3 Replies Latest reply on Jul 12, 2012 7:05 AM by caseyctg
    inserting blank page for ads according to datamerged field.checking for whether a variable exists on
    caseyctg Level 1
      Let me see if I can explain what I am trying to do. I have a script which loops through pages of an indesign document. I use a for loop to do so.
      Within each page is a text frame called "Advertising" with a Y or N as the value. If the value is Y, I want to insert a blank page before the page with the advertising field. Within the for loop however, there are calls to other data fields. My issue is that when I add a blank page, and the for loop continues, it errs out because the blank page does not contain the variable fields I am using. (highlights)...
      So my question is, how can I cause the for loop to skip the newly inserted page so that the missing variable doesn't cause the script to fail?
      should I be checking whether the layer exists then doing something like:
      if(newDoc.pages.item(i).pageItems.item("CompanyHighlights").length > 0){}
      for(var i = o; i < PageLength-1; i++){
      //some kind of check to determine whether it's a blank page, or a page with the variable.
                var highlights= newDoc.pages.item(i).pageItems.item("CompanyHighlights").contents;
                var advertising = newDoc.pages.item(i).pageItems.item("Advertising").contents;
                if(advertising == "Y")
                     //add blank page before this page
        • 1. Re: inserting blank page for ads according to datamerged field.checking for whether a variable exists on
          caseyctg Level 1
          One way I was considering was when placing the page, I would apply a master page.
          I would then check against that master page, C-Master, and if it is the C-Master page, have the code bypass the sections that call to the variable.
          //HOW DO I CHECK WHAT THE MASTER PAGE IS?
          var masterpage = //need to determine the master page of newDoc.pages.item(i)
              if(masterpage  != "C-Master"){
                         //Apply C-Master as master page.
               }else{alert("This page is an advertisement page")}
          Can someone explain how I would detect the master page? is it
          var masterpage = newDoc.pages.item(i).appliedMaster;
          • 2. Re: inserting blank page for ads according to datamerged field.checking for whether a variable exists on
            -hans- Level 4
            hi,
            try the loop backwards ...
            var myPages = app.activeDocument.pages;
            for(var i = myPages.length -1; i >= 0; i--){
            app.activeDocument.pages.add(LocationOptions.BEFORE, myPages[i]);
            • 3. Re: inserting blank page for ads according to datamerged field.checking for whether a variable exists on
              caseyctg Level 1
              Thanks Hans, I actually got it working last night: I had to run a double if statement to check the Master page and move the counter var to a global var, and then add 1 to the counter "i" since I was adding a page, and add 1 to the PageLength so the for loop can continue on the pages that were moved ahead a page number by adding a page...not the best solution, but it works and I'm on a deadline. Thank you for trying to help though.
              //make i a global variable
              var i = 0;
              for(i = 0; i < PageLength-1; i++){
              //define master page of current page in the loop
              var masterpage = newDoc.pages.item(i).appliedMaster.name;
              //if its C-Master, skip it
                     //if it contains the merged Advertising field add a page
                    var advertising = newDoc.pages.item(i).textFrames.item("Advertising").contents;
                             //Add a page.
                             newDoc.pages.add(LocationOptions.before, newDoc.pages.item(i) );
                             newDoc.pages.item(i).appliedMaster =app.activeDocument.masterSpreads.item("C-Master");
                             i=i+1;
                             PageLength = PageLength+1;
              var masterpageAgain = newDoc.pages.item(i).appliedMaster.name;
                          if(masterpageAgain  != "C-Master"){
                             var highlights=newDoc.pages.item(i).textFrames.item("CompanyHighlights").contents;
