mc" Variable _level0.superHolder20001.container.fListItem0_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem0_mc.fLabel_mc.textStyle = [object #286, class 'TextFormat'] Variable _level0.superHolder20001.container.fListItem0_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20001.container.fListItem0_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 84, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #307, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Choose Colour
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 16777215, multiline = false, length = 13,     variable = null, restrict = null, selectable = false,     text = "Choose Colour",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20001.container.fListItem1_mc" Variable _level0.superHolder20001.container.fListItem1_mc.itemNum = 1 Variable _level0.superHolder20001.container.fListItem1_mc.controller = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem1_mc.highlighted = false Variable _level0.superHolder20001.container.fListItem1_mc.width = 160 Variable _level0.superHolder20001.container.fListItem1_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20001.container.fListItem1_mc.highlight_mc" Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.controller = [movieclip:_level0.superHolder20001.container.fListItem1_mc] Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20001.container.fListItem1_mc.highlight_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.superHolder20001.container.fListItem1_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20001.container.fListItem1_mc.fLabel_mc" Variable _level0.superHolder20001.container.fListItem1_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem1_mc.fLabel_mc.textStyle = [object #286, class 'TextFormat'] Variable _level0.superHolder20001.container.fListItem1_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20001.container.fListItem1_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 68, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #311, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Page Yellow
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 11,     variable = null, restrict = null, selectable = false,     text = "Page Yellow",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20001.container.fListItem2_mc" Variable _level0.superHolder20001.container.fListItem2_mc.itemNum = 2 Variable _level0.superHolder20001.container.fListItem2_mc.controller = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem2_mc.highlighted = false Variable _level0.superHolder20001.container.fListItem2_mc.width = 160 Variable _level0.superHolder20001.container.fListItem2_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20001.container.fListItem2_mc.highlight_mc" Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.controller = [movieclip:_level0.superHolder20001.container.fListItem2_mc] Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20001.container.fListItem2_mc.highlight_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.superHolder20001.container.fListItem2_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20001.container.fListItem2_mc.fLabel_mc" Variable _level0.superHolder20001.container.fListItem2_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem2_mc.fLabel_mc.textStyle = [object #286, class 'TextFormat'] Variable _level0.superHolder20001.container.fListItem2_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20001.container.fListItem2_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 57, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #315, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Page Blue
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 9,     variable = null, restrict = null, selectable = false,     text = "Page Blue",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20001.container.fListItem3_mc" Variable _level0.superHolder20001.container.fListItem3_mc.itemNum = 3 Variable _level0.superHolder20001.container.fListItem3_mc.controller = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem3_mc.highlighted = false Variable _level0.superHolder20001.container.fListItem3_mc.width = 160 Variable _level0.superHolder20001.container.fListItem3_mc.oldFocus = false Movie Clip: Target="_level0.superHolder20001.container.fListItem3_mc.highlight_mc" Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.controller = [movieclip:_level0.superHolder20001.container.fListItem3_mc] Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.trackAsMenu = true Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.onPress = [function 'onPress'] Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.onDragOver = [function 'onDragOver'] Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.useHandCursor = false Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.onRollOver = [function 'onRollOver'] Variable _level0.superHolder20001.container.fListItem3_mc.highlight_mc.component = [movieclip:_level0.dropdownIN] Movie Clip: Target="_level0.superHolder20001.container.fListItem3_mc.highlight_mc.highlight_mc" Movie Clip: Target="_level0.superHolder20001.container.fListItem3_mc.fLabel_mc" Variable _level0.superHolder20001.container.fListItem3_mc.fLabel_mc.hostComponent = [movieclip:_level0.dropdownIN] Variable _level0.superHolder20001.container.fListItem3_mc.fLabel_mc.textStyle = [object #286, class 'TextFormat'] Variable _level0.superHolder20001.container.fListItem3_mc.fLabel_mc.enable = true Edit Text: Target="_level0.superHolder20001.container.fListItem3_mc.fLabel_mc.labelField"     styleSheet = undefined, thickness = 0,     autoSize = "none",     bottomScroll = 1, textWidth = 55, wordWrap = false, hscroll = 0,     maxChars = null, sharpness = 0, html = true, borderColor = 0,     border = false, filters = [object #319, class 'Array'] [],     antiAliasType = "normal",     htmlText = "
                        Page Red
                        ",     textHeight = 16, password = false, mouseWheelEnabled = true, embedFonts = false,     backgroundColor = 16777215, condenseWhite = false, maxscroll = 1,     gridFitType = "pixel",     tabIndex = undefined, textColor = 0, multiline = false, length = 8,     variable = null, restrict = null, selectable = false,     text = "Page Red",     scroll = 1, background = false,     type = "dynamic",     maxhscroll = 0 Movie Clip: Target="_level0.superHolder20001.faderX" Variable _level0.superHolder20001.faderX.component = [movieclip:_level0.superHolder20001] Movie Clip: Target="_level0.superHolder20001.faderX.boundingBox"
                        • 9. Re: Issue with Combo box AS2
                          Ned Murphy MVP
                          Same here
                          • 10. Re: Issue with Combo box AS2
                            BinaryBloke Community Member
                            Going back to basics. The original code that worked only when one combo was used. The combo had a 'change handler' value on the combo box called 'onSelect'. Does this need to be referenced anywhere.
                            • 11. Re: Issue with Combo box AS2
                              Ned Murphy MVP
                              Going back to basics, you need to determine what data you are after.  I do not know what is represented by the data you are trying to use, which are...
                              You need to resolve the data to be what it is supposed to be.
