5 Replies Latest reply on Apr 21, 2008 9:52 PM by Ben Keen
    How to insert multiple rows into database at once?
    Ben Keen
      I was wondering if someone knew a way to insert multiple rows into a SQL Lite database table at once, using the same SQLStatement(); Inserting them one-by-one requires a great deal of code.
      Thanks!
      - Ben
        • 1. Re: How to insert multiple rows into database at once?
          Stephen Cox
          Wait. You want to be able to run multiple inserts at the same time into the same table?
          • 2. Re: How to insert multiple rows into database at once?
            Ben Keen Level 1
            Well, yeah. Like:
            INSERT INTO table ...
            or
            INSERT INTO table (col1, col2) VALUES
            (val1, val2),
            (val3, val4),
            (val5, val6)
            The problem is that performing a single query is very verbose, e.g.
            var insert = new air.SQLStatement();
            insert.sqlConnection = db.conn;
            var sql = "INSERT INTO table (col1, col2) VALUES (val1, val2)";
            insert.text = sql;
            insert.addEventListener(air.SQLEvent.RESULT, insertResult);
            insert.addEventListener(air.SQLErrorEvent.ERROR, insertError);
            insert.execute();
            • 3. Re: How to insert multiple rows into database at once?
              enorton@adobe Adobe Employee
              Hi Ben,
              You should use parameters in your INSERT statement for the values. It will provide you better performance as well.
              I recommend reading the chapter in the on line docs on using SQL:
              http://livedocs.adobe.com/air/1/devappsflash/SQL_01.html
              var sql = "INSERT INTO table (col1, col2) VALUES (:val1, :val2)";
              insert.text = sql;
              insert.parameters[":val1"] = val1;
              insert.parameters[":val2"] = val2;
              I hope this helps!
              -Erica
              • 4. How to insert multiple rows into database at once?
                DonMitchinson Level 2
                Hi Ben:
                With SQLite you should be able to do it in one statement using the first example you provided - but not the second.
                Make sure to wrap in a transaction though.
                Haven't read the AIR SQL API carefully, but something like this should work:
                var sql = "BEGIN TRANSACTION;"
                sql = sql + "INSERT INTO table (col1, col2) VALUES (A1, B1)";
                sql = sql + "INSERT INTO table (col1, col2) VALUES (A2, B2)";
                sql = sql + "INSERT INTO table (col1, col2) VALUES (A3, B3)";
                sql = sql + "INSERT INTO table (col1, col2) VALUES (An, Bn)";
                sql = sql + "END TRANSACTION;"
                insert.text = sql;
                insert.execute();
                Don
                • 5. Re: How to insert multiple rows into database at once?
                  Ben Keen Level 1
                  Erica - thanks for the tip! Good to know.
                  Don - yes, transactions was the key. Here's the syntax, for anyone that stumbles upon this thread.
                  quote:
                  var query = new air.SQLStatement();
                  query.sqlConnection = db.conn;
                  query.sqlConnection.begin();
                  query.text =
                  "CREATE TABLE IF NOT EXISTS mytable (" +
                  " table_id INTEGER PRIMARY KEY AUTOINCREMENT, " +
                  " table_col TEXT " +
                  "INSERT INTO dg_cities (table_id, table_col) VALUES (1, 'one');" +
                  "INSERT INTO dg_cities (table_id, table_col) VALUES (2, 'two');" +
                  "INSERT INTO dg_cities (table_id, table_col) VALUES (3, 'elephant');";
                  query.sqlConnection.commit();
                  query.execute();
