0 Replies Latest reply on Jul 10, 2012 9:42 PM by strangereason
    I have the same problem w/ 2 different vcams
    strangereason
      Okay peoples,
      I'm putting together an animation in Flash CS4, on a MacBook Pro running OS X 10.5.8, and I positively need to be able to use the vcam (of course!).  But I can't make it work.
      Essentially, when I try to test or publish the movie w/ the vcam in the top layer as a tween (motion or Classic), the player won't recognize the vcam window dimensions as the player window dimensions - so, for example, everything remains the same size; I can see the vcam viewfinder as it is in creative mode, and it will move and change dimension as the tween dictates, but it is impossible to make the movie 'see' through the vcam's perspective, thus making zooming and panning - the only reasons to use a vcam - impossible - void.
      To be very honest, I have a similar problem w/ the only other vcam being offered out there, through YouTube, for free - which is why I'm bringing this to the forums - I'm probably doing something wrong with both vcams.
      I notice generally that some very knowledgeable people here don't even recommend vcams but rather 'old fashioned', sleeve-rolling animation, re-sizing symbols, etc.  I will do that if I must.  But I have to try and ask for your collective assistance.
      I.  need.  your.  help.  ...for whatever it is worth: THANK YOU.
      the compiler errors I get from trying to test or publish the more common AS3 vcam are these:
      Location  /  Description  /  Source
      Symbol=VCam_AS3, layer=actions, frame=1, Line 33  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 37  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 59  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 81  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 95  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 105  /
      Symbol=VCam_AS3, layer=actions, frame=1, Line 110  /
      Symbol=field_guide_encoding_BG, layer=Layer 1, frame=1, Line 1  /
      The class or interface 'Event' could not be loaded.  /
      A type identifier is expected after the ':'.  /
      The class or interface 'Matrix' could not be loaded.  /
      The class or interface 'ColorTransform' could not be loaded.  /
      The class or interface 'FieldGuideEncodingBG' could not be loaded.  /
      function onAdded(e:Event):void{
      function init():void{
      function onFrame(e:Event):void{
      var matrix:Matrix=this.transform.matrix.clone();
      function reset(e:Event):void{
      var matrix:Matrix=new Matrix();
      var ct:ColorTransform=new ColorTransform();
      (no source for the final Location/Description)
      here are the compiler errors I receive when trying to test or publish the movie w/ the other, 'Self-Rendering' vcam that's out there, available and demonstrated on YouTube:
      Symbol=vcam 4x3, layer=Layer 3, frame=1, Line 58  /
      Symbol=vcam 4x3, layer=Layer 3, frame=1, Line 61  /
      Symbol=vcam 4x3, layer=Layer 3, frame=1, Line 63  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 15  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 19  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 37  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 41  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 65  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 76  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 82  /
      Symbol=navbar - clip, layer=Layer3, frame=1, Line 89Symbol=field_guide_encoding_BG, layer=Layer 1, frame=1, Line 1  /
      The class or interface 'uint' could not be loaded.  /
      Syntax error.  /
      The class or interface 'MouseEvent' could not be loaded.  /
      The class or interface 'Point' could not be loaded.  /
      The class or interface 'int' could not be loaded.  /
      var encoding_bg: FieldGuideEncodingBG;  /
      var frameCount:uint;  /
      const PNG_NUMBER_LEN:uint = 5;  /
      function mouseClickHandler(evt: MouseEvent)  /
      var mouse_pos: Point = root.globalToLocal(new Point(evt.stageX, evt.stageY));  /
      function mouseReleaseHandler(evt: MouseEvent)    function mouseReleaseHandler(evt:
      MouseEvent)  /
      function enterFrameHandler(evt: Event)  /
      var new_pos: int = ((mcSeekHandle.x - bound_l) / bound_width) * MovieClip(root).totalFrames + 1;  /
      function onAddedToStage(evt: Event)  /
      function onRemovedFromStage(evt: Event)  /
