2 Replies Latest reply on Jul 12, 2012 10:55 PM by AshishSPanwar
    Rollout results in error
    AshishSPanwar Level 2
      I am using CQ 5.4 MSM to create live copies out of master site. I am not using blueprint page approach here. So I use
      New -> New live copy option.
      I noticed that while trying to rollout changes made in the master site to multiple livecopies resulted in an error. So while rolling out changes to 3 live copies, only two were updated and the third threw the following error.
      Caused by: javax.jcr.InvalidItemStateException: property /content/site/en/student/jcr:content/par/media/jcr:lastModified: the property cannot be saved because it has been modified externally.
          at org.apache.jackrabbit.core.PropertyImpl.makePersistent(PropertyImpl.java:155)
          at org.apache.jackrabbit.core.ItemSaveOperation.persistTransientItems(ItemSaveOperation.java :835)
          at org.apache.jackrabbit.core.ItemSaveOperation.perform(ItemSaveOperation.java:243)
          at org.apache.jackrabbit.core.session.SessionState.perform(SessionState.java:200)
          at org.apache.jackrabbit.core.ItemImpl.perform(ItemImpl.java:91)
          at org.apache.jackrabbit.core.ItemImpl.save(ItemImpl.java:329)
          at org.apache.jackrabbit.core.session.SessionSaveOperation.perform(SessionSaveOperation.java :42)
          at org.apache.jackrabbit.core.SessionImpl.perform(SessionImpl.java:355)
          at org.apache.jackrabbit.core.SessionImpl.save(SessionImpl.java:758)
          at com.day.crx.core.CRXSessionImpl.save(CRXSessionImpl.java:126)
          at com.day.cq.wcm.msm.impl.RolloutManagerImpl.executePageRollout(RolloutManagerImpl.java:494 )
          ... 62 more
      I've tried rolling out via sidekick and MSM control center and get the same error. Rolling out changes to a single livecopy works as expected without any error.
      In some other posts I came across, it was mentioned that it might be a Sling issue while trying to modify multiple nodes? If so how to resolve this? Has Adobe provided a hotfix for this?
      Any pointers on this? Am I missing something here?
      - Ashish
        • 1. Re: Rollout results in error
          Sham HC Level 7
          Hi Ashish,
            Though i do not have complete logs seems like you are hitting an know issue.   Please follow [1] as a temporary workaround to fix. This issue is resolved in CQ5.5.
          * Go to /system/console/configMgr/com.day.cq.wcm.msm.impl.RolloutManagerImpl web app and login as admin
          * Add "jcr:lastModified" under the "Excluded Paragraph Properties"
          * Save
          * if that configuration fixed the problem then make the same configuration at the repository level under apps using a sling:OsgiConfig
          • 2. Re: Rollout results in error
            Thanks Sham, it works!!
            Although I have also raised a daycare ticket for the hotfix that fixes this issue.
            Thanks for your prompt reply.
            - Ashish
