19 Replies Latest reply on Jul 20, 2012 7:48 PM by jodaboda1
    Help with computer setup and PP settings for faster/better previews
    jodaboda1 Level 1
      I have been using Cyberlink PowerDirector software for video editing.  It is very easy to use and can do quite a bit.  It was also accelerated by Intel HD graphics built into my system, so I could see a lot of my work at a pretty high resolution in real time.
      However, I wanted to see what PP was capable of, specifically the Warp Stabilizer.
      So I downloaded PP and have been trying to use it, but it was just slow as heck to preview anything (chop stop chop stop...), with render times being insanely long (12 hours for five minutes of footage vs. about 30 minutes with PowerDirector).
      Thinking it was a problem with my system and I needed to get a real graphics card, I got an EVGA GTX 670 (FTW) for $400, and popped it in.  I modified the text file so PP would see it as a compatible card, opened up PP and changed the engine to the new card.
      Things are faster, but I was expecting a lot more.  Here's what I'm doing:
      1. Shooting Canon 5D mark II (now III) clips 20-60 seconds long, 1080p.
      2. Import to PP and sequence them.
      3. Adding effects:
           A. Top adjustment layer for fast color correction (white balance)
           B. Next adjustment layer: 3-way color, shadow/highlight, unsharp mask, fast blur
           C. Video 1 layer has the clips with warp stabilizer applied to each, and dissolves.
      My final output will be 720p.  ( I shoot 1080p so the Warp Stabilizer will have more to work with, and I can crop without feeling like I'm degrading quality).
      My system: i7 2600k, 16GB RAM, GTX 670 graphics, 120GB SSD "Max IOPS", 2TB 7200rpm internal, 2TB 7200rpm external (USB 2.0, backup drive).
      I can currently preview at 1/4 res in realtime.  I would really like to be able to get to 1/2 res (of course full would be great).  One thing that worries me is that GPU-Z indicates that my GPU is only running at about 2% while previewing, while CPU usage is at around 50%.  I was under the impression that the Mercury thing would use GPU/CUDA to process previews and effects that are supported (that includes Warp Stabilizer).
      I've looked at Sequence Settings and fiddled with Preview File Format and size, but that doesn't seem to do anything.  I'm currently looking around at codecs (Cineform, DNxHD), but don't know if those can help.
      What settings should I alter to get better previews?
